Wifi on old Macbook Pro: so close!
Yet another post about getting wifi to work on an old Macbook Pro! I am so close!
Machine: Macbook Pro mid-2015 (11,4)
Problem: all the wireless networks show up in NetworkManager, but when I click connect it keeps asking for my passphrase but doesn’t connect
Things I’ve tried:
  • installing iwd and using iwctl: I stopped the NetworkManager service and started iwd service then entered iwctl. When I try to connect, it just says “operation failed” in red. I tried using the WPS button option (wsc in iwctl) but the same: as soon as I push the router button “operation failed” is displayed in iwctl
  • Checking the log for iwd.service I am getting a repeated error message : Invalid HE capabilities for [mac address]
  • I am guessing that there is some problem with authentication (I use WPA2-PSK for the connection).
I am frustratingly close to getting this old laptop onto the internet using Manjaro, which is otherwise running flawlessly on this 10-year old laptop. Does anyone have any suggestions to get me over the line?
Many (or at least a few) people have Manjaro running on Apple hardware.
I’m not among them …
and I don’t know whether there exist tips or howto’s here on the forum - have look.
The Arch wiki has got at least some info on some of the models.
In order to help, knowing the hardware config would certainly help:
inxi -zv8
(for the chip ID and driver information, among other things)
To see what is happening during connection attempts you could dig through the logs.
Easier may be to watch it in real time:
journalctl -f
or
sudo dmesg -w
have one of those running in a terminal while you are trying
This should tell in quite some detail what is happening and where in the process the problem is
I’d rather go back to NetworkManager and try troubleshooting with that first.
When posting terminal output, please format as “preformatted text” → this button in the edit window: </>
Regarding iwd, did you do any of the following?
systemctl stop wpa_supplicant
systemctl mask wpa_supplicant
systemctl enable iwd.service
Create the following configuration file to enable the iwd backend?:
/etc/NetworkManager/conf.d/wifi_backend.conf
[device]
wifi.backend=iwd
Reboot
Thanks for the responses.
Looking at the system logs, it seems that my router doesn’t support protected management frames so that might account for the authentication failures.
I did try what user jrichard326 suggested but same issue.
I will try and get some output from inxi but I only have access to an iPad to get online.
… there is USB tethereing - using the devices internet connection
works flawlessly with my Android phone - but I do not know about iPads - don’t have one
should work, though
[HowTo] Use public command-line pastebin services without installing anything!
for instance:
inxi -zv8 | curl -F 'file=@-' https://0x0.st
Here is the output of inxi for the network adapter:
  Device-1: Broadcom BCM43602 802.11ac Wireless LAN SoC vendor: Apple
    driver: brcmfmac v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    bus-ID: 03:00.0 chip-ID: 14e4:43ba class-ID: 0280
  IF: wlan0 state: down mac: <filter>
and the system log is giving me this when I try to connect:
invalid HE capabilities for [mac address]
That is precious little information …
This is what happens when I connect to my WiFi router:
jo@mint:~$ journalctl -f
Mär 10 07:18:31 mint NetworkManager[677]: <info>  [1741587511.7228] device (wlan0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Mär 10 07:18:31 mint NetworkManager[677]: <info>  [1741587511.7233] sup-iface[eb35b3f457ddde89,0,wlan0]: wps: type pbc start...
Mär 10 07:18:31 mint wpa_supplicant[759]: wlan0: WPS-PBC-ACTIVE
Mär 10 07:18:31 mint NetworkManager[677]: <info>  [1741587511.7572] device (wlan0): supplicant interface state: disconnected -> scanning
Mär 10 07:18:32 mint NetworkManager[677]: <warn>  [1741587512.9763] device (wlan0): no secrets: User canceled the secrets request.
Mär 10 07:18:32 mint NetworkManager[677]: <info>  [1741587512.9764] device (wlan0): state change: need-auth -> failed (reason 'no-secrets', sys-iface-state: 'managed')
Mär 10 07:18:32 mint NetworkManager[677]: <info>  [1741587512.9774] manager: NetworkManager state is now CONNECTED_LOCAL
Mär 10 07:18:32 mint NetworkManager[677]: <warn>  [1741587512.9782] device (wlan0): Activation: failed for connection 'FRITZ!Box 6660 Cable MH'
Mär 10 07:18:32 mint NetworkManager[677]: <info>  [1741587512.9785] device (wlan0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Mär 10 07:18:32 mint wpa_supplicant[759]: wlan0: WPS-CANCEL
Mär 10 07:18:59 mint NetworkManager[677]: <info>  [1741587539.9840] device (wlan0): Activation: starting connection 'FritzBox6660' (02dd07d4-412a-4266-a00f-3d2346cb16ab)
Mär 10 07:18:59 mint NetworkManager[677]: <info>  [1741587539.9841] audit: op="connection-activate" uuid="02dd07d4-412a-4266-a00f-3d2346cb16ab" name="FritzBox6660" pid=1897 uid=1000 result="success"
Mär 10 07:18:59 mint NetworkManager[677]: <info>  [1741587539.9842] device (wlan0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Mär 10 07:18:59 mint NetworkManager[677]: <info>  [1741587539.9847] manager: NetworkManager state is now CONNECTING
Mär 10 07:18:59 mint NetworkManager[677]: <info>  [1741587539.9852] device (wlan0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mär 10 07:18:59 mint NetworkManager[677]: <info>  [1741587539.9855] device (wlan0): Activation: (wifi) access point 'FritzBox6660' has security, but secrets are required.
Mär 10 07:18:59 mint NetworkManager[677]: <info>  [1741587539.9856] device (wlan0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Mär 10 07:18:59 mint NetworkManager[677]: <info>  [1741587539.9869] device (wlan0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Mär 10 07:18:59 mint NetworkManager[677]: <info>  [1741587539.9872] device (wlan0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mär 10 07:18:59 mint NetworkManager[677]: <info>  [1741587539.9876] device (wlan0): Activation: (wifi) connection 'FritzBox6660' has security, and secrets exist.  No new secrets needed.
