oh my bad i wasnt chrooted.
Jun 01 19:18:27 emil-pc kernel: Linux version 5.15.32-1-MANJARO (builduser@fv-az83-713) (gcc (GCC) 11.2.0, GNU ld (GNU Binutils) 2.38) #1 SMP PREEMPT Mon Mar 28 09:16:36 UTC 2022
Jun 01 19:18:27 emil-pc kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=a7a3aaba-c6ca-4be6-ba66-fb30a8e97305 rw quiet apparmor=1 security=apparmor udev.log_priority=3
Jun 01 19:18:27 emil-pc kernel: Unknown kernel command line parameters "BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64", will be passed to user space.
Jun 01 19:18:27 emil-pc kernel: random: get_random_u64 called from __kmem_cache_create+0x2a/0x540 with crng_init=0
Jun 01 19:18:27 emil-pc kernel: audit: type=2000 audit(1654103898.169:1): state=initialized audit_enabled=0 res=1
Jun 01 19:18:27 emil-pc kernel: ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
Jun 01 19:18:27 emil-pc kernel: SCSI subsystem initialized
Jun 01 19:18:27 emil-pc kernel: VFS: Disk quotas dquot_6.6.0
Jun 01 19:18:27 emil-pc kernel: Initialise system trusted keyrings
Jun 01 19:18:27 emil-pc kernel: Key type blacklist registered
Jun 01 19:18:27 emil-pc kernel: Key type asymmetric registered
Jun 01 19:18:27 emil-pc kernel: Asymmetric key parser 'x509' registered
Jun 01 19:18:27 emil-pc kernel: Loading compiled-in X.509 certificates
Jun 01 19:18:27 emil-pc kernel: Loaded X.509 cert 'Build time autogenerated kernel key: 9089b94c65a76d75665060005501fc15e9341c51'
Jun 01 19:18:27 emil-pc kernel: Key type ._fscrypt registered
Jun 01 19:18:27 emil-pc kernel: Key type .fscrypt registered
Jun 01 19:18:27 emil-pc kernel: Key type fscrypt-provisioning registered
Jun 01 19:18:27 emil-pc kernel: scsi 0:0:0:0: Direct-Access ATA ST4000DM004-2CV1 0001 PQ: 0 ANSI: 5
Jun 01 19:18:27 emil-pc kernel: sd 0:0:0:0: [sda] 7814037168 512-byte logical blocks: (4.00 TB/3.64 TiB)
Jun 01 19:18:27 emil-pc kernel: sd 0:0:0:0: [sda] 4096-byte physical blocks
Jun 01 19:18:27 emil-pc kernel: sd 0:0:0:0: [sda] Write Protect is off
Jun 01 19:18:27 emil-pc kernel: sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jun 01 19:18:27 emil-pc kernel: sd 0:0:0:0: [sda] Attached SCSI disk
Jun 01 19:18:27 emil-pc kernel: random: fast init done
Jun 01 19:18:27 emil-pc kernel: random: lvm: uninitialized urandom read (4 bytes read)
Jun 01 19:18:27 emil-pc kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
Jun 01 19:18:27 emil-pc kernel: audit: type=1400 audit(1654103907.196:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=391 comm="apparmor_parser"
Jun 01 19:18:27 emil-pc kernel: audit: type=1400 audit(1654103907.210:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=392 comm="apparmor_parser"
Jun 01 19:18:27 emil-pc kernel: audit: type=1400 audit(1654103907.210:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=392 comm="apparmor_parser"
Jun 01 19:18:27 emil-pc kernel: audit: type=1130 audit(1654103907.236:5): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 01 19:18:27 emil-pc systemd-random-seed[386]: Kernel entropy pool is not initialized yet, waiting until it is.
Jun 01 19:18:27 emil-pc kernel: audit: type=1130 audit(1654103907.240:6): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 01 19:18:27 emil-pc kernel: audit: type=1400 audit(1654103907.243:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="dovecot-script-login" pid=395 comm="apparmor_parser"
Jun 01 19:18:27 emil-pc kernel: audit: type=1400 audit(1654103907.253:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="php-fpm" pid=393 comm="apparmor_parser"
Jun 01 19:18:27 emil-pc kernel: audit: type=1400 audit(1654103907.260:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="samba-bgqd" pid=394 comm="apparmor_parser"
Jun 01 19:18:27 emil-pc kernel: audit: type=1400 audit(1654103907.313:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine" pid=396 comm="apparmor_parser"
Jun 01 19:18:27 emil-pc kernel: audit: type=1400 audit(1654103907.313:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=396 comm="apparmor_parser"
Jun 01 19:18:27 emil-pc kernel: ACPI Warning: SystemIO range 0x0000000000000B00-0x0000000000000B08 conflicts with OpRegion 0x0000000000000B00-0x0000000000000B0F (\GSA1.SMBI) (20210730/utaddress-204)
Jun 01 19:18:27 emil-pc kernel: acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Jun 01 19:18:27 emil-pc kernel: nvidia: loading out-of-tree module taints kernel.
Jun 01 19:18:27 emil-pc kernel: nvidia: module license 'NVIDIA' taints kernel.
Jun 01 19:18:27 emil-pc kernel: Disabling lock debugging due to kernel taint
Jun 01 19:18:27 emil-pc kernel: nvidia: module verification failed: signature and/or required key missing - tainting kernel
Jun 01 19:18:27 emil-pc kernel: ccp 0000:0c:00.1: ccp: unable to access the device: you might be running a broken BIOS.
Jun 01 19:18:27 emil-pc kernel: scsi 6:0:0:0: Direct-Access Generic STORAGE DEVICE 0830 PQ: 0 ANSI: 6
Jun 01 19:18:27 emil-pc kernel: sd 6:0:0:0: Attached scsi generic sg1 type 0
Jun 01 19:18:27 emil-pc kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 510.60.02 Wed Mar 16 11:24:05 UTC 2022
Jun 01 19:18:28 emil-pc kernel: sd 6:0:0:0: [sdb] Spinning up disk...
Jun 01 19:18:28 emil-pc kernel: random: crng init done
Jun 01 19:18:29 emil-pc kernel: .
