was this meant for me??
voilà
dmesg
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x414fd0b1]
[ 0.000000] Linux version 6.1.63-2-MANJARO-RPI5 (builduser@gitlab-runner-ampere-cax41) (gcc (GCC) 12.1.0, GNU ld (GNU Binutils) 2.38) #1 SMP PREEMPT Thu Nov 23 12:30:50 UTC 2023
[ 0.000000] random: crng init done
[ 0.000000] Machine model: Raspberry Pi 5 Model B Rev 1.0
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000001a000000, size 320 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x00000001ffffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000000007ffff]
[ 0.000000] node 0: [mem 0x0000000000080000-0x000000003f7fffff]
[ 0.000000] node 0: [mem 0x0000000040000000-0x00000001ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000001ffffffff]
[ 0.000000] On node 0, zone DMA: 512 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 14 pages/cpu s177448 r8192 d43736 u229376
[ 0.000000] pcpu-alloc: s177448 r8192 d43736 u229376 alloc=14*16384
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: detected: Hardware dirty bit management
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 521728
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 smsc95xx.macaddr=D8:3A:DD:B4:DB:75 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000 root=PARTUUID=6b6aadf9-02 rw rootwait console=ttyAMA10,115200 console=tty3 selinux=0 quiet splash plymouth.ignore-serial-consoles smsc95xx.turbo_mode=N dwc_otg.lpm_enable=0 usbhid.mousepoll=8 audit=0
[ 0.000000] audit: disabled (until reboot)
[ 0.000000] Unknown kernel command line parameters "splash selinux=0", will be passed to user space.
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 9, 8388608 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 8, 4194304 bytes, linear)
[ 0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[ 0.000000] software IO TLB: area num 4.
[ 0.000000] software IO TLB: mapped [mem 0x00000000fbffc000-0x00000000ffffc000] (64MB)
[ 0.000000] Memory: 7901024K/8380416K available (12736K kernel code, 2646K rwdata, 4144K rodata, 4544K init, 1380K bss, 151712K reserved, 327680K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 40811 entries in 40 pages
[ 0.000000] ftrace: allocated 40 pages with 2 groups
[ 0.000000] trace event string verifier disabled
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000000] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000154] Console: colour dummy device 80x25
[ 0.000175] printk: console [tty3] enabled
[ 0.000193] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=216000)
[ 0.000199] pid_max: default: 32768 minimum: 301
[ 0.000261] LSM: Security Framework initializing
[ 0.000338] Mount-cache hash table entries: 16384 (order: 3, 131072 bytes, linear)
[ 0.000365] Mountpoint-cache hash table entries: 16384 (order: 3, 131072 bytes, linear)
[ 0.000827] cgroup: Disabling memory control group subsystem
[ 0.001339] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.001344] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.001379] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.001382] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.001418] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.001421] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.001510] rcu: Hierarchical SRCU implementation.
[ 0.001513] rcu: Max phase no-delay instances is 1000.
[ 0.002151] EFI services will not be available.
[ 0.002277] smp: Bringing up secondary CPUs ...
[ 0.002510] Detected PIPT I-cache on CPU1
[ 0.002562] CPU1: Booted secondary processor 0x0000000100 [0x414fd0b1]
[ 0.002825] Detected PIPT I-cache on CPU2
[ 0.002864] CPU2: Booted secondary processor 0x0000000200 [0x414fd0b1]
[ 0.003111] Detected PIPT I-cache on CPU3
[ 0.003146] CPU3: Booted secondary processor 0x0000000300 [0x414fd0b1]
[ 0.003184] smp: Brought up 1 node, 4 CPUs
[ 0.003189] SMP: Total of 4 processors activated.
[ 0.003193] CPU features: detected: 32-bit EL0 Support
[ 0.003196] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.003198] CPU features: detected: Common not Private translations
[ 0.003201] CPU features: detected: CRC32 instructions
[ 0.003204] CPU features: detected: RCpc load-acquire (LDAPR)
[ 0.003207] CPU features: detected: LSE atomic instructions
[ 0.003209] CPU features: detected: Privileged Access Never
[ 0.003212] CPU features: detected: RAS Extension Support
[ 0.003216] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.003255] CPU: All CPU(s) started at EL2
[ 0.003257] alternatives: applying system-wide alternatives
[ 0.005200] devtmpfs: initialized
[ 0.008462] Enabled cp15_barrier support
[ 0.008470] Enabled setend support
[ 0.008540] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.008548] futex hash table entries: 1024 (order: 2, 65536 bytes, linear)
[ 0.009526] pinctrl core: initialized pinctrl subsystem
[ 0.009737] DMI not present or invalid.
