Hi, recently I’ve installed Manjaro (KDE plasma) and few minute later I’ve found the issue with network, randomly disconnect and reconnect and do this in loop for a while.
I’ve thought the problem was the cable but on Windows and debian running on VM is working fine. I’ve read some thread with the same issue caused by the tlp and tried to remove it but nothing changed.
Here there’s the journalctl -fu NetworkManager
during one disconnection and reconnection:
NetworkManager[631]: <info> [1608574906.3432] device (enp3s0): state change: activated -> unavailable (reason 'carrier-changed', sys-iface-state: 'managed')
NetworkManager[631]: <info> [1608574906.3704] dhcp4 (enp3s0): canceled DHCP transaction
NetworkManager[631]: <info> [1608574906.3704] dhcp4 (enp3s0): state changed bound -> done
NetworkManager[631]: <info> [1608574906.3822] manager: NetworkManager state is now DISCONNECTED
NetworkManager[631]: <info> [1608574907.4445] device (enp3s0): carrier: link connected
NetworkManager[631]: <info> [1608574907.4453] device (enp3s0): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
NetworkManager[631]: <info> [1608574907.4494] policy: auto-activating connection 'Wired connection 1' (ba677845-e780-3357-8877-33248beb87f9)
NetworkManager[631]: <info> [1608574907.4509] device (enp3s0): Activation: starting connection 'Wired connection 1' (ba677845-e780-3357-8877-33248beb87f9)
NetworkManager[631]: <info> [1608574907.4510] device (enp3s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
NetworkManager[631]: <info> [1608574907.4515] manager: NetworkManager state is now CONNECTING
NetworkManager[631]: <info> [1608574907.4518] device (enp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
NetworkManager[631]: <info> [1608574907.4524] device (enp3s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
NetworkManager[631]: <info> [1608574907.4529] dhcp4 (enp3s0): activation: beginning transaction (timeout in 45 seconds)
NetworkManager[631]: <info> [1608574909.5701] dhcp4 (enp3s0): option dhcp_lease_time => '86400'
NetworkManager[631]: <info> [1608574909.5702] dhcp4 (enp3s0): option domain_name_servers => '192.168.1.254'
NetworkManager[631]: <info> [1608574909.5702] dhcp4 (enp3s0): option expiry => '1608661309'
NetworkManager[631]: <info> [1608574909.5702] dhcp4 (enp3s0): option ip_address => '192.168.1.72'
NetworkManager[631]: <info> [1608574909.5702] dhcp4 (enp3s0): option requested_broadcast_address => '1'
NetworkManager[631]: <info> [1608574909.5702] dhcp4 (enp3s0): option requested_domain_name => '1'
NetworkManager[631]: <info> [1608574909.5702] dhcp4 (enp3s0): option requested_domain_name_servers => '1'
NetworkManager[631]: <info> [1608574909.5702] dhcp4 (enp3s0): option requested_domain_search => '1'
NetworkManager[631]: <info> [1608574909.5702] dhcp4 (enp3s0): option requested_host_name => '1'
NetworkManager[631]: <info> [1608574909.5702] dhcp4 (enp3s0): option requested_interface_mtu => '1'
NetworkManager[631]: <info> [1608574909.5703] dhcp4 (enp3s0): option requested_ms_classless_static_routes => '1'
NetworkManager[631]: <info> [1608574909.5703] dhcp4 (enp3s0): option requested_nis_domain => '1'
NetworkManager[631]: <info> [1608574909.5703] dhcp4 (enp3s0): option requested_nis_servers => '1'
NetworkManager[631]: <info> [1608574909.5703] dhcp4 (enp3s0): option requested_ntp_servers => '1'
NetworkManager[631]: <info> [1608574909.5703] dhcp4 (enp3s0): option requested_rfc3442_classless_static_routes => '1'
NetworkManager[631]: <info> [1608574909.5703] dhcp4 (enp3s0): option requested_root_path => '1'
NetworkManager[631]: <info> [1608574909.5703] dhcp4 (enp3s0): option requested_routers => '1'
NetworkManager[631]: <info> [1608574909.5703] dhcp4 (enp3s0): option requested_static_routes => '1'
NetworkManager[631]: <info> [1608574909.5703] dhcp4 (enp3s0): option requested_subnet_mask => '1'
NetworkManager[631]: <info> [1608574909.5704] dhcp4 (enp3s0): option requested_time_offset => '1'
NetworkManager[631]: <info> [1608574909.5704] dhcp4 (enp3s0): option requested_wpad => '1'
NetworkManager[631]: <info> [1608574909.5704] dhcp4 (enp3s0): option routers => '192.168.1.254'
NetworkManager[631]: <info> [1608574909.5704] dhcp4 (enp3s0): option subnet_mask => '255.255.255.0'
NetworkManager[631]: <info> [1608574909.5704] dhcp4 (enp3s0): state changed unknown -> bound
NetworkManager[631]: <info> [1608574909.5724] device (enp3s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
NetworkManager[631]: <info> [1608574909.5771] device (enp3s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
NetworkManager[631]: <info> [1608574909.5775] device (enp3s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
NetworkManager[631]: <info> [1608574909.5781] manager: NetworkManager state is now CONNECTED_LOCAL
NetworkManager[631]: <info> [1608574909.5797] manager: NetworkManager state is now CONNECTED_SITE
NetworkManager[631]: <info> [1608574909.5799] policy: set 'Wired connection 1' (enp3s0) as default for IPv4 routing and DNS
NetworkManager[631]: <info> [1608574909.5883] device (enp3s0): Activation: successful, device activated.
