When I reboot the computer (or suspend and unsuspend it), the OS does not recognize the keyboard, and I have to unplug it and plug it again, then it works.
Is an Akko 5087S VIA, I have another Akko keyboard without VIA (Also known as QMK) and it has no problems. This problem happens on multiple computers, all of them with Manjaro but different kernel versions. I can access the bios and works, therefore the problem might be on the OS.
I provided inxi info and dmesg logs. As you can see, the keyboard is plugged on usb 3-3
with product id fffe:000c
and is being detected at 1.30s from boot. But I have to disconnect it at 57 (i used other keyboard to log in). These logs doesn’t differ much, so tell me if any more info is needed.
Logs
Inxi
$ # Before unplugging
$ sudo inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 6.6.10-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=dbd78c17-f7c0-476f-b72a-459ec5566942 rw quiet
udev.log_priority=3
Desktop: bspwm v: 0.9.10 with: polybar tools: light-locker avail: i3lock
dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: P8Z77-V LX v: Rev X.0x serial: <filter>
part-nu: SKU uuid: 21804fa0-d7da-11dd-991e-50465d57cff2
UEFI: American Megatrends v: 1201 date: 08/17/2012
System RAM: total: 16 GiB available: 15.57 GiB used: 1.96 GiB (12.6%)
Array-1: capacity: 32 GiB slots: 4 modules: 2 EC: None
Device-1: ChannelA-DIMM0 type: DDR3 detail: synchronous size: 8 GiB
speed: 1600 MT/s volts: N/A width (bits): data: 64 total: 64
manufacturer: Kingston part-no: 99U5471-056.A00LF serial: <filter>
Device-2: ChannelA-DIMM1 type: no module installed
Device-3: ChannelB-DIMM0 type: DDR3 detail: synchronous size: 8 GiB
manufacturer: Kingston part-no: 99U5471-054.A00LF serial: <filter>
Device-4: ChannelB-DIMM1 type: no module installed
Info: model: Intel Core i7-3770 socket: LGA1155 bits: 64 type: MT MCP
arch: Ivy Bridge gen: core 3 level: v2 built: 2012-15 process: Intel 22nm
family: 6 model-id: 0x3A (58) stepping: 9 microcode: 0x21
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 3621 high: 3682 min/max: 1600/3900 base/boost: 3400/3800
scaling: driver: intel_cpufreq governor: schedutil volts: 1.0 V
ext-clock: 100 MHz cores: 1: 3646 2: 3649 3: 3612 4: 3578 5: 3671 6: 3682
7: 3578 8: 3553 bogomips: 54590
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
ept erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs
ida lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx
pae pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts
rdrand rdtscp rep_good sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid
x2apic xsave xsaveopt xtopology xtpr
vulnerable
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Type: srbds status: Vulnerable: No microcode
Device-1: NVIDIA GK104 [GeForce GTX 760] vendor: ASUSTeK driver: nvidia
v: 470.223.02 alternate: nouveau,nvidia_drm non-free: series: 470.xx+
status: legacy-active (EOL~2024-09-xx) arch: Kepler code: GKxxx
process: TSMC 28nm built: 2012-2018 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1187 class-ID: 0300
Display: x11 server: X.Org v: 21.1.10 compositor: Picom v: git-b700a
driver: X: loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 2688x1848 s-dpi: 102 s-size: 669x460mm (26.34x18.11")
s-diag: 812mm (31.96")
Monitor-1: DP-0 pos: middle-r res: 768x1360 hz: 60 dpi: 30
size: 650x1150mm (25.59x45.28") diag: 1321mm (52.01") modes: N/A
Monitor-2: DVI-I-0 pos: top-center res: 1366x768 hz: 60 dpi: 101
size: 344x193mm (13.54x7.6") diag: 394mm (15.53") modes: N/A
Monitor-3: HDMI-0 pos: primary,bottom-l res: 1920x1080 hz: 60 dpi: 96
size: 510x290mm (20.08x11.42") diag: 587mm (23.1") modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: kms_swrast surfaceless: drv: swrast x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 470.223.02
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 760/PCIe/SSE2
memory: 1.95 GiB
Device-1: Intel 7 Series/C216 Family High Definition Audio
vendor: ASUSTeK P8Z77-V LX driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1e20 class-ID: 0403
Device-2: NVIDIA GK104 HDMI Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:0e0a class-ID: 0403
API: ALSA v: k6.6.10-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.0 status: n/a (root, process) with:
3: pipewire-alsa type: plugin 4: pw-jack type: plugin
vendor: ASUSTeK P8P67 and other motherboards driver: r8169 v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0
IF-ID-1: br-bdde47fbe98c state: down mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
IF-ID-3: docker_gwbridge state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IP v6: <filter> virtual: proto kernel_ll scope: link
IF-ID-4: veth82150ea state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-5: vethbdd8717 state: up speed: 10000 Mbps duplex: full mac: <filter>
Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-1.8:3
chip-ID: 0a12:0001 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 4.0
lmp-v: 6 status: discoverable: no pairing: no class-ID: 7c0104
Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0 port: f020
bus-ID: 00:1f.2 chip-ID: 8086:2822 rev: N/A class-ID: 0104
Local Storage: total: 2.63 TiB used: 1.49 TiB (56.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EZRX-00A8LB0
family: Green size: 931.51 GiB block-size: physical: 4096 B logical: 512 B
sata: 3.0 speed: 6.0 Gb/s tech: N/A serial: <filter> fw-rev: 1A01
temp: 35 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 8y 338d 16h cycles: 3148
ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SDSSDH3 1T00
family: Marvell based SSDs size: 931.51 GiB block-size: physical: 512 B
logical: 512 B sata: 3.3 speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 20RL temp: 36 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 2y 122d 23h cycles: 1336
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD6400AAKS-22A7B2 family: Caviar Blue (SATA) size: 596.17 GiB
block-size: physical: 512 B logical: 512 B sata: 2.5 speed: 3.0 Gb/s
tech: N/A serial: <filter> fw-rev: 3B01 temp: 42 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 8y 260d 1h cycles: 5615
ID-4: /dev/sdd maj-min: 8:48 vendor: Maxtor model: STM3250310AS
family: Maxtor DiamondMax 21 size: 232.89 GiB block-size: physical: 512 B
logical: 512 B speed: 1.5 Gb/s tech: N/A serial: <filter> fw-rev: C
temp: 40 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 7y 147d 17h cycles: 3684
Pre-Fail: reallocated sector: 100 threshold: 36 attribute: Spin_Retry_Count
value: 100 worst: 100 threshold: 97
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GH40F rev: MG01
dev-links: cdrom
Features: speed: 40 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 914.07 GiB size: 898.64 GiB (98.31%)
used: 716.05 GiB (79.7%) fs: ext4 block-size: 4096 B dev: /dev/sdb2
maj-min: 8:18 label: N/A uuid: dbd78c17-f7c0-476f-b72a-459ec5566942
used: 284 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sdb1 maj-min: 8:17
label: N/A uuid: 3A3E-5F87
ID-3: /mnt/alpha raw-size: 931.07 GiB size: 931.07 GiB (100.00%)
used: 727.08 GiB (78.1%) fs: ntfs block-size: 4096 B dev: /dev/sda1
maj-min: 8:1 label: Almacenamiento Alpha uuid: 84B6C503B6C4F728
ID-4: /mnt/gamma raw-size: 596.17 GiB size: 596.17 GiB (100.00%)
used: 80.95 GiB (13.6%) fs: btrfs block-size: 4096 B dev: /dev/sdc1
maj-min: 8:33 label: gamma uuid: 7639fefe-48f6-45aa-b7b3-4f1e1209f6e7
ID-5: /var/lib/docker/volumes/home-swarm_nfs_publicmedia/_data
raw-size: N/A size: 3.49 TiB used: 1.97 TiB (56.5%) fs: nfs4
remote: :/PublicMedia
ID-1: swap-1 type: partition size: 17.15 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sdb3 maj-min: 8:19 label: N/A
uuid: 2be7c2ef-43e1-4601-95f3-aee00991978a
ID-1: /dev/sda2 maj-min: 8:2 size: 450 MiB fs: ntfs label: N/A
uuid: 0EAE6759AE67387B
ID-2: /dev/sdd1 maj-min: 8:49 size: 232.88 GiB fs: btrfs label: beta
uuid: 9e23978b-8249-4a06-ab24-e91c9297f573
Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:0024
Device-1: 1-1.1:3 info: Realtek Mass Storage Device
type: smart card,mass storage driver: usb-storage interfaces: 2 rev: 2.0
chip-ID: 0bda:0169 class-ID: 0806 serial: <filter>
Device-2: 1-1.2:4 info: 2.4G Composite Devic type: keyboard,mouse
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 1507:2814 class-ID: 0301
Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Device-1: 2-1.8:3 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 0a12:0001
class-ID: e001
Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-3:2 info: Akko Keyboard type: keyboard,HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: fffe:000c class-ID: 0300
Device-2: 3-4:3 info: Logitech G203 LIGHTSYNC Gaming Mouse type: mouse,HID
lanes: 1 mode: 1.1 power: 300mA chip-ID: 046d:c09d class-ID: 0300
serial: <filter>
Hub-6: 4-0:1 info: super-speed hub ports: 4 rev: 3.0
System Temperatures: cpu: 45.5 C mobo: N/A gpu: nvidia temp: 54 C
Fan Speeds (rpm): fan-1: 0 fan-2: 1180 fan-3: 0 fan-4: 0 fan-5: 0
gpu: nvidia fan: 48%
Power: 12v: N/A 5v: N/A 3.3v: 3.33 vbat: 3.36
Processes: 300 Power: uptime: 1m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 0 hibernate: platform
avail: shutdown,reboot,suspend,test_resume image: 6.22 GiB Init: systemd
v: 255 default: graphical tool: systemctl
Packages: 2963 pm: dpkg pkgs: 0 pm: nix-default pkgs: 0 pm: nix-sys pkgs: 0
pm: nix-usr pkgs: 0 pm: pacman pkgs: 2943 libs: 575 tools: pamac,yay
pm: flatpak pkgs: 20 Compilers: clang: 16.0.6 gcc: 13.2.1 alt: 12
Shell: Sudo (sudo) v: 1.9.15p5 default: Bash v: 5.2.21
running-in: alacritty inxi: 3.3.32
$ # After unplugging and plugging again
udev.log_priority=3
System RAM: total: 16 GiB available: 15.57 GiB used: 5.48 GiB (35.2%)
Speed (MHz): avg: 3554 high: 3907 min/max: 1600/3900 base/boost: 3400/3800
ext-clock: 100 MHz cores: 1: 3859 2: 3873 3: 3907 4: 3792 5: 3778 6: 3756
7: 3868 8: 1600 bogomips: 54576
vulnerable
memory: 1.95 GiB
mac: <filter>
IF-ID-4: veth7ba4790 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-5: vethe710185 state: up speed: 10000 Mbps duplex: full mac: <filter>
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.8:3
SMART: yes state: enabled health: PASSED on: 8y 338d 15h cycles: 3146
fw-rev: 20RL temp: 33 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 2y 122d 22h cycles: 1334
tech: N/A serial: <filter> fw-rev: 3B01 temp: 41 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 8y 260d 1h cycles: 5613
temp: 39 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 7y 147d 17h cycles: 3682
dev-links: cdrom
used: 716.2 GiB (79.7%) fs: ext4 block-size: 4096 B dev: /dev/sdb2
ID-1: swap-1 type: partition size: 17.15 GiB used: 512 MiB (2.9%)
Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Device-1: 1-1.8:3 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
class-ID: e001
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
Device-1: 2-1.1:3 info: Realtek Mass Storage Device
type: smart card,mass storage driver: usb-storage,usbfs interfaces: 2
rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 500mA
Device-2: 2-1.2:4 info: 2.4G Composite Devic type: keyboard,mouse
Device-1: 3-3:4 info: Akko Keyboard type: keyboard,HID
serial: <filter>
System Temperatures: cpu: 38.0 C mobo: N/A gpu: nvidia temp: 47 C
Fan Speeds (rpm): fan-1: 0 fan-2: 915 fan-3: 0 fan-4: 0 fan-5: 0
gpu: nvidia fan: 34%
Processes: 345 Power: uptime: 23h 33m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 1 hibernate: platform
avail: shutdown,reboot,suspend,test_resume image: 6.22 GiB daemons: upowerd
Init: systemd v: 255 default: graphical tool: systemctl
Dmesg
[ 0.000000] microcode: updated early: 0x12 -> 0x21, date = 2019-02-13
[ 0.000000] Linux version 6.6.10-1-MANJARO (builduser@fv-az1496-324) (gcc (GCC) 13.2.1 20230801, GNU ld (GNU Binutils) 2.41.0) #1 SMP PREEMPT_DYNAMIC Fri Jan 5 17:38:36 UTC 2024
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-6.6-x86_64 root=UUID=dbd78c17-f7c0-476f-b72a-459ec5566942 rw quiet udev.log_priority=3
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009efff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009f000-0x000000000009ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000ddb49fff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000ddb4a000-0x00000000de145fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000de146000-0x00000000de155fff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x00000000de156000-0x00000000de27cfff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000de27d000-0x00000000de7a4fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000de7a5000-0x00000000de830fff] type 20
[ 0.000000] BIOS-e820: [mem 0x00000000de831000-0x00000000de831fff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000de832000-0x00000000de874fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000de875000-0x00000000dec94fff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000dec95000-0x00000000deff3fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000deff4000-0x00000000deffffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed03fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000041effffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] APIC: Static calls initialized
[ 0.000000] efi: EFI v2.3.1 by American Megatrends
[ 0.000000] efi: ACPI=0xde149000 ACPI 2.0=0xde149000 SMBIOS=0xf04c0
[ 0.000000] efi: Remove mem47: MMIO range=[0xf8000000-0xfbffffff] (64MB) from e820 map
[ 0.000000] e820: remove [mem 0xf8000000-0xfbffffff] reserved
[ 0.000000] efi: Not removing mem48: MMIO range=[0xfec00000-0xfec00fff] (4KB) from e820 map
[ 0.000000] efi: Not removing mem49: MMIO range=[0xfed00000-0xfed03fff] (16KB) from e820 map
[ 0.000000] efi: Not removing mem50: MMIO range=[0xfed1c000-0xfed1ffff] (16KB) from e820 map
[ 0.000000] efi: Not removing mem51: MMIO range=[0xfee00000-0xfee00fff] (4KB) from e820 map
[ 0.000000] efi: Remove mem52: MMIO range=[0xff000000-0xffffffff] (16MB) from e820 map
[ 0.000000] e820: remove [mem 0xff000000-0xffffffff] reserved
[ 0.000000] SMBIOS 2.7 present.