[ 0.009944] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.011198] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.011255] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.011332] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.011490] thermal_sys: Registered thermal governor 'step_wise'
[ 0.011507] cpuidle: using governor menu
[ 0.011591] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.011635] ASID allocator initialised with 32768 entries
[ 0.011937] Serial: AMBA PL011 UART driver
[ 0.013788] bcm2835-mbox 107c013880.mailbox: mailbox enabled
[ 0.014494] 107d001000.serial: ttyAMA10 at MMIO 0x107d001000 (irq = 15, base_baud = 0) is a PL011 rev2
[ 0.014530] printk: console [ttyAMA10] enabled
[ 0.020911] raspberrypi-firmware soc:firmware: Attached to firmware from 2023-10-30T16:45:10, variant start_cd
[ 0.024909] raspberrypi-firmware soc:firmware: Firmware hash is 30de0ba500000000000000000000000000000000
[ 0.033466] KASLR enabled
[ 0.038604] bcm2835-dma 1000010000.dma: DMA legacy API manager, dmachans=0x1
[ 0.039708] iommu: Default domain type: Translated
[ 0.039712] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.039812] SCSI subsystem initialized
[ 0.039870] usbcore: registered new interface driver usbfs
[ 0.039884] usbcore: registered new interface driver hub
[ 0.039896] usbcore: registered new device driver usb
[ 0.040002] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 0.040088] pps_core: LinuxPPS API ver. 1 registered
[ 0.040090] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.040096] PTP clock support registered
[ 0.040367] vgaarb: loaded
[ 0.040499] clocksource: Switched to clocksource arch_sys_counter
[ 0.040661] VFS: Disk quotas dquot_6.6.0
[ 0.040680] VFS: Dquot-cache hash table entries: 2048 (order 0, 16384 bytes)
[ 0.040724] FS-Cache: Loaded
[ 0.040758] CacheFiles: Loaded
[ 0.042260] NET: Registered PF_INET protocol family
[ 0.042430] IP idents hash table entries: 131072 (order: 6, 1048576 bytes, linear)
[ 0.044863] tcp_listen_portaddr_hash hash table entries: 4096 (order: 2, 65536 bytes, linear)
[ 0.044935] Table-perturb hash table entries: 65536 (order: 4, 262144 bytes, linear)
[ 0.044942] TCP established hash table entries: 65536 (order: 5, 524288 bytes, linear)
[ 0.045212] TCP bind hash table entries: 65536 (order: 7, 2097152 bytes, linear)
[ 0.047032] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.047194] MPTCP token hash table entries: 8192 (order: 3, 196608 bytes, linear)
[ 0.047322] UDP hash table entries: 4096 (order: 3, 131072 bytes, linear)
[ 0.047423] UDP-Lite hash table entries: 4096 (order: 3, 131072 bytes, linear)
[ 0.047592] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.047753] RPC: Registered named UNIX socket transport module.
[ 0.047757] RPC: Registered udp transport module.
[ 0.047759] RPC: Registered tcp transport module.
[ 0.047761] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.047768] PCI: CLS 0 bytes, default 64
[ 0.047877] Trying to unpack rootfs image as initramfs...
[ 0.061122] hw perfevents: enabled with armv8_cortex_a76 PMU driver, 7 counters available
[ 0.061282] kvm [1]: IPA Size Limit: 40 bits
[ 0.061297] kvm [1]: GICV region size/alignment is unsafe, using trapping (reduced performance)
[ 0.061363] kvm [1]: vgic interrupt IRQ9
[ 0.061410] kvm [1]: VHE mode initialized successfully
[ 0.228588] Freeing initrd memory: 8576K
[ 0.341305] Initialise system trusted keyrings
[ 0.341454] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[ 0.343273] zbud: loaded
[ 0.344029] NFS: Registering the id_resolver key type
[ 0.344042] Key type id_resolver registered
[ 0.344045] Key type id_legacy registered
[ 0.344070] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.344075] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.344138] F2FS not supported on PAGE_SIZE(16384) != 4096
[ 0.360900] Key type asymmetric registered
[ 0.360904] Asymmetric key parser 'x509' registered
[ 0.366295] alg: self-tests for CTR-KDF (hmac(sha256)) passed
[ 0.366331] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.366372] io scheduler mq-deadline registered
[ 0.366376] io scheduler kyber registered
[ 0.366440] io scheduler bfq registered
[ 0.367055] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7c502000, parent irq: 31)
[ 0.367190] irq_brcmstb_l2: registered L2 intc (/soc/intc@7d503000, parent irq: 32)
[ 0.367304] irq_brcmstb_l2: registered L2 intc (/soc/intc@7d508380, parent irq: 33)
[ 0.367415] irq_brcmstb_l2: registered L2 intc (/soc/intc@7d508400, parent irq: 34)
[ 0.367527] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7d510600, parent irq: 35)
[ 0.367640] irq_brcmstb_l2: registered L2 intc (/soc/intc@7d517b00, parent irq: 36)
[ 0.369347] gpio-461 (RP1 RUN pin): hogged as output/high
[ 0.370105] simple-framebuffer 3f800000.framebuffer: framebuffer at 0x3f800000, 0x3f4800 bytes
[ 0.370111] simple-framebuffer 3f800000.framebuffer: format=r5g6b5, mode=1920x1080x16, linelength=3840
[ 0.370245] Console: switching to colour frame buffer device 240x67
[ 0.371750] simple-framebuffer 3f800000.framebuffer: fb0: simplefb registered!
[ 0.404969] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
[ 0.405534] 107d50c000.serial: ttyS0 at MMIO 0x107d50c000 (irq = 38, base_baud = 6000000) is a 16550A
[ 0.405580] serial serial0: tty port ttyS0 registered
[ 0.406155] iproc-rng200 107d208000.rng: hwrng registered
[ 0.406290] vc-mem: phys_addr:0x00000000 mem_base=0x3fc00000 mem_size:0x40000000(1024 MiB)
[ 0.406984] bcm2712-iommu-cache 1000005b00.iommuc: bcm2712_iommu_cache_probe
[ 0.409023] brd: module loaded
[ 0.410808] loop: module loaded
[ 0.411020] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 0.411205] Loading iSCSI transport class v2.0-870.
[ 0.412286] usbcore: registered new interface driver lan78xx
[ 0.412298] usbcore: registered new interface driver smsc95xx
[ 0.412435] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.412528] dwc_otg: FIQ enabled
[ 0.412531] dwc_otg: NAK holdoff enabled
[ 0.412533] dwc_otg: FIQ split-transaction FSM enabled
[ 0.412537] Module dwc_common_port init
[ 0.412796] usbcore: registered new interface driver uas
[ 0.412808] usbcore: registered new interface driver usb-storage
[ 0.412998] mousedev: PS/2 mouse device common for all mice
[ 0.420847] rpi-rtc soc:rpi_rtc: registered as rtc0
[ 0.422309] rpi-rtc soc:rpi_rtc: setting system clock to 1970-01-01T00:00:08 UTC (8)
[ 0.422986] bcm2835-wdt bcm2835-wdt: Poweroff handler already present!
