To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
Also, if your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
OK, I’m absolutely, % unsure 'bout this, but have you tried installing and running the application through Lutris? I know Lutris is actually meant for games, but software will also work.
proteus 8 professional , dark souls 1, and many others that worked the previous day and suddenly stopped working so I don’t think it is an application issue. even winecfg does the same behavior
Thank you. I don’'t use any of those. I only use Wine for very simple, standalone software such as WinSCP and QuickPar. Stable and Testing branches are on Wine 7.19. Unstable was upgraded recently
to 7.20:
In my use case, I need Windows only for tax software (USA) and it runs perfectly in a virtualbox VM. I would recommend that route if you can get away with it.
Just little side note: you see that thread 0110 is blocking other threads of a process. And the process is the dll loader.
Did you even try creating a new clean custom prefix with a specific version of wine? Note that there differences between versions.
When it loads forever then there is something wrong with the prefix, prefix configurations or the used wine version is buggy. Could be also DXVK etc etc etc. There are many mine fields on reverse-engineered windows libraries for linux.
Note hat 7.20 is the development version and 7.0.1 is currently the release version. So expect problems on a work-in-progress development version.
For a noob: Install a “wine manager” like for example bottles. Developers of bottles prefer flatpak, maybe better use that version then.
flatpak install com.usebottles.bottles
Get familiar with such software and use for each application one “bottle” (prefix). The good thing is: You can install/run different wine versions. And when you install it with one version, then it will never change unless you do it yourself. That way you have less surprises.
