Wired connection is very slow
I recently installed Manjaro gnome on my thinkpad, however I am facing a problem regarding the internet, i’m using a wired connection and the pages take a long time to load. I already tried with Windows 11 and I don’t have that problem, what could be happening?
this is the inxi -Fazy output:
  Kernel: 6.12.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=562f6830-f6ce-4645-baf3-32182f1eeaec rw rootflags=subvol=@ quiet
    splash apparmor=1 security=apparmor udev.log_priority=3
  Desktop: GNOME v: 47.2 tk: GTK v: 3.24.43 wm: gnome-shell
    with: Docker,docker tools: gsd-screensaver-proxy dm: GDM v: 47.0
  Type: Laptop System: LENOVO product: 21M8CTO1WW v: ThinkPad E14 Gen 6
  Mobo: LENOVO model: 21M8CTO1WW v: SDK0T76461 WIN
    serial: <superuser required> part-nu: LENOVO_MT_21M8_BU_Think_FM_ThinkPad
    E14 Gen 6 uuid: <superuser required> UEFI: LENOVO v: R2JET38W(1.15 )
    date: 10/21/2024
  ID-1: BAT0 charge: 46.0 Wh (79.3%) condition: 58.0/57.0 Wh (101.7%)
    volts: 12.1 min: 11.3 model: Sunwoda L23D3PG2 type: Li-poly serial: <filter>
    status: not charging cycles: 2
  Device-1: hidpp_battery_0 model: Logitech G305 Lightspeed Wireless Gaming
    Mouse serial: <filter> charge: 100% (should be ignored) rechargeable: yes
    status: discharging
  Info: model: Intel Core Ultra 7 155H bits: 64 type: MST AMCP
    arch: Meteor Lake level: v3 note: check built: 2023+ process: Intel 4 (7nm)
    family: 6 model-id: 0xAA (170) stepping: 4 microcode: 0x20
  Topology: cpus: 1x dies: 1 clusters: 9 cores: 16 threads: 22 mt: 6 tpc: 2
    st: 10 smt: enabled cache: 24 MiB note: check
  Speed (MHz): avg: 1899 min/max: 400/4500:4800:3800:2500 scaling:
    driver: intel_pstate governor: powersave cores: 1: 1899 2: 1899 3: 1899
    4: 1899 5: 1899 6: 1899 7: 1899 8: 1899 9: 1899 10: 1899 11: 1899 12: 1899
    13: 1899 14: 1899 15: 1899 16: 1899 17: 1899 18: 1899 19: 1899 20: 1899
    21: 1899 22: 1899 bogomips: 131824
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
    RSB filling; PBRSB-eIBRS: Not affected; BHI: BHI_DIS_S
  Device-1: Intel Meteor Lake-P [Intel Arc Graphics] vendor: Lenovo
    driver: i915 v: kernel alternate: xe arch: Xe-LPG process: Intel 4 (7nm+)
    built: 2023+ ports: active: DP-5,DP-6,eDP-1 empty: DP-1, DP-2, DP-3, DP-4,
    HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:7d55 class-ID: 0300
  Device-2: Syntek Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:4 chip-ID: 174f:1820
  Display: wayland server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4
    compositor: gnome-shell driver: gpu: i915 display-ID: 0
  Monitor-1: DP-5 model: AOC 2269W serial: <filter> built: 2016
    res: 1920x1080 dpi: 102 gamma: 1.2 size: 477x268mm (18.78x10.55")
    diag: 547mm (21.5") ratio: 16:9 modes: max: 1920x1080 min: 720x400
  Monitor-2: DP-6 model: AOC 2269W serial: <filter> built: 2016
  Monitor-3: eDP-1 model: AU Optronics 0xa195 built: 2020 res: 2240x1400
    dpi: 190 gamma: 1.2 size: 300x188mm (11.81x7.4") diag: 354mm (13.9")
    ratio: 16:10 modes: 2240x1400
    drv: iris x11: drv: iris
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.2.8-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Arc Graphics (MTL)
    device-ID: 8086:7d55 memory: 15.05 GiB unified: yes display-ID: :0.0
  Info: Tools: api: eglinfo,glxinfo x11: xprop
  Device-1: Intel Meteor Lake-P HD Audio vendor: Lenovo
    driver: sof-audio-pci-intel-mtl
    alternate: snd_hda_intel,snd_sof_pci_intel_mtl bus-ID: 00:1f.3
    chip-ID: 8086:7e28 class-ID: 0401
  API: ALSA v: k6.12.4-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
  Device-1: Intel Meteor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:7e40 class-ID: 0280
  IF: wlp0s20f3 state: down mac: <filter>
  Device-2: Intel vendor: Lenovo driver: e1000e v: kernel port: N/A
    bus-ID: 00:1f.6 chip-ID: 8086:550b class-ID: 0200
  IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: docker0 state: down mac: <filter>
  Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:5 chip-ID: 8087:0033
    class-ID: e001
  Local Storage: total: 1.86 TiB used: 198.15 GiB (10.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Seagate
    model: XPG GAMMIX S70 BLADE size: 953.87 GiB block-size: physical: 512 B
    fw-rev: 3.2.J.JE temp: 47.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Samsung model: MZAL81T0HDLB-00BLL
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 7L2QKXD7 temp: 46.9 C
    scheme: GPT
  ID-1: / raw-size: 175.78 GiB size: 175.78 GiB (100.00%)
    used: 50.95 GiB (29.0%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-2: /boot/efi raw-size: 1024 MiB size: 1022 MiB (99.80%)
    used: 584 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p3 maj-min: 259:3
  ID-3: /home raw-size: 777.09 GiB size: 763.82 GiB (98.29%)
    used: 147.2 GiB (19.3%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-4: /var/log raw-size: 175.78 GiB size: 175.78 GiB (100.00%)
  ID-1: swap-1 type: file size: 8 GiB used: 8 GiB (100.0%) priority: -2
    file: /swap/swapfile
  System Temperatures: cpu: 62.0 C mobo: 56.0 C
  Fan Speeds (rpm): fan-1: 3400 fan-2: 3400
  Memory: total: 32 GiB note: est. available: 30.82 GiB used: 23.3 GiB (75.6%)
  Processes: 561 Power: uptime: 3d 6h 29m states: freeze,mem,disk
    suspend: s2idle wakeups: 4 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 12.31 GiB services: gsd-power,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Packages: pm: pacman pkgs: 1350 libs: 384 tools: gnome-software,pamac
    pm: flatpak pkgs: 0 Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Bash
    v: 5.2.37 running-in: gnome-terminal inxi: 3.3.37
This could be indicative of many things.
Is there a reason we think this is the fault of the ethernet?
Pages load quickly when using the wireless?
Maybe using some sort of measurement would be even better.
If you use power-profiles-daemon … have you set it to some low-power state?
Thanks for your quick reply.
Web pages load much faster with WiFi than with LAN cable.
I’m using ‘Performance’ power plan.
Hello and welcome to the Manjaro Community!
Great that you provided good system information. :wink:
It’s worth checking the results of speedtest:
sudo pacman -Syu speedtest-cli
… to compare the ethernet and wireless.
Ok, moving on to some actionable approaches…
You might try setting the speed of the ethernet device. With something like this command;
ethtool -s enp0s31f6 autoneg on speed 1000 duplex full
Another approach would be to disable ‘active state power management’ for PCIe. This can be done by adding the following to boot options;
pcie_aspm=off
If you do not know how to do that … it means adding the option, between the quotes, on one of the CMDLINE_LINUX line of the file /etc/default/grub, illustrated with the following and assuming no other options;
GRUB_CMDLINE_LINUX="pcie_aspm=off"
Afterwards the following must be run to apply it;
sudo update-grub
Then reboot.
Thanks, these are the results with wired network:
Retrieving speedtest.net configuration...
Testing from Totalplay (187.190.238.233)...
Retrieving speedtest.net server list...
Selecting best server based on ping...
Hosted by INFINITUM (Ciudad Nezahualcoyotl) [9.87 km]: 68.474 ms
Testing download speed................................................................................
Download: 11.43 Mbit/s
Testing upload speed......................................................................................................
Upload: 2.26 Mbit/s
These are the results for wifi:
Hosted by Totalplay (Iztacalco) [10.61 km]: 16.159 ms
Download: 35.25 Mbit/s
Upload: 74.50 Mbit/s
Thanks for your help, just as a precaution I bought a new cat6 cable and the problem was solved.
:rofl:
Not funny… takes me back six months when I did exactly the same thing - after a day puzzling it out, a $2 10 metre cable fixed it… I imagine the old one may have been pinched and damaged at some time…