Jun 01 19:18:29 emil-pc kernel: sd 6:0:0:0: [sdb] Media removed, stopped polling
Jun 01 19:18:29 emil-pc kernel: sd 6:0:0:0: [sdb] Attached SCSI removable disk
Jun 01 19:18:30 emil-pc kernel: nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
Jun 01 19:18:30 emil-pc polkitd[598]: Loading rules from directory /etc/polkit-1/rules.d
Jun 01 19:18:30 emil-pc polkitd[598]: Loading rules from directory /usr/share/polkit-1/rules.d
Jun 01 19:18:30 emil-pc polkitd[598]: Finished loading, compiling and executing 8 rules
Jun 01 19:18:30 emil-pc polkitd[598]: Acquired the name org.freedesktop.PolicyKit1 on the system bus
Jun 01 19:18:31 emil-pc kernel: resource sanity check: requesting [mem 0x000c0000-0x000fffff], which spans more than PCI Bus 0000:00 [mem 0x000c0000-0x000dffff window]
Jun 01 19:18:31 emil-pc kernel: caller _nv000651rm+0x1ad/0x200 [nvidia] mapping multiple BARs
Jun 01 19:18:32 emil-pc kernel: kauditd_printk_skb: 33 callbacks suppressed
Jun 01 19:18:32 emil-pc kernel: audit: type=1400 audit(1654103912.786:45): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/snapd/snap-confine" pid=691 comm="apparmor_parser"
Jun 01 19:18:32 emil-pc kernel: audit: type=1300 audit(1654103912.786:45): arch=c000003e syscall=1 success=yes exit=70033 a0=6 a1=557da66dc820 a2=11191 a3=0 items=0 ppid=690 pid=691 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="apparmor_parser" exe="/usr/bin/apparmor_parser" subj==unconfined key=(null)
Jun 01 19:18:32 emil-pc kernel: audit: type=1327 audit(1654103912.786:45): proctitle=61707061726D6F725F706172736572002D2D7265706C616365002D2D77726974652D6361636865002D4F006E6F2D657870722D73696D706C696679002D2D63616368652D6C6F633D2F7661722F63616368652F61707061726D6F72002D2D736B69702D726561642D6361636865002D2D7175696574002F6574632F6170706172
Jun 01 19:18:32 emil-pc kernel: audit: type=1400 audit(1654103912.813:46): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=691 comm="apparmor_parser"
Jun 01 19:18:32 emil-pc kernel: audit: type=1300 audit(1654103912.813:46): arch=c000003e syscall=1 success=yes exit=16065 a0=6 a1=557da655fb30 a2=3ec1 a3=0 items=0 ppid=690 pid=691 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="apparmor_parser" exe="/usr/bin/apparmor_parser" subj==unconfined key=(null)
Jun 01 19:18:32 emil-pc kernel: audit: type=1327 audit(1654103912.813:46): proctitle=61707061726D6F725F706172736572002D2D7265706C616365002D2D77726974652D6361636865002D4F006E6F2D657870722D73696D706C696679002D2D63616368652D6C6F633D2F7661722F63616368652F61707061726D6F72002D2D736B69702D726561642D6361636865002D2D7175696574002F6574632F6170706172
Jun 01 19:18:33 emil-pc kernel: audit: type=1130 audit(1654103913.213:47): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 01 19:18:35 emil-pc kernel: audit: type=1334 audit(1654103915.013:48): prog-id=15 op=LOAD
Jun 01 19:18:35 emil-pc kernel: audit: type=1300 audit(1654103915.013:48): arch=c000003e syscall=321 success=yes exit=25 a0=5 a1=7ffff6b06f10 a2=80 a3=7ffff6b06f10 items=0 ppid=1 pid=631 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="NetworkManager" exe="/usr/bin/NetworkManager" subj==unconfined key=(null)
Jun 01 19:18:35 emil-pc kernel: audit: type=1327 audit(1654103915.013:48): proctitle=2F7573722F62696E2F4E6574776F726B4D616E61676572002D2D6E6F2D6461656D6F6E
Jun 01 19:18:37 emil-pc systemd[720]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[sddm] ruser=[<unknown>] rhost=[<unknown>]
Jun 01 19:18:37 emil-pc systemd[720]: xdg-user-dirs-update.service: Main process exited, code=exited, status=1/FAILURE
Jun 01 19:18:37 emil-pc systemd[720]: xdg-user-dirs-update.service: Failed with result 'exit-code'.
Jun 01 19:18:37 emil-pc systemd[720]: Failed to start Update XDG user dir configuration.
Jun 01 19:18:37 emil-pc kernel: kauditd_printk_skb: 18 callbacks suppressed
Jun 01 19:18:37 emil-pc kernel: audit: type=1130 audit(1654103917.963:63): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@963 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 01 19:18:37 emil-pc kernel: audit: type=1105 audit(1654103917.966:64): pid=718 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_open grantors=pam_unix,pam_systemd acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=:0 res=success'
Jun 01 19:18:38 emil-pc sddm-greeter[730]: QFont::fromString: Invalid description '(empty)'
Jun 01 19:18:38 emil-pc sddm-greeter[730]: QObject: Cannot create children for a parent that is in a different thread.
(Parent is QGuiApplication(0x7fff12f3c1a0), parent's thread is QThread(0x55eb5147d070), current thread is QThread(0x55eb515cbf40)
Jun 01 19:18:38 emil-pc sddm-greeter[730]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
Jun 01 19:18:38 emil-pc kernel: audit: type=1131 audit(1654103918.740:65): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 01 19:18:41 emil-pc kernel: audit: type=1131 audit(1654103921.436:66): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 01 19:18:44 emil-pc udisksd[738]: udisks daemon version 2.9.4 starting
Jun 01 19:18:44 emil-pc kernel: audit: type=1130 audit(1654103924.566:67): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 01 19:18:44 emil-pc udisksd[738]: Acquired the name org.freedesktop.UDisks2 on the system message bus
Jun 01 19:18:44 emil-pc kernel: audit: type=1334 audit(1654103924.570:68): prog-id=20 op=LOAD
Jun 01 19:18:44 emil-pc kernel: audit: type=1334 audit(1654103924.570:69): prog-id=21 op=LOAD
Jun 01 19:18:44 emil-pc kernel: audit: type=1130 audit(1654103924.603:70): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 01 19:18:44 emil-pc sddm-greeter[730]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
Jun 01 19:18:44 emil-pc sddm-greeter[730]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:127:5: Type Keyboard unavailable
Jun 01 19:18:44 emil-pc sddm-greeter[730]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
Jun 01 19:18:45 emil-pc sddm-greeter[730]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
Jun 01 19:18:45 emil-pc sddm-greeter[730]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
Jun 01 19:18:45 emil-pc sddm-greeter[730]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
Jun 01 19:18:45 emil-pc sddm-greeter[730]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:127:5: Type Keyboard unavailable
Jun 01 19:18:45 emil-pc sddm-greeter[730]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
Jun 01 19:18:47 emil-pc sddm-greeter[730]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.19'
Jun 01 19:18:47 emil-pc sddm-greeter[730]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
Jun 01 19:19:00 emil-pc kernel: audit: type=1131 audit(1654103940.880:71): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 01 19:19:01 emil-pc kernel: audit: type=1334 audit(1654103941.000:72): prog-id=0 op=UNLOAD
Jun 01 19:19:01 emil-pc kernel: audit: type=1334 audit(1654103941.000:73): prog-id=0 op=UNLOAD
Jun 01 19:19:01 emil-pc kernel: audit: type=1334 audit(1654103941.000:74): prog-id=0 op=UNLOAD
Jun 01 19:19:03 emil-pc kernel: audit: type=1100 audit(1654103943.253:75): pid=759 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="emil" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Jun 01 19:19:03 emil-pc kernel: audit: type=1101 audit(1654103943.253:76): pid=759 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="emil" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Jun 01 19:19:03 emil-pc kernel: audit: type=1103 audit(1654103943.253:77): pid=759 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="emil" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Jun 01 19:19:03 emil-pc kernel: audit: type=1006 audit(1654103943.253:78): pid=759 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
Jun 01 19:19:03 emil-pc kernel: audit: type=1300 audit(1654103943.253:78): arch=c000003e syscall=1 success=yes exit=4 a0=8 a1=7fff99d3ad80 a2=4 a3=0 items=0 ppid=649 pid=759 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="sddm-helper" exe="/usr/lib/sddm/sddm-helper" subj==unconfined key=(null)
Jun 01 19:19:03 emil-pc kernel: audit: type=1327 audit(1654103943.253:78): proctitle=2F7573722F6C69622F7364646D2F7364646D2D68656C706572002D2D736F636B6574002F746D702F7364646D2D6175746863626161656261322D346563302D343862632D613036392D303235626435333132653766002D2D69640031002D2D7374617274002F7573722F62696E2F7374617274706C61736D612D783131002D2D
Jun 01 19:19:03 emil-pc systemd[761]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[emil] ruser=[<unknown>] rhost=[<unknown>]
Jun 01 19:19:04 emil-pc startplasma-x11[774]: QIODevice::read (QFile, "/home/emil/.config/kdedefaults/package"): device not open
Jun 01 19:19:05 emil-pc startplasma-x11[774]: QDBusConnection: error: could not send signal to service "" path "//home/emil/.config/kdedefaults/kdeglobals" interface "org.kde.kconfig.notify" member "ConfigChanged": Invalid object path: //home/emil/.config/kdedefaults/kdeglobals
Jun 01 19:19:06 emil-pc startplasma-x11[774]: QDBusConnection: error: could not send signal to service "" path "//home/emil/.config/kdedefaults/kdeglobals" interface "org.kde.kconfig.notify" member "ConfigChanged": Invalid object path: //home/emil/.config/kdedefaults/kdeglobals
Jun 01 19:19:06 emil-pc kernel: kauditd_printk_skb: 15 callbacks suppressed
Jun 01 19:19:06 emil-pc kernel: audit: type=1131 audit(1654103946.576:90): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 01 19:19:06 emil-pc kernel: audit: type=1334 audit(1654103946.600:91): prog-id=0 op=UNLOAD
Jun 01 19:19:06 emil-pc kernel: audit: type=1334 audit(1654103946.600:92): prog-id=0 op=UNLOAD
Jun 01 19:19:06 emil-pc kernel: audit: type=1334 audit(1654103946.600:93): prog-id=0 op=UNLOAD
Jun 01 19:19:06 emil-pc startplasma-x11[774]: QDBusConnection: error: could not send signal to service "" path "//home/emil/.config/kdedefaults/kcminputrc" interface "org.kde.kconfig.notify" member "ConfigChanged": Invalid object path: //home/emil/.config/kdedefaults/kcminputrc
Jun 01 19:19:06 emil-pc ksplashqml[786]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
Jun 01 19:19:06 emil-pc ksplashqml[786]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath.desktop/contents/splash/Splash.qml:81:29: Unable to assign int to QEasingCurve
Jun 01 19:19:09 emil-pc startplasma-x11[774]: QDBusConnection: error: could not send signal to service "" path "//home/emil/.config/kdedefaults/kwinrc" interface "org.kde.kconfig.notify" member "ConfigChanged": Invalid object path: //home/emil/.config/kdedefaults/kwinrc
Jun 01 19:19:11 emil-pc startplasma-x11[774]: QPixmap: QGuiApplication must be created before calling defaultDepth().
