Hello, this is my first time posting here on the Manjaro forum. My laptop had been running pretty awesomely and without much issue on Manjaro XFCE for the past several months, but yesterday, out of the blue, it just suddenly stopped being able to see any wifi networks. Meanwhile, my other computer and my phone can use the wifi just fine.
Here’s my output from inxi -F
System: Host: nonplussed-inspiron3521 Kernel: 5.10.53-1-MANJARO x86_64 bits: 64 Desktop: Xfce 4.16.0 Distro: Manjaro Linux
Machine: Type: Portable System: Dell product: Inspiron 3521 v: A12 serial: <superuser required>
Mobo: Dell model: 0FXP6Y v: A00 serial: <superuser required> UEFI: Dell v: A12 date: 10/25/2013
Battery: ID-1: BAT1 charge: 11.2 Wh (56.3%) condition: 19.9/41.4 Wh (48.1%) volts: 15.2 min: 14.8
CPU: Info: Dual Core model: Intel Pentium 2127U bits: 64 type: MCP cache: L2: 2 MiB
Speed: 798 MHz min/max: 800/1900 MHz Core speeds (MHz): 1: 798 2: 798
Graphics: Device-1: Intel 3rd Gen Core processor Graphics driver: i915 v: kernel
Device-2: Suyin Integrated_Webcam_HD type: USB driver: uvcvideo
Display: x11 server: X.Org 1.20.11 driver: loaded: intel unloaded: modesetting resolution: 1366x768~60Hz
OpenGL: renderer: Mesa DRI Intel HD Graphics 2500 (IVB GT1) v: 4.2 Mesa 21.1.5
Audio: Device-1: Intel 7 Series/C216 Family High Definition Audio driver: snd_hda_intel
Sound Server-1: ALSA v: k5.10.53-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 14.2 running: yes
Network: Device-1: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169
IF: enp1s0 state: down mac: ec:f4:bb:94:0d:5a
Device-2: Broadcom BCM43142 802.11b/g/n driver: wl
IF: wlp2s0 state: dormant mac: 16:5a:e1:1b:2b:01
IF-ID-1: enp0s20u3c4i2 state: up speed: N/A duplex: N/A mac: 1a:55:e3:29:4f:f5
Drives: Local Storage: total: 465.76 GiB used: 10.25 GiB (2.2%)
ID-1: /dev/sda vendor: Toshiba model: MQ01ABF050 size: 465.76 GiB
Partition: ID-1: / size: 343.34 GiB used: 10.23 GiB (3.0%) fs: ext4 dev: /dev/sda8
ID-2: /boot/efi size: 496 MiB used: 26 MiB (5.2%) fs: vfat dev: /dev/sda1
Swap: Alert: No swap data was found.
Sensors: System Temperatures: cpu: 43.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Info: Processes: 170 Uptime: 39m Memory: 3.72 GiB used: 1.76 GiB (47.2%) Shell: Bash inxi: 3.3.06
It says that network Device-1 is down, so that seems to be the issue most likely. Could anyone give me some pointers on what I could do about this?
(It may be that there’s already other posts on this forum with this exact problem and the exact solution I need; if that’s the case I apologize, and I should search harder.)
