Wifi very slow intel card
I only have 5GHz so cant test on 2.4GHz
How do I downgrade linux-firmware?
I know this is old, but did you find a solution for this, @niclasc ? I’m facing the same problem, also with an Intel WiFi card.
My inxi -Fazy:
  Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=a471f293-3929-4daf-8260-ad6c8e45909c rw quiet apparmor=1
  security=apparmor resume=UUID=c4404437-bc8a-46a7-904b-baafe61254a9
  udev.log_priority=3
  Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: Micro-Star product: Bravo 15 B5DD v: REV:1.0
  Mobo: Micro-Star model: MS-158K v: REV:1.0 serial: <superuser required>
  UEFI: American Megatrends LLC. v: E158KAMS.105 date: 05/20/2021
  ID-1: BAT1 charge: 50.6 Wh (98.6%) condition: 51.3/52.0 Wh (98.7%)
  volts: 13.0 min: 11.4 model: MSI Corp. MS-158K type: Li-ion serial: N/A
  status: Charging
  Info: 8-Core model: AMD Ryzen 7 5800H with Radeon Graphics bits: 64
  type: MT MCP arch: Zen 3 family: 19 (25) model-id: 50 (80) stepping: 0
  microcode: A50000C cache: L1: 512 KiB L2: 4 MiB L3: 16 MiB
  flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
  bogomips: 102240
  Speed: 1559 MHz min/max: 1200/3200 MHz boost: enabled Core speeds (MHz):
  1: 1559 2: 1520 3: 1530 4: 3213 5: 2153 6: 1655 7: 1774 8: 1198 9: 1198
  10: 1197 11: 1862 12: 1543 13: 1197 14: 3281 15: 1576 16: 1214
  Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
  STIBP: always-on, RSB filling
  Device-1: AMD Navi 14 [Radeon RX 5500/5500M / Pro 5500M]
  vendor: Micro-Star MSI driver: amdgpu v: kernel bus-ID: 03:00.0
  chip-ID: 1002:7340 class-ID: 0380
  Device-2: AMD Cezanne vendor: Micro-Star MSI driver: amdgpu v: kernel
  bus-ID: 07:00.0 chip-ID: 1002:1638 class-ID: 0300
  Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver:
  loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
  display-ID: :0 screens: 1
  s-diag: 582mm (22.9")
  Monitor-1: eDP res: 1920x1080 hz: 144 dpi: 142 size: 344x193mm (13.5x7.6")
  diag: 394mm (15.5")
  OpenGL: renderer: AMD RENOIR (DRM 3.41.0 5.13.19-2-MANJARO LLVM 13.0.0)
  v: 4.6 Mesa 21.2.5 direct render: Yes
  Device-1: AMD Navi 10 HDMI Audio vendor: Micro-Star MSI
  driver: snd_hda_intel v: kernel bus-ID: 03:00.1 chip-ID: 1002:ab38
  class-ID: 0403
  Device-2: AMD vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
  bus-ID: 07:00.1 chip-ID: 1002:1637 class-ID: 0403
  Device-3: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
  vendor: Micro-Star MSI driver: snd_rn_pci_acp3x v: kernel
  alternate: snd_pci_acp3x bus-ID: 07:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-4: AMD Family 17h HD Audio vendor: Micro-Star MSI
  driver: snd_hda_intel v: kernel bus-ID: 07:00.6 chip-ID: 1022:15e3
  class-ID: 0403
  Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.40 running: yes
  vendor: Micro-Star MSI driver: r8169 v: kernel port: f000 bus-ID: 04:00.0
  IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 05:00.0
  chip-ID: 8086:2723 class-ID: 0280
  IF: wlp5s0 state: up mac: <filter>
  IF-ID-1: docker0 state: down mac: <filter>
  Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-3:3
  Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
  Local Storage: total: 476.94 GiB used: 28.73 GiB (6.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8PCP3512F-AI1
  lanes: 4 type: SSD serial: <filter> rev: ECFK52.8 temp: 31.9 C scheme: GPT
  ID-1: / raw-size: 460.12 GiB size: 451.83 GiB (98.20%)
  used: 28.73 GiB (6.4%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-1: swap-1 type: partition size: 16.52 GiB used: 0 KiB (0.0%) priority: -2
  dev: /dev/nvme0n1p3 maj-min: 259:3
  System Temperatures: cpu: 43.0 C mobo: N/A
  GPU: device: amdgpu temp: 41.0 C mem: 0.0 C fan: 65526 watts: 4.00
  device: amdgpu temp: 40.0 C
  Processes: 391 Uptime: 19h 29m wakeups: 12575 Memory: 15.02 GiB
  used: 7.06 GiB (47.0%) Init: systemd v: 249 tool: systemctl Compilers:
  gcc: 11.1.0 clang: 13.0.0 Packages: 1320 pacman: 1311 lib: 341 flatpak: 0
  snap: 9 Shell: Bash v: 5.1.8 running-in: terminator inxi: 3.3.09