Mär 10 07:18:59 mint NetworkManager[677]: <info>  [1741587539.9877] Config: added 'ssid' value 'FritzBox6660'
Mär 10 07:18:59 mint NetworkManager[677]: <info>  [1741587539.9877] Config: added 'scan_ssid' value '1'
Mär 10 07:18:59 mint NetworkManager[677]: <info>  [1741587539.9877] Config: added 'bgscan' value 'simple:30:-70:86400'
Mär 10 07:18:59 mint NetworkManager[677]: <info>  [1741587539.9877] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK'
Mär 10 07:18:59 mint NetworkManager[677]: <info>  [1741587539.9877] Config: added 'psk' value '<hidden>'
Mär 10 07:19:00 mint wpa_supplicant[759]: wlan0: SME: Trying to authenticate with 64:70:02:d8:46:7a (SSID='FritzBox6660' freq=2472 MHz)
Mär 10 07:19:00 mint kernel: wlan0: authenticate with 64:70:02:d8:46:7a (local address=84:a6:c8:e1:0d:fc)
Mär 10 07:19:00 mint kernel: wlan0: send auth to 64:70:02:d8:46:7a (try 1/3)
Mär 10 07:19:00 mint NetworkManager[677]: <info>  [1741587540.0086] device (wlan0): supplicant interface state: scanning -> authenticating
Mär 10 07:19:00 mint kernel: wlan0: authenticated
Mär 10 07:19:00 mint wpa_supplicant[759]: wlan0: Trying to associate with 64:70:02:d8:46:7a (SSID='FritzBox6660' freq=2472 MHz)
Mär 10 07:19:00 mint NetworkManager[677]: <info>  [1741587540.0199] device (wlan0): supplicant interface state: authenticating -> associating
Mär 10 07:19:00 mint kernel: wlan0: associate with 64:70:02:d8:46:7a (try 1/3)
Mär 10 07:19:00 mint kernel: wlan0: RX AssocResp from 64:70:02:d8:46:7a (capab=0x431 status=0 aid=1)
Mär 10 07:19:00 mint kernel: wlan0: associated
Mär 10 07:19:00 mint wpa_supplicant[759]: wlan0: Associated with 64:70:02:d8:46:7a
Mär 10 07:19:00 mint wpa_supplicant[759]: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Mär 10 07:19:00 mint wpa_supplicant[759]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=DE
Mär 10 07:19:00 mint NetworkManager[677]: <info>  [1741587540.0341] device (wlan0): supplicant interface state: associating -> 4way_handshake
Mär 10 07:19:00 mint wpa_supplicant[759]: wlan0: WPA: Key negotiation completed with 64:70:02:d8:46:7a [PTK=CCMP GTK=CCMP]
Mär 10 07:19:00 mint wpa_supplicant[759]: wlan0: CTRL-EVENT-CONNECTED - Connection to 64:70:02:d8:46:7a completed [id=0 id_str=]
Mär 10 07:19:00 mint NetworkManager[677]: <info>  [1741587540.0530] device (wlan0): supplicant interface state: 4way_handshake -> completed
Mär 10 07:19:00 mint NetworkManager[677]: <info>  [1741587540.0530] device (wlan0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "FritzBox6660"
Mär 10 07:19:00 mint NetworkManager[677]: <info>  [1741587540.0531] device (wlan0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Mär 10 07:19:00 mint NetworkManager[677]: <info>  [1741587540.0541] dhcp4 (wlan0): activation: beginning transaction (timeout in 45 seconds)
Mär 10 07:19:00 mint avahi-daemon[665]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::d8c5:f74b:605d:2040.
Mär 10 07:19:00 mint avahi-daemon[665]: New relevant interface wlan0.IPv6 for mDNS.
Mär 10 07:19:00 mint avahi-daemon[665]: Registering new address record for fe80::d8c5:f74b:605d:2040 on wlan0.*.
Mär 10 07:19:00 mint NetworkManager[677]: <info>  [1741587540.0644] dhcp4 (wlan0): state changed new lease, address=192.168.1.199
Mär 10 07:19:00 mint avahi-daemon[665]: Joining mDNS multicast group on interface wlan0.IPv4 with address 192.168.1.199.
Mär 10 07:19:00 mint avahi-daemon[665]: New relevant interface wlan0.IPv4 for mDNS.
Mär 10 07:19:00 mint avahi-daemon[665]: Registering new address record for 192.168.1.199 on wlan0.IPv4.
Mär 10 07:19:00 mint dbus-daemon[676]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.3' (uid=0 pid=677 comm="/usr/sbin/NetworkManager --no-daemon " label="unconfined")
Mär 10 07:19:00 mint NetworkManager[677]: <info>  [1741587540.0680] device (wlan0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Mär 10 07:19:00 mint systemd[1]: Starting Network Manager Script Dispatcher Service...
Mär 10 07:19:00 mint dbus-daemon[676]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Mär 10 07:19:00 mint systemd[1]: Started Network Manager Script Dispatcher Service.
Mär 10 07:19:00 mint NetworkManager[677]: <info>  [1741587540.0904] device (wlan0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Mär 10 07:19:00 mint NetworkManager[677]: <info>  [1741587540.0907] device (wlan0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Mär 10 07:19:00 mint NetworkManager[677]: <info>  [1741587540.0913] manager: NetworkManager state is now CONNECTED_LOCAL
Mär 10 07:19:00 mint NetworkManager[677]: <info>  [1741587540.0922] manager: NetworkManager state is now CONNECTED_SITE
Mär 10 07:19:00 mint NetworkManager[677]: <info>  [1741587540.0924] policy: set 'FritzBox6660' (wlan0) as default for IPv4 routing and DNS
Mär 10 07:19:00 mint NetworkManager[677]: <info>  [1741587540.0938] device (wlan0): Activation: successful, device activated.
