WiFi on OpenBox
I just installed the OpenBox version on a Lenovo ThinkPad W520 and I haven't been able to get the WiFi working.
I installed wifi-radar but as always it hangs up.
Do I need to install something from the XFCE or LXQt editions?
If so, which?
(To get Suspend working I installed the LXQt app, which works fine. I also am using the XFCE4-Panel)
Thanks in advance.
There is dmenu wifi, isn't it? Or you can use nm applet :man_shrugging:
The networkmanager_dmenu shows me a list of the networks present but doesn't let me to connect to them, so far.
You don't have to install anything.
Checked - by adding a - USB WiFi to my workstation.
You have two options.
  1. Click the network icon in polybar (networkmanager_dmenu)
    • select the network and press Enter
    • a passphrase entry is shown
    • enter passphrase and press Enter
  2. Click the network icon in status bar (network-manager-applet)
    • Left click the network icon
    • Select your desired network by clicking on it
    • Input your passphrase and press Enter
Both options works
No need to add extra apps. I get it to work using the provided Xfce Power Manager control panel app.
If you use xfce4 panel you may need to add a status area so the nm-applet has a place for the status icon.
I can try that
The problem was resolved by installing wpa_gui and wpa_tui
This topic was automatically closed after 90 days. New replies are no longer allowed.