[ 0.000000] DMI: System manufacturer System Product Name/P8Z77-V LX, BIOS 1201 08/17/2012
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] tsc: Detected 3409.830 MHz processor
[ 0.001311] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.001314] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.001321] last_pfn = 0x41f000 max_arch_pfn = 0x400000000
[ 0.001327] total RAM covered: 16368M
[ 0.001502] Found optimal setting for mtrr clean up
[ 0.001502] gran_size: 64K chunk_size: 32M num_reg: 7 lose cover RAM: 0G
[ 0.001506] MTRR map: 8 entries (5 fixed + 3 variable; max 25), built from 10 variable MTRRs
[ 0.001508] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.001933] e820: update [mem 0xe0000000-0xffffffff] usable ==> reserved
[ 0.001936] last_pfn = 0xdf000 max_arch_pfn = 0x400000000
[ 0.010039] found SMP MP-table at [mem 0x000fd850-0x000fd85f]
[ 0.010557] Secure boot disabled
[ 0.010558] RAMDISK: [mem 0x359dd000-0x36ce5fff]
[ 0.010563] ACPI: Early table checksum verification disabled
[ 0.010566] ACPI: RSDP 0x00000000DE149000 000024 (v02 ALASKA)
[ 0.010570] ACPI: XSDT 0x00000000DE149080 000074 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.010575] ACPI: FACP 0x00000000DE153BE0 00010C (v05 ALASKA A M I 01072009 AMI 00010013)
[ 0.010580] ACPI: DSDT 0x00000000DE149188 00AA56 (v02 ALASKA A M I 00000021 INTL 20051117)
[ 0.010583] ACPI: FACS 0x00000000DE27B080 000040
[ 0.010586] ACPI: APIC 0x00000000DE153CF0 000092 (v03 ALASKA A M I 01072009 AMI 00010013)
[ 0.010588] ACPI: FPDT 0x00000000DE153D88 000044 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.010591] ACPI: MCFG 0x00000000DE153DD0 00003C (v01 ALASKA A M I 01072009 MSFT 00000097)
[ 0.010594] ACPI: HPET 0x00000000DE153E10 000038 (v01 ALASKA A M I 01072009 AMI. 00000005)
[ 0.010597] ACPI: SSDT 0x00000000DE153E48 00036D (v01 SataRe SataTabl 00001000 INTL 20091112)
[ 0.010600] ACPI: SSDT 0x00000000DE1541B8 0009AA (v01 PmRef Cpu0Ist 00003000 INTL 20051117)
[ 0.010603] ACPI: SSDT 0x00000000DE154B68 000A92 (v01 PmRef CpuPm 00003000 INTL 20051117)
[ 0.010605] ACPI: BGRT 0x00000000DE1556D8 000038 (v00 ALASKA A M I 01072009 AMI 00010013)
[ 0.010608] ACPI: DMAR 0x00000000DE155658 000080 (v01 INTEL SNB 00000001 INTL 00000001)
[ 0.010610] ACPI: Reserving FACP table memory at [mem 0xde153be0-0xde153ceb]
[ 0.010612] ACPI: Reserving DSDT table memory at [mem 0xde149188-0xde153bdd]
[ 0.010613] ACPI: Reserving FACS table memory at [mem 0xde27b080-0xde27b0bf]
[ 0.010613] ACPI: Reserving APIC table memory at [mem 0xde153cf0-0xde153d81]
[ 0.010614] ACPI: Reserving FPDT table memory at [mem 0xde153d88-0xde153dcb]
[ 0.010615] ACPI: Reserving MCFG table memory at [mem 0xde153dd0-0xde153e0b]
[ 0.010615] ACPI: Reserving HPET table memory at [mem 0xde153e10-0xde153e47]
[ 0.010616] ACPI: Reserving SSDT table memory at [mem 0xde153e48-0xde1541b4]
[ 0.010617] ACPI: Reserving SSDT table memory at [mem 0xde1541b8-0xde154b61]
[ 0.010618] ACPI: Reserving SSDT table memory at [mem 0xde154b68-0xde1555f9]
[ 0.010618] ACPI: Reserving BGRT table memory at [mem 0xde1556d8-0xde15570f]
[ 0.010619] ACPI: Reserving DMAR table memory at [mem 0xde155658-0xde1556d7]
[ 0.010667] No NUMA configuration found
[ 0.010668] Faking a node at [mem 0x0000000000000000-0x000000041effffff]
[ 0.010671] NODE_DATA(0) allocated [mem 0x41eff0000-0x41eff4fff]
[ 0.010698] Zone ranges:
[ 0.010699] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.010700] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.010702] Normal [mem 0x0000000100000000-0x000000041effffff]
[ 0.010703] Device empty
[ 0.010704] Movable zone start for each node
[ 0.010704] Early memory node ranges
[ 0.010705] node 0: [mem 0x0000000000001000-0x000000000009efff]
[ 0.010706] node 0: [mem 0x0000000000100000-0x00000000ddb49fff]
[ 0.010707] node 0: [mem 0x00000000de831000-0x00000000de831fff]
[ 0.010708] node 0: [mem 0x00000000de875000-0x00000000dec94fff]
[ 0.010709] node 0: [mem 0x00000000deff4000-0x00000000deffffff]
[ 0.010709] node 0: [mem 0x0000000100000000-0x000000041effffff]
[ 0.010712] Initmem setup node 0 [mem 0x0000000000001000-0x000000041effffff]
[ 0.010715] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.010734] On node 0, zone DMA: 97 pages in unavailable ranges
[ 0.016234] On node 0, zone DMA32: 3303 pages in unavailable ranges
[ 0.016245] On node 0, zone DMA32: 67 pages in unavailable ranges
[ 0.016254] On node 0, zone DMA32: 863 pages in unavailable ranges
[ 0.036672] On node 0, zone Normal: 4096 pages in unavailable ranges
[ 0.036712] On node 0, zone Normal: 4096 pages in unavailable ranges
[ 0.036808] ACPI: PM-Timer IO Port: 0x408
[ 0.036815] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.036826] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
[ 0.036828] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.036830] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.036834] ACPI: Using ACPI (MADT) for SMP configuration information
[ 0.036835] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[ 0.036840] efi_bgrt: Ignoring BGRT: invalid image address
[ 0.036841] TSC deadline timer available
[ 0.036842] smpboot: Allowing 8 CPUs, 0 hotplug CPUs
[ 0.036857] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.036859] PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x0009ffff]
[ 0.036860] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[ 0.036861] PM: hibernation: Registered nosave memory: [mem 0xddb4a000-0xde145fff]
[ 0.036862] PM: hibernation: Registered nosave memory: [mem 0xde146000-0xde155fff]
[ 0.036863] PM: hibernation: Registered nosave memory: [mem 0xde156000-0xde27cfff]
[ 0.036864] PM: hibernation: Registered nosave memory: [mem 0xde27d000-0xde7a4fff]
[ 0.036864] PM: hibernation: Registered nosave memory: [mem 0xde7a5000-0xde830fff]
[ 0.036865] PM: hibernation: Registered nosave memory: [mem 0xde832000-0xde874fff]
[ 0.036867] PM: hibernation: Registered nosave memory: [mem 0xdec95000-0xdeff3fff]
[ 0.036868] PM: hibernation: Registered nosave memory: [mem 0xdf000000-0xfebfffff]
[ 0.036869] PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[ 0.036869] PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfecfffff]
[ 0.036870] PM: hibernation: Registered nosave memory: [mem 0xfed00000-0xfed03fff]
[ 0.036871] PM: hibernation: Registered nosave memory: [mem 0xfed04000-0xfed1bfff]
[ 0.036871] PM: hibernation: Registered nosave memory: [mem 0xfed1c000-0xfed1ffff]
[ 0.036872] PM: hibernation: Registered nosave memory: [mem 0xfed20000-0xfedfffff]
[ 0.036873] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[ 0.036873] PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xffffffff]
[ 0.036875] [mem 0xdf000000-0xfebfffff] available for PCI devices
[ 0.036876] Booting paravirtualized kernel on bare hardware
[ 0.036878] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[ 0.041568] setup_percpu: NR_CPUS:320 nr_cpumask_bits:8 nr_cpu_ids:8 nr_node_ids:1
[ 0.041930] percpu: Embedded 64 pages/cpu s225280 r8192 d28672 u262144
[ 0.041935] pcpu-alloc: s225280 r8192 d28672 u262144 alloc=1*2097152
[ 0.041937] pcpu-alloc: [0] 0 1 2 3 4 5 6 7
[ 0.041954] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.6-x86_64 root=UUID=dbd78c17-f7c0-476f-b72a-459ec5566942 rw quiet udev.log_priority=3
[ 0.042016] Unknown kernel command line parameters "BOOT_IMAGE=/boot/vmlinuz-6.6-x86_64", will be passed to user space.
