Strange issue with built-in QCA6174 wifi where approximately 5 minutes after connection the receive bitrate drops by half and packet loss goes from 0% to ~50% (which would explain the bitrate halving). Transmit specs seem unaffected.
Simply issuing nmcli connection up "Wifi-Name" resets the connection and full speed is again achieved for the next approximately 5 minutes, then it drops again.
Bitrate and specs were tested on local network and are not retarded on any other devices.
No QoS or power saving settings on the router/access point.
I’ve tried disabling power saving features on the card itself, and on PCI more broadly to no effect.
Whilst it drops at approximately 5 minutes after connection it doesn’t seem to be an exact timeframe like a timer, although its usually within about 30 seconds of that 5 minute mark.
Nothing is written to the journal at the time the connection degrades.
Temperatures reported by ath10k remain consistent at around 55C
ethtool -S wlp2s0 shows d_fw_crash_count: 0 so it doesn’t seem to be a firmware crash
Changing wifi specifications from 5GHz to 2.4GHz makes no difference; nor does changing the channel or channel width.
I have tried kernels going back to 6.12 and the problem occurs across all of them.
iperf3 -c 192.168.0.200 -u -b 300M -t 600 -R
Connecting to host 192.168.0.200, port 5201
Reverse mode, remote host 192.168.0.200 is sending
[ 4] local 192.168.0.50 port 39326 connected to 192.168.0.200 port 5201
[ ID] Interval Transfer Bitrate Jitter Lost/Total Datagrams
[ 4] 282.00-283.00 sec 35.8 MBytes 300 Mbits/sec 0.057 ms 0/25901 (0%)
[ 4] 283.00-284.00 sec 35.8 MBytes 300 Mbits/sec 0.028 ms 0/25895 (0%)
[ 4] 284.00-285.00 sec 35.8 MBytes 300 Mbits/sec 0.065 ms 0/25900 (0%)
[ 4] 285.00-286.00 sec 35.8 MBytes 300 Mbits/sec 0.022 ms 0/25895 (0%)
[ 4] 286.00-287.00 sec 35.8 MBytes 300 Mbits/sec 0.025 ms 0/25924 (0%)
[ 4] 287.00-288.00 sec 19.9 MBytes 167 Mbits/sec 0.034 ms 7157/21544 (33%)
[ 4] 288.00-289.00 sec 8.70 MBytes 73.0 Mbits/sec 0.289 ms 8139/14436 (56%)
[ 4] 289.00-290.00 sec 9.62 MBytes 80.6 Mbits/sec 0.072 ms 21747/28712 (76%)
[ 4] 290.00-291.00 sec 7.66 MBytes 64.2 Mbits/sec 0.085 ms 25770/31314 (82%)
[ 4] 291.00-292.00 sec 6.99 MBytes 58.7 Mbits/sec 0.140 ms 16903/21966 (77%)
[ 4] 292.00-293.00 sec 12.6 MBytes 106 Mbits/sec 0.032 ms 25376/34511 (74%)
[ 4] 293.00-294.00 sec 14.0 MBytes 118 Mbits/sec 0.040 ms 15957/26129 (61%)
[ 4] 294.00-295.00 sec 23.4 MBytes 196 Mbits/sec 0.050 ms 10341/27284 (38%)
[ 4] 295.00-296.00 sec 19.5 MBytes 164 Mbits/sec 0.259 ms 9861/23987 (41%)
[ 4] 296.00-297.00 sec 18.9 MBytes 159 Mbits/sec 0.178 ms 11747/25453 (46%)
[ 4] 297.00-298.00 sec 20.9 MBytes 176 Mbits/sec 0.088 ms 10932/26099 (42%)
[ 4] 298.00-299.00 sec 20.9 MBytes 176 Mbits/sec 0.060 ms 9710/24866 (39%)
[ 4] 299.00-300.00 sec 20.1 MBytes 168 Mbits/sec 0.042 ms 11260/25783 (44%)
[ 4] 300.00-301.00 sec 24.3 MBytes 204 Mbits/sec 0.026 ms 10525/28104 (37%)
[ 4] 301.00-302.00 sec 21.6 MBytes 181 Mbits/sec 0.043 ms 10848/26502 (41%)
[ 4] 302.00-303.00 sec 18.3 MBytes 153 Mbits/sec 0.062 ms 11701/24939 (47%)
[ 4] 303.00-304.00 sec 14.6 MBytes 122 Mbits/sec 0.072 ms 15698/26256 (60%)
