I’ve installed Manjaro (+KDE Plasma) on my 2012 11" MacBook Air. My Networks module in the system tray will list available wifi networks but is unable to log into any of them after entering the password. I have tested this with two different networks on my router (the 5 GHz and 2.4GHz ones), as well as my phone’s hotspot.
I have validated that my machine’s network hardware is good, as I am writing this from an Ubuntu partition on the same computer; here login works as expected.
Potentially relevant info:
Network controller: Broadcom Inc. and subsidiaries BCM43224 802.11a/b/g/n (rev 01)
Host: MacBookAir4,1 1.0
CPU: Intel i7-2677M (4) @ 2.900GHz
GPU: Intel 2nd Generation Core Processor Family
Is there a specific kernel or driver I should be using? What steps should I take to get wifi working properly on my Manjaro partition?
I have not exactly the same (Broadcom BMX 4360) than you but I’ve checked to this link and it is the same driver. Keep in mind that something after an update this driver is not updated. I have add this situation one time after 1 year 1/2 without any issue. And never after.
In fact there are two drivers from Broadcom and it is the first which is installed by default. i don’t know why but at least for me it has never worked for me. But the second always.
You must install the broadcom-wl-dkms
sudo pacman -S broadcom-wl-dkms
You can simply use pamac for this task or Octopi which are the both graphical tools.