[ 0.042033] random: crng init done
[ 0.043632] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.044448] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.044557] Fallback order for Node 0: 0
[ 0.044560] Built 1 zonelists, mobility grouping on. Total pages: 4116281
[ 0.044561] Policy zone: Normal
[ 0.044801] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[ 0.044809] software IO TLB: area num 8.
[ 0.093879] Memory: 16111532K/16727124K available (16384K kernel code, 2150K rwdata, 13148K rodata, 3424K init, 3784K bss, 615332K reserved, 0K cma-reserved)
[ 0.094110] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.094121] Kernel/User page tables isolation: enabled
[ 0.094153] ftrace: allocating 49011 entries in 192 pages
[ 0.101105] ftrace: allocated 192 pages with 2 groups
[ 0.101169] Dynamic Preempt: full
[ 0.101212] rcu: Preemptible hierarchical RCU implementation.
[ 0.101213] rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=8.
[ 0.101213] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.101214] Trampoline variant of Tasks RCU enabled.
[ 0.101215] Rude variant of Tasks RCU enabled.
[ 0.101215] Tracing variant of Tasks RCU enabled.
[ 0.101216] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 0.101217] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[ 0.103767] NR_IRQS: 20736, nr_irqs: 488, preallocated irqs: 16
[ 0.103948] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.104058] kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
[ 0.104087] Console: colour dummy device 80x25
[ 0.104089] printk: console [tty0] enabled
[ 0.104128] ACPI: Core revision 20230628
[ 0.104197] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[ 0.104209] APIC: Switch to symmetric I/O mode setup
[ 0.104210] DMAR: Host address width 36
[ 0.104211] DMAR: DRHD base: 0x000000fed90000 flags: 0x1
[ 0.104216] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap c9008020660262 ecap f0105a
[ 0.104218] DMAR: RMRR base: 0x000000de0bd000 end: 0x000000de0d9fff
[ 0.104220] DMAR-IR: IOAPIC id 2 under DRHD base 0xfed90000 IOMMU 0
[ 0.104221] DMAR-IR: HPET id 0 under DRHD base 0xfed90000
[ 0.104222] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[ 0.104489] DMAR-IR: Enabled IRQ remapping in x2apic mode
[ 0.104491] x2apic enabled
[ 0.104542] APIC: Switched APIC routing to: cluster x2apic
[ 0.104958] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.120876] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x312694bc765, max_idle_ns: 440795292811 ns
[ 0.120881] Calibrating delay loop (skipped), value calculated using timer frequency.. 6822.81 BogoMIPS (lpj=11366100)
[ 0.120901] CPU0: Thermal monitoring enabled (TM1)
[ 0.120918] process: using mwait in idle threads
[ 0.120921] Last level iTLB entries: 4KB 512, 2MB 8, 4MB 8
[ 0.120922] Last level dTLB entries: 4KB 512, 2MB 32, 4MB 32, 1GB 0
[ 0.120924] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.120926] Spectre V2 : Mitigation: Retpolines
[ 0.120927] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.120928] Spectre V2 : Spectre v2 / SpectreRSB : Filling RSB on VMEXIT
[ 0.120928] Spectre V2 : Enabling Restricted Speculation for firmware calls
[ 0.120930] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.120930] Spectre V2 : User space: Mitigation: STIBP via prctl
[ 0.120932] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
[ 0.120934] MDS: Mitigation: Clear CPU buffers
[ 0.120934] MMIO Stale Data: Unknown: No mitigations
[ 0.120935] SRBDS: Vulnerable: No microcode
[ 0.120939] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.120940] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.120941] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.120942] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.120943] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'standard' format.
[ 0.137345] Freeing SMP alternatives memory: 40K
[ 0.137349] pid_max: default: 32768 minimum: 301
[ 0.141325] LSM: initializing lsm=capability,landlock,lockdown,yama,bpf,integrity
[ 0.141347] landlock: Up and running.
[ 0.141349] Yama: becoming mindful.
[ 0.141353] LSM support for eBPF active
[ 0.141384] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.141399] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.144265] smpboot: CPU0: Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz (family: 0x6, model: 0x3a, stepping: 0x9)
[ 0.144434] RCU Tasks: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1.
[ 0.144450] RCU Tasks Rude: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1.
[ 0.144463] RCU Tasks Trace: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1.
[ 0.144482] Performance Events: PEBS fmt1+, IvyBridge events, 16-deep LBR, full-width counters, Intel PMU driver.
[ 0.144497] ... version: 3
[ 0.144497] ... bit width: 48
[ 0.144498] ... generic registers: 4
[ 0.144499] ... value mask: 0000ffffffffffff
[ 0.144499] ... max period: 00007fffffffffff
[ 0.144500] ... fixed-purpose events: 3
[ 0.144501] ... event mask: 000000070000000f
[ 0.144622] signal: max sigframe size: 1776
[ 0.144637] Estimated ratio of average max frequency by base frequency (times 1024): 1114
[ 0.144660] rcu: Hierarchical SRCU implementation.
[ 0.144661] rcu: Max phase no-delay instances is 1000.
[ 0.145214] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.145287] smp: Bringing up secondary CPUs ...
[ 0.145388] smpboot: x86: Booting SMP configuration:
[ 0.145390] .... node #0, CPUs: #1 #2 #3 #4 #5 #6 #7
[ 0.152886] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[ 0.157580] smp: Brought up 1 node, 8 CPUs
[ 0.157580] smpboot: Max logical packages: 1
[ 0.157580] smpboot: Total of 8 processors activated (54579.50 BogoMIPS)
[ 0.160516] devtmpfs: initialized
[ 0.160516] x86/mm: Memory block size: 128MB
[ 0.161679] ACPI: PM: Registering ACPI NVS region [mem 0xde156000-0xde27cfff] (1208320 bytes)
[ 0.161679] ACPI: PM: Registering ACPI NVS region [mem 0xde832000-0xde874fff] (274432 bytes)
[ 0.161679] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.161679] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.161679] pinctrl core: initialized pinctrl subsystem
[ 0.161679] PM: RTC time: 18:34:16, date: 2024-02-18
[ 0.161679] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.161679] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[ 0.161782] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.161890] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.161916] audit: initializing netlink subsys (disabled)
[ 0.161935] audit: type=2000 audit(1708281255.056:1): state=initialized audit_enabled=0 res=1
[ 0.161935] thermal_sys: Registered thermal governor 'fair_share'
[ 0.161935] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.161935] thermal_sys: Registered thermal governor 'step_wise'
[ 0.161935] thermal_sys: Registered thermal governor 'user_space'
[ 0.161935] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.161935] cpuidle: using governor ladder
[ 0.161935] cpuidle: using governor menu
[ 0.161935] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.161935] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.161935] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[ 0.161935] PCI: not using MMCONFIG
[ 0.161935] PCI: Using configuration type 1 for base access
[ 0.161935] core: PMU erratum BJ122, BV98, HSD29 worked around, HT is on
[ 0.161935] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.161935] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[ 0.161935] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.161935] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.161935] ACPI: Added _OSI(Module Device)
[ 0.161935] ACPI: Added _OSI(Processor Device)
[ 0.161935] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.161935] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.169311] ACPI: 4 ACPI AML tables successfully acquired and loaded
[ 0.170939] ACPI: Dynamic OEM Table Load:
[ 0.170947] ACPI: SSDT 0xFFFF946880E80000 00083B (v01 PmRef Cpu0Cst 00003001 INTL 20051117)
[ 0.171782] ACPI: Dynamic OEM Table Load:
[ 0.171788] ACPI: SSDT 0xFFFF94688191AC00 000303 (v01 PmRef ApIst 00003000 INTL 20051117)
[ 0.172452] ACPI: Dynamic OEM Table Load:
[ 0.172456] ACPI: SSDT 0xFFFF9468818CDC00 000119 (v01 PmRef ApCst 00003000 INTL 20051117)
[ 0.174610] ACPI: _OSC evaluated successfully for all CPUs
[ 0.174881] ACPI: Interpreter enabled
[ 0.174903] ACPI: PM: (supports S0 S3 S4 S5)
[ 0.174905] ACPI: Using IOAPIC for interrupt routing
[ 0.175566] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[ 0.176346] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved as ACPI motherboard resource
[ 0.176356] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.176357] PCI: Using E820 reservations for host bridge windows
[ 0.176684] ACPI: Enabled 10 GPEs in block 00 to 3F
[ 0.186114] ACPI: \_TZ_.FN00: New power resource
[ 0.186206] ACPI: \_TZ_.FN01: New power resource
[ 0.186295] ACPI: \_TZ_.FN02: New power resource
[ 0.186383] ACPI: \_TZ_.FN03: New power resource
[ 0.186471] ACPI: \_TZ_.FN04: New power resource
[ 0.187339] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
[ 0.187346] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.187554] acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug SHPCHotplug PME]
[ 0.187776] acpi PNP0A08:00: _OSC: OS now controls [AER PCIeCapability LTR DPC]
[ 0.187779] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[ 0.188600] PCI host bridge to bus 0000:00
[ 0.188602] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.188605] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.188607] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.188609] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
[ 0.188611] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xfeafffff window]
[ 0.188613] pci_bus 0000:00: root bus resource [bus 00-3e]
[ 0.188629] pci 0000:00:00.0: [8086:0150] type 00 class 0x060000
[ 0.188700] pci 0000:00:01.0: [8086:0151] type 01 class 0x060400
[ 0.188737] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.188853] pci 0000:00:14.0: [8086:1e31] type 00 class 0x0c0330
[ 0.188873] pci 0000:00:14.0: reg 0x10: [mem 0xf7100000-0xf710ffff 64bit]
[ 0.188942] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.189023] pci 0000:00:16.0: [8086:1e3a] type 00 class 0x078000
[ 0.189042] pci 0000:00:16.0: reg 0x10: [mem 0xf711a000-0xf711a00f 64bit]
[ 0.189110] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[ 0.189166] pci 0000:00:1a.0: [8086:1e2d] type 00 class 0x0c0320
[ 0.189181] pci 0000:00:1a.0: reg 0x10: [mem 0xf7118000-0xf71183ff]
[ 0.189260] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[ 0.189337] pci 0000:00:1b.0: [8086:1e20] type 00 class 0x040300
[ 0.189351] pci 0000:00:1b.0: reg 0x10: [mem 0xf7110000-0xf7113fff 64bit]
[ 0.189416] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.189512] pci 0000:00:1c.0: [8086:1e10] type 01 class 0x060400
[ 0.189664] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.189773] pci 0000:00:1c.4: [8086:1e18] type 01 class 0x060400
[ 0.189859] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[ 0.189946] pci 0000:00:1c.5: [8086:244e] type 01 class 0x060401
[ 0.190033] pci 0000:00:1c.5: PME# supported from D0 D3hot D3cold
[ 0.190116] pci 0000:00:1d.0: [8086:1e26] type 00 class 0x0c0320
[ 0.190131] pci 0000:00:1d.0: reg 0x10: [mem 0xf7117000-0xf71173ff]