Jun 01 19:19:12 emil-pc startplasma-x11[774]: QDBusConnection: error: could not send signal to service "" path "//home/emil/.kde4/share/config/kdeglobals" interface "org.kde.kconfig.notify" member "ConfigChanged": Invalid object path: //home/emil/.kde4/share/config/kdeglobals
Jun 01 19:19:12 emil-pc klauncher[806]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Jun 01 19:19:12 emil-pc kcminit_startup[810]: QDBusConnection: error: could not send signal to service "" path "//home/emil/.kde4/share/config/kdeglobals" interface "org.kde.kconfig.notify" member "ConfigChanged": Invalid object path: //home/emil/.kde4/share/config/kdeglobals
Jun 01 19:19:13 emil-pc kwin_x11[821]: Warning: Setting a new default format with a different version or profile after the global shared context is created may cause issues with context sharing.
Jun 01 19:19:13 emil-pc kwin_x11[821]: kwin_xkbcommon: XKB: inet:334:58: unrecognized keysym "XF86EmojiPicker"
Jun 01 19:19:13 emil-pc ksmserver[847]: Qt: Session management error: networkIdsList argument is NULL
Jun 01 19:19:13 emil-pc systemd[721]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[sddm] ruser=[<unknown>] rhost=[<unknown>]
Jun 01 19:19:13 emil-pc kernel: audit: type=1131 audit(1654103953.750:94): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@963 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 01 19:19:13 emil-pc kernel: audit: type=1131 audit(1654103953.753:95): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@963 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 01 19:19:13 emil-pc kwin_x11[821]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 826, resource id: 10485765, major code: 18 (ChangeProperty), minor code: 0
Jun 01 19:19:14 emil-pc polkitd[598]: Registered Authentication Agent for unix-session:2 (system bus name :1.32 [/usr/lib/polkit-kde-authentication-agent-1], object path /org/kde/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8)
Jun 01 19:19:14 emil-pc plasmashell[858]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Jun 01 19:19:14 emil-pc plasmashell[858]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Jun 01 19:19:14 emil-pc kernel: audit: type=1130 audit(1654103954.506:96): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 01 19:19:14 emil-pc backlighthelper[960]: org.kde.powerdevil: no kernel backlight interface found
Jun 01 19:19:14 emil-pc org_kde_powerdevil[876]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
Jun 01 19:19:14 emil-pc org_kde_powerdevil[876]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
Jun 01 19:19:14 emil-pc kwin_x11[821]: kwin_core: XCB error: 10 (BadAccess), sequence: 896, resource id: 489, major code: 142 (Composite), minor code: 2 (RedirectSubwindows)
Jun 01 19:19:14 emil-pc org_kde_powerdevil[876]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Jun 01 19:19:14 emil-pc org_kde_powerdevil[876]: org.kde.powerdevil: The profile "AC" tried to activate "DimDisplay" a non-existent action. This is usually due to an installation problem, a configuration problem, or because the action is not supported
Jun 01 19:19:15 emil-pc org_kde_powerdevil[876]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
Jun 01 19:19:15 emil-pc plasmashell[858]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Jun 01 19:19:15 emil-pc plasmashell[858]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Jun 01 19:19:18 emil-pc plasmashell[858]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Jun 01 19:19:18 emil-pc gst-plugin-scan[1052]: type name '-a-png-encoder-pred' contains invalid characters
Jun 01 19:19:18 emil-pc gst-plugin-scan[1052]: g_type_set_qdata: assertion 'node != NULL' failed
Jun 01 19:19:18 emil-pc plasmashell[858]: trying to show an empty dialog
Jun 01 19:19:18 emil-pc plasmashell[858]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:118:19: QML Loader: Binding loop detected for property "height"
Jun 01 19:19:18 emil-pc plasmashell[858]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/main.qml:18:1: QML DropArea: Binding loop detected for property "spacingAtMinSize"
Jun 01 19:19:18 emil-pc plasmashell[858]: <Unknown File>: QML QQuickAnchors: Binding loop detected for property "leftMargin"
Jun 01 19:19:21 emil-pc plasmashell[858]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
Jun 01 19:19:21 emil-pc plasmashell[858]: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x557d5dbba810)
Jun 01 19:19:21 emil-pc plasmashell[858]: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x557d5dbbd0c0)
Jun 01 19:19:21 emil-pc plasmashell[858]: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x557d5dbbd0c0)
Jun 01 19:19:22 emil-pc pulseaudio[914]: stat('/etc/pulse/default.pa.d'): No such file or directory
Jun 01 19:19:24 emil-pc plasmashell[858]: QDBusConnection: error: could not send signal to service "" path "/plasma-org.kde.plasma.desktop-appletsrc" interface "org.kde.kconfig.notify" member "ConfigChanged": Invalid object path: /plasma-org.kde.plasma.desktop-appletsrc
Jun 01 19:19:25 emil-pc plasmashell[858]: QDBusConnection: error: could not send signal to service "" path "/plasma-org.kde.plasma.desktop-appletsrc" interface "org.kde.kconfig.notify" member "ConfigChanged": Invalid object path: /plasma-org.kde.plasma.desktop-appletsrc
Jun 01 19:19:26 emil-pc plasmashell[858]: QDBusConnection: error: could not send signal to service "" path "/plasma-org.kde.plasma.desktop-appletsrc" interface "org.kde.kconfig.notify" member "ConfigChanged": Invalid object path: /plasma-org.kde.plasma.desktop-appletsrc
Jun 01 19:19:27 emil-pc plasmashell[858]: QDBusConnection: error: could not send signal to service "" path "/plasma-org.kde.plasma.desktop-appletsrc" interface "org.kde.kconfig.notify" member "ConfigChanged": Invalid object path: /plasma-org.kde.plasma.desktop-appletsrc
Jun 01 19:19:28 emil-pc plasmashell[858]: QDBusConnection: error: could not send signal to service "" path "/plasma-org.kde.plasma.desktop-appletsrc" interface "org.kde.kconfig.notify" member "ConfigChanged": Invalid object path: /plasma-org.kde.plasma.desktop-appletsrc
Jun 01 19:19:29 emil-pc plasmashell[858]: QDBusConnection: error: could not send signal to service "" path "/plasma-org.kde.plasma.desktop-appletsrc" interface "org.kde.kconfig.notify" member "ConfigChanged": Invalid object path: /plasma-org.kde.plasma.desktop-appletsrc
Jun 01 19:19:30 emil-pc plasmashell[858]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:531:9: QML Label: Binding loop detected for property "height"
Jun 01 19:19:30 emil-pc plasmashell[858]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:486:13: QML Label: Binding loop detected for property "height"
Jun 01 19:19:30 emil-pc plasmashell[858]: trying to show an empty dialog
Jun 01 19:19:30 emil-pc plasmashell[858]: Activity added twice "46a8a529-4757-4ea8-aa03-be0c3706757a"
Jun 01 19:19:37 emil-pc kwin_x11[821]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 17608, resource id: 4194343, major code: 18 (ChangeProperty), minor code: 0
Jun 01 19:19:37 emil-pc plasmashell[858]: org.kde.klipper: Failed to load history resource. Clipboard history cannot be read. : History file does not exist
Jun 01 19:19:37 emil-pc plasmashell[858]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
Jun 01 19:19:39 emil-pc msm_kde_notifier[905]: kf.notifications: env says KDE is running but SNI unavailable -- check KDE_FULL_SESSION and XDG_CURRENT_DESKTOP
Jun 01 19:19:40 emil-pc kdeconnectd[884]: kdeconnect.core: Could not query capabilities from notifications server
Jun 01 19:19:40 emil-pc breath2tobreath[1015]: QApplication::qAppName: Please instantiate the QApplication object first
Jun 01 19:19:40 emil-pc breath2tobreath[1015]: QSocketNotifier: Can only be used with threads started with QThread
Jun 01 19:19:40 emil-pc breath2tobreath[1015]: QCoreApplication::arguments: Please instantiate the QApplication object first
Jun 01 19:19:43 emil-pc plasmashell[858]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ExpandedRepresentation.qml:165:9: QML HiddenItemsView: Binding loop detected for property "implicitHeight"
Jun 01 19:19:43 emil-pc plasmashell[858]: trying to show an empty dialog
Jun 01 19:19:43 emil-pc plasmashell[858]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:486:13: QML Label: Binding loop detected for property "height"
Jun 01 19:19:43 emil-pc plasmashell[858]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:531:9: QML Label: Binding loop detected for property "height"
Jun 01 19:19:43 emil-pc plasmashell[858]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:553:5: QML Label: Binding loop detected for property "height"
Jun 01 19:19:45 emil-pc kded5[818]: QProcess: Destroyed while process ("/usr/lib/kf5/kconf_update") is still running.
