Wifi on X96 Max+
Thanks to the Manjaro Team. Finally I am successfully installed Manjaro Arm 20.06 in my X96 Max+ android box. I used the meson-g12a-x96-max-rmii.dtb then fixed the Green Screen Issue by changing "u-boot.sd" to "u-boot.ext" from BOOT_MNJRO partition. It runs smoothly even when I open multiple applications just like in the picture. Every apps run smoothly except for Blender, which is very laggy.
To be honest I was a stranger in the Linux World one year ago, until I met Linux Mint and switched to it for my daily driver. Then I learnt more and more about linux until I found Manjaro and fell in love in the first sight. Therefore I struggled to install it in my lovely android box as a test and it works with several notes:
  1. I want to report that Flatpak works perfectly, in fact I managed to Install DarkTable and Draw.io via flatpak because they are not in the official store.
  2. Snap store can be installed, but the moment you open it you will find a missing fonts. To fix this just delete the fonts cache and you are good to go (in Arch Forum). However, when you try to install apps via CLI in the terminal, you will find that you cannot install Snap Store Apps because they are basically for X86 and amd64 Architecture, not for Arm Architecture.
  3. No Audio at the moment both in HDMI and Audio Jack
  4. No 3D acceleration (Therefore Blender and Simple Screen Recorder are pretty Laggy, but most apps like GIMP, Krita, Inkscape, QGIS, Kdenlive, DarkTable, RawTherapee, Audacity, QCAD, VLC, Youtube from browser, etc run smoothly)
  5. No Wifi (Even though I tried using a USB wifi dongle, it is detected but does not work)
  6. Ethernet works perfectly (I tried to use tethering via USB phone, it also works perfectly)
  7. No Infrared (Therefore when you want to shutdown and start booting to Manjaro, you have to unplug and re-plug the adaptor to the cord. In Comparison, when I used android I can switch on and off easily via Infrared Remote)
  8. Printer does not works, even I couldn't find out how Manjaro Arm will detect my L120 Epson Printer.
That's all my own notes for Manjaro Arm in X96 Max+ Android Box. Should anyone find the fix please let me know. I will try to digest this new information and transform my X96 Max+ into a mini computer. At least that is my goal. Thank you very much for your Great Support!
It was a very nice experience to be able to run a cutting edge GNU/Linux in a mini computer.
Many Thanks,
rna
These two issues are general issues we have with the G12X boards right now. :slight_smile: But glad you find it's mostly working.
Thanks for your confirmation :slightly_smiling_face:
What about wifi? is there any possible Fix?
You are probably missing the firmware for the wifi chip in the board.
Once you find/install that, you should have wifi on next boot.
how to install it?
I have no idea what chipset it uses or what firmware it's looking for. But you can try installing linux-firmware if it's not installed already. That might bring in some of it.
Is there anyway to detect the wifi chipset in terminal in Manjaro Arm?
dmesg might reveal what firmware it tries to load. :slight_smile:
[rna@rna ~]$ dmesg
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd050]
[    0.000000] Linux version 5.7.0-0.3-MANJARO-ARM (spikerguy@Manjaro) (gcc version 9.2.0 (GCC), GNU ld (GNU Binutils) 2.33.1) #1 SMP PREEMPT Sun May 3 18:51:08 +03 2020
[    0.000000] Machine model: Shenzhen Amediatech Technology Co., Ltd X96 Max
[    0.000000] efi: UEFI not found.
[    0.000000] Reserved memory: created CMA memory pool at 0x00000000bd800000, size 768 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] On node 0 totalpages: 972032
[    0.000000]   DMA zone: 4096 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 261376 pages, LIFO batch:63
[    0.000000]   DMA32 zone: 11104 pages used for memmap
[    0.000000]   DMA32 zone: 710656 pages, LIFO batch:63
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.1
[    0.000000] percpu: Embedded 22 pages/cpu s52120 r8192 d29800 u90112
[    0.000000] pcpu-alloc: s52120 r8192 d29800 u90112 alloc=22*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: detected: ARM errata 1165522, 1530923
[    0.000000] alternatives: patching kernel code
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 956832
[    0.000000] Kernel command line: root=LABEL=ROOT_MNJRO rootflags=data=writeback rw console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 bootsplash.bootfile=bootsplash-themes/manjaro/bootsplash
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x39086000-0x3d086000] (64MB)
[    0.000000] Memory: 2921480K/3888128K available (16316K kernel code, 1480K rwdata, 6668K rodata, 1088K init, 946K bss, 180216K reserved, 786432K cma-reserved)
[    0.000000] random: get_random_u64 called from cache_random_seq_create+0x80/0x150 with crng_init=0
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    0.000000] 	Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000003] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000217] Console: colour dummy device 80x25
[    0.000567] printk: console [tty0] enabled
[    0.000609] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.000632] pid_max: default: 32768 minimum: 301
[    0.000789] LSM: Security Framework initializing
[    0.000856] SELinux:  Initializing.
[    0.001019] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.001047] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.002558] rcu: Hierarchical SRCU implementation.
[    0.005313] EFI services will not be available.
[    0.005652] smp: Bringing up secondary CPUs ...
[    0.006450] Detected VIPT I-cache on CPU1
[    0.006508] CPU1: Booted secondary processor 0x0000000100 [0x411fd050]
[    0.007328] Detected VIPT I-cache on CPU2
[    0.007367] CPU2: Booted secondary processor 0x0000000200 [0x411fd050]
[    0.008132] Detected VIPT I-cache on CPU3
[    0.008168] CPU3: Booted secondary processor 0x0000000300 [0x411fd050]
[    0.008242] smp: Brought up 1 node, 4 CPUs
[    0.008309] SMP: Total of 4 processors activated.
[    0.008319] CPU features: detected: Privileged Access Never
[    0.008330] CPU features: detected: LSE atomic instructions
[    0.008343] CPU features: detected: User Access Override
[    0.008355] CPU features: detected: 32-bit EL0 Support
[    0.008366] CPU features: detected: Common not Private translations
[    0.008379] CPU features: detected: RAS Extension Support
[    0.008390] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    0.008406] CPU features: detected: CRC32 instructions
[    0.039551] CPU: All CPU(s) started at EL2
[    0.041918] devtmpfs: initialized
[    0.055542] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.055582] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.071416] xor: measuring software checksum speed
[    0.170665]    8regs     :  2242.000 MB/sec
[    0.270692]    32regs    :  2833.200 MB/sec
[    0.370732]    arm64_neon:  2483.200 MB/sec
[    0.370744] xor: using function: 32regs (2833.200 MB/sec)
[    0.370806] pinctrl core: initialized pinctrl subsystem
[    0.371575] thermal_sys: Registered thermal governor 'step_wise'
[    0.372274] DMI not present or invalid.