Mär 10 07:19:00 mint NetworkManager[677]: <info>  [1741587540.0947] manager: NetworkManager state is now CONNECTED_GLOBAL
Mär 10 07:19:00 mint dnsmasq[1186]: vorgelagerte Server von DBus gesetzt
Mär 10 07:19:00 mint dnsmasq[1186]: Benutze Namensserver 1.1.1.1#53(via wlan0)
Mär 10 07:19:00 mint dnsmasq[1186]: using nameserver 1.1.1.1#53 for Domain 1.168.192.in-addr.arpa
Mär 10 07:19:00 mint dnsmasq[1186]: Benutze Namensserver 8.8.8.8#53(via wlan0)
Mär 10 07:19:00 mint dnsmasq[1186]: using nameserver 8.8.8.8#53 for Domain 1.168.192.in-addr.arpa
Mär 10 07:19:00 mint systemd-resolved[621]: wlan0: Bus client set default route setting: yes
Mär 10 07:19:00 mint systemd-resolved[621]: wlan0: Bus client set DNS server list to: 1.1.1.1, 8.8.8.8
Mär 10 07:19:00 mint wpa_supplicant[759]: wlan0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-33 noise=9999 txrate=1000
Mär 10 07:19:02 mint systemd[1]: systemd-hostnamed.service: Deactivated successfully.
Mär 10 07:19:02 mint NetworkManager[677]: <info>  [1741587542.1416] dhcp6 (wlan0): activation: beginning transaction (timeout in 45 seconds)
Mär 10 07:19:02 mint dnsmasq[1186]: vorgelagerte Server von DBus gesetzt
Mär 10 07:19:02 mint dnsmasq[1186]: Benutze Namensserver 1.1.1.1#53(via wlan0)
Mär 10 07:19:02 mint dnsmasq[1186]: using nameserver 1.1.1.1#53 for Domain 1.168.192.in-addr.arpa
Mär 10 07:19:02 mint dnsmasq[1186]: Benutze Namensserver 8.8.8.8#53(via wlan0)
Mär 10 07:19:02 mint dnsmasq[1186]: using nameserver 8.8.8.8#53 for Domain 1.168.192.in-addr.arpa
Mär 10 07:19:02 mint dnsmasq[1186]: using nameserver fd63:4eaf:713d::1#53 for Domain 0.0.0.0.d.3.1.7.f.a.e.4.3.6.d.f.ip6.arpa
Mär 10 07:19:02 mint dnsmasq[1186]: using nameserver fd63:4eaf:713d::1#53 for Domain 0.0.0.0.0.0.0.0.0.0.0.0.0.8.e.f.ip6.arpa
Mär 10 07:19:02 mint dnsmasq[1186]: using nameserver fd63:4eaf:713d::1#53 for Domain d.3.1.7.f.a.e.4.3.6.d.f.ip6.arpa
Mär 10 07:19:02 mint avahi-daemon[665]: Leaving mDNS multicast group on interface wlan0.IPv6 with address fe80::d8c5:f74b:605d:2040.
Mär 10 07:19:02 mint avahi-daemon[665]: Joining mDNS multicast group on interface wlan0.IPv6 with address fd63:4eaf:713d:0:6ecd:5f0e:43f4:718d.
Mär 10 07:19:02 mint avahi-daemon[665]: Registering new address record for fd63:4eaf:713d:0:6ecd:5f0e:43f4:718d on wlan0.*.
Mär 10 07:19:02 mint avahi-daemon[665]: Withdrawing address record for fe80::d8c5:f74b:605d:2040 on wlan0.
Mär 10 07:19:03 mint NetworkManager[677]: <info>  [1741587543.1672] dhcp6 (wlan0): state changed new lease, address=fd63:4eaf:713d::4fe
Mär 10 07:19:03 mint avahi-daemon[665]: Registering new address record for fd63:4eaf:713d::4fe on wlan0.*.
Mär 10 07:19:03 mint avahi-daemon[665]: Registering new address record for fd63:4eaf:713d:0:c1d6:5037:37cb:172 on wlan0.*.
Mär 10 07:19:06 mint ntpd[960]: Listen normally on 10 wlan0 192.168.1.199:123
Mär 10 07:19:06 mint ntpd[960]: Listen normally on 11 wlan0 [fd63:4eaf:713d::4fe]:123
Mär 10 07:19:06 mint ntpd[960]: Listen normally on 12 wlan0 [fd63:4eaf:713d:0:c1d6:5037:37cb:172]:123
Mär 10 07:19:06 mint ntpd[960]: Listen normally on 13 wlan0 [fd63:4eaf:713d:0:6ecd:5f0e:43f4:718d]:123
Mär 10 07:19:06 mint ntpd[960]: Listen normally on 14 wlan0 [fe80::d8c5:f74b:605d:2040%3]:123
Mär 10 07:19:06 mint ntpd[960]: new interface(s) found: waking up resolver
that’s from journalctl -f
There is a lot more information in there.
The more important part is at the beginning.
and this is what happens when it fails to connect to my other router
Mär 10 08:41:48 mint NetworkManager[677]: <info>  [1741592508.9057] device (wlan0): Activation: starting connection 'FB6660' (3f2edf00-f756-4392-a42e-8fbe50734e2e)
Mär 10 08:41:48 mint NetworkManager[677]: <info>  [1741592508.9058] audit: op="connection-activate" uuid="3f2edf00-f756-4392-a42e-8fbe50734e2e" name="FB6660" pid=1897 uid=1000 result="success"
Mär 10 08:41:48 mint NetworkManager[677]: <info>  [1741592508.9060] device (wlan0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Mär 10 08:41:48 mint NetworkManager[677]: <info>  [1741592508.9065] manager: NetworkManager state is now CONNECTING
Mär 10 08:41:48 mint NetworkManager[677]: <info>  [1741592508.9069] device (wlan0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mär 10 08:41:48 mint NetworkManager[677]: <info>  [1741592508.9073] device (wlan0): Activation: (wifi) access point 'FB6660' has security, but secrets are required.