[ 0.422990] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 0.425805] sdhci: Secure Digital Host Controller Interface driver
[ 0.425808] sdhci: Copyright(c) Pierre Ossman
[ 0.425957] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.426376] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.426414] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 0.426425] hid: raw HID events driver (C) Jiri Kosina
[ 0.426456] usbcore: registered new interface driver usbhid
[ 0.426459] usbhid: USB HID core driver
[ 0.426647] Initializing XFRM netlink socket
[ 0.426663] NET: Registered PF_PACKET protocol family
[ 0.426692] Key type dns_resolver registered
[ 0.426970] registered taskstats version 1
[ 0.426991] Loading compiled-in X.509 certificates
[ 0.427170] Key type .fscrypt registered
[ 0.427174] Key type fscrypt-provisioning registered
[ 0.429524] brcm-pcie 1000120000.pcie: host bridge /axi/pcie@120000 ranges:
[ 0.429530] brcm-pcie 1000120000.pcie: No bus range found for /axi/pcie@120000, using [bus 00-ff]
[ 0.429547] brcm-pcie 1000120000.pcie: MEM 0x1f00000000..0x1ffffffffb -> 0x0000000000
[ 0.429556] brcm-pcie 1000120000.pcie: MEM 0x1c00000000..0x1effffffff -> 0x0400000000
[ 0.429572] brcm-pcie 1000120000.pcie: IB MEM 0x1f00000000..0x1f003fffff -> 0x0000000000
[ 0.429580] brcm-pcie 1000120000.pcie: IB MEM 0x0000000000..0x0fffffffff -> 0x1000000000
[ 0.430750] brcm-pcie 1000120000.pcie: setting SCB_ACCESS_EN, READ_UR_MODE, MAX_BURST_SIZE
[ 0.430756] brcm-pcie 1000120000.pcie: Forcing gen 2
[ 0.430793] brcm-pcie 1000120000.pcie: PCI host bridge to bus 0000:00
[ 0.430796] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.430799] pci_bus 0000:00: root bus resource [mem 0x1f00000000-0x1ffffffffb] (bus address [0x00000000-0xfffffffb])
[ 0.430802] pci_bus 0000:00: root bus resource [mem 0x1c00000000-0x1effffffff pref] (bus address [0x400000000-0x6ffffffff])
[ 0.430815] pci 0000:00:00.0: [14e4:2712] type 01 class 0x060400
[ 0.430854] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 0.431491] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.536501] brcm-pcie 1000120000.pcie: link up, 5.0 GT/s PCIe x4 (!SSC)
[ 0.536524] pci 0000:01:00.0: [1de4:0001] type 00 class 0x020000
[ 0.536539] pci 0000:01:00.0: reg 0x10: [mem 0xffffc000-0xffffffff]
[ 0.536548] pci 0000:01:00.0: reg 0x14: [mem 0xffc00000-0xffffffff]
[ 0.536555] pci 0000:01:00.0: reg 0x18: [mem 0xffff0000-0xffffffff]
[ 0.536634] pci 0000:01:00.0: supports D1
[ 0.536636] pci 0000:01:00.0: PME# supported from D0 D1 D3hot D3cold
[ 0.548519] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 0.548531] pci 0000:00:00.0: BAR 8: assigned [mem 0x1f00000000-0x1f005fffff]
[ 0.548536] pci 0000:01:00.0: BAR 1: assigned [mem 0x1f00000000-0x1f003fffff]
[ 0.548543] pci 0000:01:00.0: BAR 2: assigned [mem 0x1f00400000-0x1f0040ffff]
[ 0.548549] pci 0000:01:00.0: BAR 0: assigned [mem 0x1f00410000-0x1f00413fff]
[ 0.548555] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 0.548560] pci 0000:00:00.0: bridge window [mem 0x1f00000000-0x1f005fffff]
[ 0.548569] pci 0000:00:00.0: Max Payload Size set to 256/ 512 (was 128), Max Read Rq 512
[ 0.548580] pci 0000:01:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 512
[ 0.548703] pcieport 0000:00:00.0: enabling device (0000 -> 0002)
[ 0.548757] pcieport 0000:00:00.0: PME: Signaling with IRQ 39
[ 0.548847] pcieport 0000:00:00.0: AER: enabled with IRQ 39
[ 0.549039] rp1 0000:01:00.0: bar0 len 0x4000, start 0x1f00410000, end 0x1f00413fff, flags, 0x40200
[ 0.549044] rp1 0000:01:00.0: bar1 len 0x400000, start 0x1f00000000, end 0x1f003fffff, flags, 0x40200
[ 0.549057] rp1 0000:01:00.0: enabling device (0000 -> 0002)
[ 0.550289] rp1 0000:01:00.0: chip_id 0x20001927
[ 0.575903] macb 1f00100000.ethernet eth0: Cadence GEM rev 0x00070109 at 0x1f00100000 irq 107 (d8:3a:dd:b4:db:75)
[ 0.576683] dw_axi_dmac_platform 1f00188000.dma: DesignWare AXI DMA Controller, 8 channels
[ 0.636621] xhci-hcd xhci-hcd.0: xHCI Host Controller
[ 0.636631] xhci-hcd xhci-hcd.0: new USB bus registered, assigned bus number 1
[ 0.637090] xhci-hcd xhci-hcd.0: hcc params 0x0240fe6d hci version 0x110 quirks 0x0000000000010810
[ 0.637107] xhci-hcd xhci-hcd.0: irq 132, io mem 0x1f00200000
[ 0.637187] xhci-hcd xhci-hcd.0: xHCI Host Controller
[ 0.637191] xhci-hcd xhci-hcd.0: new USB bus registered, assigned bus number 2
