I’m booting manjaro on my pendrive, and after selecting the open source option and loading into the installation screen It freezes after ~30 seconds, but I’m still able to move my mouse. I’m kinda noob at this, so I have no clue on why its happening
I have also no clue becuase you haven’t shared any system info
See how to provide basic Information:
somehow i got the system to run and was able to type the command and stuff
Kernel: 5.15.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
misobasedir=manjaro misolabel=MANJARO_XFCE_2121 quiet
systemd.show_status=1 apparmor=1 security=apparmor driver=free
nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: SAMSUNG product: QX310/QX410/QX510/SF310/SF410/SF510
v: 05MX serial: <superuser required> Chassis: type: 9
Mobo: SAMSUNG model: QX310/QX410/QX510/SF310/SF410/SF510 v: 05MX
serial: <superuser required> BIOS: American Megatrends
v: 05MX.M008.20110525.SCY date: 05/25/2011
ID-1: BAT1 charge: 43.3 Wh (100.0%) condition: 43.3/61.0 Wh (70.9%)
volts: 12.2 min: 11.1 model: SAMSUNG Electronics type: Li-ion serial: N/A
status: Full
RAM: total: 3.62 GiB used: 1.33 GiB (36.6%)
RAM Report:
Info: model: Intel Core i3 M 370 bits: 64 type: MT MCP arch: Westmere
family: 6 model-id: 0x25 (37) stepping: 5 microcode: 0x7
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1462 high: 1463 min/max: 933/2399 scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 1463 2: 1463 3: 1462
4: 1463 bogomips: 19157
Flags: acpi aperfmperf apic arat arch_perfmon bts clflush cmov
constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts ept est flexpriority
flush_l1d fpu fxsr ht ibpb ibrs lahf_lm lm mca mce mmx monitor msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pdcm pebs pge pni popcnt pse pse36
pti rdtscp rep_good sep ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
tm2 tpr_shadow tsc vme vmx vnmi vpid xtopology xtpr
Type: l1tf
Type: mds
status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT vulnerable
Device-1: Intel Core Processor Integrated Graphics vendor: Samsung Co
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0046 class-ID: 0300
Device-2: NVIDIA GT218M [GeForce 310M] vendor: Samsung Co driver: nouveau
v: kernel bus-ID: 01:00.0 chip-ID: 10de:0a70 class-ID: 0302
Device-3: Silicon Motion WebCam SCB-0370N type: USB driver: uvcvideo
bus-ID: 1-1.4:3 chip-ID: 2232:1001 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.21.1.2 compositor: xfwm4 v: 4.16.1 driver:
loaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: LVDS-1 res: 1366x768 hz: 60 dpi: 112
size: 309x174mm (12.2x6.9") diag: 355mm (14")
Device-1: Intel 5 Series/3400 Series High Definition Audio
vendor: Samsung Co driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:3b56 class-ID: 0403
Device-2: NVIDIA High Definition Audio driver: snd_hda_intel v: kernel
bus-ID: 01:00.1 chip-ID: 10de:0be3 class-ID: 0403
Sound Server-1: ALSA v: k5.15.12-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.42 running: no
Device-1: Broadcom BCM4313 802.11bgn Wireless Network Adapter vendor: Askey
driver: bcma-pci-bridge v: N/A modules: bcma bus-ID: 02:00.0
chip-ID: 14e4:4727 class-ID: 0280
Device-2: Marvell Yukon Optima 88E8059 [PCIe Gigabit Ethernet with AVB]
vendor: Samsung Co driver: sky2 v: 1.30 port: b000 bus-ID: 03:00.0
chip-ID: 11ab:4381 class-ID: 0200
IF-ID-1: wlp2s0b1 state: down mac: <filter>
WAN IP: No WAN IP found. Connected to web? SSL issues? Try enabling dig
Local Storage: total: 252.87 GiB used: 0 KiB (0.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WDS240G2G0A-00JH30 size: 223.57 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: SSD serial: <filter> rev: 0400
scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 type: USB model: N/A size: 29.3 GiB
block-size: physical: 512 B logical: 512 B type: N/A serial: <filter>
rev: 2.00 scheme: MBR
Message: No partition data found.
ID-1: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: ntfs
label: Reservado pelo Sistema uuid: C2AEC2EEAEC2DA55
ID-2: /dev/sda2 maj-min: 8:2 size: 173.4 GiB fs: ntfs label: N/A
uuid: 01D805721A5469E0
ID-3: /dev/sda3 maj-min: 8:3 size: 1 KiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/sda5 maj-min: 8:5 size: 50.07 GiB fs: ntfs label: N/A
uuid: 01D805721F84B0F0
ID-5: /dev/sdb1 maj-min: 8:17 size: 29.3 GiB fs: vfat label: UUI
uuid: 5057-EFD8
ID-6: /dev/sdb4 maj-min: 8:20 size: 3.33 GiB fs: iso9660
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
speed: 480 Mb/s chip-ID: 8087:0020 class-ID: 0900
Device-1: 1-1.4:3 info: Silicon Motion WebCam SCB-0370N type: Video
Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Device-1: 2-1.1:3 info: USB Disk 2.0 type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 100mA
chip-ID: ffff:5678 class-ID: 0806 serial: <filter>
Device-2: 2-1.2:4 info: Logitech G203 LIGHTSYNC Gaming Mouse
type: Mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 300mA chip-ID: 046d:c092 class-ID: 0300
serial: <filter>
System Temperatures: cpu: 65.0 C mobo: 65.0 C gpu: nouveau temp: 55.0 C
Processes: 203 Uptime: 3m wakeups: 1 Init: systemd v: 250 tool: systemctl
Compilers: gcc: N/A Packages: pacman: 1150 lib: 317 flatpak: 0 Shell: Bash
v: 5.1.12 running-in: xfce4-terminal inxi: 3.3.11
is there something wrong in here
ok so, I proceeded with the installation and it went alright. not sure what was happening, but im using manjaro now, and it seems like its 100% working. still gotta test other things
