Hi there,
I have a weird and annoying issue with my manjaro install.
It seems like there are a lot of windows open when I am starting my computer. “Konversations” i.e. and then also randomly others, mostly programs which have been open while shutting down. But not all of them and I fail to find a pattern in it.
I am not sure which information is needed in order to find the problem so here the usual:
$ inxi -Fazy
Kernel: 5.9.11-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=96197d22-38ae-4c28-9aa9-c6524b7e8040 rw
resume=UUID=99721703-11e6-4ea0-95f2-38b90e2256d2 udev.log_priority=3
Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 20BHS0L000 v: ThinkPad W540
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 20BHS0L000 serial: <filter> UEFI: LENOVO
v: GNET90WW (2.38 ) date: 03/25/2019
ID-1: BAT0 charge: 89.1 Wh condition: 89.4/99.5 Wh (90%) volts: 12.3/10.8
model: SANYO 45N1779 type: Li-ion serial: <filter> status: Unknown
Info: Quad Core model: Intel Core i7-4800MQ bits: 64 type: MT MCP
arch: Haswell family: 6 model-id: 3C (60) stepping: 3 microcode: 28
L2 cache: 6144 KiB
bogomips: 43119
Speed: 2542 MHz min/max: 800/3700 MHz Core speeds (MHz): 1: 798 2: 798
3: 798 4: 800 5: 798 6: 799 7: 798 8: 800
Type: l1tf
Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Lenovo
driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0416
Device-2: NVIDIA GK107GLM [Quadro K1100M] driver: N/A
alternate: nouveau, nvidia_drm, nvidia bus ID: 01:00.0 chip ID: 10de:0ff6
Device-3: Lite-On Integrated Camera type: USB driver: uvcvideo
bus ID: 2-12:7 chip ID: 04ca:7035
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: intel
display ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1013x285mm (39.9x11.2")
s-diag: 1052mm (41.4")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4600 (HSW GT2)
v: 4.5 Mesa 20.2.3 compat-v: 3.0 direct render: Yes
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
vendor: Lenovo driver: snd_hda_intel v: kernel bus ID: 00:03.0
chip ID: 8086:0c0c
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:8c20
Device-3: NVIDIA GK107 HDMI Audio driver: snd_hda_intel v: kernel
bus ID: 01:00.1 chip ID: 10de:0e1b
Sound Server: ALSA v: k5.9.11-3-MANJARO
Device-1: Intel Ethernet I217-LM vendor: Lenovo driver: e1000e v: kernel
port: 5080 bus ID: 00:19.0 chip ID: 8086:153a
IF: enp0s25 state: down mac: <filter>
Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel port: efa0
bus ID: 03:00.0 chip ID: 8086:08b2
Local Storage: total: 931.52 GiB used: 217.19 GiB (23.3%)
ID-1: /dev/sda vendor: Intenso model: SSD Sata III size: 465.76 GiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
rev: 6A scheme: GPT
ID-2: /dev/sdb vendor: Crucial model: CT500MX500SSD1 size: 465.76 GiB
rev: 023 scheme: GPT
ID-1: / raw size: 448.39 GiB size: 440.35 GiB (98.21%)
used: 217.19 GiB (49.3%) fs: ext4 dev: /dev/sda2
ID-1: swap-1 type: partition size: 17.07 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda3
System Temperatures: cpu: 47.0 C mobo: 0.0 C
Fan Speeds (RPM): cpu: 1623
Processes: 241 Uptime: 27m Memory: 15.52 GiB used: 2.84 GiB (18.3%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1439 lib: 376
Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.08
greets