[ 0.637196] xhci-hcd xhci-hcd.0: Host supports USB 3.0 SuperSpeed
[ 0.637286] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[ 0.637291] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.637295] usb usb1: Product: xHCI Host Controller
[ 0.637298] usb usb1: Manufacturer: Linux 6.1.63-2-MANJARO-RPI5 xhci-hcd
[ 0.637301] usb usb1: SerialNumber: xhci-hcd.0
[ 0.637456] hub 1-0:1.0: USB hub found
[ 0.637475] hub 1-0:1.0: 2 ports detected
[ 0.637697] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[ 0.637701] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.637705] usb usb2: Product: xHCI Host Controller
[ 0.637708] usb usb2: Manufacturer: Linux 6.1.63-2-MANJARO-RPI5 xhci-hcd
[ 0.637711] usb usb2: SerialNumber: xhci-hcd.0
[ 0.637825] hub 2-0:1.0: USB hub found
[ 0.637843] hub 2-0:1.0: 1 port detected
[ 0.696648] xhci-hcd xhci-hcd.1: xHCI Host Controller
[ 0.696656] xhci-hcd xhci-hcd.1: new USB bus registered, assigned bus number 3
[ 0.697120] xhci-hcd xhci-hcd.1: hcc params 0x0240fe6d hci version 0x110 quirks 0x0000000000010810
[ 0.697145] xhci-hcd xhci-hcd.1: irq 137, io mem 0x1f00300000
[ 0.697228] xhci-hcd xhci-hcd.1: xHCI Host Controller
[ 0.697233] xhci-hcd xhci-hcd.1: new USB bus registered, assigned bus number 4
[ 0.697238] xhci-hcd xhci-hcd.1: Host supports USB 3.0 SuperSpeed
[ 0.697309] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[ 0.697314] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.697317] usb usb3: Product: xHCI Host Controller
[ 0.697320] usb usb3: Manufacturer: Linux 6.1.63-2-MANJARO-RPI5 xhci-hcd
[ 0.697323] usb usb3: SerialNumber: xhci-hcd.1
[ 0.697452] hub 3-0:1.0: USB hub found
[ 0.697470] hub 3-0:1.0: 2 ports detected
[ 0.697683] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[ 0.697687] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.697691] usb usb4: Product: xHCI Host Controller
[ 0.697694] usb usb4: Manufacturer: Linux 6.1.63-2-MANJARO-RPI5 xhci-hcd
[ 0.697696] usb usb4: SerialNumber: xhci-hcd.1
[ 0.697815] hub 4-0:1.0: USB hub found
[ 0.697831] hub 4-0:1.0: 1 port detected
[ 0.698789] bcm2712-iommu 1000005100.iommu: bcm2712_iommu_init: DEBUG_INFO = 0x20804774
[ 0.699205] platform 1000800000.codec: bcm2712_iommu_probe_device: MMU 1000005100.iommu
[ 0.699209] platform 1000800000.codec: bcm2712_iommu_device_group: MMU 1000005100.iommu
[ 0.699215] platform 1000800000.codec: Adding to iommu group 0
[ 0.699248] platform 1000880000.pisp_be: bcm2712_iommu_probe_device: MMU 1000005100.iommu
[ 0.699251] platform 1000880000.pisp_be: bcm2712_iommu_device_group: MMU 1000005100.iommu
[ 0.699257] platform 1000880000.pisp_be: Adding to iommu group 0
[ 0.699302] platform 1000800000.codec: bcm2712_iommu_attach_dev: MMU 1000005100.iommu
[ 0.699305] platform 1000880000.pisp_be: bcm2712_iommu_attach_dev: MMU 1000005100.iommu
[ 0.699313] bcm2712-iommu 1000005100.iommu: bcm2712_iommu_probe: Success
[ 0.699921] bcm2712-iommu 1000005200.iommu: bcm2712_iommu_init: DEBUG_INFO = 0x20804774
[ 0.700273] platform axi:gpu: bcm2712_iommu_probe_device: MMU 1000005200.iommu
[ 0.700276] platform axi:gpu: bcm2712_iommu_device_group: MMU 1000005200.iommu
[ 0.700281] platform axi:gpu: Adding to iommu group 1
[ 0.700328] platform axi:gpu: bcm2712_iommu_attach_dev: MMU 1000005200.iommu
[ 0.700334] bcm2712-iommu 1000005200.iommu: bcm2712_iommu_probe: Success
[ 0.700828] bcm2712-iommu 1000005280.iommu: bcm2712_iommu_init: DEBUG_INFO = 0x20804774
[ 0.701201] bcm2712-iommu 1000005280.iommu: bcm2712_iommu_probe: Success
[ 0.701403] sdhci-brcmstb 1000fff000.mmc: there is not valid maps for state default
[ 0.701929] mmc1: CQHCI version 5.10
[ 0.701975] mmc0: CQHCI version 5.10
[ 0.703224] of_cfs_init
[ 0.703251] of_cfs_init: OK
[ 0.737554] mmc0: SDHCI controller on 1000fff000.mmc [1000fff000.mmc] using ADMA 64-bit
[ 0.832657] mmc0: new ultra high speed SDR104 SDXC card at address 59b4
[ 0.832937] mmcblk0: mmc0:59b4 USD00 118 GiB
[ 0.834247] mmcblk0: p1 p2
[ 0.834351] mmcblk0: mmc0:59b4 USD00 118 GiB
[ 0.891044] mmc1: SDHCI controller on 1001100000.mmc [1001100000.mmc] using ADMA 64-bit
[ 0.893947] Freeing unused kernel memory: 4544K
[ 0.894003] Run /init as init process
[ 0.894007] with arguments:
[ 0.894009] /init
[ 0.894011] splash
[ 0.894013] with environment:
[ 0.894015] HOME=/
[ 0.894018] TERM=linux
[ 0.894020] selinux=0
[ 0.896523] usb 1-2: new low-speed USB device number 2 using xhci-hcd
