Hello all.
I’m a Manjaro noob, using KDE and I’m having issues with my WiFi. My WiFi was working just fine before recent updates. However, now my laptop isn’t connecting to my home WiFi network. I can see other wireless networks. I’ve tried entering the password for my home wireless network and the following displays:
Wireless interface wlp4s0 Authorization supplicant failed
Connection deactivated
Here’s what my inxi -Fazy command returned:
Kernel: 5.16.11-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.16-x86_64
root=UUID=f1589404-1a69-4c95-84b0-ad1ddbffca96 rw quiet apparmor=1
Console: pty pts/1 wm: kwin_x11 DM: SDDM Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: LENOVO product: 20DKS05400 v: ThinkPad S1 Yoga 12
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 20DKS05400 v: SDK0E50510 WIN serial: <filter>
UEFI-[Legacy]: LENOVO v: JEET85WW (1.34 ) date: 10/11/2018
ID-1: BAT0 charge: 42.4 Wh (100.0%) condition: 42.4/47.1 Wh (90.0%)
volts: 16.4 min: 14.8 model: SONY 45N1705 type: Li-poly serial: <filter>
status: Full
Info: model: Intel Core i7-5600U socket: BGA1168 (U3E1) note: check bits: 64
type: MT MCP arch: Broadwell family: 6 model-id: 0x3D (61) stepping: 4
microcode: 0x2F
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1236 high: 1369 min/max: 500/3200 base/boost: 2600/3600
scaling: driver: intel_cpufreq governor: schedutil volts: 1.1 V
ext-clock: 100 MHz cores: 1: 920 2: 1362 3: 1369 4: 1293 bogomips: 20760
Type: l1tf
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Device-1: Intel HD Graphics 5500 vendor: Lenovo driver: i915 v: kernel
ports: active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:1616 class-ID: 0300
Display: server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0
screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 model: LG built: 2013 res: 1920x1080 hz: 60 dpi: 177
gamma: 1.2 size: 276x156mm (10.9x6.1") diag: 317mm (12.5") ratio: 16:9
modes: 1920x1080
OpenGL: renderer: Mesa Intel HD Graphics 5500 (BDW GT2) v: 4.6 Mesa 21.3.7
direct render: Yes
Device-1: Intel Broadwell-U Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 00:03.0 chip-ID: 8086:160c class-ID: 0403
Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9ca0
class-ID: 0403
Sound Server-1: ALSA v: k5.16.11-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.47 running: yes
Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:095b class-ID: 0280
IF: wlp4s0 state: down mac: <filter>
Device-2: ASIX AX88179 Gigabit Ethernet type: USB driver: ax88179_178a
bus-ID: 3-1.1:3 chip-ID: 0b95:1790 class-ID: ff00 serial: <filter>
IF: enp0s20u1u1 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 238.47 GiB used: 22.76 GiB (9.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: THNSFJ256GCSU
family: HG6 Series SSD size: 238.47 GiB block-size: physical: 512 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 1102 temp: 29 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 285d 7h cycles: 4493
ID-1: / raw-size: 238.47 GiB size: 233.67 GiB (97.99%)
used: 22.76 GiB (9.7%) fs: ext4 block-size: 4096 B dev: /dev/sda1
maj-min: 8:1
System Temperatures: cpu: 53.0 C pch: 43.5 C mobo: 1.0 C
Fan Speeds (RPM): cpu: 257
Processes: 195 Uptime: 27m wakeups: 1 Memory: 7.42 GiB
used: 2.09 GiB (28.1%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1217 lib: 335 flatpak: 0
Shell: Bash (sudo) v: 5.1.16 running-in: konsole inxi: 3.3.13
I need help to figure out what I can do to get my laptop connected to my home wireless network. I’m currently working off a usb ethernet adapter to connect to the internet.
I also have a Lenovo Thinkpad Yoga 12 laptop and I’m running the KDE desktop environment. I don’t know if this helps.
I have a similar issue, can’t get it towork either, I rolled back recent upgrades and it works again, sadly there’s not a lot or even no information in the logs either regarding the issues. For me it just get’s stuck at authorization and after a while just stopps.
Thinkpad P15v here.
Hello,
Gonzo_909:
driver: iwlwifi
See those two linked topics from here
I have similar issue with Wifi since upgrading packages around February 28th. I’m using Lenovo ThinkPad T460s.
I’m able to select network and attempt to connect to it, but it always ends with an error “Failed to get secrets”.
I found a post on forum that the issue might be related to networkmanager
1.36, but when I checked what version is on my device it turned out it is 1.34 which should worked fine based on the comments.
https://bugs.archlinux.org/task/73948
I also found similar information about wpa_supplicant
having issues on 2.10. I used pamac
to downgrade to 2.9, but with no success.
