I’m currently running manjaro on a razer blade laptop with an Intel Wifi 6 AX200 as the wireless adapter. I can scan for networks, and even attempt to connect however it will never successfully connect to my wifi. I have used three seperate kernel versions (5.18, 5.12, and 5.10) and still run into the same problem. I have attempted to install arch believing it to be a KDE issue and still ran into the same problem on the usb.
EDIT: My hotspot does work.
Are there any other fixes for this or should I buy a panda adapter?
Ran into the same issue using a panda adapter I had laying around so it might be, I’ll try booting into a different distro tomorrow and see how it works.
Additionally how would I go about removing the wpa_supplicant package?
I don’t think you would really want to remove wpa_supplicant. It would be better to mask the service. iwd is a wpa_supplicant replacement. Note that I have not tried it, so I have no opinion on iwd.
Both use the same NetworkManager (only different version) and both use wpa-supplicant. If that is really your problem, then try to switch to WPA2 on the router. Then it should work.
