Window size of konsole won't remember
Fresh installed KDE6 iso. Window size of konsole won’t remember. “RememberWindowSize=false” set to “true”.
Also the same problem with windows of new message in kontact.
You can do that using KDE’s Window management features / Window rules, here’s how :
Open Konsole then right-click the title bar → More Actions > Configure Special Window SettingsAdd PropertySize then check the Apply Initially and then enter the desired Width and Height (or leave the current) → Ok