[ 0.190210] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 0.190283] pci 0000:00:1f.0: [8086:1e44] type 00 class 0x060100
[ 0.190449] pci 0000:00:1f.2: [8086:2822] type 00 class 0x010400
[ 0.190461] pci 0000:00:1f.2: reg 0x10: [io 0xf070-0xf077]
[ 0.190467] pci 0000:00:1f.2: reg 0x14: [io 0xf060-0xf063]
[ 0.190474] pci 0000:00:1f.2: reg 0x18: [io 0xf050-0xf057]
[ 0.190480] pci 0000:00:1f.2: reg 0x1c: [io 0xf040-0xf043]
[ 0.190486] pci 0000:00:1f.2: reg 0x20: [io 0xf020-0xf03f]
[ 0.190493] pci 0000:00:1f.2: reg 0x24: [mem 0xf7116000-0xf71167ff]
[ 0.190529] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.190588] pci 0000:00:1f.3: [8086:1e22] type 00 class 0x0c0500
[ 0.190604] pci 0000:00:1f.3: reg 0x10: [mem 0xf7115000-0xf71150ff 64bit]
[ 0.190622] pci 0000:00:1f.3: reg 0x20: [io 0xf000-0xf01f]
[ 0.190716] pci 0000:01:00.0: [10de:1187] type 00 class 0x030000
[ 0.190725] pci 0000:01:00.0: reg 0x10: [mem 0xf6000000-0xf6ffffff]
[ 0.190733] pci 0000:01:00.0: reg 0x14: [mem 0xe8000000-0xefffffff 64bit pref]
[ 0.190742] pci 0000:01:00.0: reg 0x1c: [mem 0xf0000000-0xf1ffffff 64bit pref]
[ 0.190747] pci 0000:01:00.0: reg 0x24: [io 0xe000-0xe07f]
[ 0.190753] pci 0000:01:00.0: reg 0x30: [mem 0xf7000000-0xf707ffff pref]
[ 0.190757] pci 0000:01:00.0: enabling Extended Tags
[ 0.190769] pci 0000:01:00.0: BAR 3: assigned to efifb
[ 0.190772] pci 0000:01:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.190826] pci 0000:01:00.0: 32.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x16 link at 0000:00:01.0 (capable of 126.016 Gb/s with 8.0 GT/s PCIe x16 link)
[ 0.190872] pci 0000:01:00.1: [10de:0e0a] type 00 class 0x040300
[ 0.190882] pci 0000:01:00.1: reg 0x10: [mem 0xf7080000-0xf7083fff]
[ 0.190906] pci 0000:01:00.1: enabling Extended Tags
[ 0.190983] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.190986] pci 0000:00:01.0: bridge window [io 0xe000-0xefff]
[ 0.190987] pci 0000:00:01.0: bridge window [mem 0xf6000000-0xf70fffff]
[ 0.190990] pci 0000:00:01.0: bridge window [mem 0xe8000000-0xf1ffffff 64bit pref]
[ 0.191049] pci 0000:00:1c.0: PCI bridge to [bus 02]
[ 0.191131] pci 0000:03:00.0: [10ec:8168] type 00 class 0x020000
[ 0.191155] pci 0000:03:00.0: reg 0x10: [io 0xd000-0xd0ff]
[ 0.191186] pci 0000:03:00.0: reg 0x18: [mem 0xf2104000-0xf2104fff 64bit pref]
[ 0.191206] pci 0000:03:00.0: reg 0x20: [mem 0xf2100000-0xf2103fff 64bit pref]
[ 0.191331] pci 0000:03:00.0: supports D1 D2
[ 0.191332] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.191508] pci 0000:00:1c.4: PCI bridge to [bus 03]
[ 0.191511] pci 0000:00:1c.4: bridge window [io 0xd000-0xdfff]
[ 0.191518] pci 0000:00:1c.4: bridge window [mem 0xf2100000-0xf21fffff 64bit pref]
[ 0.191583] pci 0000:04:00.0: [1b21:1080] type 01 class 0x060401
[ 0.191770] pci 0000:00:1c.5: PCI bridge to [bus 04-05] (subtractive decode)
[ 0.191780] pci 0000:00:1c.5: bridge window [io 0x0000-0x0cf7 window] (subtractive decode)
[ 0.191782] pci 0000:00:1c.5: bridge window [io 0x0d00-0xffff window] (subtractive decode)
[ 0.191783] pci 0000:00:1c.5: bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode)
[ 0.191784] pci 0000:00:1c.5: bridge window [mem 0x000dc000-0x000dffff window] (subtractive decode)
[ 0.191785] pci 0000:00:1c.5: bridge window [mem 0xe0000000-0xfeafffff window] (subtractive decode)
[ 0.191816] pci_bus 0000:05: extended config space not accessible
[ 0.191896] pci 0000:04:00.0: PCI bridge to [bus 05] (subtractive decode)
[ 0.191917] pci 0000:04:00.0: bridge window [io 0x0000-0x0cf7 window] (subtractive decode)
[ 0.191918] pci 0000:04:00.0: bridge window [io 0x0d00-0xffff window] (subtractive decode)
[ 0.191919] pci 0000:04:00.0: bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode)
[ 0.191920] pci 0000:04:00.0: bridge window [mem 0x000dc000-0x000dffff window] (subtractive decode)
[ 0.191922] pci 0000:04:00.0: bridge window [mem 0xe0000000-0xfeafffff window] (subtractive decode)
[ 0.192418] ACPI: PCI: Interrupt link LNKA configured for IRQ 11
[ 0.192467] ACPI: PCI: Interrupt link LNKB configured for IRQ 10
[ 0.192514] ACPI: PCI: Interrupt link LNKC configured for IRQ 10
[ 0.192561] ACPI: PCI: Interrupt link LNKD configured for IRQ 3
[ 0.192608] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[ 0.192609] ACPI: PCI: Interrupt link LNKE disabled
[ 0.192655] ACPI: PCI: Interrupt link LNKF configured for IRQ 5
[ 0.192702] ACPI: PCI: Interrupt link LNKG configured for IRQ 11
[ 0.192750] ACPI: PCI: Interrupt link LNKH configured for IRQ 6
[ 0.194245] iommu: Default domain type: Translated
[ 0.194245] iommu: DMA domain TLB invalidation policy: lazy mode
[ 0.194355] SCSI subsystem initialized
[ 0.194361] libata version 3.00 loaded.
[ 0.194361] ACPI: bus type USB registered
[ 0.194361] usbcore: registered new interface driver usbfs
[ 0.194361] usbcore: registered new interface driver hub
[ 0.194361] usbcore: registered new device driver usb
[ 0.194361] pps_core: LinuxPPS API ver. 1 registered
[ 0.194361] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.194361] PTP clock support registered
[ 0.194361] EDAC MC: Ver: 3.0.0
[ 0.194361] efivars: Registered efivars operations
[ 0.194378] NetLabel: Initializing
[ 0.194379] NetLabel: domain hash size = 128
[ 0.194380] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.194392] NetLabel: unlabeled traffic allowed by default
[ 0.194396] mctp: management component transport protocol core
[ 0.194397] NET: Registered PF_MCTP protocol family
[ 0.194400] PCI: Using ACPI for IRQ routing
[ 0.195040] PCI: pci_cache_line_size set to 64 bytes
[ 0.195080] e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
[ 0.195082] e820: reserve RAM buffer [mem 0xddb4a000-0xdfffffff]
[ 0.195083] e820: reserve RAM buffer [mem 0xde832000-0xdfffffff]
[ 0.195084] e820: reserve RAM buffer [mem 0xdec95000-0xdfffffff]
[ 0.195085] e820: reserve RAM buffer [mem 0xdf000000-0xdfffffff]
[ 0.195086] e820: reserve RAM buffer [mem 0x41f000000-0x41fffffff]
[ 0.197569] pci 0000:01:00.0: vgaarb: setting as boot VGA device
[ 0.197569] pci 0000:01:00.0: vgaarb: bridge control possible
[ 0.197569] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.197569] vgaarb: loaded
[ 0.198579] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 0.198587] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[ 0.200593] clocksource: Switched to clocksource tsc-early
[ 0.200699] VFS: Disk quotas dquot_6.6.0
[ 0.200715] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.200790] pnp: PnP ACPI init
[ 0.200879] system 00:00: [mem 0xfed40000-0xfed44fff] has been reserved
[ 0.200911] system 00:01: [io 0x0680-0x069f] has been reserved
[ 0.200913] system 00:01: [io 0x1000-0x100f] has been reserved
[ 0.200915] system 00:01: [io 0xffff] has been reserved
[ 0.200916] system 00:01: [io 0xffff] has been reserved
[ 0.200917] system 00:01: [io 0x0400-0x0453] has been reserved
[ 0.200919] system 00:01: [io 0x0458-0x047f] has been reserved
[ 0.200920] system 00:01: [io 0x0500-0x057f] has been reserved
[ 0.200921] system 00:01: [io 0x164e-0x164f] has been reserved
[ 0.200985] system 00:03: [io 0x0454-0x0457] has been reserved
[ 0.201070] system 00:04: [io 0x0290-0x029f] has been reserved
[ 0.201115] system 00:05: [io 0x04d0-0x04d1] has been reserved
[ 0.201319] pnp 00:06: [dma 0 disabled]
[ 0.201532] system 00:07: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.201535] system 00:07: [mem 0xfed10000-0xfed17fff] has been reserved
[ 0.201536] system 00:07: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.201538] system 00:07: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.201539] system 00:07: [mem 0xf8000000-0xfbffffff] has been reserved
[ 0.201541] system 00:07: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.201542] system 00:07: [mem 0xfed90000-0xfed93fff] could not be reserved
[ 0.201544] system 00:07: [mem 0xfed45000-0xfed8ffff] has been reserved
[ 0.201545] system 00:07: [mem 0xff000000-0xffffffff] has been reserved
[ 0.201546] system 00:07: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.201548] system 00:07: [mem 0xe0000000-0xe0000fff] has been reserved
[ 0.201661] pnp: PnP ACPI: found 8 devices
[ 0.207199] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.207254] NET: Registered PF_INET protocol family
[ 0.207369] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.209986] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 0.210012] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.210062] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.210238] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[ 0.210456] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.210522] MPTCP token hash table entries: 16384 (order: 6, 393216 bytes, linear)
[ 0.210560] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.210595] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.210643] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.210649] NET: Registered PF_XDP protocol family
[ 0.210659] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.210663] pci 0000:00:01.0: bridge window [io 0xe000-0xefff]
[ 0.210665] pci 0000:00:01.0: bridge window [mem 0xf6000000-0xf70fffff]
[ 0.210667] pci 0000:00:01.0: bridge window [mem 0xe8000000-0xf1ffffff 64bit pref]
[ 0.210670] pci 0000:00:1c.0: PCI bridge to [bus 02]
[ 0.210686] pci 0000:00:1c.4: PCI bridge to [bus 03]
[ 0.210688] pci 0000:00:1c.4: bridge window [io 0xd000-0xdfff]
[ 0.210694] pci 0000:00:1c.4: bridge window [mem 0xf2100000-0xf21fffff 64bit pref]
[ 0.210699] pci 0000:04:00.0: PCI bridge to [bus 05]
[ 0.210717] pci 0000:00:1c.5: PCI bridge to [bus 04-05]
[ 0.210727] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.210729] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.210730] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.210731] pci_bus 0000:00: resource 7 [mem 0x000dc000-0x000dffff window]
[ 0.210733] pci_bus 0000:00: resource 8 [mem 0xe0000000-0xfeafffff window]
[ 0.210734] pci_bus 0000:01: resource 0 [io 0xe000-0xefff]
[ 0.210735] pci_bus 0000:01: resource 1 [mem 0xf6000000-0xf70fffff]
[ 0.210736] pci_bus 0000:01: resource 2 [mem 0xe8000000-0xf1ffffff 64bit pref]
[ 0.210737] pci_bus 0000:03: resource 0 [io 0xd000-0xdfff]
[ 0.210738] pci_bus 0000:03: resource 2 [mem 0xf2100000-0xf21fffff 64bit pref]
[ 0.210740] pci_bus 0000:04: resource 4 [io 0x0000-0x0cf7 window]
[ 0.210741] pci_bus 0000:04: resource 5 [io 0x0d00-0xffff window]
[ 0.210742] pci_bus 0000:04: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.210743] pci_bus 0000:04: resource 7 [mem 0x000dc000-0x000dffff window]
[ 0.210745] pci_bus 0000:04: resource 8 [mem 0xe0000000-0xfeafffff window]
[ 0.210746] pci_bus 0000:05: resource 4 [io 0x0000-0x0cf7 window]
[ 0.210747] pci_bus 0000:05: resource 5 [io 0x0d00-0xffff window]
[ 0.210748] pci_bus 0000:05: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.210749] pci_bus 0000:05: resource 7 [mem 0x000dc000-0x000dffff window]
[ 0.210750] pci_bus 0000:05: resource 8 [mem 0xe0000000-0xfeafffff window]
[ 0.211286] pci 0000:01:00.1: extending delay after power-on from D3hot to 20 msec
[ 0.211309] pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
[ 0.211317] pci 0000:03:00.0: CLS mismatch (64 != 32), using 64 bytes
[ 0.211319] pci 0000:04:00.0: Disabling ASPM L0s/L1
[ 0.211333] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.211334] software IO TLB: mapped [mem 0x00000000cde17000-0x00000000d1e17000] (64MB)
[ 0.211369] Trying to unpack rootfs image as initramfs...