[ 4] 304.00-305.00 sec 17.5 MBytes 147 Mbits/sec 0.057 ms 12697/25385 (50%)
inxi -zv8
Kernel: 7.3.0-rc6-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-7.3-x86_64
root=UUID=ca0fb9dc-ae10-46f2-a467-6c788f67cecc rw rootflags=subvol=@
quiet loglevel=3 rd.udev.log_level=3 splash
resume=UUID=a044a1dc-dfd0-493a-b7d8-18cbe3abe8c1 udev.log_priority=3
sysrq_always_enabled=1 zswap.enabled=1
Desktop: KDE Plasma v: 6.7.5 tk: Qt v: N/A info: frameworks v: 6.30.0
wm: kwin_wayland vt: 2 dm: N/A Distro: Manjaro base: Arch Linux
Type: Convertible System: Dell product: XPS 15 9575 v: N/A
serial: <superuser required> Chassis: type: 31 serial: <superuser required>
Mobo: Dell model: 0C32VW v: A00 serial: <superuser required> part-nu: 080D
uuid: <superuser required> Firmware: UEFI vendor: Dell v: 1.28.0
date: 07/11/2023
ID-1: BAT0 charge: 44.4 Wh (100%) condition: 44.4/75 Wh (59.2%) volts: 12.51
min: 11.4 model: BYD DELL TMFYT8C type: Li-poly serial: <filter> charging:
status: full type: trickle avail: adaptive,custom,fast,standard,trickle
cycles: N/A
System RAM: total: 16 GiB available: 15.46 GiB used: 4.17 GiB (27.0%)
Array-1: capacity: 16 GiB slots: 1 modules: 1 EC: None
Device-1: Motherboard type: DDR4 detail: synchronous unbuffered
(unregistered) size: 16 GiB speed: 2400 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: SK Hynix
part-no: HMAA51S6AMR6N-UH serial: N/A
Info: model: Intel Core i7-8705G bits: 64 type: MT MCP arch: Kaby Lake
gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 9 microcode: 0xF8
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 3908 min/max: 800/4100 scaling: driver: intel_pstate
governor: powersave cores: 1: 3908 2: 3908 3: 3908 4: 3908 5: 3908 6: 3908
7: 3908 8: 3908 bogomips: 49599
smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
vulnerable
Device-1: Intel Kaby Lake-H GT2 [HD Graphics 630] vendor: Dell driver: i915
v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
active: eDP-1 empty: DP-1,DP-2,DP-3 bus-ID: 00:02.0 chip-ID: 8086:591b
class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Polaris 22 XL [Radeon RX Vega
M GL] vendor: Dell driver: amdgpu v: kernel arch: GCN-4
code: Arctic Islands process: GF 14nm built: 2016-20 pcie: gen: 3
speed: 8 GT/s lanes: 8 bus-ID: 01:00.0 chip-ID: 1002:694e class-ID: 0380
temp: 51.0 C
Device-3: Realtek Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:2 chip-ID: 0bda:58f4
Display: wayland server: X.org v: 1.21.1.24 with: Xwayland v: 24.1.13
compositor: kwin_wayland driver: X: loaded: amdgpu,modesetting
alternate: fbdev,vesa dri: iris,radeonsi gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: Sharp 0x148d built: 2018 res: mode: 2560x1440
hz: 60 scale: 125% (1.25) to: 2048x1152 dpi: 284 gamma: 1.2 chroma: red:
x: 0.667 y: 0.325 green: x: 0.208 y: 0.737 blue: x: 0.145 y: 0.047 white:
x: 0.318 y: 0.337 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 3840x2160
API: EGL v: 1.5 hw: drv: intel iris drv: amd radeonsi platforms: device: 0
drv: radeonsi device: 1 drv: iris device: 2 drv: swrast gbm: drv: radeonsi
surfaceless: drv: radeonsi wayland: drv: iris x11: drv: iris
API: OpenGL v: 4.6 vendor: intel mesa v: 26.2.4-arch1.1 glx-v: 1.4
