you can try this
sudo iw reg set DE
sudo systemctl restart NetworkManager.service
sudo ip link set wlp2s0 up
you can try this
sudo iw reg set DE
Is there a date filter or a way to print last some hours of log?
I scrolled thousands of lines and they didn’t seem to be ordered. There were logs from April but then in between some from March again.
There has been a tailscale update on Unstable branch, lately.
stable1.38.4-1
testing1.38.4-1
unstable1.40.0-1
yes journalctl has a lot of filtering ability
# since last boot
-b
# just previous boot
-b -1
# date / time
--since="2012-10-30 18:17:16"
--until="2012-10-30"
Can you temporarily turn off tailscale, to see if it is a factor in the problem?
➜ ~ iw reg get
global
country DE: DFS-ETSI
(2400 - 2483 @ 40), (N/A, 20), (N/A)
(5150 - 5250 @ 80), (N/A, 23), (N/A), NO-OUTDOOR, AUTO-BW
(5250 - 5350 @ 80), (N/A, 20), (0 ms), NO-OUTDOOR, DFS, AUTO-BW
(5470 - 5725 @ 160), (N/A, 26), (0 ms), DFS
(5725 - 5875 @ 80), (N/A, 13), (N/A)
(5945 - 6425 @ 160), (N/A, 23), (N/A), NO-OUTDOOR
(57000 - 66000 @ 2160), (N/A, 40), (N/A)
phy#0 (self-managed)
(2402 - 2482 @ 40), (N/A, 20), (N/A)
(5170 - 5250 @ 80), (N/A, 23), (N/A), NO-OUTDOOR, AUTO-BW
(5250 - 5330 @ 80), (N/A, 23), (0 ms), NO-OUTDOOR, DFS, AUTO-BW
(5490 - 5590 @ 80), (N/A, 30), (0 ms), DFS, AUTO-BW
(5590 - 5650 @ 40), (N/A, 30), (600000 ms), DFS, AUTO-BW
(5650 - 5710 @ 40), (N/A, 30), (0 ms), DFS, AUTO-BW
(5735 - 5875 @ 80), (N/A, 14), (N/A), AUTO-BW
Still not connecting.
type or paste cod[20055.481059] wlp2s0: send auth to f4:05:95:4d:6e:93 (try 3/3)
[20056.504336] wlp2s0: authentication with f4:05:95:4d:6e:93 timed out
[20066.638339] wlp2s0: authenticate with f4:05:95:4d:6e:93
[20066.663102] wlp2s0: send auth to f4:05:95:4d:6e:93 (try 1/3)
[20067.517689] wlp2s0: send auth to f4:05:95:4d:6e:93 (try 2/3)
[20068.477696] wlp2s0: send auth to f4:05:95:4d:6e:93 (try 3/3)
[20069.490664] wlp2s0: authentication with f4:05:95:4d:6e:93 timed out
[20082.203140] ath11k_pci 0000:02:00.0: Failed to set the requested Country regulatory setting
[20082.203191] ath11k_pci 0000:02:00.0: Failed to set the requested Country regulatory setting
[20082.439231] wlp2s0: authenticate with f4:05:95:4d:6e:93
[20082.487794] wlp2s0: send auth to f4:05:95:4d:6e:93 (try 1/3)
[20083.384053] wlp2s0: send auth to f4:05:95:4d:6e:93 (try 2/3)
[20084.423889] wlp2s0: send auth to f4:05:95:4d:6e:93 (try 3/3)
[20085.381906] wlp2s0: authentication with f4:05:95:4d:6e:93 timed out
[20095.534402] wlp2s0: authenticate with f4:05:95:4d:6e:93
[20095.556924] wlp2s0: send auth to f4:05:95:4d:6e:93 (try 1/3)
[20096.457600] wlp2s0: send auth to f4:05:95:4d:6e:93 (try 2/3)
[20097.437306] wlp2s0: send auth to f4:05:95:4d:6e:93 (try 3/3)
[20098.450508] wlp2s0: authentication with f4:05:95:4d:6e:93 timed out
[20111.107018] ath11k_pci 0000:02:00.0: Failed to set the requested Country regulatory setting
[20111.107381] ath11k_pci 0000:02:00.0: Failed to set the requested Country regulatory setting
[20111.379105] wlp2s0: authenticate with f4:05:95:4d:6e:93
[20111.411996] wlp2s0: send auth to f4:05:95:4d:6e:93 (try 1/3)
[20112.477184] wlp2s0: send auth to f4:05:95:4d:6e:93 (try 2/3)
[20113.456263] wlp2s0: send auth to f4:05:95:4d:6e:93 (try 3/3)
[20114.477536] wlp2s0: authentication with f4:05:95:4d:6e:93 timed out
[20115.399443] audit: type=1334 audit(1683374741.888:725): prog-id=114 op=LOAD