Mär 10 08:41:48 mint NetworkManager[677]: <info>  [1741592508.9073] device (wlan0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Mär 10 08:41:49 mint dbus-daemon[676]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.70' (uid=1000 pid=1897 comm="nm-applet " label="unconfined")
Mär 10 08:41:49 mint systemd[1]: Starting Hostname Service...
Mär 10 08:41:49 mint dbus-daemon[676]: [system] Successfully activated service 'org.freedesktop.hostname1'
Mär 10 08:41:49 mint systemd[1]: Started Hostname Service.
Mär 10 08:41:58 mint NetworkManager[677]: <info>  [1741592518.2965] device (wlan0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Mär 10 08:41:58 mint NetworkManager[677]: <info>  [1741592518.2970] device (wlan0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mär 10 08:41:58 mint NetworkManager[677]: <info>  [1741592518.2974] device (wlan0): Activation: (wifi) connection 'FB6660' has security, and secrets exist.  No new secrets needed.
Mär 10 08:41:58 mint NetworkManager[677]: <info>  [1741592518.2974] Config: added 'ssid' value 'FB6660'
Mär 10 08:41:58 mint NetworkManager[677]: <info>  [1741592518.2975] Config: added 'scan_ssid' value '1'
Mär 10 08:41:58 mint NetworkManager[677]: <info>  [1741592518.2975] Config: added 'bgscan' value 'simple:30:-70:86400'
Mär 10 08:41:58 mint NetworkManager[677]: <info>  [1741592518.2975] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK'
Mär 10 08:41:58 mint NetworkManager[677]: <info>  [1741592518.2975] Config: added 'auth_alg' value 'OPEN'
Mär 10 08:41:58 mint NetworkManager[677]: <info>  [1741592518.2975] Config: added 'psk' value '<hidden>'
Mär 10 08:41:58 mint NetworkManager[677]: <info>  [1741592518.3200] device (wlan0): supplicant interface state: disconnected -> scanning
Mär 10 08:41:58 mint wpa_supplicant[759]: wlan0: SME: Trying to authenticate with 50:e6:36:42:b9:b4 (SSID='FB6660' freq=2462 MHz)
Mär 10 08:41:58 mint kernel: wlan0: authenticate with 50:e6:36:42:b9:b4 (local address=84:a6:c8:e1:0d:fc)
Mär 10 08:41:58 mint kernel: wlan0: send auth to 50:e6:36:42:b9:b4 (try 1/3)
Mär 10 08:41:58 mint NetworkManager[677]: <info>  [1741592518.8158] device (wlan0): supplicant interface state: scanning -> authenticating
Mär 10 08:41:58 mint kernel: wlan0: authenticated
Mär 10 08:41:58 mint wpa_supplicant[759]: wlan0: Trying to associate with 50:e6:36:42:b9:b4 (SSID='FB6660' freq=2462 MHz)
Mär 10 08:41:58 mint NetworkManager[677]: <info>  [1741592518.8433] device (wlan0): supplicant interface state: authenticating -> associating
Mär 10 08:41:58 mint kernel: wlan0: associate with 50:e6:36:42:b9:b4 (try 1/3)
Mär 10 08:41:58 mint kernel: wlan0: RX AssocResp from 50:e6:36:42:b9:b4 (capab=0x1431 status=0 aid=129)
Mär 10 08:41:58 mint kernel: wlan0: associated
Mär 10 08:41:58 mint wpa_supplicant[759]: wlan0: Associated with 50:e6:36:42:b9:b4
Mär 10 08:41:58 mint wpa_supplicant[759]: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Mär 10 08:41:58 mint wpa_supplicant[759]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=DE
Mär 10 08:41:58 mint NetworkManager[677]: <info>  [1741592518.8820] device (wlan0): supplicant interface state: associating -> associated
Mär 10 08:41:58 mint kernel: wlan0: Limiting TX power to 20 (20 - 0) dBm as advertised by 50:e6:36:42:b9:b4
Mär 10 08:42:02 mint kernel: wlan0: deauthenticated from 50:e6:36:42:b9:b4 (Reason: 7=CLASS3_FRAME_FROM_NONASSOC_STA)
Mär 10 08:42:02 mint wpa_supplicant[759]: wlan0: CTRL-EVENT-DISCONNECTED bssid=50:e6:36:42:b9:b4 reason=7
Mär 10 08:42:02 mint wpa_supplicant[759]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Mär 10 08:42:02 mint NetworkManager[677]: <info>  [1741592522.9888] device (wlan0): supplicant interface state: associated -> disconnected
Mär 10 08:42:03 mint NetworkManager[677]: <info>  [1741592523.0889] device (wlan0): supplicant interface state: disconnected -> scanning
Mär 10 08:42:03 mint wpa_supplicant[759]: wlan0: SME: Trying to authenticate with 50:e6:36:42:b9:b4 (SSID='FB6660' freq=2462 MHz)
Mär 10 08:42:03 mint kernel: wlan0: authenticate with 50:e6:36:42:b9:b4 (local address=84:a6:c8:e1:0d:fc)
Mär 10 08:42:03 mint kernel: wlan0: send auth to 50:e6:36:42:b9:b4 (try 1/3)
Mär 10 08:42:03 mint NetworkManager[677]: <info>  [1741592523.6318] device (wlan0): supplicant interface state: scanning -> authenticating
Mär 10 08:42:03 mint kernel: wlan0: send auth to 50:e6:36:42:b9:b4 (try 2/3)
Mär 10 08:42:03 mint wpa_supplicant[759]: wlan0: Trying to associate with 50:e6:36:42:b9:b4 (SSID='FB6660' freq=2462 MHz)
Mär 10 08:42:03 mint kernel: wlan0: authenticated