[ 0.221377] Initialise system trusted keyrings
[ 0.221387] Key type blacklist registered
[ 0.221425] workingset: timestamp_bits=41 max_order=22 bucket_order=0
[ 0.221433] zbud: loaded
[ 0.221556] integrity: Platform Keyring initialized
[ 0.221559] integrity: Machine keyring initialized
[ 0.228914] Key type asymmetric registered
[ 0.228916] Asymmetric key parser 'x509' registered
[ 0.228928] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[ 0.228962] io scheduler mq-deadline registered
[ 0.228965] io scheduler kyber registered
[ 0.228976] io scheduler bfq registered
[ 0.229628] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.230031] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 0.230075] ACPI: button: Power Button [PWRB]
[ 0.230101] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 0.230135] ACPI: button: Power Button [PWRF]
[ 0.230754] thermal LNXTHERM:00: registered as thermal_zone0
[ 0.230757] ACPI: thermal: Thermal Zone [TZ00] (28 C)
[ 0.230998] thermal LNXTHERM:01: registered as thermal_zone1
[ 0.231000] ACPI: thermal: Thermal Zone [TZ01] (30 C)
[ 0.231125] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.231289] 00:06: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[ 0.233023] Non-volatile memory driver v1.3
[ 0.233025] Linux agpgart interface v0.103
[ 0.233046] AMD-Vi: AMD IOMMUv2 functionality not available on this system - This is not a bug.
[ 0.233088] ACPI: bus type drm_connector registered
[ 0.233394] [drm] Initialized simpledrm 1.0.0 20200625 for simple-framebuffer.0 on minor 0
[ 0.233643] fbcon: Deferring console take-over
[ 0.233645] simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
[ 0.234173] ahci 0000:00:1f.2: version 3.0
[ 0.247587] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x3f impl RAID mode
[ 0.247592] ahci 0000:00:1f.2: flags: 64bit ncq led clo pio slum part ems apst
[ 0.298076] scsi host0: ahci
[ 0.298338] scsi host1: ahci
[ 0.298490] scsi host2: ahci
[ 0.298606] scsi host3: ahci
[ 0.298715] scsi host4: ahci
[ 0.298786] scsi host5: ahci
[ 0.298813] ata1: SATA max UDMA/133 abar m2048@0xf7116000 port 0xf7116100 irq 26
[ 0.298816] ata2: SATA max UDMA/133 abar m2048@0xf7116000 port 0xf7116180 irq 26
[ 0.298817] ata3: SATA max UDMA/133 abar m2048@0xf7116000 port 0xf7116200 irq 26
[ 0.298818] ata4: SATA max UDMA/133 abar m2048@0xf7116000 port 0xf7116280 irq 26
[ 0.298820] ata5: SATA max UDMA/133 abar m2048@0xf7116000 port 0xf7116300 irq 26
[ 0.298821] ata6: SATA max UDMA/133 abar m2048@0xf7116000 port 0xf7116380 irq 26
[ 0.298913] usbcore: registered new interface driver usbserial_generic
[ 0.298917] usbserial: USB Serial support registered for generic
[ 0.298993] rtc_cmos 00:02: RTC can wake from S4
[ 0.299195] ehci-pci 0000:00:1d.0: EHCI Host Controller
[ 0.299202] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 1
[ 0.299214] ehci-pci 0000:00:1d.0: debug port 2
[ 0.299222] rtc_cmos 00:02: registered as rtc0
[ 0.299265] rtc_cmos 00:02: setting system clock to 2024-02-18T18:34:16 UTC (1708281256)
[ 0.299290] rtc_cmos 00:02: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[ 0.303133] ehci-pci 0000:00:1d.0: irq 23, io mem 0xf7117000
[ 0.303180] intel_pstate: Intel P-state driver initializing
[ 0.303492] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.303721] hid: raw HID events driver (C) Jiri Kosina
[ 0.303796] drop_monitor: Initializing network drop monitor service
[ 0.314102] Initializing XFRM netlink socket
[ 0.314135] NET: Registered PF_INET6 protocol family
[ 0.314228] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[ 0.314355] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
[ 0.314359] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.314360] usb usb1: Product: EHCI Host Controller
[ 0.314361] usb usb1: Manufacturer: Linux 6.6.10-1-MANJARO ehci_hcd
[ 0.314362] usb usb1: SerialNumber: 0000:00:1d.0
[ 0.314551] hub 1-0:1.0: USB hub found
[ 0.314591] hub 1-0:1.0: 2 ports detected
[ 0.314780] ehci-pci 0000:00:1a.0: EHCI Host Controller
[ 0.314785] ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 2
[ 0.314795] ehci-pci 0000:00:1a.0: debug port 2
[ 0.318724] ehci-pci 0000:00:1a.0: irq 23, io mem 0xf7118000
[ 0.330895] ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[ 0.331201] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
[ 0.331204] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.331206] usb usb2: Product: EHCI Host Controller
[ 0.331207] usb usb2: Manufacturer: Linux 6.6.10-1-MANJARO ehci_hcd
[ 0.331208] usb usb2: SerialNumber: 0000:00:1a.0
[ 0.331410] hub 2-0:1.0: USB hub found
[ 0.331444] hub 2-0:1.0: 2 ports detected
[ 0.348986] Freeing initrd memory: 19492K
[ 0.354331] Segment Routing with IPv6
[ 0.354342] RPL Segment Routing with IPv6
[ 0.354364] In-situ OAM (IOAM) with IPv6
[ 0.354389] NET: Registered PF_PACKET protocol family
[ 0.355375] microcode: Microcode Update Driver: v2.2.
[ 0.355380] IPI shorthand broadcast: enabled
[ 0.356672] sched_clock: Marking stable (355139214, 233122)->(373595688, -18223352)
[ 0.356881] registered taskstats version 1
[ 0.357317] Loading compiled-in X.509 certificates
[ 0.359869] Loaded X.509 cert 'Build time autogenerated kernel key: f1405f75fd94c9f4ce0f81c9d9af43094e90009f'
[ 0.361624] zswap: loaded using pool zstd/zsmalloc
[ 0.363058] Key type .fscrypt registered
[ 0.363059] Key type fscrypt-provisioning registered
[ 0.363738] PM: Magic number: 12:267:595
[ 0.366197] RAS: Correctable Errors collector initialized.
[ 0.366257] clk: Disabling unused clocks
[ 0.567575] usb 1-1: new high-speed USB device number 2 using ehci-pci
[ 0.580908] usb 2-1: new high-speed USB device number 2 using ehci-pci
[ 0.614244] ata5: SATA link down (SStatus 0 SControl 300)
[ 0.614270] ata4: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 0.614296] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 0.614325] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 0.614351] ata6: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 0.614364] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 0.614978] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.SPT5._GTF.DSSP], AE_NOT_FOUND (20230628/psargs-330)
[ 0.614987] ACPI Error: Aborting method \_SB.PCI0.SAT0.SPT5._GTF due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 0.615038] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.SPT3._GTF.DSSP], AE_NOT_FOUND (20230628/psargs-330)
[ 0.615050] ACPI Error: Aborting method \_SB.PCI0.SAT0.SPT3._GTF due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 0.615099] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.SPT1._GTF.DSSP], AE_NOT_FOUND (20230628/psargs-330)
[ 0.615106] ACPI Error: Aborting method \_SB.PCI0.SAT0.SPT1._GTF due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 0.615112] ata2.00: ATA-11: SanDisk SDSSDH3 1T00, 401120RL, max UDMA/133
[ 0.615159] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.SPT0._GTF.DSSP], AE_NOT_FOUND (20230628/psargs-330)
[ 0.615165] ACPI Error: Aborting method \_SB.PCI0.SAT0.SPT0._GTF due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 0.615173] ata6.00: ATA-7: MAXTOR STM3250310AS, 3.AAC, max UDMA/133
[ 0.615177] ata6.00: 488397168 sectors, multi 16: LBA48 NCQ (depth 32)
[ 0.615285] ata1.00: ATA-8: WDC WD10EZRX-00A8LB0, 01.01A01, max UDMA/133
[ 0.615487] ata4.00: ATA-8: WDC WD6400AAKS-22A7B2, 01.03B01, max UDMA/133
[ 0.615569] ata4.00: 1250263728 sectors, multi 16: LBA48 NCQ (depth 32), AA
[ 0.615673] ata2.00: 1953525168 sectors, multi 1: LBA48 NCQ (depth 32), AA
[ 0.615871] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.SPT5._GTF.DSSP], AE_NOT_FOUND (20230628/psargs-330)
[ 0.615879] ACPI Error: Aborting method \_SB.PCI0.SAT0.SPT5._GTF due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 0.615968] ata1.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[ 0.616001] ata6.00: configured for UDMA/133
[ 0.616394] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.SPT3._GTF.DSSP], AE_NOT_FOUND (20230628/psargs-330)
[ 0.616411] ACPI Error: Aborting method \_SB.PCI0.SAT0.SPT3._GTF due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 0.616631] ata4.00: configured for UDMA/133
[ 0.616838] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.SPT0._GTF.DSSP], AE_NOT_FOUND (20230628/psargs-330)
[ 0.616849] ACPI Error: Aborting method \_SB.PCI0.SAT0.SPT0._GTF due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 0.616993] ata1.00: configured for UDMA/133
[ 0.617238] ata2.00: Features: Dev-Sleep
[ 0.617240] scsi 0:0:0:0: Direct-Access ATA WDC WD10EZRX-00A 1A01 PQ: 0 ANSI: 5
[ 0.617367] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.SPT2._GTF.DSSP], AE_NOT_FOUND (20230628/psargs-330)
[ 0.617374] ACPI Error: Aborting method \_SB.PCI0.SAT0.SPT2._GTF due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 0.617379] ata3.00: ATAPI: HL-DT-ST DVDRAM GH40F, MG01, max UDMA/100
[ 0.617538] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 0.617541] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 0.617555] sd 0:0:0:0: [sda] Write Protect is off
[ 0.617557] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 0.617583] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 0.617604] sd 0:0:0:0: [sda] Preferred minimum I/O size 4096 bytes
[ 0.618061] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.SPT1._GTF.DSSP], AE_NOT_FOUND (20230628/psargs-330)
[ 0.618067] ACPI Error: Aborting method \_SB.PCI0.SAT0.SPT1._GTF due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 0.620447] ata2.00: configured for UDMA/133
[ 0.620503] scsi 1:0:0:0: Direct-Access ATA SanDisk SDSSDH3 20RL PQ: 0 ANSI: 5
[ 0.620754] sd 1:0:0:0: [sdb] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 0.620761] sd 1:0:0:0: [sdb] Write Protect is off
[ 0.620763] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 0.620772] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 0.620785] sd 1:0:0:0: [sdb] Preferred minimum I/O size 512 bytes