[20115.622248] audit: type=1130 audit(1683374742.111:726): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[20120.340761] audit: type=1100 audit(1683374746.831:727): pid=19806 uid=1000 auid=1000 ses=12 subj=unconfined msg='op=PAM:authentication grantors=pam_unix acct="singhd" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[20120.342762] audit: type=1101 audit(1683374746.831:728): pid=19806 uid=1000 auid=1000 ses=12 subj=unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="singhd" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[20120.344033] audit: type=1110 audit(1683374746.835:729): pid=19806 uid=1000 auid=1000 ses=12 subj=unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[20120.344203] audit: type=1105 audit(1683374746.835:730): pid=19806 uid=1000 auid=1000 ses=12 subj=unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[20124.615471] wlp2s0: authenticate with f4:05:95:4d:6e:93
[20124.637640] wlp2s0: send auth to f4:05:95:4d:6e:93 (try 1/3)
[20125.467222] wlp2s0: send auth to f4:05:95:4d:6e:93 (try 2/3)
[20126.480355] wlp2s0: send auth to f4:05:95:4d:6e:93 (try 3/3)
[20127.493693] wlp2s0: authentication with f4:05:95:4d:6e:93 timed out
[20140.197308] ath11k_pci 0000:02:00.0: Failed to set the requested Country regulatory setting
[20140.197348] ath11k_pci 0000:02:00.0: Failed to set the requested Country regulatory setting
[20140.436109] wlp2s0: authenticate with e6:05:95:4d:6e:93
[20140.482859] wlp2s0: send auth to e6:05:95:4d:6e:93 (try 1/3)
[20141.514837] wlp2s0: send auth to e6:05:95:4d:6e:93 (try 2/3)
[20142.397222] wlp2s0: send auth to e6:05:95:4d:6e:93 (try 3/3)
[20143.490755] wlp2s0: authentication with e6:05:95:4d:6e:93 timed out
[20146.104580] audit: type=1131 audit(1683374772.595:731): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[20146.190841] audit: type=1334 audit(1683374772.681:732): prog-id=114 op=UNLOAD
e here
➜ ~ tailscale version
1.38.4-dev20230405
tailscale commit: 043a34500dd2bb07c34e3b28a56cdbc8b5434454-dirty
go version: go1.20.3
Which one do I have?
honestly, without knowing what your IT-guy configured it’s almost impossible to figure out how to get this wifi-connection running. you should ask your IT-guy to look for the configuration and i would not recommend to change or alter further setting. it will brake more than it solves. your hardware seems okay, the connection to the router is established but it is still denied due to an authentification issue that is obviously something of the special connection that is configured from your IT-guy.
He won’t be happy if you demolish the settings and i don’t think that anyone from us can oversee it from here because we would have to know what the IT-guy did.
Yeah, makes sense. I was thinking the same. Will have to wait until Monday.
How can I undo this?
don’t worry, keep in mind that you set the iw-setting to DE, but that’s nothing to concern. the restart of the network-manager is done every time you boot your computer and to set up the wifi-connection again is also nothing to worry.
Your original setting was global: 00 (unset), device: US
So you can do
sudo iw reg set US
plus the other two lines
Thanks everyone. I will post the updates on Monday.
This morning there were some updates, so I did:
yay -Syyu
and a reboot, after which it started to work fine again.
nice to hear but there is something you should think about:
yay is not recommended for updates anymore. you should use pamac and pacman to prevent broken systems. if you used yay in the past you shouldn’t be surprised if something doesn’t work after updating and wondering as it came out of nowhere. there are reasons why not to use yay anymore.