Jun 01 19:19:45 emil-pc kded5[818]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.10'
Jun 01 19:19:45 emil-pc plasmashell[858]: trying to show an empty dialog
Jun 01 19:19:45 emil-pc plasmashell[858]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:118:19: QML Loader: Binding loop detected for property "height"
Jun 01 19:19:45 emil-pc kwin_x11[821]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 21999, resource id: 46137347, major code: 12 (ConfigureWindow), minor code: 0
Jun 01 19:19:47 emil-pc dbus-daemon[597]: [system] Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
Jun 01 19:19:47 emil-pc pulseaudio[914]: GetManagedObjects() failed: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
Jun 01 19:19:48 emil-pc xembedsniproxy[865]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 449, resource id: 46137347, major code: 7 (ReparentWindow), minor code: 0
Jun 01 19:19:48 emil-pc xembedsniproxy[865]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 451, resource id: 46137347, major code: 142 (Unknown), minor code: 1
Jun 01 19:19:48 emil-pc xembedsniproxy[865]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 452, resource id: 46137347, major code: 6 (ChangeSaveSet), minor code: 0
Jun 01 19:19:48 emil-pc xembedsniproxy[865]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 453, resource id: 46137347, major code: 25 (SendEvent), minor code: 0
Jun 01 19:19:48 emil-pc xembedsniproxy[865]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 454, resource id: 46137347, major code: 12 (ConfigureWindow), minor code: 0
Jun 01 19:19:48 emil-pc xembedsniproxy[865]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 456, resource id: 46137347, major code: 12 (ConfigureWindow), minor code: 0
Jun 01 19:19:48 emil-pc xembedsniproxy[865]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 457, resource id: 46137347, major code: 8 (MapWindow), minor code: 0
Jun 01 19:19:48 emil-pc xembedsniproxy[865]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 458, resource id: 46137347, major code: 61 (ClearArea), minor code: 0
Jun 01 19:19:50 emil-pc plasmashell[858]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Jun 01 19:19:50 emil-pc plasmashell[858]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Jun 01 19:19:50 emil-pc plasmashell[858]: file:///usr/lib/qt/qml/org/kde/plasma/components.3/ScrollView.qml:37:27: QML ScrollBar: Binding loop detected for property "visible"
Jun 01 19:19:51 emil-pc plasmashell[858]: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x557d5ee31300)
Jun 01 19:19:51 emil-pc plasmashell[858]: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x557d5ed44000)
Jun 01 19:19:51 emil-pc plasmashell[858]: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x557d5ed44050)
Jun 01 19:19:51 emil-pc plasmashell[858]: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x557d5edfa700)
Jun 01 19:19:51 emil-pc plasmashell[858]: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x557d5ed43e70)
Jun 01 19:19:51 emil-pc plasmashell[858]: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x557d5ed43ec0)
Jun 01 19:19:51 emil-pc plasmashell[858]: trying to show an empty dialog
Jun 01 19:19:51 emil-pc plasmashell[858]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:118:19: QML Loader: Binding loop detected for property "height"
Jun 01 19:19:51 emil-pc plasmashell[858]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Jun 01 19:19:51 emil-pc kwin_x11[821]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 27092, resource id: 27263059, major code: 15 (QueryTree), minor code: 0
Jun 01 19:19:51 emil-pc plasmashell[858]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Jun 01 19:19:51 emil-pc plasmashell[858]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Jun 01 19:19:51 emil-pc pamac-tray-plasma[922]: kf.notifications: env says KDE is running but SNI unavailable -- check KDE_FULL_SESSION and XDG_CURRENT_DESKTOP
Jun 01 19:19:52 emil-pc plasmashell[858]: file:///usr/share/plasma/plasmoids/org.kde.plasma.battery/contents/ui/CompactRepresentation.qml:71:17: Unable to assign [undefined] to int
Jun 01 19:19:53 emil-pc plasmashell[858]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Jun 01 19:19:54 emil-pc plasmashell[858]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Jun 01 19:19:54 emil-pc plasmashell[858]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Jun 01 19:19:55 emil-pc plasmashell[858]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Jun 01 19:19:58 emil-pc kwin_x11[821]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 32256, resource id: 27263077, major code: 19 (DeleteProperty), minor code: 0
Jun 01 19:19:58 emil-pc kwin_x11[821]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 32259, resource id: 27263077, major code: 19 (DeleteProperty), minor code: 0
Jun 01 19:19:58 emil-pc kwin_x11[821]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 32260, resource id: 27263077, major code: 18 (ChangeProperty), minor code: 0
Jun 01 19:19:58 emil-pc kwin_x11[821]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 32261, resource id: 27263077, major code: 19 (DeleteProperty), minor code: 0
Jun 01 19:19:58 emil-pc kwin_x11[821]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 32262, resource id: 27263077, major code: 19 (DeleteProperty), minor code: 0
Jun 01 19:19:58 emil-pc kwin_x11[821]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 32263, resource id: 27263077, major code: 19 (DeleteProperty), minor code: 0
Jun 01 19:19:58 emil-pc kwin_x11[821]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 32264, resource id: 27263077, major code: 7 (ReparentWindow), minor code: 0
Jun 01 19:19:58 emil-pc kwin_x11[821]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 32265, resource id: 27263077, major code: 6 (ChangeSaveSet), minor code: 0
Jun 01 19:19:58 emil-pc kwin_x11[821]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 32266, resource id: 27263077, major code: 2 (ChangeWindowAttributes), minor code: 0
Jun 01 19:19:58 emil-pc kwin_x11[821]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 32267, resource id: 27263077, major code: 10 (UnmapWindow), minor code: 0
Jun 01 19:19:58 emil-pc kwin_x11[821]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 32361, resource id: 27263123, major code: 19 (DeleteProperty), minor code: 0
Jun 01 19:19:58 emil-pc kwin_x11[821]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 32364, resource id: 27263123, major code: 19 (DeleteProperty), minor code: 0
Jun 01 19:19:58 emil-pc kwin_x11[821]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 32365, resource id: 27263123, major code: 18 (ChangeProperty), minor code: 0
Jun 01 19:19:58 emil-pc kwin_x11[821]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 32366, resource id: 27263123, major code: 19 (DeleteProperty), minor code: 0
Jun 01 19:19:58 emil-pc kwin_x11[821]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 32367, resource id: 27263123, major code: 19 (DeleteProperty), minor code: 0
Jun 01 19:19:58 emil-pc kwin_x11[821]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 32368, resource id: 27263123, major code: 19 (DeleteProperty), minor code: 0
Jun 01 19:19:58 emil-pc kwin_x11[821]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 32369, resource id: 27263123, major code: 7 (ReparentWindow), minor code: 0
Jun 01 19:19:58 emil-pc kwin_x11[821]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 32370, resource id: 27263123, major code: 6 (ChangeSaveSet), minor code: 0
Jun 01 19:19:58 emil-pc kwin_x11[821]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 32371, resource id: 27263123, major code: 2 (ChangeWindowAttributes), minor code: 0
Jun 01 19:19:58 emil-pc kwin_x11[821]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 32372, resource id: 27263123, major code: 10 (UnmapWindow), minor code: 0
Jun 01 19:20:07 emil-pc plasmashell[858]: trying to show an empty dialog
Jun 01 19:20:13 emil-pc kded5[818]: kf.bluezqt: PendingCall Error: "Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken."