[    0.372756] NET: Registered protocol family 16
[    0.374188] DMA: preallocated 256 KiB pool for atomic allocations
[    0.374222] audit: initializing netlink subsys (disabled)
[    0.374388] audit: type=2000 audit(0.370:1): state=initialized audit_enabled=0 res=1
[    0.376004] cpuidle: using governor ladder
[    0.376040] cpuidle: using governor menu
[    0.376347] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.376458] ASID allocator initialised with 65536 entries
[    0.377701] Serial: AMBA PL011 UART driver
[    0.396343] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.396371] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.396385] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.396399] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.401496] cryptd: max_cpu_qlen set to 1000
[    0.570869] raid6: neonx8   gen()  2133 MB/s
[    0.740921] raid6: neonx8   xor()  1658 MB/s
[    0.910978] raid6: neonx4   gen()  2193 MB/s
[    1.081035] raid6: neonx4   xor()  1650 MB/s
[    1.251126] raid6: neonx2   gen()  2082 MB/s
[    1.421156] raid6: neonx2   xor()  1509 MB/s
[    1.591221] raid6: neonx1   gen()  1789 MB/s
[    1.761264] raid6: neonx1   xor()  1281 MB/s
[    1.931324] raid6: int64x8  gen()  1524 MB/s
[    2.101398] raid6: int64x8  xor()   784 MB/s
[    2.271443] raid6: int64x4  gen()  1649 MB/s
[    2.441494] raid6: int64x4  xor()   840 MB/s
[    2.611556] raid6: int64x2  gen()  1480 MB/s
[    2.781602] raid6: int64x2  xor()   742 MB/s
[    2.951656] raid6: int64x1  gen()  1120 MB/s
[    3.121710] raid6: int64x1  xor()   581 MB/s
[    3.121721] raid6: using algorithm neonx4 gen() 2193 MB/s
[    3.121734] raid6: .... xor() 1650 MB/s, rmw enabled
[    3.121745] raid6: using neon recovery algorithm
[    3.121972] ACPI: Interpreter disabled.
[    3.123872] VDDAO_3V3: supplied by DC_IN
[    3.124330] iommu: Default domain type: Translated
[    3.124608] vgaarb: loaded
[    3.125104] SCSI subsystem initialized
[    3.125290] libata version 3.00 loaded.
[    3.125537] usbcore: registered new interface driver usbfs
[    3.125594] usbcore: registered new interface driver hub
[    3.125674] usbcore: registered new device driver usb
[    3.126100] pps_core: LinuxPPS API ver. 1 registered
[    3.126117] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    3.126144] PTP clock support registered
[    3.126175] EDAC MC: Ver: 3.0.0
[    3.126840] FPGA manager framework
[    3.126938] Advanced Linux Sound Architecture Driver Initialized.
[    3.127506] NetLabel: Initializing
[    3.127518] NetLabel:  domain hash size = 128
[    3.127529] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    3.127586] NetLabel:  unlabeled traffic allowed by default
[    3.127998] clocksource: Switched to clocksource arch_sys_counter
[    3.128255] VFS: Disk quotas dquot_6.6.0
[    3.128322] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    3.128435] FS-Cache: Loaded
[    3.128831] pnp: PnP ACPI: disabled
[    3.136042] NET: Registered protocol family 2
[    3.136552] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    3.136605] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    3.136799] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[    3.137188] TCP: Hash tables configured (established 32768 bind 32768)
[    3.137318] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    3.137390] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    3.137621] NET: Registered protocol family 1
[    3.138125] RPC: Registered named UNIX socket transport module.
[    3.138140] RPC: Registered udp transport module.
[    3.138152] RPC: Registered tcp transport module.
[    3.138163] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    3.138183] PCI: CLS 0 bytes, default 64
[    3.138390] Trying to unpack rootfs image as initramfs...
[    3.410674] Freeing initrd memory: 7652K
[    3.411666] kvm [1]: IPA Size Limit: 40bits
[    3.411805] kvm [1]: vgic interrupt IRQ1
[    3.411940] kvm [1]: VHE mode initialized successfully
[    3.651150] Initialise system trusted keyrings
[    3.651332] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[    3.658672] zbud: loaded
[    3.660230] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    3.660592] FS-Cache: Netfs 'nfs' registered for caching
[    3.661275] NFS: Registering the id_resolver key type
[    3.661313] Key type id_resolver registered
[    3.661327] Key type id_legacy registered
[    3.661345] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    3.661358] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    3.662618] FS-Cache: Netfs 'cifs' registered for caching
[    3.662957] Key type cifs.spnego registered
[    3.662978] Key type cifs.idmap registered
[    3.662996] ntfs: driver 2.1.32 [Flags: R/W].