[ 0.921842] mmc1: new ultra high speed DDR50 SDIO card at address 0001
[ 0.942359] vc4-drm axi:gpu: bcm2712_iommu_of_xlate: MMU 1000005200.iommu
[ 0.943152] Console: switching to colour dummy device 80x25
[ 0.945055] vc4-drm axi:gpu: bound 107c580000.hvs (ops vc4_hvs_ops [vc4])
[ 0.956511] usb 3-2: new high-speed USB device number 2 using xhci-hcd
[ 1.051825] usb 1-2: New USB device found, idVendor=093a, idProduct=2510, bcdDevice= 1.00
[ 1.051833] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.051836] usb 1-2: Product: USB Optical Mouse
[ 1.051839] usb 1-2: Manufacturer: PixArt
[ 1.062584] input: pwr_button as /devices/platform/pwr_button/input/input0
[ 1.065766] vc4-drm axi:gpu: bound 107c580000.hvs (ops vc4_hvs_ops [vc4])
[ 1.071562] input: PixArt USB Optical Mouse as /devices/platform/axi/1000120000.pcie/1f00200000.usb/xhci-hcd.0/usb1/1-2/1-2:1.0/0003:093A:2510.0001/input/input1
[ 1.071658] hid-generic 0003:093A:2510.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-xhci-hcd.0-2/input0
[ 1.074983] vc4-drm axi:gpu: bound 107c580000.hvs (ops vc4_hvs_ops [vc4])
[ 1.081099] vc4-drm axi:gpu: bound 107c580000.hvs (ops vc4_hvs_ops [vc4])
[ 1.095323] [drm] Initialized v3d 1.0.0 20180419 for 1002000000.v3d on minor 0
[ 1.101651] vc4-drm axi:gpu: bound 107c580000.hvs (ops vc4_hvs_ops [vc4])
[ 1.105771] usb 3-2: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=32.98
[ 1.105778] usb 3-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.105781] usb 3-2: Product: USB2.0 Hub
[ 1.111782] vc4-drm axi:gpu: bound 107c580000.hvs (ops vc4_hvs_ops [vc4])
[ 1.145581] hub 3-2:1.0: USB hub found
[ 1.145868] hub 3-2:1.0: 4 ports detected
[ 1.214612] vc4-drm axi:gpu: bound 107c580000.hvs (ops vc4_hvs_ops [vc4])
[ 1.376477] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
[ 1.496509] usb 3-2.1: new low-speed USB device number 3 using xhci-hcd
[ 1.609986] systemd[1]: System time before build time, advancing clock.
[ 1.620958] usb 3-2.1: New USB device found, idVendor=04d9, idProduct=0006, bcdDevice= 1.50
[ 1.620964] usb 3-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.620967] usb 3-2.1: Product: RPI Wired Keyboard 5
[ 1.620971] usb 3-2.1: Manufacturer:
[ 1.673662] NET: Registered PF_INET6 protocol family
[ 1.674131] Segment Routing with IPv6
[ 1.674141] In-situ OAM (IOAM) with IPv6
[ 1.705388] systemd[1]: systemd 254.6-2-arch running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[ 1.705401] systemd[1]: Detected architecture arm64.
[ 1.709597] systemd[1]: Hostname set to <rpi5-manjaro>.
[ 1.721398] input: RPI Wired Keyboard 5 as /devices/platform/axi/1000120000.pcie/1f00300000.usb/xhci-hcd.1/usb3/3-2/3-2.1/3-2.1:1.0/0003:04D9:0006.0002/input/input2
[ 1.780744] hid-generic 0003:04D9:0006.0002: input,hidraw1: USB HID v1.11 Keyboard [ RPI Wired Keyboard 5] on usb-xhci-hcd.1-2.1/input0
[ 1.784587] vc4-drm axi:gpu: bound 107c580000.hvs (ops vc4_hvs_ops [vc4])
[ 1.800516] systemd[1]: bpf-lsm: BPF LSM hook not enabled in the kernel, BPF LSM not supported
[ 1.817373] input: RPI Wired Keyboard 5 as /devices/platform/axi/1000120000.pcie/1f00300000.usb/xhci-hcd.1/usb3/3-2/3-2.1/3-2.1:1.1/0003:04D9:0006.0003/input/input3
[ 1.876681] hid-generic 0003:04D9:0006.0003: input,hidraw2: USB HID v1.11 Device [ RPI Wired Keyboard 5] on usb-xhci-hcd.1-2.1/input1
[ 1.880402] vc4-drm axi:gpu: bound 107c580000.hvs (ops vc4_hvs_ops [vc4])
[ 1.887059] uart-pl011 107d001000.serial: no DMA platform data
[ 1.998114] systemd[1]: /usr/lib/systemd/system/stop-dmesg.service:2: Unknown key name 'USER' in section 'Unit', ignoring.
[ 2.082854] systemd[1]: Queued start job for default target Graphical Interface.
[ 2.105429] systemd[1]: Created slice Slice /system/getty.
[ 2.105828] systemd[1]: Created slice Slice /system/modprobe.
[ 2.106131] systemd[1]: Created slice Slice /system/serial-getty.
[ 2.106330] systemd[1]: Created slice User and Session Slice.
[ 2.106438] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 2.106707] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 2.106792] systemd[1]: Reached target Local Integrity Protected Volumes.
[ 2.106857] systemd[1]: Reached target Remote Encrypted Volumes.
[ 2.106879] systemd[1]: Reached target Remote File Systems.
[ 2.106900] systemd[1]: Reached target Slice Units.
[ 2.106929] systemd[1]: Reached target Swaps.