[ 0.621277] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.SPT2._GTF.DSSP], AE_NOT_FOUND (20230628/psargs-330)
[ 0.621285] ACPI Error: Aborting method \_SB.PCI0.SAT0.SPT2._GTF due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 0.621292] ata3.00: configured for UDMA/100
[ 0.622362] sdb: sdb1 sdb2 sdb3
[ 0.622585] sd 1:0:0:0: [sdb] Attached SCSI disk
[ 0.628865] scsi 2:0:0:0: CD-ROM HL-DT-ST DVDRAM GH40F MG01 PQ: 0 ANSI: 5
[ 0.635094] sda: sda1 sda2
[ 0.635376] sd 0:0:0:0: [sda] Attached SCSI disk
[ 0.656395] scsi 3:0:0:0: Direct-Access ATA WDC WD6400AAKS-2 3B01 PQ: 0 ANSI: 5
[ 0.657119] sd 3:0:0:0: [sdc] 1250263728 512-byte logical blocks: (640 GB/596 GiB)
[ 0.657130] sd 3:0:0:0: [sdc] Write Protect is off
[ 0.657133] sd 3:0:0:0: [sdc] Mode Sense: 00 3a 00 00
[ 0.657159] sd 3:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 0.657192] sd 3:0:0:0: [sdc] Preferred minimum I/O size 512 bytes
[ 0.657217] scsi 5:0:0:0: Direct-Access ATA MAXTOR STM325031 C PQ: 0 ANSI: 5
[ 0.657483] sd 5:0:0:0: [sdd] 488397168 512-byte logical blocks: (250 GB/233 GiB)
[ 0.657494] sd 5:0:0:0: [sdd] Write Protect is off
[ 0.657496] sd 5:0:0:0: [sdd] Mode Sense: 00 3a 00 00
[ 0.657520] sd 5:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 0.657541] sd 5:0:0:0: [sdd] Preferred minimum I/O size 512 bytes
[ 0.667184] sdd: sdd1
[ 0.667270] sd 5:0:0:0: [sdd] Attached SCSI disk
[ 0.674490] sdc: sdc1
[ 0.674566] sd 3:0:0:0: [sdc] Attached SCSI disk
[ 0.676615] Freeing unused decrypted memory: 2028K
[ 0.677028] Freeing unused kernel image (initmem) memory: 3424K
[ 0.677059] Write protecting the kernel read-only data: 30720k
[ 0.677376] Freeing unused kernel image (rodata/data gap) memory: 1188K
[ 0.714618] usb 1-1: New USB device found, idVendor=8087, idProduct=0024, bcdDevice= 0.00
[ 0.714623] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 0.715070] hub 1-1:1.0: USB hub found
[ 0.715241] hub 1-1:1.0: 8 ports detected
[ 0.727865] usb 2-1: New USB device found, idVendor=8087, idProduct=0024, bcdDevice= 0.00
[ 0.727869] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 0.728209] hub 2-1:1.0: USB hub found
[ 0.728363] hub 2-1:1.0: 6 ports detected
[ 0.728539] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 0.728543] rodata_test: all tests were successful
[ 0.728545] x86/mm: Checking user space page tables
[ 0.764308] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 0.764317] Run /init as init process
[ 0.764318] with arguments:
[ 0.764319] /init
[ 0.764320] with environment:
[ 0.764320] HOME=/
[ 0.764321] TERM=linux
[ 0.764322] BOOT_IMAGE=/boot/vmlinuz-6.6-x86_64
[ 0.906343] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 0.906353] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
[ 0.907415] xhci_hcd 0000:00:14.0: hcc params 0x20007181 hci version 0x100 quirks 0x000000000000b930
[ 0.907608] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 0.907613] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 4
[ 0.907616] xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
[ 0.907668] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
[ 0.907671] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.907674] usb usb3: Product: xHCI Host Controller
[ 0.907676] usb usb3: Manufacturer: Linux 6.6.10-1-MANJARO xhci-hcd
[ 0.907677] usb usb3: SerialNumber: 0000:00:14.0
[ 0.907814] hub 3-0:1.0: USB hub found
[ 0.907826] hub 3-0:1.0: 4 ports detected
[ 0.908510] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.06
[ 0.908513] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.908516] usb usb4: Product: xHCI Host Controller
[ 0.908517] usb usb4: Manufacturer: Linux 6.6.10-1-MANJARO xhci-hcd
[ 0.908519] usb usb4: SerialNumber: 0000:00:14.0
[ 0.908621] hub 4-0:1.0: USB hub found
[ 0.908631] hub 4-0:1.0: 4 ports detected
[ 0.972141] sr 2:0:0:0: [sr0] scsi3-mmc drive: 40x/40x writer dvd-ram cd/rw xa/form2 cdda tray
[ 0.972151] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 0.994229] usb 1-1.8: new full-speed USB device number 3 using ehci-pci
[ 1.010914] usb 2-1.1: new high-speed USB device number 3 using ehci-pci
[ 1.026202] sr 2:0:0:0: Attached scsi CD-ROM sr0
[ 1.128402] usb 1-1.8: New USB device found, idVendor=0a12, idProduct=0001, bcdDevice=88.91
[ 1.128411] usb 1-1.8: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.163605] usb 3-3: new full-speed USB device number 2 using xhci_hcd
[ 1.226925] tsc: Refined TSC clocksource calibration: 3410.013 MHz
[ 1.226942] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x3127418e06e, max_idle_ns: 440795285561 ns
[ 1.226988] clocksource: Switched to clocksource tsc
[ 1.267910] usb 2-1.1: New USB device found, idVendor=0bda, idProduct=0169, bcdDevice=61.23
[ 1.267918] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.267921] usb 2-1.1: Product: USB2.0-CRW
[ 1.267923] usb 2-1.1: Manufacturer: Generic
[ 1.267925] usb 2-1.1: SerialNumber: 20070818000000000
[ 1.276252] usb-storage 2-1.1:1.1: USB Mass Storage device detected
[ 1.276649] scsi host6: usb-storage 2-1.1:1.1
[ 1.276835] usbcore: registered new interface driver usb-storage
[ 1.282728] usbcore: registered new interface driver uas
[ 1.308276] usb 3-3: New USB device found, idVendor=fffe, idProduct=000c, bcdDevice= 1.04
[ 1.308284] usb 3-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.308287] usb 3-3: Product: Akko Keyboard
[ 1.308289] usb 3-3: Manufacturer: Akko
[ 1.321304] input: Akko Akko Keyboard as /devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3:1.0/0003:FFFE:000C.0001/input/input2
[ 1.346940] usb 2-1.2: new full-speed USB device number 4 using ehci-pci
[ 1.377412] hid-generic 0003:FFFE:000C.0001: input,hidraw0: USB HID v1.11 Keyboard [Akko Akko Keyboard] on usb-0000:00:14.0-3/input0
[ 1.378152] hid-generic 0003:FFFE:000C.0002: hiddev96,hidraw1: USB HID v1.11 Device [Akko Akko Keyboard] on usb-0000:00:14.0-3/input1
[ 1.378207] usbcore: registered new interface driver usbhid
[ 1.378208] usbhid: USB HID core driver
[ 1.430268] usb 3-4: new full-speed USB device number 3 using xhci_hcd
[ 1.446660] usb 2-1.2: New USB device found, idVendor=1507, idProduct=2814, bcdDevice= 2.00
[ 1.446668] usb 2-1.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.446671] usb 2-1.2: Product: 2.4G Composite Devic
[ 1.449029] input: 2.4G Composite Devic as /devices/pci0000:00/0000:00:1a.0/usb2/2-1/2-1.2/2-1.2:1.0/0003:1507:2814.0003/input/input3
[ 1.503832] hid-generic 0003:1507:2814.0003: input,hidraw2: USB HID v1.10 Keyboard [2.4G Composite Devic] on usb-0000:00:1a.0-1.2/input0
[ 1.506751] input: 2.4G Composite Devic Mouse as /devices/pci0000:00/0000:00:1a.0/usb2/2-1/2-1.2/2-1.2:1.1/0003:1507:2814.0004/input/input4
[ 1.506864] input: 2.4G Composite Devic Consumer Control as /devices/pci0000:00/0000:00:1a.0/usb2/2-1/2-1.2/2-1.2:1.1/0003:1507:2814.0004/input/input5
[ 1.560376] input: 2.4G Composite Devic System Control as /devices/pci0000:00/0000:00:1a.0/usb2/2-1/2-1.2/2-1.2:1.1/0003:1507:2814.0004/input/input6
[ 1.560458] hid-generic 0003:1507:2814.0004: input,hidraw3: USB HID v1.10 Mouse [2.4G Composite Devic] on usb-0000:00:1a.0-1.2/input1
[ 1.571670] usb 3-4: New USB device found, idVendor=046d, idProduct=c09d, bcdDevice=52.02
[ 1.571678] usb 3-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.571681] usb 3-4: Product: G203 LIGHTSYNC Gaming Mouse
[ 1.571683] usb 3-4: Manufacturer: Logitech
[ 1.571685] usb 3-4: SerialNumber: 206436694858
[ 1.573198] input: Logitech G203 LIGHTSYNC Gaming Mouse as /devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4:1.0/0003:046D:C09D.0005/input/input7
[ 1.573305] hid-generic 0003:046D:C09D.0005: input,hidraw4: USB HID v1.11 Mouse [Logitech G203 LIGHTSYNC Gaming Mouse] on usb-0000:00:14.0-4/input0
[ 1.574674] input: Logitech G203 LIGHTSYNC Gaming Mouse Keyboard as /devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4:1.1/0003:046D:C09D.0006/input/input8
[ 1.630458] hid-generic 0003:046D:C09D.0006: input,hiddev97,hidraw5: USB HID v1.11 Keyboard [Logitech G203 LIGHTSYNC Gaming Mouse] on usb-0000:00:14.0-4/input1
[ 2.065416] fbcon: Taking over console
[ 2.068380] Console: switching to colour frame buffer device 128x48
[ 2.274614] EXT4-fs (sdb2): mounted filesystem dbd78c17-f7c0-476f-b72a-459ec5566942 r/w with ordered data mode. Quota mode: none.
[ 2.310076] scsi 6:0:0:0: Direct-Access Generic- Multi-Card 1.00 PQ: 0 ANSI: 0 CCS
[ 2.311644] sd 6:0:0:0: [sde] Media removed, stopped polling
[ 2.311973] sd 6:0:0:0: [sde] Attached SCSI removable disk
[ 2.402638] systemd[1]: systemd 255.2-2-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[ 2.402645] systemd[1]: Detected architecture x86-64.
[ 2.404659] systemd[1]: Hostname set to <iscandar>.
[ 2.810385] systemd[1]: bpf-lsm: LSM BPF program attached
[ 3.116613] systemd[1]: Queued start job for default target Graphical Interface.
[ 3.162142] systemd[1]: Created slice Slice /system/avahi-alias.
[ 3.162533] systemd[1]: Created slice Slice /system/avahi-alias-ip6.
[ 3.162876] systemd[1]: Created slice Slice /system/getty.
[ 3.163224] systemd[1]: Created slice Slice /system/modprobe.
[ 3.163574] systemd[1]: Created slice Slice /system/systemd-fsck.
[ 3.163853] systemd[1]: Created slice User and Session Slice.
[ 3.163913] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 3.163958] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.164112] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 3.164132] systemd[1]: Expecting device /dev/disk/by-uuid/2be7c2ef-43e1-4601-95f3-aee00991978a...
[ 3.164141] systemd[1]: Expecting device /dev/disk/by-uuid/3A3E-5F87...
[ 3.164151] systemd[1]: Reached target Local Encrypted Volumes.
[ 3.164163] systemd[1]: Reached target Login Prompts.
[ 3.164177] systemd[1]: Reached target Local Integrity Protected Volumes.
