I read that MGLRU Patch promises good performance improvents. It is now included in 6.1 kernel but is not enabled by default. Will manjaro enable this while releasing 6.1 Kernel?
Would be greate. It give huge perfomance boost. Maple Tree as well
It should probably remained disabled by default.
MGLRU was already enabled in Kernel 6.1, not 6.0.
Check if it is enabled:
$ zgrep LRU /proc/config.gz
CONFIG_LRU_GEN=y
CONFIG_LRU_GEN_ENABLED=y
# CONFIG_LRU_GEN_STATS is not set
CONFIG_DAMON_LRU_SORT=y
CONFIG_LRU_CACHE=m
See the Kernel document.
Are you on the Stable branch?
The latest available kernel for me on Stable is 6.0 (and for LTS, 5.15).
No, the testing branch and Manjaro kernel 6.0.
I checked the unstable branch with Manjaro kernel 6.1 in VM.
This is
