Since a couple of days ago, I began having this problem.
I never touched my NIC and the antenna is still perfectly put.
The system is able to find WiFi networks (my home modem, my phone if I turn Tethering on), but it won’t connect.
After a while trying to establish a connection I receive a notification that says “Wireless Interface (wlp2s0) - The WiFi network could not be found”.
My other devices have no problem with this. I really don’t even know how should I debug something network related, so any help would be appreciated.
Welcome to Manjaro!
- Please read the information behind this link. It will help you to post necessary information. [HowTo] Provide System Information
- Please press the three dots … below your post and then press the
- If you give us information about your system, we can see what we’re talking about and make better suggestions.
- You can do this by using
inxi
in a terminal or in console.
- Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
- Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
- Copy the output from inxi (including the command) and paste it into your post.
- To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
Hey, try putting airplane mode on and back. It solved the problem for me hope it works for you.