[ 2.106965] systemd[1]: Reached target Local Verity Protected Volumes.
[ 2.107086] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 2.107663] systemd[1]: Listening on LVM2 poll daemon socket.
[ 2.109647] systemd[1]: Listening on Process Core Dump Socket.
[ 2.112097] systemd[1]: Journal Audit Socket was skipped because of an unmet condition check (ConditionSecurity=audit).
[ 2.112349] systemd[1]: Listening on Journal Socket (/dev/log).
[ 2.112609] systemd[1]: Listening on Journal Socket.
[ 2.112883] systemd[1]: Listening on Network Service Netlink Socket.
[ 2.112919] systemd[1]: Userspace Out-Of-Memory (OOM) Killer Socket was skipped because of an unmet condition check (ConditionPathExists=/proc/pressure/memory).
[ 2.113144] systemd[1]: Listening on udev Control Socket.
[ 2.113330] systemd[1]: Listening on udev Kernel Socket.
[ 2.113491] systemd[1]: Listening on User Database Manager Socket.
[ 2.113704] systemd[1]: Huge Pages File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/mm/hugepages).
[ 2.114890] systemd[1]: Mounting POSIX Message Queue File System...
[ 2.116083] systemd[1]: Mounting Kernel Debug File System...
[ 2.117387] systemd[1]: Mounting Kernel Trace File System...
[ 2.129732] systemd[1]: Mounting Temporary Directory /tmp...
[ 2.131436] systemd[1]: Starting Create List of Static Device Nodes...
[ 2.132769] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 2.134488] systemd[1]: Starting Load Kernel Module configfs...
[ 2.135814] systemd[1]: Starting Load Kernel Module dm_mod...
[ 2.137493] systemd[1]: Starting Load Kernel Module drm...
[ 2.139319] systemd[1]: Starting Load Kernel Module efi_pstore...
[ 2.141038] systemd[1]: Starting Load Kernel Module fuse...
[ 2.143425] systemd[1]: Starting Load Kernel Module loop...
[ 2.143847] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
[ 2.146614] systemd[1]: Starting Journal Service...
[ 2.179763] systemd[1]: Starting Load Kernel Modules...
[ 2.181118] systemd[1]: Starting Generate network units from Kernel command line...
[ 2.181211] systemd[1]: TPM2 PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/StubPcrKernelImage-4a67b082-0a4c-41cf-b6c7-440b29bb8c4f).
[ 2.182497] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 2.183692] systemd[1]: Starting Coldplug All udev Devices...
[ 2.184835] systemd[1]: Starting Virtual Console Setup...
[ 2.187241] systemd[1]: Mounted POSIX Message Queue File System.
[ 2.187357] systemd[1]: Mounted Kernel Debug File System.
[ 2.187431] systemd[1]: Mounted Kernel Trace File System.
[ 2.187506] systemd[1]: Mounted Temporary Directory /tmp.
[ 2.187721] systemd[1]: Finished Create List of Static Device Nodes.
[ 2.190671] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 2.190818] systemd[1]: Finished Load Kernel Module configfs.
[ 2.191147] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[ 2.191299] systemd[1]: Finished Load Kernel Module efi_pstore.
[ 2.191579] systemd[1]: modprobe@loop.service: Deactivated successfully.
[ 2.191684] systemd[1]: Finished Load Kernel Module loop.
[ 2.192909] systemd[1]: Mounting Kernel Configuration File System...
[ 2.194794] systemd[1]: Starting Create Static Device Nodes in /dev gracefully...
[ 2.195287] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 2.195582] systemd[1]: Finished Load Kernel Module drm.
[ 2.196449] device-mapper: ioctl: 4.47.0-ioctl (2022-07-28) initialised: dm-devel@redhat.com
[ 2.199214] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
[ 2.199384] systemd[1]: Finished Load Kernel Module dm_mod.
[ 2.199742] systemd[1]: Repartition Root Disk was skipped because no trigger condition checks were met.
[ 2.199930] systemd[1]: Mounted Kernel Configuration File System.
[ 2.207533] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
[ 2.208545] systemd-journald[221]: Collecting audit messages is disabled.
[ 2.208596] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 2.211800] fuse: init (API version 7.37)
[ 2.224040] systemd[1]: Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
[ 2.224106] systemd[1]: Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
[ 2.225220] systemd[1]: Starting Load/Save OS Random Seed...
[ 2.225882] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 2.226051] systemd[1]: Finished Load Kernel Module fuse.
[ 2.226394] systemd[1]: Finished Generate network units from Kernel command line.
[ 2.226727] systemd[1]: Finished Load Kernel Modules.
[ 2.227715] systemd[1]: Mounting FUSE Control File System...
[ 2.229050] systemd[1]: Starting Apply Kernel Variables...
[ 2.231408] systemd[1]: Mounted FUSE Control File System.
[ 2.245078] systemd[1]: Started Journal Service.
[ 2.275000] systemd-journald[221]: Received client request to flush runtime journal.
[ 2.360858] systemd-journald[221]: /var/log/journal/f93566d1e53e4e77aa4eb03cf3c30e01/system.journal: Realtime clock jumped backwards relative to last journal entry, rotating.
[ 2.360882] systemd-journald[221]: Rotating system journal.