Mär 10 08:42:03 mint kernel: wlan0: associate with 50:e6:36:42:b9:b4 (try 1/3)
Mär 10 08:42:03 mint NetworkManager[677]: <info>  [1741592523.7410] device (wlan0): supplicant interface state: authenticating -> associating
Mär 10 08:42:03 mint kernel: wlan0: RX AssocResp from 50:e6:36:42:b9:b4 (capab=0x1431 status=0 aid=129)
Mär 10 08:42:03 mint kernel: wlan0: associated
Mär 10 08:42:03 mint wpa_supplicant[759]: wlan0: Associated with 50:e6:36:42:b9:b4
Mär 10 08:42:03 mint wpa_supplicant[759]: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Mär 10 08:42:03 mint wpa_supplicant[759]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=DE
Mär 10 08:42:03 mint NetworkManager[677]: <info>  [1741592523.7725] device (wlan0): supplicant interface state: associating -> associated
Mär 10 08:42:03 mint kernel: wlan0: Limiting TX power to 20 (20 - 0) dBm as advertised by 50:e6:36:42:b9:b4
Mär 10 08:42:07 mint kernel: wlan0: deauthenticated from 50:e6:36:42:b9:b4 (Reason: 7=CLASS3_FRAME_FROM_NONASSOC_STA)
Mär 10 08:42:07 mint wpa_supplicant[759]: wlan0: CTRL-EVENT-DISCONNECTED bssid=50:e6:36:42:b9:b4 reason=7
Mär 10 08:42:07 mint wpa_supplicant[759]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Mär 10 08:42:07 mint NetworkManager[677]: <info>  [1741592527.8813] device (wlan0): supplicant interface state: associated -> disconnected
Mär 10 08:42:07 mint NetworkManager[677]: <info>  [1741592527.9815] device (wlan0): supplicant interface state: disconnected -> scanning
Mär 10 08:42:08 mint wpa_supplicant[759]: wlan0: SME: Trying to authenticate with 50:e6:36:42:b9:b4 (SSID='FB6660' freq=2462 MHz)
Mär 10 08:42:08 mint kernel: wlan0: authenticate with 50:e6:36:42:b9:b4 (local address=84:a6:c8:e1:0d:fc)
Mär 10 08:42:08 mint kernel: wlan0: send auth to 50:e6:36:42:b9:b4 (try 1/3)
Mär 10 08:42:08 mint NetworkManager[677]: <info>  [1741592528.4444] device (wlan0): supplicant interface state: scanning -> authenticating
Mär 10 08:42:08 mint wpa_supplicant[759]: wlan0: Trying to associate with 50:e6:36:42:b9:b4 (SSID='FB6660' freq=2462 MHz)
Mär 10 08:42:08 mint kernel: wlan0: authenticated
Mär 10 08:42:08 mint kernel: wlan0: associate with 50:e6:36:42:b9:b4 (try 1/3)
Mär 10 08:42:08 mint NetworkManager[677]: <info>  [1741592528.4521] device (wlan0): supplicant interface state: authenticating -> associating
Mär 10 08:42:08 mint kernel: wlan0: RX AssocResp from 50:e6:36:42:b9:b4 (capab=0x1431 status=0 aid=129)
Mär 10 08:42:08 mint kernel: wlan0: associated
Mär 10 08:42:08 mint wpa_supplicant[759]: wlan0: Associated with 50:e6:36:42:b9:b4
Mär 10 08:42:08 mint wpa_supplicant[759]: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Mär 10 08:42:08 mint wpa_supplicant[759]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=DE
Mär 10 08:42:08 mint NetworkManager[677]: <info>  [1741592528.4780] device (wlan0): supplicant interface state: associating -> associated
Mär 10 08:42:08 mint kernel: wlan0: Limiting TX power to 20 (20 - 0) dBm as advertised by 50:e6:36:42:b9:b4
Mär 10 08:42:12 mint kernel: wlan0: deauthenticated from 50:e6:36:42:b9:b4 (Reason: 7=CLASS3_FRAME_FROM_NONASSOC_STA)
Mär 10 08:42:12 mint wpa_supplicant[759]: wlan0: CTRL-EVENT-DISCONNECTED bssid=50:e6:36:42:b9:b4 reason=7
Mär 10 08:42:12 mint wpa_supplicant[759]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Mär 10 08:42:12 mint NetworkManager[677]: <info>  [1741592532.5892] device (wlan0): supplicant interface state: associated -> disconnected
Mär 10 08:42:12 mint NetworkManager[677]: <info>  [1741592532.6893] device (wlan0): supplicant interface state: disconnected -> scanning
Mär 10 08:42:13 mint wpa_supplicant[759]: wlan0: SME: Trying to authenticate with 50:e6:36:42:b9:b4 (SSID='FB6660' freq=2462 MHz)
Mär 10 08:42:13 mint kernel: wlan0: authenticate with 50:e6:36:42:b9:b4 (local address=84:a6:c8:e1:0d:fc)
Mär 10 08:42:13 mint kernel: wlan0: send auth to 50:e6:36:42:b9:b4 (try 1/3)
Mär 10 08:42:13 mint NetworkManager[677]: <info>  [1741592533.2548] device (wlan0): supplicant interface state: scanning -> authenticating
Mär 10 08:42:13 mint wpa_supplicant[759]: wlan0: Trying to associate with 50:e6:36:42:b9:b4 (SSID='FB6660' freq=2462 MHz)
Mär 10 08:42:13 mint kernel: wlan0: authenticated
Mär 10 08:42:13 mint kernel: wlan0: associate with 50:e6:36:42:b9:b4 (try 1/3)
Mär 10 08:42:13 mint NetworkManager[677]: <info>  [1741592533.2629] device (wlan0): supplicant interface state: authenticating -> associating
Mär 10 08:42:13 mint kernel: wlan0: RX AssocResp from 50:e6:36:42:b9:b4 (capab=0x1431 status=0 aid=129)