[    3.663679] JFS: nTxBlock = 8192, nTxLock = 65536
[    3.668430] SGI XFS with ACLs, security attributes, realtime, quota, no debug enabled
[    3.670340] ocfs2: Registered cluster interface o2cb
[    3.670536] OCFS2 User DLM kernel interface loaded
[    3.672224] gfs2: GFS2 installed
[    3.690376] Key type asymmetric registered
[    3.690404] Asymmetric key parser 'x509' registered
[    3.690414] Asymmetric key parser 'pkcs8' registered
[    3.690480] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    3.690670] io scheduler mq-deadline registered
[    3.690684] io scheduler kyber registered
[    3.690893] io scheduler bfq registered
[    3.706857] soc soc0: Amlogic Meson SM1 (Unknown) Revision 2b:c (10:2) Detected
[    3.708402] pwm-regulator: supplied by regulator-dummy
[    3.708679] VCC_3V3: supplied by VDDAO_3V3
[    3.708757] FLASH_1V8: supplied by VCC_3V3
[    3.708819] VCC_1V8: supplied by VCC_3V3
[    3.708881] VDDAO_1V8: supplied by VDDAO_3V3
[    3.712746] Serial: 8250/16550 driver, 5 ports, IRQ sharing enabled
[    3.714755] Serial: AMBA driver
[    3.715193] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 14, base_baud = 1500000) is a meson_uart
[    4.713786] printk: console [ttyAML0] enabled
[    4.718798] ffd24000.serial: ttyAML6 at MMIO 0xffd24000 (irq = 19, base_baud = 1500000) is a meson_uart
[    4.727513] serial serial0: tty port ttyAML6 registered
[    4.737371] panfrost ffe40000.gpu: clock rate = 799999987
[    4.737931] panfrost ffe40000.gpu: supply mali not found, using dummy regulator
[    4.745358] panfrost ffe40000.gpu: mali-g31 id 0x7093 major 0x0 minor 0x0 status 0x0
[    4.752844] panfrost ffe40000.gpu: features: 00000000,3fde77ff, issues: 00000000,00000400
[    4.760952] panfrost ffe40000.gpu: Features: L2:0x07100206 Shader:0x00000000 Tiler:0x00000209 Mem:0x1 MMU:0x00002821 AS:0xff JS:0x7
[    4.772668] panfrost ffe40000.gpu: shader_present=0x1 l2_present=0x1
[    4.780195] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 0
[    4.794235] brd: module loaded
[    4.802483] loop: module loaded
[    4.805663] libphy: Fixed MDIO Bus: probed
[    4.807729] VFIO - User Level meta-driver version: 0.3
[    4.810741] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    4.815710] ehci-pci: EHCI PCI platform driver
[    4.820173] ehci-platform: EHCI generic platform driver
[    4.825413] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    4.831420] ohci-pci: OHCI PCI platform driver
[    4.835837] ohci-platform: OHCI generic platform driver
[    4.841436] usbcore: registered new interface driver usb-storage
[    4.847147] mousedev: PS/2 mouse device common for all mice
[    4.853137] i2c /dev entries driver
[    4.862326] sdhci: Secure Digital Host Controller Interface driver
[    4.862875] sdhci: Copyright(c) Pierre Ossman
[    4.867203] Synopsys Designware Multimedia Card Interface Driver
[    4.874063] meson-gx-mmc ffe03000.sd: allocated mmc-pwrseq
[    4.905105] meson-gx-mmc ffe05000.sd: Got CD GPIO
[    4.912020] meson-gx-mmc ffe03000.sd: card claims to support voltages below defined range
[    4.931947] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq
[    4.948329] mmc0: new ultra high speed SDR50 SDIO card at address 0001
[    4.960503] sdhci-pltfm: SDHCI platform and OF driver helper
[    4.961791] ledtrig-cpu: registered to indicate activity on CPUs
[    4.967059] meson-sm: secure-monitor enabled
[    4.971177] hid: raw HID events driver (C) Jiri Kosina
[    4.972862] mmc1: new high speed SDHC card at address e624
[    4.976101] usbcore: registered new interface driver usbhid
[    4.982187] mmcblk1: mmc1:e624 SC32G 29.7 GiB
[    4.986782] usbhid: USB HID core driver
[    4.995503]  mmcblk1: p1 p2
[    5.000746] Initializing XFRM netlink socket
[    5.002466] NET: Registered protocol family 10
[    5.028259] Segment Routing with IPv6
[    5.028832] NET: Registered protocol family 17
[    5.031798] Key type dns_resolver registered
[    5.035369] registered taskstats version 1
[    5.039011] Loading compiled-in X.509 certificates
[    5.043854] zswap: loaded using pool lzo/zbud
[    5.048431] Key type ._fscrypt registered
[    5.052842] Key type .fscrypt registered
[    5.055893] Key type fscrypt-provisioning registered
[    5.061769] Btrfs loaded, crc32c=crc32c-generic
[    5.078087] Key type encrypted registered
[    5.097166] VCC_5V: supplied by DC_IN
[    5.176811] meson-drm ff900000.vpu: Queued 3 outputs on vpu
[    5.177029] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    5.189301] mmc2: new high speed MMC card at address 0001
[    5.189879] mmcblk2: mmc2:0001 064G30 58.2 GiB
[    5.193814] mmcblk2boot0: mmc2:0001 064G30 partition 1 4.00 MiB
[    5.199719] mmcblk2boot1: mmc2:0001 064G30 partition 2 4.00 MiB
[    5.206245] mmcblk2rpmb: mmc2:0001 064G30 partition 3 4.00 MiB, chardev (243:0)
[    5.218091] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[    5.222704] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[    5.230867] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops)
[    5.238016] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 1
[    5.281567] random: fast init done
[    5.368399] [drm] kms: can't enable cloning when we probably wanted to.
[    5.550641] meson-dw-hdmi ff600000.hdmi-tx: HDMI infoframe: Auxiliary Video Information (AVI), version 2, length 13
[    5.550699] meson-dw-hdmi ff600000.hdmi-tx:     colorspace: YCbCr 4:2:2
[    5.550741] meson-dw-hdmi ff600000.hdmi-tx:     scan mode: Underscan
[    5.550784] meson-dw-hdmi ff600000.hdmi-tx:     colorimetry: ITU709
[    5.550826] meson-dw-hdmi ff600000.hdmi-tx:     picture aspect: 16:9
[    5.550870] meson-dw-hdmi ff600000.hdmi-tx:     active aspect: Same as Picture
[    5.550909] meson-dw-hdmi ff600000.hdmi-tx:     itc: No Data
[    5.550950] meson-dw-hdmi ff600000.hdmi-tx:     extended colorimetry: xvYCC 709
[    5.550992] meson-dw-hdmi ff600000.hdmi-tx:     quantization range: Default
[    5.551033] meson-dw-hdmi ff600000.hdmi-tx:     nups: Unknown Non-uniform Scaling
[    5.551076] meson-dw-hdmi ff600000.hdmi-tx:     video code: 16
[    5.551118] meson-dw-hdmi ff600000.hdmi-tx:     ycc quantization range: Limited
[    5.551158] meson-dw-hdmi ff600000.hdmi-tx:     hdmi content type: Graphics
[    5.551200] meson-dw-hdmi ff600000.hdmi-tx:     pixel repeat: 0
[    5.551249] meson-dw-hdmi ff600000.hdmi-tx:     bar top 0, bottom 0, left 0, right 0
[    5.551354] meson-dw-hdmi ff600000.hdmi-tx: HDMI infoframe: Source Product Description (SPD), version 1, length 25
[    5.551394] meson-dw-hdmi ff600000.hdmi-tx:     vendor: DW
[    5.551434] meson-dw-hdmi ff600000.hdmi-tx:     product: HDMI
[    5.551482] meson-dw-hdmi ff600000.hdmi-tx:     source device information: PC General (0x9)
[    5.609881] Console: switching to colour frame buffer device 240x67
[    5.765546] meson-drm ff900000.vpu: fb0: mesondrmfb frame buffer device