[ 2.553933] macb 1f00100000.ethernet end0: renamed from eth0
[ 2.635106] rpi-gpiomem 107d508500.gpiomem: window base 0x107d508500 size 0x00000040
[ 2.637015] rpi-gpiomem 107d508500.gpiomem: initialised 1 regions as /dev/gpiomem1
[ 2.637962] vc4-drm axi:gpu: bound 107c580000.hvs (ops vc4_hvs_ops [vc4])
[ 2.638341] rpi-gpiomem 107d517c00.gpiomem: window base 0x107d517c00 size 0x00000040
[ 2.642460] vc4-drm axi:gpu: bound 107c580000.hvs (ops vc4_hvs_ops [vc4])
[ 2.645272] rpi-gpiomem 107d517c00.gpiomem: initialised 1 regions as /dev/gpiomem2
[ 2.645727] rpi-gpiomem 107d504100.gpiomem: window base 0x107d504100 size 0x00000020
[ 2.652096] vc4-drm axi:gpu: bound 107c580000.hvs (ops vc4_hvs_ops [vc4])
[ 2.659918] rpi-gpiomem 107d504100.gpiomem: initialised 1 regions as /dev/gpiomem3
[ 2.663509] rpi-gpiomem 107d510700.gpiomem: window base 0x107d510700 size 0x00000020
[ 2.664898] vc4-drm axi:gpu: bound 107c580000.hvs (ops vc4_hvs_ops [vc4])
[ 2.664983] rpi-gpiomem 107d510700.gpiomem: initialised 1 regions as /dev/gpiomem4
[ 2.665194] rpi-gpiomem 1f000d0000.gpiomem: window base 0x1f000d0000 size 0x00030000
[ 2.665228] rpi-gpiomem 1f000d0000.gpiomem: initialised 1 regions as /dev/gpiomem0
[ 2.667676] vc4-drm axi:gpu: bound 107c580000.hvs (ops vc4_hvs_ops [vc4])
[ 2.670773] vc4-drm axi:gpu: bound 107c580000.hvs (ops vc4_hvs_ops [vc4])
[ 2.682541] mc: Linux media interface: v0.10
[ 2.704876] brcmstb-i2c 107d508200.i2c: @200000hz registered in interrupt mode
[ 2.711080] vc4-drm axi:gpu: bound 107c580000.hvs (ops vc4_hvs_ops [vc4])
[ 2.712198] videodev: Linux video capture interface: v2.00
[ 2.718613] brcmstb-i2c 107d508280.i2c: @200000hz registered in interrupt mode
[ 2.719167] Registered IR keymap rc-cec
[ 2.719223] rc rc0: vc4-hdmi-0 as /devices/platform/soc/107c701400.hdmi/rc/rc0
[ 2.719303] input: vc4-hdmi-0 as /devices/platform/soc/107c701400.hdmi/rc/rc0/input4
[ 2.734754] vc4-drm axi:gpu: bound 107c701400.hdmi (ops vc4_hdmi_ops [vc4])
[ 2.749907] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 2.751847] Registered IR keymap rc-cec
[ 2.751923] rc rc1: vc4-hdmi-1 as /devices/platform/soc/107c706400.hdmi/rc/rc1
[ 2.752014] input: vc4-hdmi-1 as /devices/platform/soc/107c706400.hdmi/rc/rc1/input5
[ 2.760197] cfg80211: Loaded X.509 cert 'benh@debian.org: 577e021cb980e0e820821ba7b54b4961b8b4fadf'
[ 2.760408] cfg80211: Loaded X.509 cert 'romain.perier@gmail.com: 3abbc6ec146e09d1b6016ab9d6cf71dd233f0328'
[ 2.760626] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 2.761874] vc4-drm axi:gpu: bound 107c706400.hdmi (ops vc4_hdmi_ops [vc4])
[ 2.762011] vc4-drm axi:gpu: bound 107c500000.mop (ops vc4_txp_ops [vc4])
[ 2.762082] vc4-drm axi:gpu: bound 107c501000.moplet (ops vc4_txp_ops [vc4])
[ 2.762156] vc4-drm axi:gpu: bound 107c410000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 2.762214] vc4-drm axi:gpu: bound 107c411000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 2.801136] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 2.804571] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 2.804769] usbcore: registered new interface driver brcmfmac
[ 2.822008] Bluetooth: Core ver 2.22
[ 2.822037] NET: Registered PF_BLUETOOTH protocol family
[ 2.822040] Bluetooth: HCI device and connection manager initialized
[ 2.822047] Bluetooth: HCI socket layer initialized
[ 2.822050] Bluetooth: L2CAP socket layer initialized
[ 2.822056] Bluetooth: SCO socket layer initialized
[ 2.830462] rpivid_hevc: module is from the staging directory, the quality is unknown, you have been warned.
