Hello everybody!
I have a Dell Latitude e5470 laptop with an internal smart card reader. I managed to get an external smart card reader to work via USB using that wiki page:
https://wiki.archlinux.org/title/Electronic_identification
Since there is an internal card reader present, I want to get it working (it worked in Win10, before I removed from this laptop).
Probably some kind of driver is missing. In need of some guidance!!
My system info:
Kernel: 5.10.41-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=57bccc67-b3a9-429d-94d7-c0c8d74e8c1d rw quiet apparmor=1
Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1
Type: Laptop System: Dell product: Latitude E5470 v: N/A serial: <filter>
Chassis: type: 9 serial: <filter>
Mobo: Dell model: 0VHKV0 v: A00 serial: <filter> UEFI: Dell v: 1.25.3
date: 03/19/2021
ID-1: BAT0 charge: 47.2 Wh (100.0%) condition: 47.2/57.1 Wh (82.6%)
volts: 8.4 min: 7.6 model: Panasonic DELL 79VRK6A type: Li-poly
serial: <filter> status: Full
RAM: total: 7.67 GiB used: 2.83 GiB (36.9%)
Info: Dual Core model: Intel Core i5-6300U bits: 64 type: MT MCP
arch: Skylake family: 6 model-id: 4E (78) stepping: 3 microcode: E2 cache:
L2: 3 MiB bogomips: 20004
Speed: 500 MHz min/max: 400/3000 MHz Core speeds (MHz): 1: 500 2: 500 3: 500
4: 500
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
f16c flexpriority flush_l1d fma fpu fsgsbase fxsr hle ht hwp hwp_act_window
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good rtm sdbg sep smap smep smx ss ssbd sse sse2
xsaves xtopology xtpr
Type: l1tf
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Dell driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
Device-2: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-2:2 chip-ID: 0bda:57c3 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0
screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 157 size: 310x170mm (12.2x6.7")
diag: 354mm (13.9")
OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 21.1.2
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d70
class-ID: 0403
Sound Server-1: ALSA v: k5.10.41-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.28 running: yes
Device-1: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel
port: f040 bus-ID: 00:1f.6 chip-ID: 8086:156f class-ID: 0200
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel port: f040
bus-ID: 01:00.0 chip-ID: 8086:24f3 class-ID: 0280
bus-ID: 1-8:5 chip-ID: 8087:0a2b class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: f060 bus-ID: 00:17.0 chip-ID: 8086.282a rev: 21 class-ID: 0104
Local Storage: total: 238.47 GiB used: 47.82 GiB (20.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Intel model: SSDSCKKF256H6 SATA 256GB
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: D16N scheme: GPT
ID-1: / raw-size: 31.25 GiB size: 30.59 GiB (97.88%) used: 14 GiB (45.8%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 57bccc67-b3a9-429d-94d7-c0c8d74e8c1d
used: 8.8 MiB (2.9%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: FC70-35FA
ID-3: /home raw-size: 118.54 GiB size: 116.18 GiB (98.01%)
used: 33.81 GiB (29.1%) fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 5c8a4c84-ff33-4300-8276-be73e90da708
ID-1: swap-1 type: partition size: 17.58 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: 680bd736-5a89-4b19-9ed5-373c5af9ff18
ID-1: /dev/sda4 maj-min: 8:4 size: 49.33 GiB fs: ext4 label: N/A
uuid: f91dead5-9430-44e9-aaaa-9b0791c234b6
ID-2: /dev/sda6 maj-min: 8:6 size: 21.48 GiB fs: ext4 label: N/A
uuid: 5974260c-bd51-4344-a18f-6828616d10e9
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 1-2:2 info: Realtek Integrated_Webcam_HD type: Video
Device-2: 1-4:3 info: Logitech G102 LIGHTSYNC Gaming Mouse type: Mouse,HID
power: 300mA chip-ID: 046d:c092 class-ID: 0300 serial: <filter>
Device-3: 1-7:4 info: Broadcom 5880 type: Smart Card driver: N/A
interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 0a5c:5832
class-ID: 0b00 serial: <filter>
Device-4: 1-8:5 info: Intel Bluetooth wireless interface type: Bluetooth
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 48.5 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 202 Uptime: 29m wakeups: 1 Init: systemd v: 247 tool: systemctl
Compilers: gcc: 11.1.0 Packages: pacman: 1415 lib: 375 flatpak: 0
Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.04