[ 3.164199] systemd[1]: Reached target Remote File Systems.
[ 3.164209] systemd[1]: Reached target Slice Units.
[ 3.164221] systemd[1]: Reached target Mounting snaps.
[ 3.164232] systemd[1]: Reached target Mounted snaps.
[ 3.164254] systemd[1]: Reached target Local Verity Protected Volumes.
[ 3.164319] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 3.164429] systemd[1]: Listening on LVM2 poll daemon socket.
[ 3.165521] systemd[1]: Listening on Process Core Dump Socket.
[ 3.165631] systemd[1]: Listening on Journal Socket (/dev/log).
[ 3.165733] systemd[1]: Listening on Journal Socket.
[ 3.165763] systemd[1]: TPM2 PCR Extension (Varlink) was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ 3.166603] systemd[1]: Listening on udev Control Socket.
[ 3.166708] systemd[1]: Listening on udev Kernel Socket.
[ 3.167748] systemd[1]: Mounting Huge Pages File System...
[ 3.168416] systemd[1]: Mounting POSIX Message Queue File System...
[ 3.169096] systemd[1]: Mounting Kernel Debug File System...
[ 3.169761] systemd[1]: Mounting Kernel Trace File System...
[ 3.169845] systemd[1]: Load AppArmor profiles was skipped because of an unmet condition check (ConditionSecurity=apparmor).
[ 3.171121] systemd[1]: Starting Create List of Static Device Nodes...
[ 3.172179] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 3.173127] systemd[1]: Starting Load Kernel Module configfs...
[ 3.174784] systemd[1]: Starting Load Kernel Module dm_mod...
[ 3.175672] systemd[1]: Starting Load Kernel Module drm...
[ 3.176723] systemd[1]: Starting Load Kernel Module fuse...
[ 3.177746] systemd[1]: Starting Load Kernel Module loop...
[ 3.177787] systemd[1]: Load AppArmor profiles managed internally by snapd was skipped because of an unmet condition check (ConditionSecurity=apparmor).
[ 3.177865] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
[ 3.179482] systemd[1]: Starting Load Kernel Modules...
[ 3.179509] systemd[1]: TPM2 PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ 3.180625] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 3.180685] systemd[1]: TPM2 SRK Setup (Early) was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ 3.181757] systemd[1]: Starting Coldplug All udev Devices...
[ 3.183407] systemd[1]: Mounted Huge Pages File System.
[ 3.183511] systemd[1]: Mounted POSIX Message Queue File System.
[ 3.183614] systemd[1]: Mounted Kernel Debug File System.
[ 3.183723] systemd[1]: Mounted Kernel Trace File System.
[ 3.195223] loop: module loaded
[ 3.195240] device-mapper: uevent: version 1.0.3
[ 3.195317] device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@redhat.com
[ 3.197813] fuse: init (API version 7.39)
[ 3.202909] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 3.202935] sd 1:0:0:0: Attached scsi generic sg1 type 0
[ 3.202958] sr 2:0:0:0: Attached scsi generic sg2 type 5
[ 3.202977] sd 3:0:0:0: Attached scsi generic sg3 type 0
[ 3.202996] sd 5:0:0:0: Attached scsi generic sg4 type 0
[ 3.203014] sd 6:0:0:0: Attached scsi generic sg5 type 0
[ 3.207263] systemd[1]: Finished Create List of Static Device Nodes.
[ 3.207336] EXT4-fs (sdb2): re-mounted dbd78c17-f7c0-476f-b72a-459ec5566942 r/w. Quota mode: none.
[ 3.208170] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 3.208372] vboxdrv: loading out-of-tree module taints kernel.
[ 3.208376] vboxdrv: module verification failed: signature and/or required key missing - tainting kernel
[ 3.222540] vboxdrv: Found 8 processor cores/threads
[ 3.243863] vboxdrv: TSC mode is Invariant, tentative frequency 3410011331 Hz
[ 3.243865] vboxdrv: Successfully loaded version 7.0.12 r159484 (interface 0x00330004)
[ 3.245221] VBoxNetAdp: Successfully started.
[ 3.246998] VBoxNetFlt: Successfully started.
[ 3.250524] systemd[1]: Finished Load Kernel Module configfs.
[ 3.250945] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
[ 3.283786] systemd[1]: Finished Load Kernel Module dm_mod.
[ 3.284093] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 3.333773] systemd[1]: Finished Load Kernel Module drm.
[ 3.334109] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 3.360492] systemd[1]: Finished Load Kernel Module fuse.
[ 3.360802] systemd[1]: modprobe@loop.service: Deactivated successfully.
[ 3.390493] systemd[1]: Finished Load Kernel Module loop.
[ 3.427181] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[ 3.457163] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 3.480507] systemd[1]: Finished Coldplug All udev Devices.
[ 3.513793] systemd[1]: Mounting FUSE Control File System...
[ 3.514676] systemd[1]: Mounting Kernel Configuration File System...
[ 3.515047] systemd[1]: Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
[ 3.515845] systemd[1]: Starting Load/Save OS Random Seed...
[ 3.515889] systemd[1]: Repartition Root Disk was skipped because no trigger condition checks were met.
[ 3.516585] systemd[1]: Starting Create Static Device Nodes in /dev gracefully...
[ 3.516605] systemd[1]: TPM2 SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ 3.517364] systemd[1]: Mounted FUSE Control File System.
[ 3.519635] systemd[1]: Mounted Kernel Configuration File System.
[ 3.553808] systemd[1]: Finished Load/Save OS Random Seed.
[ 3.610448] systemd[1]: Finished Create Static Device Nodes in /dev gracefully.
[ 3.610634] systemd[1]: Create System Users was skipped because no trigger condition checks were met.
[ 3.640467] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 3.680410] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 3.680518] systemd[1]: Reached target Preparation for Local File Systems.
[ 3.680795] systemd[1]: Set up automount mnt-alpha.automount.
[ 3.681034] systemd[1]: Set up automount mnt-beta.automount.
[ 3.681268] systemd[1]: Set up automount mnt-gamma.automount.
[ 3.681295] systemd[1]: Virtual Machine and Container Storage (Compatibility) was skipped because of an unmet condition check (ConditionPathExists=/var/lib/machines.raw).
[ 3.681329] systemd[1]: Entropy Daemon based on the HAVEGE algorithm was skipped because of an unmet condition check (ConditionKernelVersion=<5.6).
[ 3.713797] systemd[1]: Starting Journal Service...
[ 3.715152] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[ 3.724472] systemd-journald[257]: Collecting audit messages is disabled.
[ 3.766309] systemd[1]: Started Journal Service.
[ 3.794664] systemd-journald[257]: Received client request to flush runtime journal.
[ 3.795614] systemd-journald[257]: File /var/log/journal/4e4219c4df824631a9cef4853d3f65b5/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 4.042712] EDAC ie31200: No ECC support
[ 4.043643] EDAC ie31200: No ECC support
[ 4.091184] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20230628/utaddress-204)
[ 4.091197] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[ 4.091201] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20230628/utaddress-204)
[ 4.091205] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[ 4.091208] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20230628/utaddress-204)
[ 4.091212] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[ 4.091214] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20230628/utaddress-204)
[ 4.091218] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[ 4.091219] lpc_ich: Resource conflict(s) found affecting gpio_ich
[ 4.091880] Adding 17983908k swap on /dev/sdb3. Priority:-2 extents:1 across:17983908k SS
[ 4.122967] input: PC Speaker as /devices/platform/pcspkr/input/input11
[ 4.172912] raid6: skipped pq benchmark and selected sse2x4
[ 4.172917] raid6: using ssse3x2 recovery algorithm
[ 4.182057] mousedev: PS/2 mouse device common for all mice
[ 4.184537] xor: automatically using best checksumming function avx
[ 4.185676] i8042: PNP: No PS/2 controller found.
[ 4.204422] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
[ 4.206657] i2c i2c-0: 2/4 memory slots populated (from DMI)
[ 4.210456] i2c i2c-0: Successfully instantiated SPD at 0x50
[ 4.211016] i2c i2c-0: Successfully instantiated SPD at 0x52
[ 4.224446] r8169 0000:03:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 4.227025] RAPL PMU: API unit is 2^-32 Joules, 2 fixed counters, 163840 ms ovfl timer
[ 4.227028] RAPL PMU: hw unit of domain pp0-core 2^-16 Joules
[ 4.227030] RAPL PMU: hw unit of domain package 2^-16 Joules
[ 4.227036] asus_wmi: ASUS WMI generic driver loaded
[ 4.238413] cryptd: max_cpu_qlen set to 1000
[ 4.241632] asus_wmi: Initialization: 0x0
[ 4.241671] asus_wmi: BIOS WMI version: 0.9
[ 4.241741] asus_wmi: SFUN value: 0x0
[ 4.241744] eeepc-wmi eeepc-wmi: Detected ASUSWMI, use DCTS
[ 4.244450] input: Eee PC WMI hotkeys as /devices/platform/eeepc-wmi/input/input12
[ 4.278473] r8169 0000:03:00.0 eth0: RTL8168evl/8111evl, ########, XID 2c9, IRQ 29
[ 4.278480] r8169 0000:03:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
[ 4.352381] AVX version of gcm_enc/dec engaged.
[ 4.352410] AES CTR mode by8 optimization enabled
[ 4.388845] Btrfs loaded, zoned=yes, fsverity=yes
[ 4.400485] Bluetooth: Core ver 2.22
[ 4.400505] NET: Registered PF_BLUETOOTH protocol family
[ 4.400507] Bluetooth: HCI device and connection manager initialized
[ 4.400511] Bluetooth: HCI socket layer initialized
[ 4.400513] Bluetooth: L2CAP socket layer initialized
[ 4.400517] Bluetooth: SCO socket layer initialized
[ 4.401060] BTRFS: device label beta devid 1 transid 38 /dev/sdd1 scanned by (udev-worker) (290)
[ 4.401465] iTCO_vendor_support: vendor-support=0
[ 4.401467] BTRFS: device label gamma devid 1 transid 10077 /dev/sdc1 scanned by (udev-worker) (291)
[ 4.435204] iTCO_wdt iTCO_wdt.1.auto: Found a Panther Point TCO device (Version=2, TCOBASE=0x0460)
[ 4.435315] iTCO_wdt iTCO_wdt.1.auto: initialized. heartbeat=30 sec (nowayout=0)
[ 4.449920] at24 0-0050: supply vcc not found, using dummy regulator
[ 4.451055] at24 0-0050: 256 byte spd EEPROM, read-only
[ 4.451298] at24 0-0052: supply vcc not found, using dummy regulator
[ 4.451890] at24 0-0052: 256 byte spd EEPROM, read-only
[ 4.451952] r8169 0000:03:00.0 enp3s0: renamed from eth0
[ 4.453205] usbcore: registered new interface driver btusb
[ 4.454465] Bluetooth: hci0: CSR: Setting up dongle with HCI ver=6 rev=22bb
[ 4.454468] Bluetooth: hci0: LMP ver=6 subver=22bb; manufacturer=10
[ 4.458989] snd_hda_intel 0000:00:1b.0: enabling device (0000 -> 0002)
[ 4.459296] snd_hda_intel 0000:01:00.1: enabling device (0000 -> 0002)
[ 4.459341] snd_hda_intel 0000:01:00.1: Disabling MSI
[ 4.459346] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[ 4.492339] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC887-VD: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
[ 4.492345] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 4.492347] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ 4.492348] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 4.492349] snd_hda_codec_realtek hdaudioC0D0: dig-out=0x11/0x1e
[ 4.492350] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 4.492351] snd_hda_codec_realtek hdaudioC0D0: Front Mic=0x19
[ 4.492352] snd_hda_codec_realtek hdaudioC0D0: Rear Mic=0x18
[ 4.492353] snd_hda_codec_realtek hdaudioC0D0: Line=0x1a
[ 4.499509] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input13
[ 4.499567] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input14
[ 4.499615] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input15
[ 4.499667] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input16
[ 4.521708] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input17
[ 4.521785] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input18
[ 4.521851] input: HDA Intel PCH Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input19
[ 4.527522] nvidia: module license 'NVIDIA' taints kernel.