[    5.772885] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found
[    5.778670] meson8b-dwmac ff3f0000.ethernet: IRQ eth_lpi not found
[    5.784907] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock
[    5.790743] meson8b-dwmac ff3f0000.ethernet: no reset control found
[    5.797877] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37
[    5.804040] meson8b-dwmac ff3f0000.ethernet: 	DWMAC1000
[    5.809194] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported
[    5.816602] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported
[    5.824031] meson8b-dwmac ff3f0000.ethernet: COE Type 2
[    5.829202] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported
[    5.836183] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported
[    5.842601] meson8b-dwmac ff3f0000.ethernet: Normal descriptors
[    5.848438] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled
[    5.854210] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    5.862438] libphy: stmmac: probed
[    5.866605] dwc3-meson-g12a ffe09000.usb: USB2 ports: 2
[    5.870712] dwc3-meson-g12a ffe09000.usb: USB3 ports: 1
[    5.878712] dwc2 ff400000.usb: supply vusb_d not found, using dummy regulator
[    5.882993] dwc2 ff400000.usb: supply vusb_a not found, using dummy regulator
[    5.890183] dwc2 ff400000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM
[    5.897977] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[    5.902460] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 1
[    5.910141] xhci-hcd xhci-hcd.3.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x0000000000010010
[    5.919373] xhci-hcd xhci-hcd.3.auto: irq 28, io mem 0xff500000
[    5.925432] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.07
[    5.933397] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.940560] usb usb1: Product: xHCI Host Controller
[    5.945373] usb usb1: Manufacturer: Linux 5.7.0-0.3-MANJARO-ARM xhci-hcd
[    5.952030] usb usb1: SerialNumber: xhci-hcd.3.auto
[    5.957216] hub 1-0:1.0: USB hub found
[    5.960594] hub 1-0:1.0: 2 ports detected
[    5.964757] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[    5.969983] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 2
[    5.977559] xhci-hcd xhci-hcd.3.auto: Host supports USB 3.0 SuperSpeed
[    5.984071] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    5.992110] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.07
[    6.000246] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.007393] usb usb2: Product: xHCI Host Controller
[    6.012227] usb usb2: Manufacturer: Linux 5.7.0-0.3-MANJARO-ARM xhci-hcd
[    6.018872] usb usb2: SerialNumber: xhci-hcd.3.auto
[    6.024014] hub 2-0:1.0: USB hub found
[    6.027415] hub 2-0:1.0: 1 port detected
[    6.034673] printk: console [netcon0] enabled
[    6.037488] netconsole: network logging started
[    6.041195] ALSA device list:
[    6.044132]   No soundcards found.
[    6.047350] Freeing unused kernel memory: 1088K
[    6.078063] Run /init as init process
[    6.110272]   with arguments:
[    6.110276]     /init
[    6.110277]   with environment:
[    6.110279]     HOME=/
[    6.110281]     TERM=linux
[    6.408088] usb 1-1: new full-speed USB device number 2 using xhci-hcd
[    6.591116] usb 1-1: New USB device found, idVendor=4147, idProduct=2800, bcdDevice= 2.00
[    6.614100] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    6.636024] usb 1-1: Product: 2.4G Composite Devic
[    6.686407] input: 2.4G Composite Devic as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.3.auto/usb1/1-1/1-1:1.0/0003:4147:2800.0001/input/input0
[    6.793550] hid-generic 0003:4147:2800.0001: input,hidraw0: USB HID v1.10 Keyboard [2.4G Composite Devic] on usb-xhci-hcd.3.auto-1/input0
[    6.867928] input: 2.4G Composite Devic Mouse as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.3.auto/usb1/1-1/1-1:1.1/0003:4147:2800.0002/input/input1
[    6.880489] input: 2.4G Composite Devic Consumer Control as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.3.auto/usb1/1-1/1-1:1.1/0003:4147:2800.0002/input/input2
[    6.958260] input: 2.4G Composite Devic System Control as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.3.auto/usb1/1-1/1-1:1.1/0003:4147:2800.0002/input/input3
[    6.971886] hid-generic 0003:4147:2800.0002: input,hidraw1: USB HID v1.10 Mouse [2.4G Composite Devic] on usb-xhci-hcd.3.auto-1/input1
[    7.305116] EXT4-fs (mmcblk1p2): mounted filesystem with writeback data mode. Opts: data=writeback
[    8.074608] systemd[1]: System time before build time, advancing clock.
[    8.200823] systemd[1]: systemd 245.6-6-arch running in system mode. (+PAM +AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[    8.229210] systemd[1]: Detected architecture arm64.
[    8.314275] systemd[1]: Set hostname to <rna>.
[    9.709019] systemd[1]: Configuration file /usr/lib/systemd/system/sound.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[    9.727410] systemd[1]: Configuration file /usr/lib/systemd/system/khadas-utils.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[    9.819580] systemd[1]: Configuration file /usr/lib/systemd/system/bluetooth-khadas.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[    9.844124] random: systemd: uninitialized urandom read (16 bytes read)
[    9.853459] systemd[1]: Created slice system-getty.slice.
[    9.864401] random: systemd: uninitialized urandom read (16 bytes read)
[    9.871658] systemd[1]: Created slice system-modprobe.slice.
[    9.882766] random: systemd: uninitialized urandom read (16 bytes read)
[    9.889365] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    9.900972] systemd[1]: Created slice User and Session Slice.
[    9.910514] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    9.922334] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    9.934361] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    9.947722] systemd[1]: Reached target Local Encrypted Volumes.
[    9.957908] systemd[1]: Reached target Paths.
[    9.967607] systemd[1]: Reached target Remote Encrypted Volumes.
[    9.977538] systemd[1]: Reached target Remote File Systems.
[    9.987320] systemd[1]: Reached target Slices.
[    9.997154] systemd[1]: Reached target Swap.
[   10.007138] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[   10.020680] systemd[1]: Listening on LVM2 metadata daemon socket.
[   10.034373] systemd[1]: Listening on LVM2 poll daemon socket.
[   10.054449] systemd[1]: Listening on Process Core Dump Socket.
[   10.067931] systemd[1]: Listening on initctl Compatibility Named Pipe.
[   10.080424] systemd[1]: Listening on Journal Audit Socket.
[   10.092177] systemd[1]: Listening on Journal Socket (/dev/log).
[   10.103130] systemd[1]: Listening on Journal Socket.
[   10.114055] systemd[1]: Listening on Network Service Netlink Socket.
[   10.125043] systemd[1]: Listening on udev Control Socket.