Mär 10 08:42:13 mint kernel: wlan0: associated
Mär 10 08:42:13 mint wpa_supplicant[759]: wlan0: Associated with 50:e6:36:42:b9:b4
Mär 10 08:42:13 mint wpa_supplicant[759]: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Mär 10 08:42:13 mint wpa_supplicant[759]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=DE
Mär 10 08:42:13 mint NetworkManager[677]: <info>  [1741592533.2926] device (wlan0): supplicant interface state: associating -> associated
Mär 10 08:42:13 mint kernel: wlan0: Limiting TX power to 20 (20 - 0) dBm as advertised by 50:e6:36:42:b9:b4
Mär 10 08:42:17 mint kernel: wlan0: deauthenticated from 50:e6:36:42:b9:b4 (Reason: 7=CLASS3_FRAME_FROM_NONASSOC_STA)
Mär 10 08:42:17 mint wpa_supplicant[759]: wlan0: CTRL-EVENT-DISCONNECTED bssid=50:e6:36:42:b9:b4 reason=7
Mär 10 08:42:17 mint wpa_supplicant[759]: wlan0: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="FB6660" auth_failures=1 duration=10 reason=CONN_FAILED
Mär 10 08:42:17 mint wpa_supplicant[759]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Mär 10 08:42:17 mint NetworkManager[677]: <info>  [1741592537.4055] device (wlan0): supplicant interface state: associated -> disconnected
Mär 10 08:42:17 mint NetworkManager[677]: <info>  [1741592537.5053] device (wlan0): supplicant interface state: disconnected -> scanning
Mär 10 08:42:19 mint systemd[1]: systemd-hostnamed.service: Deactivated successfully.
Mär 10 08:42:22 mint rtkit-daemon[1349]: Supervising 7 threads of 4 processes of 1 users.
Mär 10 08:42:23 mint NetworkManager[677]: <warn>  [1741592543.5774] device (wlan0): Activation: (wifi) association took too long
Mär 10 08:42:23 mint NetworkManager[677]: <info>  [1741592543.5776] device (wlan0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Mär 10 08:42:23 mint NetworkManager[677]: <warn>  [1741592543.5785] device (wlan0): Activation: (wifi) asking for new secrets
Mär 10 08:42:23 mint dbus-daemon[676]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.70' (uid=1000 pid=1897 comm="nm-applet " label="unconfined")
Mär 10 08:42:23 mint systemd[1]: Starting Hostname Service...
Mär 10 08:42:24 mint dbus-daemon[676]: [system] Successfully activated service 'org.freedesktop.hostname1'
Mär 10 08:42:24 mint systemd[1]: Started Hostname Service.
Mär 10 08:42:28 mint NetworkManager[677]: <info>  [1741592548.0772] device (wlan0): supplicant interface state: scanning -> inactive
Mär 10 08:42:36 mint NetworkManager[677]: <warn>  [1741592556.6988] device (wlan0): no secrets: User canceled the secrets request.
Mär 10 08:42:36 mint NetworkManager[677]: <info>  [1741592556.6988] device (wlan0): state change: need-auth -> failed (reason 'no-secrets', sys-iface-state: 'managed')
Mär 10 08:42:36 mint NetworkManager[677]: <info>  [1741592556.6993] manager: NetworkManager state is now CONNECTED_LOCAL
Mär 10 08:42:36 mint NetworkManager[677]: <warn>  [1741592556.7004] device (wlan0): Activation: failed for connection 'FB6660'
Mär 10 08:42:36 mint NetworkManager[677]: <info>  [1741592556.7008] device (wlan0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Mär 10 08:42:37 mint NetworkManager[677]: <info>  [1741592557.2188] policy: auto-activating connection 'FRITZ!Box 6660 Cable MH' (4f3313e5-ffb2-40fd-8ce5-d82b6fa167d2)
Mär 10 08:42:37 mint NetworkManager[677]: <info>  [1741592557.2234] device (wlan0): Activation: starting connection 'FRITZ!Box 6660 Cable MH' (4f3313e5-ffb2-40fd-8ce5-d82b6fa167d2)
Mär 10 08:42:37 mint NetworkManager[677]: <info>  [1741592557.2249] device (wlan0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Mär 10 08:42:37 mint NetworkManager[677]: <info>  [1741592557.2254] manager: NetworkManager state is now CONNECTING
Mär 10 08:42:37 mint NetworkManager[677]: <info>  [1741592557.2259] device (wlan0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mär 10 08:42:37 mint NetworkManager[677]: <info>  [1741592557.2263] device (wlan0): Activation: (wifi) access point 'FRITZ!Box 6660 Cable MH' has security, but secrets are required.
Mär 10 08:42:37 mint NetworkManager[677]: <info>  [1741592557.2263] device (wlan0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Mär 10 08:42:37 mint NetworkManager[677]: <info>  [1741592557.2265] sup-iface[1fae1a4f54976f19,1,wlan0]: wps: type pbc start...
Mär 10 08:42:37 mint wpa_supplicant[759]: wlan0: WPS-PBC-ACTIVE
Mär 10 08:42:37 mint NetworkManager[677]: <info>  [1741592557.2362] device (wlan0): supplicant interface state: inactive -> scanning
Mär 10 08:42:38 mint NetworkManager[677]: <warn>  [1741592558.9689] device (wlan0): no secrets: User canceled the secrets request.