direct-render: yes renderer: Mesa Intel HD Graphics 630 (KBL GT2)
device-ID: 8086:591b memory: 15.09 GiB unified: yes display-ID: :0.0
API: Vulkan v: 1.4.363 layers: 13 device: 0 type: integrated-gpu
name: Intel HD Graphics 630 (KBL GT2) driver: mesa intel v: 26.2.4-arch1.1
device-ID: 8086:591b surfaces: N/A device: 1 type: discrete-gpu name: AMD
Radeon RX Vega M GL Graphics (RADV VEGAM) driver: mesa radv
v: 26.2.4-arch1.1 device-ID: 1002:694e surfaces: N/A
de: kscreen-console,kscreen-doctor gpu: amdgpu_top wl: wayland-info
x11: xdpyinfo, xprop, xrandr
Device-1: Intel HM175/QM175/CM238 HD Audio vendor: Dell
driver: snd_hda_intel v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3
chip-ID: 8086:a171 class-ID: 0403
API: ALSA v: k7.3.0-rc6-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.6.9 status: active with: 1: pipewire-pulse
Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Rivet Networks Killer 1435 Wireless-AC driver: ath10k_pci v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:003e
class-ID: 0280 temp: 51.0 C
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-2.2:3
chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp0s20f0u2u2 state: down mac: <filter>
Device-1: Foxconn / Hon Hai driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:4 chip-ID: 0489:e0a2
class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 4.2
lmp-v: 8 status: discoverable: no pairing: no class-ID: 6c0000
Local Storage: total: 1.82 TiB used: 193.64 GiB (10.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT2000T710SSD8
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 126 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: PBCR5103 temp: 39.9 C
scheme: GPT
ID-1: / raw-size: 1.8 TiB size: 1.8 TiB (100.00%) used: 193.64 GiB (10.5%)
fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3 label: Manjaro
uuid: ca0fb9dc-ae10-46f2-a467-6c788f67cecc
used: 720 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: EFI
uuid: FF0B-6823
ID-3: /home raw-size: 1.8 TiB size: 1.8 TiB (100.00%)
used: 193.64 GiB (10.5%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
label: Manjaro uuid: ca0fb9dc-ae10-46f2-a467-6c788f67cecc
ID-4: /home/<filter>/mnt/Dropbox raw-size: N/A size: 2.01 TiB
used: 340.94 GiB (16.6%) fs: fuse.rclone remote: Dropbox:
ID-5: /home/<filter>/mnt/GDrive raw-size: N/A size: 102 GiB
used: 86.71 GiB (85.0%) fs: fuse.rclone remote: GDrive:
ID-6: /home/<filter>/mnt/OneDrive raw-size: N/A size: 205 GiB
used: 145.3 GiB (70.9%) fs: fuse.rclone remote: OneDrive:
ID-7: /var/cache raw-size: 1.8 TiB size: 1.8 TiB (100.00%)
ID-8: /var/log raw-size: 1.8 TiB size: 1.8 TiB (100.00%)
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default) zswap: yes
ID-1: swap-1 type: partition size: 17.58 GiB used: 0 KiB (0.0%)
priority: -1 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: a044a1dc-dfd0-493a-b7d8-18cbe3abe8c1
Device-1: 1-1:2 info: Realtek Integrated_Webcam_HD type: video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 0bda:58f4 class-ID: 0e02
serial: <filter>
Hub-2: 1-2:3 info: VIA Labs VL820 Hub ports: 5 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2820
Device-1: 1-2.1:6 info: Bizlink DELL DA300 type: HID