[   10.134972] systemd[1]: Listening on udev Kernel Socket.
[   10.144773] systemd[1]: Listening on User Database Manager Socket.
[   10.158204] systemd[1]: Mounting Huge Pages File System...
[   10.171118] systemd[1]: Mounting POSIX Message Queue File System...
[   10.184494] systemd[1]: Mounting Kernel Debug File System...
[   10.193909] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
[   10.206893] systemd[1]: Mounting Temporary Directory (/tmp)...
[   10.217508] systemd[1]: Condition check resulted in Load AppArmor profiles being skipped.
[   10.229081] systemd[1]: Starting Create list of static device nodes for the current kernel...
[   10.244915] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[   10.258693] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[   10.265449] systemd[1]: Condition check resulted in Load AppArmor profiles managed internally by snapd being skipped.
[   10.309696] systemd[1]: Starting Set Up Additional Binary Formats...
[   10.349600] systemd[1]: Starting Load Kernel Modules...
[   10.366885] systemd[1]: Starting Remount Root and Kernel File Systems...
[   10.384839] systemd[1]: Starting Repartition Root Disk...
[   10.397320] systemd[1]: Starting udev Coldplug all Devices...
[   10.410645] systemd[1]: Mounted Huge Pages File System.
[   10.420458] systemd[1]: Mounted POSIX Message Queue File System.
[   10.430392] systemd[1]: Mounted Kernel Debug File System.
[   10.440086] systemd[1]: Mounted Temporary Directory (/tmp).
[   10.450678] systemd[1]: Finished Create list of static device nodes for the current kernel.
[   10.464534] systemd[1]: Finished Load Kernel Modules.
[   10.475431] systemd[1]: Finished Remount Root and Kernel File Systems.
[   10.487431] systemd[1]: Finished Repartition Root Disk.
[   10.497063] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 423 (systemd-binfmt)
[   10.512796] systemd[1]: Mounting Arbitrary Executable File Formats File System...
[   10.525022] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[   10.535642] systemd[1]: Mounting Kernel Configuration File System...
[   10.562256] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[   10.570649] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[   10.592997] systemd[1]: Starting Load/Save Random Seed...
[   10.606025] systemd[1]: Starting Apply Kernel Variables...
[   10.616014] systemd[1]: Condition check resulted in Create System Users being skipped.
[   10.626725] systemd[1]: Starting Create Static Device Nodes in /dev...
[   10.642613] systemd[1]: Mounted Arbitrary Executable File Formats File System.
[   10.655936] systemd[1]: Mounted Kernel Configuration File System.
[   10.668163] systemd[1]: Finished Set Up Additional Binary Formats.
[   10.680391] systemd[1]: Finished Apply Kernel Variables.
[   10.692413] systemd[1]: Finished Create Static Device Nodes in /dev.
[   10.707143] systemd[1]: Started Entropy Daemon based on the HAVEGE algorithm.
[   10.723531] systemd[1]: Starting Journal Service...
[   10.736769] systemd[1]: Starting udev Kernel Device Manager...
[   10.796847] systemd[1]: Finished udev Coldplug all Devices.
[   11.295401] systemd[1]: Started Journal Service.
[   11.305168] audit: type=1130 audit(1591903808.220:2): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   11.363611] systemd-journald[437]: Received client request to flush runtime journal.
[   11.366717] random: crng init done
[   11.374930] random: 7 urandom warning(s) missed due to ratelimiting
[   11.389711] audit: type=1130 audit(1591903808.310:3): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   11.417731] audit: type=1130 audit(1591903808.330:4): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   11.545218] audit: type=1130 audit(1591903808.460:5): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   11.573636] audit: type=1130 audit(1591903808.490:6): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=lvm2-lvmetad comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   12.027216] libphy: mdio_mux: probed
[   12.033548] mc: Linux media interface: v0.10
[   12.153613] videodev: Linux video capture interface: v2.00
[   12.178244] debugfs: Directory 'ff800280.cec' with parent 'regmap' already present!
[   12.202057] axg-sound-card sound: snd-soc-dummy-dai <-> ff6421c0.audio-controller mapping ok
[   12.211163] libphy: mdio_mux: probed
[   12.217128] meson-vrtc ff8000a8.rtc: registered as rtc0
[   12.226082] meson-vrtc ff8000a8.rtc: setting system clock to 1970-01-01T00:00:12 UTC (12)
[   12.275992] axg-sound-card sound: snd-soc-dummy-dai <-> ff642200.audio-controller mapping ok
[   12.288720] axg-sound-card sound: snd-soc-dummy-dai <-> ff642240.audio-controller mapping ok
[   12.289666] Registered IR keymap rc-x96max
[   12.298504] axg-sound-card sound: I2S IN B <-> TDM Pad mapping ok
[   12.309643] axg-sound-card sound: snd-soc-dummy-dai <-> TDM Loopback mapping ok
[   12.317157] axg-sound-card sound: multicodec <-> ff642480.audio-controller mapping ok
[   12.325684] axg-sound-card sound: SPDIF IN B <-> ff642680.audio-controller mapping ok
[   12.333553] axg-sound-card sound: i2s-hifi <-> I2S OUT mapping ok
[   12.340160] axg-sound-card sound: ASoC: no DMI vendor name!
[   12.365882] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
[   12.375744] IR NEC protocol handler initialized
[   12.418692] rc rc0: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0
[   12.430685] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
[   12.446812] input: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input4
[   12.471566] audit: type=1130 audit(12.740:7): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=systemd-networkd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   12.509467] meson-ir ff808000.ir: receiver initialized
[   12.650626] Bluetooth: Core ver 2.22
[   12.656507] NET: Registered protocol family 31
[   12.662510] Bluetooth: HCI device and connection manager initialized
[   12.668635] Bluetooth: HCI socket layer initialized
[   12.673991] Bluetooth: L2CAP socket layer initialized
[   12.679757] Bluetooth: SCO socket layer initialized
[   12.744096] audit: type=1130 audit(13.010:8): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   12.799119] Bluetooth: HCI UART driver ver 2.3
[   12.799127] Bluetooth: HCI UART protocol H4 registered
[   12.799130] Bluetooth: HCI UART protocol BCSP registered
[   12.799196] Bluetooth: HCI UART protocol LL registered
[   12.799199] Bluetooth: HCI UART protocol ATH3K registered
[   12.799240] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   12.799541] Bluetooth: HCI UART protocol Intel registered
[   12.799792] Bluetooth: HCI UART protocol Broadcom registered
[   12.799834] Bluetooth: HCI UART protocol QCA registered
[   12.799837] Bluetooth: HCI UART protocol AG6XX registered
[   12.799872] Bluetooth: HCI UART protocol Marvell registered
[   12.799953] hci_uart_bcm serial0-0: supply vbat not found, using dummy regulator
[   12.800041] hci_uart_bcm serial0-0: supply vddio not found, using dummy regulator
[   13.005312] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[   13.127683] audit: type=1130 audit(13.390:9): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   13.490696] audit: type=1130 audit(13.760:10): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   13.562866] audit: type=1127 audit(13.830:11): pid=553 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
[   14.590736] zram: Added device: zram0
[   14.636854] zram0: detected capacity change from 0 to 5708779520
[   14.758791] Adding 5574976k swap on /dev/zram0.  Priority:100 extents:1 across:5574976k SSFS
[   14.912181] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   14.916041] Bluetooth: BNEP filters: protocol multicast
[   14.920955] Bluetooth: BNEP socket layer initialized
[   15.118070] Bluetooth: hci0: command 0xfc18 tx timeout
[   15.843950] [drm] kms: can't enable cloning when we probably wanted to.