NetworkManager[631]: <info> [1608574909.7566] manager: NetworkManager state is now CONNECTED_GLOBAL
NetworkManager[631]: <info> [1608574919.7007] device (enp3s0): state change: activated -> unavailable (reason 'carrier-changed', sys-iface-state: 'managed')
NetworkManager[631]: <info> [1608574919.7505] dhcp4 (enp3s0): canceled DHCP transaction
NetworkManager[631]: <info> [1608574919.7505] dhcp4 (enp3s0): state changed bound -> done
NetworkManager[631]: <info> [1608574919.7618] manager: NetworkManager state is now DISCONNECTED
NetworkManager[631]: <info> [1608574920.7982] device (enp3s0): carrier: link connected
NetworkManager[631]: <info> [1608574920.7987] device (enp3s0): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
NetworkManager[631]: <info> [1608574920.8000] policy: auto-activating connection 'Wired connection 1' (ba677845-e780-3357-8877-33248beb87f9)
NetworkManager[631]: <info> [1608574920.8010] device (enp3s0): Activation: starting connection 'Wired connection 1' (ba677845-e780-3357-8877-33248beb87f9)
NetworkManager[631]: <info> [1608574920.8012] device (enp3s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
NetworkManager[631]: <info> [1608574920.8017] manager: NetworkManager state is now CONNECTING
NetworkManager[631]: <info> [1608574920.8021] device (enp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
NetworkManager[631]: <info> [1608574920.8032] device (enp3s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
NetworkManager[631]: <info> [1608574920.8036] dhcp4 (enp3s0): activation: beginning transaction (timeout in 45 seconds)
NetworkManager[631]: <info> [1608574925.7323] dhcp4 (enp3s0): option dhcp_lease_time => '86400'
NetworkManager[631]: <info> [1608574925.7323] dhcp4 (enp3s0): option domain_name_servers => '192.168.1.254'
NetworkManager[631]: <info> [1608574925.7323] dhcp4 (enp3s0): option expiry => '1608661323'
NetworkManager[631]: <info> [1608574925.7323] dhcp4 (enp3s0): option ip_address => '192.168.1.72'
NetworkManager[631]: <info> [1608574925.7323] dhcp4 (enp3s0): option requested_broadcast_address => '1'
NetworkManager[631]: <info> [1608574925.7323] dhcp4 (enp3s0): option requested_domain_name => '1'
NetworkManager[631]: <info> [1608574925.7324] dhcp4 (enp3s0): option requested_domain_name_servers => '1'
NetworkManager[631]: <info> [1608574925.7324] dhcp4 (enp3s0): option requested_domain_search => '1'
NetworkManager[631]: <info> [1608574925.7324] dhcp4 (enp3s0): option requested_host_name => '1'
NetworkManager[631]: <info> [1608574925.7324] dhcp4 (enp3s0): option requested_interface_mtu => '1'
NetworkManager[631]: <info> [1608574925.7324] dhcp4 (enp3s0): option requested_ms_classless_static_routes => '1'
NetworkManager[631]: <info> [1608574925.7324] dhcp4 (enp3s0): option requested_nis_domain => '1'
NetworkManager[631]: <info> [1608574925.7324] dhcp4 (enp3s0): option requested_nis_servers => '1'
NetworkManager[631]: <info> [1608574925.7324] dhcp4 (enp3s0): option requested_ntp_servers => '1'
NetworkManager[631]: <info> [1608574925.7324] dhcp4 (enp3s0): option requested_rfc3442_classless_static_routes => '1'
NetworkManager[631]: <info> [1608574925.7325] dhcp4 (enp3s0): option requested_root_path => '1'
NetworkManager[631]: <info> [1608574925.7325] dhcp4 (enp3s0): option requested_routers => '1'
NetworkManager[631]: <info> [1608574925.7325] dhcp4 (enp3s0): option requested_static_routes => '1'
NetworkManager[631]: <info> [1608574925.7325] dhcp4 (enp3s0): option requested_subnet_mask => '1'
NetworkManager[631]: <info> [1608574925.7325] dhcp4 (enp3s0): option requested_time_offset => '1'
NetworkManager[631]: <info> [1608574925.7325] dhcp4 (enp3s0): option requested_wpad => '1'
NetworkManager[631]: <info> [1608574925.7325] dhcp4 (enp3s0): option routers => '192.168.1.254'
NetworkManager[631]: <info> [1608574925.7325] dhcp4 (enp3s0): option subnet_mask => '255.255.255.0'
NetworkManager[631]: <info> [1608574925.7325] dhcp4 (enp3s0): state changed unknown -> bound
NetworkManager[631]: <info> [1608574925.7341] device (enp3s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
NetworkManager[631]: <info> [1608574925.7371] device (enp3s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
NetworkManager[631]: <info> [1608574925.7374] device (enp3s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
NetworkManager[631]: <info> [1608574925.7381] manager: NetworkManager state is now CONNECTED_LOCAL
NetworkManager[631]: <info> [1608574925.7396] manager: NetworkManager state is now CONNECTED_SITE
NetworkManager[631]: <info> [1608574925.7397] policy: set 'Wired connection 1' (enp3s0) as default for IPv4 routing and DNS
NetworkManager[631]: <info> [1608574925.7471] device (enp3s0): Activation: successful, device activated.
What is the problem?
Thanks in advance