Mär 10 08:42:38 mint NetworkManager[677]: <info>  [1741592558.9690] device (wlan0): state change: need-auth -> failed (reason 'no-secrets', sys-iface-state: 'managed')
Mär 10 08:42:38 mint NetworkManager[677]: <info>  [1741592558.9698] manager: NetworkManager state is now CONNECTED_LOCAL
Mär 10 08:42:38 mint NetworkManager[677]: <warn>  [1741592558.9706] device (wlan0): Activation: failed for connection 'FRITZ!Box 6660 Cable MH'
Mär 10 08:42:38 mint NetworkManager[677]: <info>  [1741592558.9711] device (wlan0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Mär 10 08:42:38 mint wpa_supplicant[759]: wlan0: Reject scan trigger since one is alreadyjo@mint:~$ journalctl -f
Mär 10 08:42:38 mint wpa_supplicant[759]: wlan0: Reject scan trigger since one is already pending
Mär 10 08:42:38 mint wpa_supplicant[759]: wlan0: WPS-CANCEL
 pending
Try this method, which has also helped another user with a similar problem:
EDIT: obviously you have to back to NetworkManager instead of iwd.
Thanks for the top, but sadly that didn’t work.
Here’s what happens when I try to connect:
Mar 11 00:05:19 manjaro wpa_supplicant[809]: wlp3s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Mar 11 00:05:22 manjaro wpa_supplicant[809]: wlp3s0: Reject scan trigger since one is already pending
Mar 11 00:05:39 manjaro plasmashell[1303]: qrc:/qt/qml/org/kde/plasma/components/ScrollView.qml:53:29: QML ScrollBar: Binding loop detected for property "visible":
                                           qrc:/qt/qml/org/kde/plasma/components/ScrollBar.qml:24:5
Mar 11 00:05:46 manjaro systemd[1161]: app-systemsettings@885187bdf22d4d058faeb99485a45750.service: Consumed 22.600s CPU time, 120M memory peak.
Mar 11 00:06:00 manjaro wpa_supplicant[809]: wlp3s0: Reject scan trigger since one is already pending
Mar 11 00:06:06 manjaro NetworkManager[2392]: <info>  [1741651566.5630] device (wlp3s0): Activation: starting connection 'The_Lodge2' (c66e9424-a299-46c2-b0f7-d3a2b27e4e16)
Mar 11 00:06:06 manjaro NetworkManager[2392]: <info>  [1741651566.5631] audit: op="connection-activate" uuid="c66e9424-a299-46c2-b0f7-d3a2b27e4e16" name="The_Lodge2" pid=1303 uid=1000 result="success"
Mar 11 00:06:06 manjaro NetworkManager[2392]: <info>  [1741651566.5632] device (wlp3s0): state change: disconnected -> prepare (reason 'none', managed-type: 'full')
Mar 11 00:06:06 manjaro NetworkManager[2392]: <info>  [1741651566.5636] manager: NetworkManager state is now CONNECTING
Mar 11 00:06:07 manjaro NetworkManager[2392]: <info>  [1741651567.0862] device (wlp3s0): set-hw-addr: reset MAC address to A0:99:9B:1B:BE:A9 (preserve)
Mar 11 00:06:07 manjaro NetworkManager[2392]: <info>  [1741651567.0898] device (wlp3s0): state change: prepare -> config (reason 'none', managed-type: 'full')
Mar 11 00:06:07 manjaro NetworkManager[2392]: <info>  [1741651567.0900] device (wlp3s0): Activation: (wifi) access point 'The_Lodge2' has security, but secrets are required.
Mar 11 00:06:07 manjaro NetworkManager[2392]: <info>  [1741651567.0901] device (wlp3s0): state change: config -> need-auth (reason 'none', managed-type: 'full')
Mar 11 00:06:07 manjaro NetworkManager[2392]: <info>  [1741651567.0914] device (wlp3s0): state change: need-auth -> prepare (reason 'none', managed-type: 'full')
Mar 11 00:06:07 manjaro NetworkManager[2392]: <info>  [1741651567.0919] device (wlp3s0): state change: prepare -> config (reason 'none', managed-type: 'full')
Mar 11 00:06:07 manjaro NetworkManager[2392]: <info>  [1741651567.0921] device (wlp3s0): Activation: (wifi) connection 'The_Lodge2' has security, and secrets exist.  No new secrets needed.