Jun 01 19:20:13 emil-pc dbus-daemon[597]: [system] Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
Jun 01 19:20:14 emil-pc plasmashell[858]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Jun 01 19:20:14 emil-pc plasmashell[858]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Jun 01 19:20:17 emil-pc plasmashell[858]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Jun 01 19:20:17 emil-pc plasmashell[858]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Jun 01 19:20:21 emil-pc kwin_x11[821]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 50788, resource id: 27263175, major code: 15 (QueryTree), minor code: 0
Jun 01 19:20:22 emil-pc kwin_x11[821]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 51407, resource id: 27263181, major code: 15 (QueryTree), minor code: 0
Jun 01 19:20:24 emil-pc kwin_x11[821]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 52452, resource id: 58720263, major code: 15 (QueryTree), minor code: 0
Jun 01 19:20:26 emil-pc kwin_x11[821]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 55044, resource id: 27263187, major code: 18 (ChangeProperty), minor code: 0
Jun 01 19:20:26 emil-pc plasmashell[858]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:366: Unable to assign [undefined] to QString
Jun 01 19:20:27 emil-pc kernel: audit: type=1130 audit(1654104027.076:97): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 01 19:20:27 emil-pc pamac-manager[1157]: gdk_window_set_cursor: assertion 'GDK_IS_WINDOW (window)' failed
Jun 01 19:20:33 emil-pc plasmashell[858]: org.kde.plasma.runner.bookmarks: No default firefox profile found
Jun 01 19:20:33 emil-pc plasmashell[858]: kf.sonnet.core: Sonnet: Unable to load plugin "/usr/lib/qt/plugins/kf5/sonnet/sonnet_aspell.so" Error: "Cannot load library /usr/lib/qt/plugins/kf5/sonnet/sonnet_aspell.so: (libaspell.so.15: cannot open shared object file: No such file or directory)"
Jun 01 19:20:33 emil-pc plasmashell[858]: kf.sonnet.core: Sonnet: Unable to load plugin "/usr/lib/qt/plugins/kf5/sonnet/sonnet_hspell.so" Error: "Cannot load library /usr/lib/qt/plugins/kf5/sonnet/sonnet_hspell.so: (libhspell.so.0: cannot open shared object file: No such file or directory)"
Jun 01 19:20:33 emil-pc plasmashell[858]: kf.sonnet.core: Sonnet: Unable to load plugin "/usr/lib/qt/plugins/kf5/sonnet/sonnet_voikko.so" Error: "Cannot load library /usr/lib/qt/plugins/kf5/sonnet/sonnet_voikko.so: (libvoikko.so.1: cannot open shared object file: No such file or directory)"
Jun 01 19:20:33 emil-pc plasmashell[858]: kf.sonnet.core: No language dictionaries for the language: "en_US" trying to load en_US as default
Jun 01 19:20:33 emil-pc plasmashell[858]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Jun 01 19:21:09 emil-pc kwin_x11[821]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 9203, resource id: 58720357, major code: 15 (QueryTree), minor code: 0
Jun 01 19:21:22 emil-pc kwin_x11[821]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 15408, resource id: 58720261, major code: 18 (ChangeProperty), minor code: 0
Jun 01 19:21:22 emil-pc kwin_x11[821]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 15413, resource id: 58720262, major code: 18 (ChangeProperty), minor code: 0
Jun 01 19:21:22 emil-pc kwin_x11[821]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 15417, resource id: 58720263, major code: 18 (ChangeProperty), minor code: 0
Jun 01 19:22:20 emil-pc kwin_x11[821]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 33738, resource id: 69206060, major code: 15 (QueryTree), minor code: 0
Jun 01 19:22:25 emil-pc kwin_x11[821]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 36825, resource id: 27263195, major code: 18 (ChangeProperty), minor code: 0
Jun 01 19:22:26 emil-pc plasmashell[858]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:366: Unable to assign [undefined] to QString
Jun 01 19:22:26 emil-pc pamac-manager[1621]: gdk_window_set_cursor: assertion 'GDK_IS_WINDOW (window)' failed
Jun 01 19:22:52 emil-pc kernel: audit: type=1100 audit(1654104172.736:98): pid=1655 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="emil" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
Jun 01 19:22:52 emil-pc kernel: audit: type=1101 audit(1654104172.736:99): pid=1655 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="emil" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
Jun 01 19:22:52 emil-pc polkitd[598]: Operator of unix-session:2 successfully authenticated as unix-user:emil to gain TEMPORARY authorization for action org.manjaro.pamac.commit for system-bus-name::1.78 [/usr/bin/pamac-manager --gapplication-service] (owned by unix-user:emil)
Jun 01 19:23:04 emil-pc kwin_x11[821]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1949, resource id: 58732234, major code: 15 (QueryTree), minor code: 0
Jun 01 19:23:16 emil-pc kernel: audit: type=1130 audit(1654104196.683:100): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-wait-online comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 01 19:23:16 emil-pc kernel: audit: type=1130 audit(1654104196.686:101): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=packagekit comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 01 19:23:55 emil-pc plasmashell[858]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:366: Unable to assign [undefined] to QString
Jun 01 19:32:42 emil-pc polkitd[598]: Reloading rules
Jun 01 19:32:42 emil-pc polkitd[598]: Collecting garbage unconditionally...
Jun 01 19:32:42 emil-pc polkitd[598]: Loading rules from directory /etc/polkit-1/rules.d
Jun 01 19:32:42 emil-pc polkitd[598]: Loading rules from directory /usr/share/polkit-1/rules.d
Jun 01 19:32:42 emil-pc polkitd[598]: Finished loading, compiling and executing 7 rules
Jun 01 19:32:42 emil-pc polkitd[598]: Finished loading, compiling and executing 8 rules
Jun 01 19:32:42 emil-pc systemd[1]: Reexecuting.
Jun 01 19:32:42 emil-pc kernel: audit: type=1334 audit(1654104762.750:102): prog-id=23 op=LOAD
Jun 01 19:32:42 emil-pc kernel: audit: type=1334 audit(1654104762.750:103): prog-id=0 op=UNLOAD
Jun 01 19:32:42 emil-pc kernel: audit: type=1334 audit(1654104762.750:104): prog-id=24 op=LOAD
Jun 01 19:32:42 emil-pc kernel: audit: type=1334 audit(1654104762.750:105): prog-id=0 op=UNLOAD
Jun 01 19:32:42 emil-pc kernel: audit: type=1334 audit(1654104762.846:106): prog-id=25 op=LOAD
Jun 01 19:32:42 emil-pc kernel: audit: type=1334 audit(1654104762.846:107): prog-id=0 op=UNLOAD
Jun 01 19:32:42 emil-pc kernel: audit: type=1334 audit(1654104762.846:108): prog-id=26 op=LOAD
Jun 01 19:32:42 emil-pc kernel: audit: type=1334 audit(1654104762.846:109): prog-id=27 op=LOAD
Jun 01 19:32:42 emil-pc kernel: audit: type=1334 audit(1654104762.846:110): prog-id=0 op=UNLOAD
Jun 01 19:32:42 emil-pc kernel: audit: type=1334 audit(1654104762.846:111): prog-id=0 op=UNLOAD
Jun 01 19:32:49 emil-pc polkitd[598]: Reloading rules
Jun 01 19:32:49 emil-pc polkitd[598]: Collecting garbage unconditionally...
