As the title says my wifi doesn’t connect after my system starts (i have a dual boot with windows). It tries to connect and fails and keeps asking me for password. But if i run sudo modprobe -rv iwlmvm
followed by sudo modprobe iwlmvm
and switch off and on the wifi, it starts working normally and is able to connect to network without needing to enter password (it is saved). I had this same problem on PopOS and also on Linux Mint (on a different machine). But this problem does not exist on Windows. How can I fix this? Is it a problem with the wifi router or the Linux drivers?
Make sure that fastboot and Windows hibernation are disabled. Always shut Windows completely down when in a dual boot situation. If you had the same problem with Mint and PopOS then it isn’t really a Manjaro problem.