[   16.278406] meson8b-dwmac ff3f0000.ethernet eth0: validation of rmii with support 000,00000000,00006280 and advertisement 000,00000000,00006280 failed: -22
[   16.286979] meson8b-dwmac ff3f0000.ethernet eth0: no phy at addr -1
[   16.292897] meson8b-dwmac ff3f0000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19)
[   16.488700] meson8b-dwmac ff3f0000.ethernet eth0: validation of rmii with support 000,00000000,00006280 and advertisement 000,00000000,00006280 failed: -22
[   16.497443] meson8b-dwmac ff3f0000.ethernet eth0: no phy at addr -1
[   16.503191] meson8b-dwmac ff3f0000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19)
[   16.608392] meson8b-dwmac ff3f0000.ethernet eth0: validation of rmii with support 000,00000000,00006280 and advertisement 000,00000000,00006280 failed: -22
[   16.616874] meson8b-dwmac ff3f0000.ethernet eth0: no phy at addr -1
[   16.622861] meson8b-dwmac ff3f0000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19)
[   16.728609] meson8b-dwmac ff3f0000.ethernet eth0: validation of rmii with support 000,00000000,00006280 and advertisement 000,00000000,00006280 failed: -22
[   16.737216] meson8b-dwmac ff3f0000.ethernet eth0: no phy at addr -1
[   16.743203] meson8b-dwmac ff3f0000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19)
[   16.848481] meson8b-dwmac ff3f0000.ethernet eth0: validation of rmii with support 000,00000000,00006280 and advertisement 000,00000000,00006280 failed: -22
[   16.857108] meson8b-dwmac ff3f0000.ethernet eth0: no phy at addr -1
[   16.864929] meson8b-dwmac ff3f0000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19)
[   16.920569] kauditd_printk_skb: 26 callbacks suppressed
[   16.920579] audit: type=1130 audit(1593136442.516:38): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=NetworkManager-wait-online comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   16.994657] audit: type=1130 audit(1593136442.586:39): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=polkit comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   17.009333] audit: type=1130 audit(1593136442.606:40): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=accounts-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   17.608764] audit: type=1131 audit(1593136443.206:41): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=bluetooth-khadas comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[   20.325391] audit: type=1103 audit(1593136445.916:42): pid=704 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[   20.360275] audit: type=1334 audit(1593136445.956:43): prog-id=13 op=LOAD
[   20.361478] audit: type=1334 audit(1593136445.956:44): prog-id=14 op=LOAD
[   20.882522] audit: type=1130 audit(1593136446.476:45): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=systemd-userdbd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   20.985519] audit: type=1130 audit(1593136446.576:46): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=user-runtime-dir@972 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   21.041825] audit: type=1101 audit(1593136446.636:47): pid=712 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='op=PAM:accounting grantors=pam_tally2,pam_access,pam_unix,pam_permit,pam_time acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   23.104335] fuse: init (API version 7.31)
[   23.518067] Bluetooth: hci0: BCM: failed to write update baudrate (-110)
[   23.519122] Bluetooth: hci0: Failed to set baudrate
[   25.598065] Bluetooth: hci0: command 0x0c03 tx timeout
[   26.026263] kauditd_printk_skb: 12 callbacks suppressed
[   26.026269] audit: type=1131 audit(1593136451.616:56): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   30.694534] audit: type=1100 audit(1593136456.286:57): pid=763 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='op=PAM:authentication grantors=pam_tally2,pam_shells,pam_unix,pam_permit,pam_gnome_keyring acct="rna" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[   30.713990] audit: type=1101 audit(1593136456.296:58): pid=763 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='op=PAM:accounting grantors=pam_tally2,pam_access,pam_unix,pam_permit,pam_time acct="rna" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[   30.993026] audit: type=1106 audit(1593136456.586:59): pid=704 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='op=PAM:session_close grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[   31.009389] audit: type=1104 audit(1593136456.586:60): pid=704 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[   31.035615] audit: type=1103 audit(1593136456.626:61): pid=763 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='op=PAM:setcred grantors=pam_tally2,pam_shells,pam_unix,pam_permit,pam_gnome_keyring acct="rna" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[   31.054824] audit: type=1006 audit(1593136456.626:62): pid=763 uid=0 subj=kernel old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
[   31.068321] audit: type=1300 audit(1593136456.626:62): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffe2b06ee0 a2=4 a3=0 items=0 ppid=652 pid=763 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="lightdm" exe="/usr/bin/lightdm" subj=kernel key=(null)
[   31.094438] audit: type=1327 audit(1593136456.626:62): proctitle=6C69676874646D002D2D73657373696F6E2D6368696C64003132003139
[   31.153293] audit: type=1130 audit(1593136456.746:63): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   31.188729] audit: type=1101 audit(1593136456.786:64): pid=773 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='op=PAM:accounting grantors=pam_tally2,pam_access,pam_unix,pam_permit,pam_time acct="rna" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   31.207684] audit: type=1103 audit(1593136456.786:65): pid=773 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='op=PAM:setcred grantors=? acct="rna" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[   31.227469] audit: type=1006 audit(1593136456.786:66): pid=773 uid=0 subj=kernel old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=3 res=1
[   31.241076] audit: type=1300 audit(1593136456.786:66): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffe94ac860 a2=4 a3=ffffa7df1f10 items=0 ppid=1 pid=773 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="(systemd)" exe="/usr/lib/systemd/systemd" subj=kernel key=(null)
[   31.268805] audit: type=1327 audit(1593136456.786:66): proctitle="(systemd)"
[   33.758055] Bluetooth: hci0: BCM: Reset failed (-110)
[   35.112119]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.113534]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.120549]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.127600]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.134576]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.142196]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.148161]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.154978]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.162227]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.169063]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.184354]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.185984]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.193111]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.200034]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.206916]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.214977]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.220599]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.227455]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.234573]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.241490]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.248976]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.254817]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.261818]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.268886]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.275725]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.283466]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.289376]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.296223]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.303478]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.310287]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.318317]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.324018]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.330930]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.337981]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.344865]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.352956]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.358621]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.365429]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.372597]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.379463]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.386959]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.392874]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.399753]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.406816]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.413800]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.421388]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.427313]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.434177]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.441405]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.448324]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.456454]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.462061]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.468932]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.475973]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.482932]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.490998]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.496556]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.503529]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.510576]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.517418]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.805855]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.807333]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.814350]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.821650]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.828688]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.836022]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.842504]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.849056]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.855832]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.863179]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.871267]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.876503]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.883489]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.890579]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.897426]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.905513]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.911134]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.917959]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.925536]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.932316]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.940027]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.945340]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.952670]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.959672]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.966254]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.973870]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.979892]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.986712]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   