Jun 01 19:32:49 emil-pc polkitd[598]: Loading rules from directory /etc/polkit-1/rules.d
Jun 01 19:32:49 emil-pc polkitd[598]: Loading rules from directory /usr/share/polkit-1/rules.d
Jun 01 19:32:49 emil-pc polkitd[598]: Finished loading, compiling and executing 7 rules
Jun 01 19:32:49 emil-pc polkitd[598]: Finished loading, compiling and executing 8 rules
Jun 01 19:32:50 emil-pc polkitd[598]: Reloading rules
Jun 01 19:32:50 emil-pc polkitd[598]: Collecting garbage unconditionally...
Jun 01 19:32:50 emil-pc polkitd[598]: Loading rules from directory /etc/polkit-1/rules.d
Jun 01 19:32:50 emil-pc polkitd[598]: Loading rules from directory /usr/share/polkit-1/rules.d
Jun 01 19:32:50 emil-pc polkitd[598]: Finished loading, compiling and executing 7 rules
Jun 01 19:32:50 emil-pc polkitd[598]: Finished loading, compiling and executing 8 rules
Jun 01 19:33:01 emil-pc crond[596]: (root) CAN'T OPEN (/etc/crontab): No such file or directory
Jun 01 19:33:12 emil-pc kglobalaccel5[845]: Skipped method "globalShortcutsByKey" : Unregistered input type in parameter list: KGlobalAccel::MatchType
Jun 01 19:33:12 emil-pc kernel: kauditd_printk_skb: 16 callbacks suppressed
Jun 01 19:33:12 emil-pc kernel: audit: type=1334 audit(1654104792.263:128): prog-id=36 op=LOAD
Jun 01 19:33:12 emil-pc kernel: audit: type=1334 audit(1654104792.263:129): prog-id=0 op=UNLOAD
Jun 01 19:33:12 emil-pc kernel: audit: type=1334 audit(1654104792.263:130): prog-id=37 op=LOAD
Jun 01 19:33:12 emil-pc kernel: audit: type=1334 audit(1654104792.263:131): prog-id=38 op=LOAD
Jun 01 19:33:12 emil-pc kernel: audit: type=1334 audit(1654104792.263:132): prog-id=0 op=UNLOAD
Jun 01 19:33:12 emil-pc kernel: audit: type=1334 audit(1654104792.263:133): prog-id=0 op=UNLOAD
Jun 01 19:33:12 emil-pc kernel: audit: type=1334 audit(1654104792.263:134): prog-id=39 op=LOAD
Jun 01 19:33:12 emil-pc kernel: audit: type=1334 audit(1654104792.263:135): prog-id=0 op=UNLOAD
Jun 01 19:33:12 emil-pc kernel: audit: type=1334 audit(1654104792.263:136): prog-id=40 op=LOAD
Jun 01 19:33:12 emil-pc kernel: audit: type=1334 audit(1654104792.263:137): prog-id=41 op=LOAD
Jun 01 19:33:20 emil-pc kernel: kauditd_printk_skb: 12 callbacks suppressed
Jun 01 19:33:20 emil-pc kernel: audit: type=1131 audit(1654104800.023:150): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 01 19:33:20 emil-pc kernel: audit: type=1130 audit(1654104800.023:151): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 01 19:33:20 emil-pc kernel: audit: type=1130 audit(1654104800.030:152): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 01 19:33:20 emil-pc kernel: audit: type=1131 audit(1654104800.030:153): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 01 19:33:21 emil-pc plasmashell[858]: kf.sonnet.core: No language dictionaries for the language: "en_US" trying to load en_US as default
Jun 01 19:33:31 emil-pc kernel: NVRM: API mismatch: the client has the version 510.73.05, but
NVRM: this kernel module has the version 510.60.02. Please
NVRM: make sure that this kernel module and all NVIDIA driver
NVRM: components have the same version.
Jun 01 19:33:31 emil-pc systemsettings[9649]: Warning: fallback to QtQuick software backend.
Jun 01 19:33:31 emil-pc systemsettings[9649]: file:///usr/lib/qt/qml/org/kde/kirigami.2/PlaceholderMessage.qml:235:5: QML Heading: Binding loop detected for property "verticalAlignment"
Jun 01 19:33:31 emil-pc systemsettings[9649]: kf.coreaddons: "Could not load plugin from kcm_kscreen: The shared library was not found."
Jun 01 19:33:31 emil-pc systemsettings[9649]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
Jun 01 19:33:31 emil-pc systemsettings[9649]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Jun 01 19:33:33 emil-pc root[10359]: os-prober: debug: running /usr/lib/os-probes/mounted/05efi on mounted /dev/nvme0n1p1
Jun 01 19:33:33 emil-pc root[10359]: 05efi: debug: /dev/nvme0n1p1 is a FAT32 partition
Jun 01 19:33:33 emil-pc root[10359]: 05efi: debug: /dev/nvme0n1p1 partition scheme is gpt
Jun 01 19:33:33 emil-pc root[10359]: 05efi: debug: /dev/nvme0n1p1 partition type is c12a7328-f81f-11d2-ba4b-00a0c93ec93b
Jun 01 19:33:33 emil-pc root[10359]: 05efi: debug: running subtest /usr/lib/os-probes/mounted/efi/10elilo
Jun 01 19:33:33 emil-pc root[10359]: 05efi: debug: running subtest /usr/lib/os-probes/mounted/efi/20microsoft
Jun 01 19:33:33 emil-pc root[10359]: 20microsoft: result: Microsoft/Boot/bootmgfw.efi:Windows Boot Manager:Windows
Jun 01 19:33:33 emil-pc root[10359]: 05efi: debug: bootloader Microsoft/Boot/bootmgfw.efi:Windows Boot Manager:Windows found by subtest /usr/lib/os-probes/mounted/efi/20microsoft
Jun 01 19:33:33 emil-pc root[10359]: 05efi: result: /dev/nvme0n1p1@/EFI/Microsoft/Boot/bootmgfw.efi:Windows Boot Manager:Windows:efi
Jun 01 19:33:33 emil-pc root[10359]: os-prober: debug: os detected by /usr/lib/os-probes/mounted/05efi
Jun 01 19:33:33 emil-pc root[10359]: os-prober: debug: running /usr/lib/os-probes/50mounted-tests on /dev/nvme0n1p2
Jun 01 19:33:33 emil-pc root[10359]: 50mounted-tests: debug: /dev/nvme0n1p2 type not recognised; skipping
Jun 01 19:33:33 emil-pc root[10359]: os-prober: debug: running /usr/lib/os-probes/50mounted-tests.orig on /dev/nvme0n1p2
Jun 01 19:33:33 emil-pc root[10359]: 50mounted-tests.orig: debug: /dev/nvme0n1p2 type not recognised; skipping
Jun 01 19:33:33 emil-pc root[10359]: os-prober: debug: os detected by /usr/lib/os-probes/50mounted-tests.orig
Jun 01 19:33:33 emil-pc root[10359]: os-prober: debug: running /usr/lib/os-probes/50mounted-tests on /dev/nvme0n1p3
Jun 01 19:33:33 emil-pc root[10359]: 50mounted-tests: debug: mounted using GRUB ntfs filesystem driver
Jun 01 19:33:33 emil-pc root[10359]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/05efi
Jun 01 19:33:33 emil-pc root[10359]: 05efi: debug: /dev/nvme0n1p3 is ntfs partition: exiting
Jun 01 19:33:33 emil-pc root[10359]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/10freedos
Jun 01 19:33:33 emil-pc root[10359]: 10freedos: debug: /dev/nvme0n1p3 is not a FAT partition: exiting
Jun 01 19:33:33 emil-pc root[10359]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/10qnx
Jun 01 19:33:33 emil-pc root[10359]: 10qnx: debug: /dev/nvme0n1p3 is not a QNX4 partition: exiting
Jun 01 19:33:33 emil-pc root[10359]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/20macosx
Jun 01 19:33:33 emil-pc macosx-prober[10514]: debug: /dev/nvme0n1p3 is not an HFS+ partition: exiting
Jun 01 19:33:33 emil-pc root[10359]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/20microsoft
Jun 01 19:33:33 emil-pc root[10359]: 20microsoft: debug: Skipping legacy bootloaders on UEFI system
Jun 01 19:33:33 emil-pc root[10359]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/30utility
Jun 01 19:33:33 emil-pc root[10359]: 30utility: debug: /dev/nvme0n1p3 is not a FAT partition: exiting
Jun 01 19:33:33 emil-pc root[10359]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/40lsb
Jun 01 19:33:33 emil-pc root[10359]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/70hurd
Jun 01 19:33:33 emil-pc root[10359]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/80minix
Jun 01 19:33:33 emil-pc root[10359]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/83haiku
Jun 01 19:33:33 emil-pc root[10359]: 83haiku: debug: /dev/nvme0n1p3 is not a BeFS partition: exiting
Jun 01 19:33:33 emil-pc root[10359]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/90linux-distro
Jun 01 19:33:33 emil-pc root[10359]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/90linux-distro.orig
Jun 01 19:33:33 emil-pc root[10359]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/90solaris
Jun 01 19:33:33 emil-pc root[10359]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/efi
Jun 01 19:33:33 emil-pc root[10359]: os-prober: debug: running /usr/lib/os-probes/50mounted-tests.orig on /dev/nvme0n1p3