Mar 11 00:06:07 manjaro NetworkManager[2392]: <info>  [1741651567.0921] Config: added 'ssid' value 'The_Lodge2'
Mar 11 00:06:07 manjaro NetworkManager[2392]: <info>  [1741651567.0921] Config: added 'mode' value '2'
Mar 11 00:06:07 manjaro NetworkManager[2392]: <info>  [1741651567.0921] Config: added 'frequency' value '2437'
Mar 11 00:06:07 manjaro NetworkManager[2392]: <info>  [1741651567.0921] Config: added 'ht40' value '0'
Mar 11 00:06:07 manjaro NetworkManager[2392]: <info>  [1741651567.0921] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256'
Mar 11 00:06:07 manjaro NetworkManager[2392]: <info>  [1741651567.0922] Config: added 'psk' value '<hidden>'
Mar 11 00:06:07 manjaro wpa_supplicant[809]: Note: nl80211 driver interface is not designed to be used with ap_scan=2; this can result in connection failures
Mar 11 00:06:07 manjaro kded6[1254]: kf.networkmanagerqt: void NetworkManager::ConnectionPrivate::onPropertiesChanged(const QVariantMap&) Unhandled property "VersionId"
Mar 11 00:06:07 manjaro plasmashell[1303]: kf.networkmanagerqt: void NetworkManager::ConnectionPrivate::onPropertiesChanged(const QVariantMap&) Unhandled property "VersionId"
Mar 11 00:06:07 manjaro plasmashell[1303]: qrc:/qt/qml/org/kde/plasma/components/ScrollView.qml:53:29: QML ScrollBar: Binding loop detected for property "visible":
Mar 11 00:06:07 manjaro wpa_supplicant[809]: wlp3s0: interface state UNINITIALIZED->ENABLED
Mar 11 00:06:07 manjaro wpa_supplicant[809]: wlp3s0: AP-ENABLED
Mar 11 00:06:07 manjaro wpa_supplicant[809]: wlp3s0: CTRL-EVENT-CONNECTED - Connection to a0:99:9b:1b:be:a9 completed [id=0 id_str=]
Mar 11 00:06:07 manjaro NetworkManager[2392]: <info>  [1741651567.2883] device (wlp3s0): supplicant interface state: disconnected -> completed
Mar 11 00:06:07 manjaro NetworkManager[2392]: <info>  [1741651567.2884] device (wlp3s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Started Wi-Fi Hotspot "The_Lodge2"
Mar 11 00:06:07 manjaro NetworkManager[2392]: <info>  [1741651567.2884] device (p2p-dev-wlp3s0): supplicant management interface state: disconnected -> completed
Mar 11 00:06:07 manjaro NetworkManager[2392]: <info>  [1741651567.2885] device (wlp3s0): state change: config -> ip-config (reason 'none', managed-type: 'full')
Mar 11 00:06:07 manjaro NetworkManager[2392]: <info>  [1741651567.2890] dhcp4 (wlp3s0): activation: beginning transaction (timeout in 45 seconds)
Mar 11 00:06:12 manjaro wpa_supplicant[809]: wlp3s0: CTRL-EVENT-SCAN-FAILED ret=-11
Mar 11 00:06:12 manjaro kernel: ieee80211 phy0: brcmf_cfg80211_scan: Scanning suppressed: status (4)
Mar 11 00:06:22 manjaro wpa_supplicant[809]: wlp3s0: CTRL-EVENT-SCAN-FAILED ret=-11
Mar 11 00:06:22 manjaro kernel: ieee80211 phy0: brcmf_cfg80211_scan: Scanning suppressed: status (4)
Mar 11 00:06:33 manjaro wpa_supplicant[809]: wlp3s0: CTRL-EVENT-SCAN-FAILED ret=-11
Mar 11 00:06:33 manjaro kernel: ieee80211 phy0: brcmf_cfg80211_scan: Scanning suppressed: status (4)
Mar 11 00:06:44 manjaro wpa_supplicant[809]: wlp3s0: CTRL-EVENT-SCAN-FAILED ret=-11
Mar 11 00:06:44 manjaro kernel: ieee80211 phy0: brcmf_cfg80211_scan: Scanning suppressed: status (4)
Mar 11 00:06:52 manjaro NetworkManager[2392]: <info>  [1741651612.1774] device (wlp3s0): state change: ip-config -> failed (reason 'ip-config-unavailable', managed-type: 'full')
Mar 11 00:06:52 manjaro NetworkManager[2392]: <info>  [1741651612.1789] manager: NetworkManager state is now DISCONNECTED
Mar 11 00:06:52 manjaro NetworkManager[2392]: <warn>  [1741651612.1799] device (wlp3s0): Activation: failed for connection 'The_Lodge2'
Mar 11 00:06:52 manjaro NetworkManager[2392]: <info>  [1741651612.1807] device (wlp3s0): state change: failed -> disconnected (reason 'none', managed-type: 'full')
Mar 11 00:06:52 manjaro NetworkManager[2392]: <info>  [1741651612.2074] dhcp4 (wlp3s0): canceled DHCP transaction
Mar 11 00:06:52 manjaro NetworkManager[2392]: <info>  [1741651612.2075] dhcp4 (wlp3s0): activation: beginning transaction (timeout in 45 seconds)
Mar 11 00:06:52 manjaro NetworkManager[2392]: <info>  [1741651612.2075] dhcp4 (wlp3s0): state changed no lease
Mar 11 00:06:52 manjaro wpa_supplicant[809]: wlp3s0: interface state ENABLED->DISABLED
Mar 11 00:06:52 manjaro wpa_supplicant[809]: wlp3s0: AP-DISABLED
Mar 11 00:06:52 manjaro kernel: ieee80211 phy0: brcmf_vif_set_mgmt_ie: vndr ie set error : -52
Mar 11 00:06:53 manjaro kernel: usb 1-1: new high-speed USB device number 4 using xhci_hcd
Mar 11 00:06:53 manjaro wpa_supplicant[809]: wlp3s0: CTRL-EVENT-DISCONNECTED bssid=a0:99:9b:1b:be:a9 reason=3 locally_generated=1
This may be of interest.
Is this set to 2 on purpose?
A possible workaround would be to set ap_scan=1 in /etc/wpa_supplicant/wpa_supplicant.conf.
I might also suggest considering iwd to replace wpa_supplicant.
I note you seem to have tried already but there are numerous errors in the above messages.
iwd does not exclude NetworkManager and they can be used together.
But whether applying the backend config or using the networkmanager-iwd AUR package, when used with NM the service should not be enabled/started.
https://wiki.archlinux.org/title/NetworkManager#Using_iwd_as_the_Wi-Fi_backend
Finally there is the possibility this is simply the result of incompatibility.
  • Try down-grading wpa_supplicant
  • Those chips often have issues with 5GHz wifi, set to 2,4GHz
  • Try different/older ‘Wifi Security’ WPA settings on router
If nothing works switch driver to wl or b43 (needs b43-firmware pkg), see ‘Internet’ section here.
My friend Tom has to use a dongle to get wifi to work. Have you tried a dongle?
That’s what I ended up doing. I had a $10 BT/wifi dongle I was using for my MiSTer so I tried that and it connected straight away.
I might try the suggestions of 6x12 to change the driver, but the dongle is working just fine.
Thank you everyone for your suggestions. Manjaro is such as great distro, and these forums are a really great place to hang out.
