Не работает wifi с networkmanager
#1
Здравствуйте! При нажатии на “Включить wi-fi” в networkmanager ничего не происходит, однако с помощью wifi-menu я могу подключиться.
сервисы
accounts-daemon.service loaded active running Accounts Service
alsa-restore.service loaded active exited Save/Restore Sound Card State
bluetooth.service loaded active running Bluetooth service
bumblebeed.service loaded active running Bumblebee C Daemon
cronie.service loaded active running Periodic Command Scheduler
dbus.service loaded active running D-Bus System Message Bus
kmod-static-nodes.service loaded active exited Create list of required static device nodes for the current kernel
ldconfig.service loaded active exited Rebuild Dynamic Linker Cache
lightdm.service loaded active running Light Display Manager
ModemManager.service loaded active running Modem Manager
netctl@wlp3s0\x2dcall\x20me\x20maybe.service loaded active exited Networking for netctl profile wlp3s0-call me maybe
NetworkManager.service loaded active running Network Manager
ntpd.service loaded active running Network Time Service
polkit.service loaded active running Authorization Manager
rtkit-daemon.service loaded active running RealtimeKit Scheduling Policy Service
systemd-backlight@backlight:intel_backlight.service loaded active exited Load/Save Screen Backlight Brightness of backlight:intel_backlight
systemd-journal-catalog-update.service loaded active exited Rebuild Journal Catalog
systemd-journal-flush.service loaded active exited Flush Journal to Persistent Storage
systemd-journald.service loaded active running Journal Service
systemd-logind.service loaded active running Login Service
systemd-modules-load.service loaded active exited Load Kernel Modules
systemd-random-seed.service loaded active exited Load/Save Random Seed
systemd-remount-fs.service loaded active exited Remount Root and Kernel File Systems
systemd-sysctl.service loaded active exited Apply Kernel Variables
systemd-sysusers.service loaded active exited Create System Users
systemd-tmpfiles-setup-dev.service loaded active exited Create Static Device Nodes in /dev
systemd-tmpfiles-setup.service loaded active exited Create Volatile Files and Directories
systemd-udev-trigger.service loaded active exited udev Coldplug all Devices
systemd-udevd.service loaded active running udev Kernel Device Manager
systemd-update-done.service loaded active exited Update is Completed
systemd-update-utmp.service loaded active exited Update UTMP about System Boot/Shutdown
systemd-user-sessions.service loaded active exited Permit User Sessions
upower.service loaded active running Daemon for power management
user@1000.service loaded active running User Manager for UID 1000
сетевая карта
03:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8821AE 802.11ac PCIe Wireless Network Adapter
04:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethenet Controller (rev 10)
Как настроить wifi подключение через networkmanager?
#2
Здравствуйте! Добро пожаловать!
Какое у вас окружение рабочего стола?
Пробовали в терминале nmtui?
#3
По моему я догадываюсь, в чём может быть проблема.
Нельзя одновременно включать NetworkManager и netctl (wifi-menu).
sudo netctl disable wlp3s0-dcall-0me-0maybe
sudo systemctl stop netctl@wlp3s0\x2dcall\x20me\x20maybe.service
sudo systemctl enable NetworkManager
sudo systemctl start NetworkManager
Потом или nmtui или для разборки, если будут проблемы
nmcli device wifi rescan
nmcli device wifi list
nmcli device wifi connect [ssid] password [password]
nmcli device status
#4
А не проще ли через аплет NM создать соединение wi-fi с указанием SSID, MAC-адреса карты, типа шифрования и пароля? С указанием автоподключения.
#5
Не проще чем что?
Нужно по любому сначала отключить netctl и включить NetworkManager.
#6
Не проще чем что?
Чем использовать nmcli. Это ж каждый раз набирать руками, или создавать батник и засовывать его в автостарт. Зачем выстругивать новый костыль, если уже есть готовый.
К тому же NetworkManager ведь включен:
#7
nmcli я предложил только для диагностики, так как из nmtui сложно скопировать результат терминала.
Значит включать самому не обязательно, но отключить netctl нужно будет.
#8
Это да. Непонятно только, как он включен-то оказался. При установке системы он не включен. Похоже на шаловливые ручки :slight_smile:
#9
@ikimi4 читали ArchWiki, там с wifi-menu инсталяция начинается.
closed #10