Jun 01 19:33:33 emil-pc root[10359]: 50mounted-tests.orig: debug: mounted using GRUB ntfs filesystem driver
Jun 01 19:33:33 emil-pc root[10359]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/05efi
Jun 01 19:33:33 emil-pc root[10359]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/10freedos
Jun 01 19:33:33 emil-pc root[10359]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/10qnx
Jun 01 19:33:33 emil-pc root[10359]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/20macosx
Jun 01 19:33:33 emil-pc macosx-prober[10579]: debug: /dev/nvme0n1p3 is not an HFS+ partition: exiting
Jun 01 19:33:33 emil-pc root[10359]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/20microsoft
Jun 01 19:33:33 emil-pc root[10359]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/30utility
Jun 01 19:33:33 emil-pc root[10359]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/40lsb
Jun 01 19:33:33 emil-pc root[10359]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/70hurd
Jun 01 19:33:33 emil-pc root[10359]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/80minix
Jun 01 19:33:33 emil-pc root[10359]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/83haiku
Jun 01 19:33:33 emil-pc root[10359]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/90linux-distro
Jun 01 19:33:33 emil-pc root[10359]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/90linux-distro.orig
Jun 01 19:33:33 emil-pc root[10359]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/90solaris
Jun 01 19:33:33 emil-pc root[10359]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/efi
Jun 01 19:33:33 emil-pc root[10359]: os-prober: debug: running /usr/lib/os-probes/50mounted-tests on /dev/nvme0n1p4
Jun 01 19:33:33 emil-pc root[10359]: 05efi: debug: /dev/nvme0n1p4 is ntfs partition: exiting
Jun 01 19:33:33 emil-pc root[10359]: 10freedos: debug: /dev/nvme0n1p4 is not a FAT partition: exiting
Jun 01 19:33:33 emil-pc root[10359]: 10qnx: debug: /dev/nvme0n1p4 is not a QNX4 partition: exiting
Jun 01 19:33:33 emil-pc macosx-prober[10649]: debug: /dev/nvme0n1p4 is not an HFS+ partition: exiting
Jun 01 19:33:33 emil-pc root[10359]: 30utility: debug: /dev/nvme0n1p4 is not a FAT partition: exiting
Jun 01 19:33:33 emil-pc root[10359]: 83haiku: debug: /dev/nvme0n1p4 is not a BeFS partition: exiting
Jun 01 19:33:33 emil-pc root[10359]: os-prober: debug: running /usr/lib/os-probes/50mounted-tests.orig on /dev/nvme0n1p4
Jun 01 19:33:33 emil-pc macosx-prober[10714]: debug: /dev/nvme0n1p4 is not an HFS+ partition: exiting
Jun 01 19:33:33 emil-pc root[10359]: os-prober: debug: running /usr/lib/os-probes/50mounted-tests on /dev/sda1
Jun 01 19:33:33 emil-pc root[10359]: 50mounted-tests: debug: /dev/sda1 type not recognised; skipping
Jun 01 19:33:33 emil-pc root[10359]: os-prober: debug: running /usr/lib/os-probes/50mounted-tests.orig on /dev/sda1
Jun 01 19:33:33 emil-pc root[10359]: 50mounted-tests.orig: debug: /dev/sda1 type not recognised; skipping
Jun 01 19:33:33 emil-pc root[10359]: os-prober: debug: running /usr/lib/os-probes/50mounted-tests on /dev/sda2
Jun 01 19:33:34 emil-pc root[10359]: 50mounted-tests: debug: mounted using GRUB ntfs filesystem driver
Jun 01 19:33:34 emil-pc root[10359]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/05efi
Jun 01 19:33:34 emil-pc root[10359]: 05efi: debug: /dev/sda2 is ntfs partition: exiting
Jun 01 19:33:34 emil-pc root[10359]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/10freedos
Jun 01 19:33:34 emil-pc root[10359]: 10freedos: debug: /dev/sda2 is not a FAT partition: exiting
Jun 01 19:33:34 emil-pc root[10359]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/10qnx
Jun 01 19:33:34 emil-pc root[10359]: 10qnx: debug: /dev/sda2 is not a QNX4 partition: exiting
Jun 01 19:33:34 emil-pc root[10359]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/20macosx
Jun 01 19:33:34 emil-pc macosx-prober[10807]: debug: /dev/sda2 is not an HFS+ partition: exiting
Jun 01 19:33:34 emil-pc root[10359]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/20microsoft
Jun 01 19:33:34 emil-pc root[10359]: 20microsoft: debug: Skipping legacy bootloaders on UEFI system
Jun 01 19:33:34 emil-pc root[10359]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/30utility
Jun 01 19:33:34 emil-pc root[10359]: 30utility: debug: /dev/sda2 is not a FAT partition: exiting
Jun 01 19:33:34 emil-pc root[10359]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/40lsb
Jun 01 19:33:34 emil-pc root[10359]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/70hurd
Jun 01 19:33:34 emil-pc root[10359]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/80minix
Jun 01 19:33:34 emil-pc root[10359]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/83haiku
Jun 01 19:33:34 emil-pc root[10359]: 83haiku: debug: /dev/sda2 is not a BeFS partition: exiting
Jun 01 19:33:34 emil-pc root[10359]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/90linux-distro
Jun 01 19:33:34 emil-pc root[10359]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/90linux-distro.orig
Jun 01 19:33:34 emil-pc root[10359]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/90solaris
Jun 01 19:33:34 emil-pc root[10359]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/efi
Jun 01 19:33:34 emil-pc root[10359]: os-prober: debug: running /usr/lib/os-probes/50mounted-tests.orig on /dev/sda2
Jun 01 19:33:34 emil-pc root[10359]: 50mounted-tests.orig: debug: mounted using GRUB ntfs filesystem driver
Jun 01 19:33:34 emil-pc root[10359]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/05efi
Jun 01 19:33:34 emil-pc root[10359]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/10freedos
Jun 01 19:33:34 emil-pc root[10359]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/10qnx
Jun 01 19:33:34 emil-pc root[10359]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/20macosx
Jun 01 19:33:34 emil-pc macosx-prober[10861]: debug: /dev/sda2 is not an HFS+ partition: exiting
Jun 01 19:33:34 emil-pc root[10359]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/20microsoft
Jun 01 19:33:34 emil-pc root[10359]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/30utility
Jun 01 19:33:34 emil-pc root[10359]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/40lsb
Jun 01 19:33:34 emil-pc root[10359]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/70hurd
Jun 01 19:33:34 emil-pc root[10359]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/80minix
Jun 01 19:33:34 emil-pc root[10359]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/83haiku
Jun 01 19:33:34 emil-pc root[10359]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/90linux-distro
Jun 01 19:33:34 emil-pc root[10359]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/90linux-distro.orig
Jun 01 19:33:34 emil-pc root[10359]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/90solaris
Jun 01 19:33:34 emil-pc root[10359]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/efi
Jun 01 19:33:37 emil-pc plasmashell[858]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Jun 01 19:33:37 emil-pc plasmashell[858]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Jun 01 19:33:38 emil-pc plasmashell[858]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Jun 01 19:33:40 emil-pc kwin_x11[821]: kwin_core: XCB error: 152 (BadDamage), sequence: 40467, resource id: 14723457, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Jun 01 19:33:43 emil-pc kwin_x11[821]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 43639, resource id: 27263228, major code: 15 (QueryTree), minor code: 0
Jun 01 19:33:43 emil-pc kwin_x11[821]: kwin_core: XCB error: 152 (BadDamage), sequence: 43686, resource id: 14723288, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Jun 01 19:34:14 emil-pc systemsettings[9649]: kf.coreaddons: "Could not load plugin from kcm_kscreen: The shared library was not found."