35.993919]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.000780]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.008827]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.014521]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.021440]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.028574]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.035404]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.043553]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.049146]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.055987]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.063173]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.069993]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.077463]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.083477]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.090297]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.097330]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.104312]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.112085]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.117822]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.124812]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.131877]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.138784]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.146840]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.152569]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.159485]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.166501]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.173485]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.181732]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.187060]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.194018]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.201087]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.207939]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.248295]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.249766]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.256662]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.263890]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.270778]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.278806]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.284262]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.291805]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.298651]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.305212]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.313818]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.319297]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.325884]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.333453]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.340223]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.347870]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.353938]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.360721]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.367474]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.374841]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.382228]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.387761]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.395158]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.402192]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.408969]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.416442]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.422695]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.429466]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.436288]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.443995]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.452380]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.456966]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.464295]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.471342]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.477838]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.486442]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.491622]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.498858]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.505517]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.513206]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.521032]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.525762]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.532796]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.539820]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.546662]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.554487]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.560367]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.567157]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.574362]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.581261]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.589359]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.594931]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.602000]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.608991]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.615843]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.624188]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.629567]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.636399]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.643565]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.650486]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.687729]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.689248]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.696084]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.703291]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.710193]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.717918]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.723773]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.730661]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.737733]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.744708]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.752918]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.758423]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.765271]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.772453]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.779335]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.787516]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.793455]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.799952]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.806969]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.814441]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.821972]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.827212]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.834647]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.841821]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.848550]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.856093]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.868275]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.869751]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.876994]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.884335]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.892007]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.897541]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.904885]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.911885]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.918794]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.926590]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.932583]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.939281]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.946112]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.953460]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.960943]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.966349]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.973743]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.980675]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.987279]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   36.997072]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.001171]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.007750]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.018448]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.021743]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.030392]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.035526]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.042961]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.055205]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.060725]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.069453]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.071164]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.080576]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.089117]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.092064]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.141298]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.142755]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.150122]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.156787]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.163832]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.171893]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.177262]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.184558]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.191630]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.198244]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.206225]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.212009]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.218868]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.225920]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.232870]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.240998]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.246500]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.253441]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.260512]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.267370]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.275076]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.280839]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.287657]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.294887]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.301732]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.309443]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.315266]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.322210]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.329317]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.336165]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.344282]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.350015]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.356792]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.364000]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.370837]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.378989]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.384537]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.391454]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.398581]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.405321]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.413020]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.418828]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.425680]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.432877]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.439722]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.447468]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.453326]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.460215]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.467278]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.474294]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.482356]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.487938]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.495332]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.502011]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.508863]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.517022]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.522621]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.529432]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.536464]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.543469]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.575739]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.577181]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