So this has been a journey, and I’m just at a loss as to what to do. I’m on a dual boot with Windows, and I was noticing that wifi was faster/connecting from farther on Windows, so I did research and saw that there were alternate drivers on the AUR. After a lot of messing around, I did manage to switch them, but now my wifi is broken. Ethernet/USB tethering and Bluetooth still work, just Wifi, which is really odd. No networks show up in the tray and the checkbox cannot be toggled in the tray.
Here is inxi -Fxxza
System: Kernel: 5.8.3-2-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64 root=UUID=d6824384-9dfc-4f7d-b68a-8f8b487fda10 rw quiet
apparmor=1 security=apparmor resume=UUID=24908b5b-e96b-4e3a-acc1-ed049bd1aadf udev.log_priority=3 acpi_osi=
Desktop: KDE Plasma 5.19.4 tk: Qt 5.15.0 wm: kwin_x11 dm: LightDM 1.30.0, SDDM Distro: Manjaro Linux
Machine: Type: Convertible System: HP product: HP ENVY x360 Convertible 15-ds0xxx v: N/A serial: <filter> Chassis:
type: 31 serial: <filter>
Mobo: HP model: 85DD v: 40.36 serial: <filter> UEFI: AMI v: F.18 date: 11/07/2019
Battery: ID-1: BAT0 charge: 49.7 Wh condition: 53.9/53.9 Wh (100%) volts: 17.4/15.1 model: 333-AC-3E-A SA04055XL
type: Li-ion serial: <filter> status: Charging
CPU: Topology: Quad Core model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx bits: 64 type: MT MCP arch: Zen+
family: 17 (23) model-id: 18 (24) stepping: 1 microcode: 8108102 L2 cache: 2048 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 33550
Speed: 1397 MHz min/max: 1400/2100 MHz boost: enabled Core speeds (MHz): 1: 1397 2: 1393 3: 1291 4: 1222
5: 1253 6: 1296 7: 1397 8: 1395
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP: disabled, RSB filling
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Picasso vendor: Hewlett-Packard driver: amdgpu v: kernel
bus ID: 04:00.0 chip ID: 1002:15d8
Device-2: Cheng Uei Precision Industry (Foxlink) HP Wide Vision HD Camera type: USB driver: uvcvideo
bus ID: 3-1:2 chip ID: 05c8:03d3
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: amdgpu FAILED: ati unloaded: modesetting
alternate: fbdev,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 142 size: 344x194mm (13.5x7.6") diag: 395mm (15.5")
OpenGL: renderer: AMD RAVEN (DRM 3.38.0 5.8.3-2-MANJARO LLVM 10.0.1) v: 4.6 Mesa 20.1.6 direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus ID: 04:00.1 chip ID: 1002:15de
Device-2: Advanced Micro Devices [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: Hewlett-Packard driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x bus ID: 04:00.5
chip ID: 1022:15e2
Device-3: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Hewlett-Packard driver: snd_hda_intel
v: kernel bus ID: 04:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.8.3-2-MANJARO
Network: Device-1: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter vendor: Hewlett-Packard driver: rtw_8822be v: N/A
modules: rtw88_8822be port: f000 bus ID: 02:00.0 chip ID: 10ec:b822
IF: wlo1 state: down mac: <filter>
IF-ID-1: enp4s0f3u2 state: unknown speed: N/A duplex: N/A mac: <filter>
Drives: Local Storage: total: 238.47 GiB used: 54.51 GiB (22.9%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB256HAHQ-000H1 size: 238.47 GiB block size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: EXD70H1Q scheme: GPT
Partition: ID-1: / raw size: 73.66 GiB size: 72.26 GiB (98.09%) used: 54.51 GiB (75.4%) fs: ext4 dev: /dev/nvme0n1p8
Swap: Kernel: swappiness: 60 (default) cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 8.26 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p9
Sensors: System Temperatures: cpu: 56.5 C mobo: 44.0 C gpu: amdgpu temp: 56 C
Info: Processes: 254 Uptime: 1h 29m Memory: 29.33 GiB used: 2.21 GiB (7.5%) Init: systemd v: 246 Compilers:
gcc: 10.2.0 clang: 10.0.1 Packages: pacman: 1677 lib: 422 flatpak: 0 Shell: Bash v: 5.0.18
running in: konsole inxi: 3.1.05
Here is `rfkill list all’:
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
1: hp-wifi: Wireless LAN
Soft blocked: yes
Hard blocked: yes
2: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
Of note is that when I started this process, hp-wifi did not even exist, and the wifi did work. Wifi does work on the Windows OS.
