I have got a brand new manjaro KDE installation on a laptop, which (i have no idea why) has no “keep above other windows” … icon on windows title bar.
Refer to the photo: the 2nd icon.
Where to add it ?
Thanks.
Where to add it ?
Thanks.
did you you look in settings, i would think appearance or kwin section.
maybe use the search function in settings.
you’ll recognize it right away, the buttons are drag & drop.
Under system settings: appearance… : title bar icon
sorry i couldn’t be more precise, i’m not a kde user.
only played with it briefly to try out the tiling, as i prefer tiling.
i only have rpi’s (rip4 4gb, rpi400) so i find kde slow & clunky on my specs.
i mostly use sway, a tiling wm.
Thanks, i have got it… appreciate your help.