lanes: 1 mode: 1.1 power: 100mA chip-ID: 06c4:c412 class-ID: 0300
serial: <filter>
Device-2: 1-2.3:8 info: Lite-On USB Multimedia Keyboard type: keyboard,HID
chip-ID: 04ca:0027 class-ID: 0300
Device-3: 1-6:4 info: Foxconn / Hon Hai type: bluetooth driver: btusb
interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 100mA chip-ID: 0489:e0a2 class-ID: e001
Device-4: 1-10:9 info: Shenzhen Goodix Fingerprint Reader
type: abstract (modem),CDC-data driver: N/A interfaces: 2 rev: 2.0
chip-ID: 27c6:5395 class-ID: 0a00 serial: <filter>
Device-5: 1-11:7 info: Logitech G502 Mouse type: mouse,HID
lanes: 1 mode: 1.1 power: 300mA chip-ID: 046d:c07d class-ID: 0300
serial: <filter>
Hub-3: 2-0:1 info: super-speed hub ports: 8 rev: 3.0
Hub-4: 2-2:2 info: VIA Labs VL820 Hub ports: 4 rev: 3.1
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0820
Device-1: 2-2.2:3 info: Realtek RTL8153 Gigabit Ethernet Adapter
type: Network driver: r8152 interfaces: 1 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 288mA
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 51.0 C
Fan Speeds (rpm): N/A
Packages: 1819 pm: pacman pkgs: 1812 libs: 454 tools: pamac,yay pm: flatpak
pkgs: 7
1: https://muug.ca/mirror/manjaro/testing/$repo/$arch
2: https://ohioix.mm.fcix.net/manjaro/testing/$repo/$arch
3: https://mirror.math.princeton.edu/pub/manjaro/testing/$repo/$arch
4: https://ftp.linux.org.tr/manjaro/testing/$repo/$arch
5: https://mirror.telepoint.bg/manjaro/testing/$repo/$arch
Processes:
CPU top: 5 of 299
1: cpu: 100% command: ps pid: 14583 mem: 3.80 MiB (0.0%)
2: cpu: 10.0% command: librewolf pid: 9301 mem: 788.2 MiB (4.9%)
3: cpu: 3.7% command: librewolf pid: 11878 mem: 433.3 MiB (2.7%)
4: cpu: 3.3% command: librewolf pid: 9534 mem: 92.8 MiB (0.5%)
5: cpu: 1.8% command: librewolf pid: 9570 mem: 286.0 MiB (1.8%)
Memory top: 5 of 299
1: mem: 788.2 MiB (4.9%) command: librewolf pid: 9301 cpu: 10.0%
2: mem: 502.0 MiB (3.1%) command: librewolf pid: 9850 cpu: 1.4%
3: mem: 433.3 MiB (2.7%) command: librewolf pid: 11878 cpu: 3.7%
4: mem: 381.0 MiB (2.4%) command: plasmashell pid: 3369 cpu: 0.0%
5: mem: 367.2 MiB (2.3%) command: librewolf pid: 9592 cpu: 0.3%
Processes: 299 Power: uptime: 10h 27m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 1 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 6.14 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 261 default: graphical
tool: systemctl
Compilers: clang: 23.1.1 gcc: 16.2.1 Shell: Zsh v: 5.9.2
running-in: konsole inxi: 3.3.41
EDIT 11 Oct 2026: I found an old installation I had on a USB stick running the 6.19 kernel and that installation does not have the issue, so it is a change that has occurred since then. Will do some more testing to try an narrow it down.
Edit 14 Oct 2026: I have narrowed the culprit down to wpa_supplicant. Specifically version 2.11 works normally, and 2.12 has the issue explained above. There are build differences in the Arch package so I’m first working through those and then will bisect the source changes if the package changes aren’t implicated.
Edit 16 Oct 2026: I’ve narrowed it down to CONFIG_NAN_USD inclusion in the Arch package. Testing against all other package option changes isolated CONFIG_NAN_USD.
