Hi guys.
I just installed a few days ago Manjaro Minimal, KDE.
It is working fine and connected to internet through WiFi.
The issue I have is that the WiFi icon on the tool bar is saying I am having limited connection or not connected sometimes despite I can actually browse the internet normally.
This is not a big issue but it is irritating, it shouldn’t be like this.
How can I fix that?
(This is the machine I will reinstall it again on it)
$ inxi -Fxxx
Host: mx Kernel: 6.1.0-32-amd64 arch: x86_64 bits: 64 compiler: gcc
v: 12.2.0 Desktop: KDE Plasma v: 5.27.5 wm: kwin_x11 vt: 7 dm: SDDM
Distro: MX-23.5_KDE_x64 Libretto September 15 2024 base: Debian GNU/Linux
12 (bookworm)
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X415FAC_X415FA
v: 1.0 serial: <superuser required>
Mobo: ASUSTeK model: X415FAC v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: X415FAC.202 date: 07/08/2021
ID-1: BAT0 charge: 30.4 Wh (100.0%) condition: 30.4/37.1 Wh (81.8%)
volts: 7.8 min: 7.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: not charging cycles: 54
Info: dual core model: Intel Core i3-10110U bits: 64 type: MT MCP
smt: enabled arch: Comet/Whiskey Lake note: check rev: C cache: L1: 128 KiB
L2: 512 KiB L3: 4 MiB
Speed (MHz): avg: 782 high: 800 min/max: 400/4100 cores: 1: 800 2: 787
3: 800 4: 742 bogomips: 20799
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: ASUSTeK driver: i915
v: kernel arch: Gen-9.5 ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:9b41 class-ID: 0300
Device-2: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-5:3 chip-ID: 13d3:56e6 class-ID: 0e02 serial: 0000
Display: x11 server: X.Org v: 1.21.1.7 with: Xwayland v: 22.1.9
compositor: kwin_x11 driver: X: loaded: modesetting unloaded: fbdev,vesa
dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: ChiMei InnoLux 0x14d6 res: 1366x768 hz: 60
dpi: 112 size: 309x173mm (12.17x6.81") diag: 354mm (13.9") modes: 1366x768
API: OpenGL v: 4.6 Mesa 24.2.2-1~mx23ahs renderer: Mesa Intel UHD
Graphics (CML GT2) direct-render: Yes
Device-1: Intel Comet Lake PCH-LP cAVS vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3 chip-ID: 8086:02c8 class-ID: 0403
API: ALSA v: k6.1.0-32-amd64 status: kernel-api
Server-1: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
IF: wlan0 state: up mac: xxxxxxxx
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-10:4 chip-ID: 8087:0aaa class-ID: e001
Report: hciconfig ID: hci0 rfk-id: 3 state: up address: 7C:70:DB:E2:29:F2
bt-v: 3.0 lmp-v: 5.1 sub-v: 2184 hci-v: 5.1 rev: 2184
Local Storage: total: 295.76 GiB used: 113.9 GiB (38.5%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: PC SN530
SDBPNPZ-256G-1002 size: 238.47 GiB speed: 31.6 Gb/s lanes: 4 type: SSD
serial: 2127HE443513 rev: 21106000 temp: 42.9 C scheme: MBR
ID-2: /dev/sda type: USB vendor: SanDisk model: Ultra USB 3.0
size: 57.28 GiB type: N/A serial: xxxxxxxxxx rev: 1.00 scheme: MBR
ID-1: / size: 100 GiB used: 13.02 GiB (13.0%) fs: btrfs dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 1022 MiB used: 576 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p1
ID-3: /home size: 137.47 GiB used: 43.32 GiB (31.5%) fs: btrfs
dev: /dev/nvme0n1p3
ID-1: swap-1 type: file size: 4 GiB used: 0 KiB (0.0%) priority: -2
file: /swap/swap
System Temperatures: cpu: 50.0 C pch: 45.0 C mobo: N/A
Fan Speeds (RPM): cpu: 1900
Processes: 306 Uptime: 50m wakeups: 2 Memory: 19.37 GiB
used: 7.38 GiB (38.1%) Init: systemd v: 252 target: graphical (5)
default: graphical Compilers: gcc: 12.2.0 alt: 12 Packages: pm: dpkg
pkgs: 2593 Shell: Bash v: 5.2.15 running-in: konsole inxi: 3.3.26
limo@mx:/
I will highly appreciate your help.