.584201]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.591250]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.598223]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.605808]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.611753]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.618643]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.625707]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.632682]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.640808]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.646383]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.653341]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.660405]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.667272]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.675353]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.680978]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.687824]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.694960]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.701849]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.709385]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.715205]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.722177]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.729421]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.736119]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.743887]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.749828]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.756614]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.763795]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.770699]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.778783]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.784400]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.791369]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.798483]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.805272]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.813542]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.819034]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.825838]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.833051]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.839912]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.847587]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.853344]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.860213]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.867220]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.874288]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.882012]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.887711]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.894669]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.901802]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.908679]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.916891]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.922461]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.929327]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.936371]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.943331]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.951954]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.956940]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.963937]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.970971]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.977838]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   37.984305] kauditd_printk_skb: 9 callbacks suppressed
[   37.984309] audit: type=1334 audit(1593136463.576:74): prog-id=17 op=LOAD
[   37.997345] audit: type=1334 audit(1593136463.586:75): prog-id=18 op=LOAD
[   38.929396] audit: type=1130 audit(1593136464.526:76): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   39.103603] audit: type=1130 audit(1593136464.696:77): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   41.385922] audit: type=1131 audit(1593136466.976:78): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=user@972 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   41.431762] audit: type=1131 audit(1593136467.026:79): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=user-runtime-dir@972 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   43.311667] audit: type=1130 audit(1593136468.906:80): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   43.343423] audit: type=1131 audit(1593136468.936:81): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   45.636774] audit: type=1131 audit(1593136471.226:82): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   46.028519] audit: type=1334 audit(1593136471.626:83): prog-id=12 op=UNLOAD
[   46.029867] audit: type=1334 audit(1593136471.626:84): prog-id=11 op=UNLOAD
[   46.883825] audit: type=1130 audit(1593136472.476:85): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   77.969823] audit: type=1131 audit(1593136503.566:86): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  130.260518] usb 1-2: new high-speed USB device number 3 using xhci-hcd
[  130.442680] usb 1-2: New USB device found, idVendor=04e8, idProduct=6860, bcdDevice= 4.00
[  130.445293] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  130.452547] usb 1-2: Product: SAMSUNG_Android
[  130.456659] usb 1-2: Manufacturer: SAMSUNG
[  130.460681] usb 1-2: SerialNumber: 02c2f2d5
[  131.421076] cdc_acm 1-2:1.1: ttyACM0: USB ACM device
[  131.423020] usbcore: registered new interface driver cdc_acm
[  131.426014] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[  132.741716] audit: type=1130 audit(1593136558.336:87): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=systemd-networkd-wait-online comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[  139.941868] usb 1-2: USB disconnect, device number 3
[  140.368321] usb 1-2: new high-speed USB device number 4 using xhci-hcd
[  140.549759] usb 1-2: New USB device found, idVendor=04e8, idProduct=6864, bcdDevice= 4.00
[  140.552312] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  140.559476] usb 1-2: Product: SAMSUNG_Android
[  140.563690] usb 1-2: Manufacturer: SAMSUNG
[  140.567742] usb 1-2: SerialNumber: 02c2f2d5
[  141.420858] usbcore: registered new interface driver cdc_ether
[  141.427534] rndis_host 1-2:1.0 usb0: register 'rndis_host' at usb-xhci-hcd.3.auto-2, RNDIS device, 8e:30:b7:9e:ae:d2
[  141.439449] usbcore: registered new interface driver rndis_host
[  141.868301] audit: type=1130 audit(1593136567.456:88): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  143.429419] audit: type=1130 audit(1593152726.471:89): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=nmb comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  144.306231] audit: type=1130 audit(1593152727.351:90): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=smb comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  144.917134] audit: type=1130 audit(1593152727.961:91): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=tlp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  152.037426] audit: type=1131 audit(1593152735.081:92): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  317.103164] meson8b-dwmac ff3f0000.ethernet eth0: validation of rmii with support 000,00000000,00006280 and advertisement 000,00000000,00006280 failed: -22
[  317.113984] meson8b-dwmac ff3f0000.ethernet eth0: no phy at addr -1
[  317.117607] meson8b-dwmac ff3f0000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19)
[  317.223174] meson8b-dwmac ff3f0000.ethernet eth0: validation of rmii with support 000,00000000,00006280 and advertisement 000,00000000,00006280 failed: -22
[  317.240583] meson8b-dwmac ff3f0000.ethernet eth0: no phy at addr -1
[  317.241239] meson8b-dwmac ff3f0000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19)
[  317.393182] meson8b-dwmac ff3f0000.ethernet eth0: validation of rmii with support 000,00000000,00006280 and advertisement 000,00000000,00006280 failed: -22
[  317.405530] meson8b-dwmac ff3f0000.ethernet eth0: no phy at addr -1
[  317.407610] meson8b-dwmac ff3f0000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19)
[  317.523145] meson8b-dwmac ff3f0000.ethernet eth0: validation of rmii with support 000,00000000,00006280 and advertisement 000,00000000,00006280 failed: -22
[  317.531682] meson8b-dwmac ff3f0000.ethernet eth0: no phy at addr -1
[  317.538849] meson8b-dwmac ff3f0000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19)
[rna@rna ~]$
According to the DTS file in the kernel, it uses firmware compatible with bcm4329. So you would have to hunt that down somewhere, if it's not in linux-firmware.
which line does it say 'bcm4329' and how to hunt it down? is there any wiki I can read? sorry I am new to this subject.
I found it in the kernel DTS file. But it's not mention in your dmesg at all. So I don't know what will help after this. :frowning:
I found this from the armbian forum by using your keyword 'bcm4329'
but don't know how to start?
Okay. Seems the wifi chip is the ap6212 then.
You can try placing the files from this repo inside /usr/lib/firmware/brcm/.
Hello and Welcome to Manjaro Community.
This won't work, these are very old.
It is better to use from. LibreElecs repo.
Updated firmware can be found here
I will check which device is this and I think you should have wifi working out of the box for ap6212a as I have it in kvim1-firmware package.
Try to install it using
sudo pacman -S kvim1-firmware --overwrite "*"
And reboot to see if you have a working wifi.
BTW which image did you flash ? I assume Khadas Vim3 image and then you switched the dtb and u-boot.
Install these packages mesa-demos and glmark2
sudo pacman -S mesa-demos glmark2
After installing the above package , can you please share output of the following
inxi -Fzxi
I feel your'e making use of LLVMPipe instead of `Panfrost, so just want to confirm it from the above output.
Update: I just saw the image you shared on the OP, I see that it is using LLVMPipe as I suspected.
To make use of panfrost you will have to add 01-panfrost.conf file in /etc/X11/xorg.conf.d/
Enter the below content in 01-panfrost.conf and reboot.
Section "Device"
    Identifier  "Default Device"
    Driver      "modesetting"
    Option      "AccelMethod"    "glamor"     ### "glamor" to enable 3D acceleration, "none" to disable.
EndSection
Section "ServerFlags"
        Option  "AutoAddGPU" "off"
        Option "Debug" "dmabuf_capable"
EndSection
Section "OutputClass"
        Identifier "Panfrost"
        MatchDriver "meson"  # sun4i-drm  rockchip
        Option "PrimaryGPU" "true"
EndSection
This will make use of panfrost driver for graphical Acceleration.
Good Luck.
UPDATE2: I read the dts you're using, it have a different audio driver name so you will have to replace the name of the driver in sound script used.
I hope it should work by just replacing the name
Install this package
sudo pacman -S khadas-utils
change card=G12HDMI to card=G12-HDMI-SPDIF in /usr/bin/g12_sound.sh
then enable it using
sudo systemctl enable sound --now
then reboot, HDMI audio should work after reboot.
Good Luck.
Thanks for your detail explanation, I will try your suggestion.
Just to confirm:
I use the Khadas Vim3 Image, using "meson-g12a-x96-max-rmii.dtb"
In case of LLVMPipe, originally it didn't appear until I install GLX info and Mesa from the Official Store. And Magically it appears that way.
Wait for a sec,
There are 3 steps that you mentioned.
Which one should I choose to start with?
Because in your first step (Original), I have to change my firmware to Khadas Vim1, am I right?
Step Two (Update): Change to Panfrost
Step Three (Update 2): Fix Audio
Should I try three of them? or just the step 2 and 3?
These three are focused on individual fixes, First is for Wifi, second is for GPU and third is for Audio.
Try them individually to get clear understanding of the results.
Try third and check if you have audio, then try second to check if it shows Panfrost instead of LLVMPipe then try first.
All the best.
ok, sounds cool. I'll try and let you know
Sorry, I have a silly question. How to open this file with root access? I cannot modify it.
In Linux Mint I can easily use "file manager" right click in that folder and "open as root" how can I do it in Manjaro?
Many thanks
Haha It's ok, it should be the same way.
do this
sudo nano /usr/bin/g12_sound.sh
edit the file and then press Ctrl + o to save and Ctrl + x to close
