Hey, Manjaro team and enthusiasts.
Usually when I go with Ubuntu-based distribution and something is not working, it is working on Manjaro and this made Manjaro one of my favorite distributions and first choice.
This time I have a problem. My WiFi is not detected at all. Ethernet cable connection is working without any problems.
Searched here and there, usually, I find fixes on my own, this time I couldn’t.
So I switched to Ubuntu to try a fix I found online: GitHub - lwfinger/rtw89: Driver for Realtek 8852AE, an 802.11ax device .
And this made my WiFi work. Later discovered “same” fix in the aur.
The only problem is you need to do after every kernel update.
I know manjaro adds its own fixes. Any way this can be baked in the OS?
Thanks for the hard work.