https://forum.manjaro.org/t/wifi-connection-fails-on-thinkpad-x230/103659/3
Here’s output from commands that were suggested in other threads:
inxi -Fxxxza --no-host
root=UUID=26f2dfe3-2e65-4241-ac69-d579868ab1a6 rw quiet apparmor=1
security=apparmor resume=UUID=4fd3670e-e13b-41fd-8799-597dd2ddd569
udev.log_priority=3
Desktop: KDE Plasma 5.24.2 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: LENOVO product: 20F90061MS v: ThinkPad T460s
Mobo: LENOVO model: 20F90061MS v: SDK0J40705 WIN
serial: <superuser required> UEFI: LENOVO v: N1CET79W (1.47 )
date: 11/25/2019
ID-1: BAT0 charge: 9.5 Wh (48.5%) condition: 19.6/23.5 Wh (83.3%)
volts: 11.2 min: 11.4 model: SMP 00HW023 type: Li-poly serial: <filter>
status: Discharging
ID-2: BAT1 charge: 19.6 Wh (100.0%) condition: 19.6/26.3 Wh (74.5%)
volts: 12.6 min: 11.4 model: SANYO 01AV405 type: Li-ion serial: <filter>
status: Not charging
Info: model: Intel Core i5-6300U bits: 64 type: MT MCP arch: Skylake
family: 6 model-id: 0x4E (78) stepping: 3 microcode: 0xEC
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 900 min/max: 400/3000 scaling: driver: intel_pstate
governor: powersave cores: 1: 900 2: 900 3: 900 4: 900 bogomips: 20004
Type: l1tf
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Lenovo driver: i915
v: kernel ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
Device-2: Acer ThinkPad P50 Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-8:4 chip-ID: 5986:0706 class-ID: 0e02
Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 120 s-size: 406x228mm (16.0x9.0")
s-diag: 466mm (18.3")
Monitor-1: eDP-1 model: AU Optronics built: 2016 res: 1920x1080 hz: 60
dpi: 158 gamma: 1.2 size: 309x173mm (12.2x6.8") diag: 354mm (13.9")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 21.3.7
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d70 class-ID: 0403
Sound Server-4: PipeWire v: 0.3.47 running: no
Device-1: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:156f class-ID: 0200
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:24f3 class-ID: 0280
Local Storage: total: 238.47 GiB used: 90.22 GiB (37.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Intel model: SSDSCKKF256H6L
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: L12P scheme: GPT
ID-1: / raw-size: 97.66 GiB size: 95.62 GiB (97.92%)
used: 44.25 GiB (46.3%) fs: ext4 dev: /dev/sda3 maj-min: 8:3
ID-2: /boot/efi raw-size: 513 MiB size: 512 MiB (99.80%)
used: 308 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 85.32 GiB size: 82.98 GiB (97.26%)
used: 45.97 GiB (55.4%) fs: ext4 dev: /dev/sda4 maj-min: 8:4
ID-1: swap-1 type: partition size: 4.88 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 28.0 C pch: 27.5 C mobo: N/A
Fan Speeds (RPM): fan-1: 0
Processes: 169 Uptime: 6m wakeups: 7 Memory: 7.62 GiB
used: 1.23 GiB (16.1%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: 1775 pacman: 1767 lib: 458 flatpak: 0
snap: 8 Shell: Zsh v: 5.8.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.13
dmesg | grep iwl
[ 3.231145] iwlwifi 0000:04:00.0: enabling device (0000 -> 0002)
[ 3.242317] iwlwifi 0000:04:00.0: loaded firmware version 36.ca7b901d.0 8000C-36.ucode op_mode iwlmvm
[ 3.802453] iwlwifi 0000:04:00.0: Detected Intel(R) Dual Band Wireless AC 8260, REV=0x204
[ 3.880489] iwlwifi 0000:04:00.0: base HW address: f0:d5:bf:f6:c6:e2
[ 3.970896] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[ 3.993756] iwlwifi 0000:04:00.0 wlp4s0: renamed from wlan0
6x12
6 March 2022 20:00
5
Could be the firmware:
This is not a support request, I’ve already solved my problem. But I want to open this so that others encountering the same issue can find it and not suffer like I did
Unfortunately Intel has a habit of breaking AX20x series wifi/bluetooth chips with updates to iwlwifi. This issue has been encountered in may places, the most comprehensive documentation of this can be found here . Typically the issues with bad firmware manifest themselves as unstable bluetooth connections, frequ…
I’m on different hardware but lost a single connection (client broadcom/host qualcom, both manjaro) after the update that threw the ‘missing fw’ pamac warning on the client. Tried all 3 drivers, downgraded wpa_supplicant, same issue, however, current live iso can connect.
It’s not for me, I narrowed it down to KDE and KDE-framworks now,
Plasma 5.23.5 + Frameworks 5.90.0 is fine, 5.24.2 + 5.91.0 is not.
Problem came up with Feb. 27th upgrade, I upgraded and downgraded a bunch of times to find out what can and cannot be upgraded, linux-firmware doesn’t seem to be the cause, both old and new versions work with old KDE but both don’t with new. Also bluetooth is always disabled on boot with new KDE, even if set to be enabled on boot.
I posted a workaround that I found on the KDE forum here:
There seems to be a workaround:
https://bugs.kde.org/show_bug.cgi?id=449984
TL;DR
~/.config/kioslaverc should look like this:
[Proxy Settings]
ProxyType=0
Reboot, and it should work. If proxy settings are necessary, Wifi can still be enabled via commandline:
nmcli --ask connection up <connection>
It goes as follows:
449984 – Plasma 5.24.0 NetworkManager cannot get secrets using DBus when using a proxy
TL;DR
[Proxy Settings]
ProxyType=0
I decided to do a full reinstall of the system and it seems to have solved the problem. This is not the best solution as I even had to nuke my /home folder as even after first reinstall some config still persisted and still cause WiFi issues.
There were also other problems like “Add Software” freezing when typing in a search box, so I guess there were some deeper issues that I have no sufficient knowledge to be able to resolve myself.
