Hi, I am new to linux and this is my first time installing Manjaro.
My wifi is not working since installation. It worked fine on windows and ubuntu.
I guess the software for network adapter is not installed. output for inxi
Kernel: 5.10.41-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=fa1d89df-84a7-4b37-8cb0-6a22e420f31f rw quiet apparmor=1
Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: HP product: HP Laptop 15-da0xxx v: Type1ProductConfigId
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 84AA v: 82.43 serial: <filter> UEFI: Insyde v: F.21
date: 07/25/2019
ID-1: BAT1 charge: 5.8 Wh (14.5%) condition: 39.9/41.9 Wh (95.1%)
volts: 10.8 min: 11.6 model: COMPAL PABAS0241231 type: Li-ion
serial: <filter> status: Discharging
RAM: total: 3.66 GiB used: 1.96 GiB (53.5%)
Info: Dual Core model: Intel Celeron N4000 bits: 64 type: MCP
arch: Goldmont Plus family: 6 model-id: 7A (122) stepping: 1 microcode: 34
cache: L2: 4 MiB bogomips: 4378
Speed: 796 MHz min/max: 800/2600 MHz Core speeds (MHz): 1: 796 2: 796
Flags: 3dnowprefetch acpi aes aperfmperf apic arat arch_capabilities
arch_perfmon art bts cat_l2 cdp_l2 clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts erms est fpu fsgsbase
fxsr ht ibpb ibrs ibrs_enhanced ida intel_pt lahf_lm lm mca mce md_clear mmx
monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdpid rdrand rdseed rdt_a
rdtscp rep_good sdbg sep sha_ni smap smep ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tsc tsc_adjust tsc_deadline_timer tsc_known_freq
umip vme x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Device-1: Intel UHD Graphics 605 vendor: Hewlett-Packard driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:3185 class-ID: 0300
Device-2: Cheng Uei Precision Industry (Foxlink) HP TrueVision HD Camera
type: USB driver: uvcvideo bus-ID: 1-5:4 chip-ID: 05c8:03d2 class-ID: 0e02
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0
screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 102 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel UHD Graphics 600 (GLK 2) v: 4.6 Mesa 21.1.2
direct render: Yes
Device-1: Intel Celeron/Pentium Silver Processor High Definition Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:0e.0 chip-ID: 8086:3198
class-ID: 0403
Sound Server-1: ALSA v: k5.10.41-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.28 running: no
vendor: Hewlett-Packard driver: r8168 v: 8.048.03-NAPI modules: r8169
port: 2000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: N/A modules: rtw88_8821ce port: 1000
bus-ID: 02:00.0 chip-ID: 10ec:c821 class-ID: 0280
IF-ID-1: enp0s21f0u1 state: unknown speed: N/A duplex: N/A mac: <filter>
Device-1: Xiaomi Mi/Redmi series (RNDIS) type: USB driver: rndis_host
v: kernel bus-ID: 1-1:5 chip-ID: 2717:ff80 class-ID: 0a00 serial: <filter>
Device-2: Realtek Realtek Bluetooth 4.2 Adapter type: USB driver: btusb
v: 0.8 bus-ID: 1-4:3 chip-ID: 0bda:b00a class-ID: e001 serial: <filter>
Report: ID: hci0 rfk-id: 0 state: up address: N/A
Local Storage: total: 465.76 GiB used: 17.39 GiB (3.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD5000LPCX-60VHAT1 size: 465.76 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: 1A03
scheme: GPT
Optical-1: /dev/sr0 vendor: hp model: DVDRW DA8AESH rev: XH6M
dev-links: cdrom
rw: cd-r,cd-rw,dvd-r state: running
ID-1: / raw-size: 465.46 GiB size: 457.09 GiB (98.20%)
used: 17.39 GiB (3.8%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: fa1d89df-84a7-4b37-8cb0-6a22e420f31f
used: 296 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: D6DA-2E05
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 9 rev: 2.0
Device-1: 1-1:5 info: Xiaomi Mi/Redmi series (RNDIS)
type: Bluetooth,CDC-Data driver: rndis_host interfaces: 2 rev: 2.1
speed: 480 Mb/s power: 500mA chip-ID: 2717:ff80 class-ID: 0a00
serial: <filter>
Device-2: 1-4:3 info: Realtek Realtek Bluetooth 4.2 Adapter type: Bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA
Device-3: 1-5:4
info: Cheng Uei Precision Industry (Foxlink) HP TrueVision HD Camera
type: Video driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s
power: 500mA chip-ID: 05c8:03d2 class-ID: 0e02
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 7 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 49.0 C mobo: 20.0 C
Processes: 143 Uptime: 9m wakeups: 3 Init: systemd v: 247 tool: systemctl
Compilers: gcc: N/A Packages: pacman: 1187 lib: 324 flatpak: 0 Shell: Bash
v: 5.1.8 running-in: konsole inxi: 3.3.04
Any help would be appreciated.
Thanks in advance.