[ 4.527529] Disabling lock debugging due to kernel taint
[ 4.527533] nvidia: module license taints kernel.
[ 4.863860] nvidia-nvlink: Nvlink Core is being initialized, major device number 236
[ 4.864606] nvidia 0000:01:00.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=none:owns=io+mem
[ 4.891963] intel_rapl_common: Found RAPL domain package
[ 4.891966] intel_rapl_common: Found RAPL domain core
[ 4.891971] intel_rapl_common: package-0:package:long_term locked by BIOS
[ 4.891973] intel_rapl_common: package-0:package:short_term locked by BIOS
[ 6.379125] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 470.223.02 Sat Oct 7 15:39:11 UTC 2023
[ 6.450724] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 470.223.02 Sat Oct 7 15:32:36 UTC 2023
[ 6.502613] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ 6.502617] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 1
[ 7.024977] nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
[ 7.137342] nvidia-uvm: Loaded the UVM driver, major device number 234.
[ 7.143066] i2c_dev: i2c /dev entries driver
[ 7.663534] nct6775: Found NCT6779D or compatible chip at 0x2e:0x290
[ 7.690833] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 7.690836] Bluetooth: BNEP filters: protocol multicast
[ 7.690840] Bluetooth: BNEP socket layer initialized
[ 7.691806] Bluetooth: MGMT ver 1.22
[ 7.697506] NET: Registered PF_ALG protocol family
[ 7.760529] loop0: detected capacity change from 0 to 8
[ 7.766646] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 8.027083] RTL8211E Gigabit Ethernet r8169-0-300:00: attached PHY driver (mii_bus:phy_addr=r8169-0-300:00, irq=MAC)
[ 8.043613] NET: Registered PF_QIPCRTR protocol family
[ 8.262382] r8169 0000:03:00.0 enp3s0: Link is Down
[ 8.761211] resource: resource sanity check: requesting [mem 0x00000000000c0000-0x00000000000fffff], which spans more than PCI Bus 0000:00 [mem 0x000dc000-0x000dffff window]
[ 8.761217] caller _nv000720rm+0x1ad/0x200 [nvidia] mapping multiple BARs
[ 11.205619] r8169 0000:03:00.0 enp3s0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 11.251977] Xorg[731]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
[ 13.840426] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 13.844381] Bridge firewalling registered
[ 15.061387] br0: renamed from ov-001000-rswte
[ 15.143896] vxlan0: renamed from vx-001000-rswte
[ 15.160424] br0: port 1(vxlan0) entered blocking state
[ 15.160441] br0: port 1(vxlan0) entered disabled state
[ 15.160450] vxlan0: entered allmulticast mode
[ 15.160504] vxlan0: entered promiscuous mode
[ 15.160707] br0: port 1(vxlan0) entered blocking state
[ 15.160711] br0: port 1(vxlan0) entered forwarding state
[ 15.213895] veth0: renamed from vethffc3b18
[ 15.243794] br0: port 2(veth0) entered blocking state
[ 15.243807] br0: port 2(veth0) entered disabled state
[ 15.243814] veth0: entered allmulticast mode
[ 15.243878] veth0: entered promiscuous mode
[ 15.244022] br0: port 2(veth0) entered blocking state
[ 15.244025] br0: port 2(veth0) entered forwarding state
[ 15.307203] eth0: renamed from vethb063de8
[ 15.332875] docker_gwbridge: port 1(veth1b55504) entered blocking state
[ 15.332880] docker_gwbridge: port 1(veth1b55504) entered disabled state
[ 15.332887] veth1b55504: entered allmulticast mode
[ 15.333016] veth1b55504: entered promiscuous mode
[ 15.333128] docker_gwbridge: port 1(veth1b55504) entered blocking state
[ 15.333131] docker_gwbridge: port 1(veth1b55504) entered forwarding state
[ 15.333410] docker_gwbridge: port 1(veth1b55504) entered disabled state
[ 15.380666] eth1: renamed from veth42b3687
[ 15.407257] docker_gwbridge: port 1(veth1b55504) entered blocking state
[ 15.407262] docker_gwbridge: port 1(veth1b55504) entered forwarding state
[ 15.429183] IPVS: Registered protocols (TCP, UDP, SCTP, AH, ESP)
[ 15.429206] IPVS: Connection hash table configured (size=32768, memory=256Kbytes)
[ 15.429322] IPVS: ipvs loaded.
[ 15.468873] IPVS: [rr] scheduler registered.
[ 15.470580] IPVS: starting estimator thread 0...
[ 15.543612] IPVS: using max 18672 ests per chain, 933600 per kthread
[ 15.567127] br0: renamed from ov-001002-ubfiv
[ 15.647288] vxlan0: renamed from vx-001002-ubfiv
[ 15.683754] br0: port 1(vxlan0) entered blocking state
[ 15.683766] br0: port 1(vxlan0) entered disabled state
[ 15.683771] vxlan0: entered allmulticast mode
[ 15.683803] vxlan0: entered promiscuous mode
[ 15.683912] br0: port 1(vxlan0) entered blocking state
[ 15.683914] br0: port 1(vxlan0) entered forwarding state
[ 15.720678] veth0: renamed from veth818c531
[ 15.747296] br0: port 2(veth0) entered blocking state
[ 15.747309] br0: port 2(veth0) entered disabled state
[ 15.747317] veth0: entered allmulticast mode
[ 15.747387] veth0: entered promiscuous mode
[ 15.747519] br0: port 2(veth0) entered blocking state
[ 15.747522] br0: port 2(veth0) entered forwarding state
[ 15.797235] eth0: renamed from veth5180cd9
[ 15.833203] IPVS: starting estimator thread 0...
[ 15.871157] FS-Cache: Loaded
[ 15.903585] IPVS: using max 12624 ests per chain, 631200 per kthread
[ 15.928972] RPC: Registered named UNIX socket transport module.
[ 15.928976] RPC: Registered udp transport module.
[ 15.928976] RPC: Registered tcp transport module.
[ 15.928977] RPC: Registered tcp-with-tls transport module.
[ 15.928977] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 15.989798] Key type dns_resolver registered
[ 16.180128] NFS: Registering the id_resolver key type
[ 16.180140] Key type id_resolver registered
[ 16.180141] Key type id_legacy registered
[ 16.287663] br0: port 2(veth0) entered disabled state
[ 16.287675] br0: port 1(vxlan0) entered disabled state
[ 16.287733] ov-001002-ubfiv: renamed from br0
[ 16.303714] veth0: left allmulticast mode
[ 16.303718] veth0: left promiscuous mode
[ 16.303735] ov-001002-ubfiv: port 2(veth0) entered disabled state
[ 16.326984] vxlan0: left allmulticast mode
[ 16.326988] vxlan0: left promiscuous mode
[ 16.327009] ov-001002-ubfiv: port 1(vxlan0) entered disabled state
[ 16.423781] vx-001002-ubfiv: renamed from vxlan0
[ 16.467235] veth818c531: renamed from veth0
[ 16.523900] veth5180cd9: renamed from eth0
[ 16.753905] IPVS: stop unused estimator thread 0...
[ 19.953046] br0: renamed from ov-001002-ubfiv
[ 20.030586] vxlan0: renamed from vx-001002-ubfiv
[ 20.060500] br0: port 1(vxlan0) entered blocking state
[ 20.060513] br0: port 1(vxlan0) entered disabled state
[ 20.060521] vxlan0: entered allmulticast mode
[ 20.060568] vxlan0: entered promiscuous mode
[ 20.060704] br0: port 1(vxlan0) entered blocking state
[ 20.060706] br0: port 1(vxlan0) entered forwarding state
[ 20.084088] veth0: renamed from vethe03b37f
[ 20.127188] br0: port 2(veth0) entered blocking state
[ 20.127212] br0: port 2(veth0) entered disabled state
[ 20.127220] veth0: entered allmulticast mode
[ 20.127272] veth0: entered promiscuous mode
[ 20.127391] br0: port 2(veth0) entered blocking state
[ 20.127394] br0: port 2(veth0) entered forwarding state
[ 20.183923] eth0: renamed from veth3316c32
[ 20.232008] IPVS: starting estimator thread 0...
[ 20.270579] veth1: renamed from veth4b6ec50
[ 20.297253] br0: port 3(veth1) entered blocking state
[ 20.297259] br0: port 3(veth1) entered disabled state
[ 20.297269] veth1: entered allmulticast mode
[ 20.297316] veth1: entered promiscuous mode
[ 20.297412] br0: port 3(veth1) entered blocking state
[ 20.297415] br0: port 3(veth1) entered forwarding state
[ 20.299243] docker_gwbridge: port 2(vethaa97b5a) entered blocking state
[ 20.299248] docker_gwbridge: port 2(vethaa97b5a) entered disabled state
[ 20.299254] vethaa97b5a: entered allmulticast mode
[ 20.299302] vethaa97b5a: entered promiscuous mode
[ 20.299391] docker_gwbridge: port 2(vethaa97b5a) entered blocking state
[ 20.299394] docker_gwbridge: port 2(vethaa97b5a) entered forwarding state
[ 20.306973] IPVS: using max 13872 ests per chain, 693600 per kthread
[ 20.517253] eth0: renamed from veth0fa1e46
[ 20.547426] docker_gwbridge: port 2(vethaa97b5a) entered disabled state
[ 20.570581] eth1: renamed from veth76b1a4c
[ 20.604024] docker_gwbridge: port 2(vethaa97b5a) entered blocking state
[ 20.604030] docker_gwbridge: port 2(vethaa97b5a) entered forwarding state
[ 36.160944] systemd-journald[257]: File /var/log/journal/4e4219c4df824631a9cef4853d3f65b5/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
[ 36.452938] traps: dunst[1812] trap int3 ip:7f46d0e42485 sp:7ffddee95f60 error:0 in libglib-2.0.so.0.7800.3[7f46d0dfe000+9e000]
[ 36.916824] BTRFS info (device sdc1): first mount of filesystem 7639fefe-48f6-45aa-b7b3-4f1e1209f6e7
[ 36.916840] BTRFS info (device sdc1): using crc32c (crc32c-intel) checksum algorithm
[ 36.916845] BTRFS info (device sdc1): using free space tree
[ 37.059382] input: uinput-unifiedremote as /devices/virtual/input/input20
[ 37.699506] Bluetooth: RFCOMM TTY layer initialized
[ 37.699514] Bluetooth: RFCOMM socket layer initialized
[ 37.699519] Bluetooth: RFCOMM ver 1.11
[ 57.389157] usb 3-3: USB disconnect, device number 2
[ 67.686268] usb 3-3: new full-speed USB device number 4 using xhci_hcd
[ 67.834345] usb 3-3: New USB device found, idVendor=fffe, idProduct=000c, bcdDevice= 1.04
[ 67.834355] usb 3-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 67.834359] usb 3-3: Product: Akko Keyboard
[ 67.834361] usb 3-3: Manufacturer: Akko
[ 67.835918] input: Akko Akko Keyboard as /devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3:1.0/0003:FFFE:000C.0007/input/input21
[ 67.889991] hid-generic 0003:FFFE:000C.0007: input,hidraw0: USB HID v1.11 Keyboard [Akko Akko Keyboard] on usb-0000:00:14.0-3/input0
[ 67.890526] hid-generic 0003:FFFE:000C.0008: hiddev96,hidraw1: USB HID v1.11 Device [Akko Akko Keyboard] on usb-0000:00:14.0-3/input1