Jun 01 19:34:14 emil-pc kwin_x11[821]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 62668, resource id: 14724054, major code: 3 (GetWindowAttributes), minor code: 0
Jun 01 19:34:14 emil-pc kwin_x11[821]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 62669, resource id: 14724054, major code: 14 (GetGeometry), minor code: 0
Jun 01 19:34:14 emil-pc kwin_x11[821]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 62672, resource id: 14724055, major code: 3 (GetWindowAttributes), minor code: 0
Jun 01 19:34:14 emil-pc kwin_x11[821]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 62673, resource id: 14724055, major code: 14 (GetGeometry), minor code: 0
Jun 01 19:34:27 emil-pc systemd-logind[600]: System is rebooting.
Jun 01 19:34:27 emil-pc kded5[818]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
Jun 01 19:34:27 emil-pc sddm[649]: Authentication error: "Process crashed"
Jun 01 19:34:27 emil-pc sddm[649]: Auth: sddm-helper crashed (exit code 15)
Jun 01 19:34:27 emil-pc sddm[649]: Auth: sddm-helper exited with 15
Jun 01 19:34:27 emil-pc kernel: audit: type=1131 audit(1654104867.246:154): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-wait-online comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 01 19:34:27 emil-pc kded5[818]: The X11 connection broke: I/O error (code 1)
Jun 01 19:34:27 emil-pc kernel: audit: type=1131 audit(1654104867.250:155): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cups comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 01 19:34:27 emil-pc kernel: audit: type=1131 audit(1654104867.250:156): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 01 19:34:27 emil-pc kernel: audit: type=1131 audit(1654104867.253:157): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 01 19:34:27 emil-pc kernel: audit: type=1131 audit(1654104867.253:158): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=alsa-restore comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 01 19:34:27 emil-pc kernel: audit: type=1131 audit(1654104867.253:159): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 01 19:34:27 emil-pc polkitd[598]: Unregistered Authentication Agent for unix-session:2 (system bus name :1.32, object path /org/kde/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8) (disconnected from bus)
Jun 01 19:34:27 emil-pc kernel: audit: type=1131 audit(1654104867.266:160): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=ModemManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 01 19:34:27 emil-pc udisksd[738]: udisks daemon version 2.9.4 exiting
Jun 01 19:34:27 emil-pc kernel: audit: type=1334 audit(1654104867.280:161): prog-id=0 op=UNLOAD
Jun 01 19:34:27 emil-pc kernel: audit: type=1334 audit(1654104867.280:162): prog-id=0 op=UNLOAD
Jun 01 19:34:27 emil-pc kernel: audit: type=1131 audit(1654104867.280:163): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 01 19:34:27 emil-pc kglobalaccel5[845]: The X11 connection broke (error 1). Did the X11 server die?
Jun 01 19:34:27 emil-pc pulseaudio[914]: ICE I/O error handler called
Jun 01 19:34:27 emil-pc kactivitymanagerd[889]: The X11 connection broke (error 1). Did the X11 server die?
Jun 01 19:34:27 emil-pc kwin_x11[821]: The X11 connection broke: I/O error (code 1)
Jun 01 19:34:27 emil-pc kwin_x11[821]: QObject::killTimer: Timers cannot be stopped from another thread
Jun 01 19:34:27 emil-pc kwin_x11[821]: QObject::~QObject: Timers cannot be stopped from another thread
Jun 01 19:34:27 emil-pc kscreen_backend_launcher[984]: The X11 connection broke (error 1). Did the X11 server die?
Jun 01 19:34:27 emil-pc xdg-desktop-portal-kde[1033]: The X11 connection broke (error 1). Did the X11 server die?
Jun 01 19:34:27 emil-pc baloorunner[1233]: The X11 connection broke (error 1). Did the X11 server die?
Jun 01 19:34:27 emil-pc pulseaudio[914]: X11 I/O error handler called
Jun 01 19:34:27 emil-pc pulseaudio[914]: X11 I/O error exit handler called, preparing to tear down X11 modules
Jun 01 19:34:27 emil-pc systemd-coredump[11496]: Failed to connect to coredump service: Connection refused
Jun 01 19:34:27 emil-pc systemd[761]: pulseaudio.service: Main process exited, code=dumped, status=11/SEGV
Jun 01 19:34:27 emil-pc systemd[761]: pulseaudio.service: Killing process 1086 (gdbus) with signal SIGKILL.
Jun 01 19:34:27 emil-pc systemd[761]: pulseaudio.service: Failed with result 'core-dump'.
Jun 01 19:34:27 emil-pc systemd[761]: app-firefox-089c5f1935454fdfa49b5516bfc33faf.scope: Killing process 2253 (ImageIO) with signal SIGKILL.
Jun 01 19:34:27 emil-pc systemd[761]: xdg-permission-store.service: Main process exited, code=exited, status=1/FAILURE
Jun 01 19:34:27 emil-pc systemd[761]: xdg-permission-store.service: Failed with result 'exit-code'.
Jun 01 19:34:27 emil-pc systemd[761]: app-firefox-089c5f1935454fdfa49b5516bfc33faf.scope: Consumed 10min 23.290s CPU time.
Jun 01 19:34:27 emil-pc systemd[761]: xdg-document-portal.service: Main process exited, code=exited, status=20/n/a
Jun 01 19:34:27 emil-pc systemd[761]: xdg-document-portal.service: Failed with result 'exit-code'.
Jun 01 19:34:27 emil-pc systemd[761]: app.slice: Consumed 10min 47.549s CPU time.
Jun 01 19:34:27 emil-pc kernel: NVRM: API mismatch: the client has the version 510.73.05, but
Jun 01 19:34:27 emil-pc sddm[649]: Failed to read display number from pipe
Jun 01 19:34:27 emil-pc systemd[762]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[emil] ruser=[<unknown>] rhost=[<unknown>]
Jun 01 19:34:27 emil-pc sddm[649]: Attempt 1 starting the Display server on vt 1 failed
Jun 01 19:34:27 emil-pc sddm[649]: Signal received: SIGTERM
Jun 01 19:34:27 emil-pc systemd[1]: user@1000.service: Consumed 11min 14.408s CPU time.
Jun 01 19:34:27 emil-pc systemd[1]: user-1000.slice: Consumed 12min 18.714s CPU time.
Jun 01 19:34:28 emil-pc systemd[1]: user.slice: Consumed 12min 20.691s CPU time.
Jun 01 19:34:28 emil-pc systemd[1]: Shutting down.
Jun 01 19:34:28 emil-pc kernel: watchdog: watchdog0: watchdog did not stop!
but for clarification: manjaro doesnt even boot. it isnt even found by the bios. if i try too boot from the drive with windows and manjaro installed i see the grub screen: please select a proper boot device
I have checked the uuid in the fstab of my installation and it matches the uuid of my partition