[ 2.831325] rpivid 1000800000.codec: bcm2712_iommu_of_xlate: MMU 1000005100.iommu
[ 2.835262] [drm] Initialized vc4 0.0.0 20140616 for axi:gpu on minor 1
[ 2.835798] Bluetooth: HCI UART driver ver 2.3
[ 2.835804] Bluetooth: HCI UART protocol H4 registered
[ 2.835841] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 2.835982] Bluetooth: HCI UART protocol Broadcom registered
[ 2.836053] hci_uart_bcm serial0-0: supply vbat not found, using dummy regulator
[ 2.837803] hci_uart_bcm serial0-0: supply vddio not found, using dummy regulator
[ 2.860812] rpivid 1000800000.codec: Device registered as /dev/video19
[ 2.873690] pispbe 1000880000.pisp_be: bcm2712_iommu_of_xlate: MMU 1000005100.iommu
[ 2.875277] pispbe 1000880000.pisp_be: pispbe_probe: HW version: 0x02252700
[ 2.875286] pispbe 1000880000.pisp_be: pispbe_probe: BatchStatus: 0x00000000
[ 2.875289] pispbe 1000880000.pisp_be: pispbe_probe: Status: 0x00000000
[ 2.875293] pispbe 1000880000.pisp_be: Register nodes for group 0
[ 2.885789] pispbe 1000880000.pisp_be: input device node registered as /dev/video20
[ 2.889163] pispbe 1000880000.pisp_be: tdn_input device node registered as /dev/video21
[ 2.893360] pispbe 1000880000.pisp_be: stitch_input device node registered as /dev/video22
[ 2.893404] pispbe 1000880000.pisp_be: hog_output device node registered as /dev/video23
[ 2.893430] pispbe 1000880000.pisp_be: output0 device node registered as /dev/video24
[ 2.893455] pispbe 1000880000.pisp_be: output1 device node registered as /dev/video25
[ 2.893478] pispbe 1000880000.pisp_be: tdn_output device node registered as /dev/video26
[ 2.893505] pispbe 1000880000.pisp_be: stitch_output device node registered as /dev/video27
[ 2.893536] pispbe 1000880000.pisp_be: config device node registered as /dev/video28
[ 2.893821] pispbe 1000880000.pisp_be: Register nodes for group 1
[ 2.893902] pispbe 1000880000.pisp_be: input device node registered as /dev/video29
[ 2.893996] pispbe 1000880000.pisp_be: tdn_input device node registered as /dev/video30
[ 2.894062] pispbe 1000880000.pisp_be: stitch_input device node registered as /dev/video31
[ 2.894104] pispbe 1000880000.pisp_be: hog_output device node registered as /dev/video32
[ 2.894125] pispbe 1000880000.pisp_be: output0 device node registered as /dev/video33
[ 2.894151] pispbe 1000880000.pisp_be: output1 device node registered as /dev/video34
[ 2.894172] pispbe 1000880000.pisp_be: tdn_output device node registered as /dev/video35
[ 2.894193] pispbe 1000880000.pisp_be: stitch_output device node registered as /dev/video36
[ 2.894234] pispbe 1000880000.pisp_be: config device node registered as /dev/video37
[ 2.902912] Console: switching to colour frame buffer device 240x75
[ 2.920692] vc4-drm axi:gpu: [drm] fb0: vc4drmfb frame buffer device
[ 2.984904] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov 1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
[ 3.193096] Bluetooth: hci0: BCM: chip id 107
[ 3.193321] Bluetooth: hci0: BCM: features 0x2f
[ 3.194431] Bluetooth: hci0: BCM4345C0
[ 3.194435] Bluetooth: hci0: BCM4345C0 (003.001.025) build 0000
[ 3.199094] Bluetooth: hci0: BCM4345C0 'brcm/BCM4345C0.hcd' Patch
[ 3.377199] zram: Added device: zram0
[ 3.386481] zram0: detected capacity change from 0 to 24725472
[ 3.416918] Adding 12362720k swap on /dev/zram0. Priority:100 extents:1 across:12362720k SSFS
[ 3.449570] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 3.449579] Bluetooth: BNEP filters: protocol multicast
[ 3.449585] Bluetooth: BNEP socket layer initialized
[ 3.893201] Bluetooth: hci0: BCM: features 0x2f
[ 3.894563] Bluetooth: hci0: BCM43455 37.4MHz Raspberry Pi 3+-0190
[ 3.894568] Bluetooth: hci0: BCM4345C0 (003.001.025) build 0382
[ 3.894875] Bluetooth: hci0: BCM: Using default device address (43:45:c0:00:1f:ac)
[ 3.912436] Bluetooth: MGMT ver 1.22
[ 3.917577] NET: Registered PF_ALG protocol family
[ 4.754182] macb 1f00100000.ethernet end0: PHY [1f00100000.ethernet-ffffffff:01] driver [Broadcom BCM54213PE] (irq=POLL)
[ 4.754192] macb 1f00100000.ethernet end0: configuring for phy/rgmii-id link mode
[ 4.756649] pps pps0: new PPS source ptp0
[ 4.756726] macb 1f00100000.ethernet: gem-ptp-timer ptp clock registered.
[ 4.788425] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 8.841551] macb 1f00100000.ethernet end0: Link is Up - 1Gbps/Full - flow control off
[ 8.841571] IPv6: ADDRCONF(NETDEV_CHANGE): end0: link becomes ready
[ 10.496545] Bluetooth: RFCOMM TTY layer initialized
[ 10.496568] Bluetooth: RFCOMM socket layer initialized
[ 10.496581] Bluetooth: RFCOMM ver 1.11
[ 37.065906] systemd-journald[221]: /var/log/journal/f93566d1e53e4e77aa4eb03cf3c30e01/user-1000.journal: Journal file uses a different sequence number ID, rotating.
voilà
$ hwinfo --short
cpu:
CPU
CPU
CPU
CPU
keyboard:
/dev/input/event2 Holtek Wired Keyboard (78/79 key) [RPI Wired Keyboard 5]
mouse:
/dev/input/mice Pixart Imaging Optical Mouse
network:
Ethernet controller
end0 ARM Ethernet controller
wlan0 ARM Ethernet controller
Broadcom BCM43455 WLAN card
network interface:
end0 Ethernet network interface
wlan0 WLAN network interface
lo Loopback network interface
disk:
/dev/ram2 Disk
/dev/ram0 Disk
/dev/ram9 Disk
/dev/mmcblk0 Disk
/dev/ram14 Disk
/dev/ram7 Disk
/dev/ram12 Disk
/dev/ram5 Disk
/dev/ram10 Disk
/dev/ram3 Disk
/dev/ram1 Disk
/dev/ram15 Disk
/dev/ram8 Disk
/dev/zram0 Disk
/dev/ram13 Disk
/dev/ram6 Disk
/dev/ram11 Disk
/dev/ram4 Disk
partition:
/dev/mmcblk0p1 Partition
/dev/mmcblk0p2 Partition
usb controller:
ARM USB controller
ARM USB XHCI controller
ARM USB controller
bridge:
Broadcom PCI bridge
hub:
Linux Foundation 2.0 root hub
Linux Foundation 3.0 root hub
Genesys Logic Hub
memory:
Main Memory
unknown:
/dev/input/event3 Holtek Wired Keyboard (78/79 key) [RPI Wired Keyboard 5]
anything more I can send?
