Hi, I am a newbie here, I updated my system, a couple of days ago, after an update, I noticed a drop in internet speed.
My wifi speed is 150 Mbps(5GHz) meanwhile I am getting only 30 Mbps (at max), checked through my phone and other devices, Wifi speed is fine.
I am on dual boot, so I tried it in Windows and there it is normal.
Already tried these things:-
- Update drivers.
- Downgraded to 5.13 Kernel and Upgraded back.
- Rebooted my device and wifi.
- Tried this speed test on ubuntu(I had it also on boot, ubuntu also have the same issue)
- Tried different browsers and speed test sites.
Required Info:-
inxi -Fazy
Kernel: 5.16.2-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.16-x86_64
root=UUID=6d05b175-1995-4c5a-b920-523159456756 rw quiet apparmor=1
Desktop: KDE Plasma 5.23.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Acer product: Aspire E5-573 v: V3.72
serial: <superuser required>
Mobo: Acer model: ZORO_BH v: Type2 - A01 Board Version
serial: <superuser required> UEFI: Insyde v: 1.15 date: 05/27/2015
ID-1: BAT1 charge: 19.1 Wh (87.2%) condition: 21.9/37.0 Wh (59.2%)
volts: 16.1 min: 14.8 model: SANYO AL15A32 type: Li-ion serial: <filter>
status: Discharging
Info: model: Intel Core i3-5005U bits: 64 type: MT MCP arch: Broadwell
family: 6 model-id: 0x3D (61) stepping: 4 microcode: 0x2F
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1217 high: 1900 min/max: 500/1900 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1129 2: 917 3: 1900
4: 925 bogomips: 16006
Type: l1tf
Device-1: Intel HD Graphics 5500 vendor: Acer Incorporated ALI driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:1616 class-ID: 0300
Device-2: Sunplus Innovation HD WebCam type: USB driver: uvcvideo
bus-ID: 2-7:4 chip-ID: 1bcf:2c81 class-ID: 0e02
Display: x11 server: X.Org 1.21.1.3 compositor: kwin_x11 driver:
loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP-1 res: 1366x768 hz: 60 dpi: 101 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
Device-1: Intel Broadwell-U Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:160c
class-ID: 0403
Device-2: Intel Wildcat Point-LP High Definition Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:9ca0 class-ID: 0403
Sound Server-1: ALSA v: k5.16.2-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.43 running: yes
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 3000
bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Foxconn driver: ath10k_pci v: kernel bus-ID: 03:00.0
chip-ID: 168c:0042 class-ID: 0280
Device-1: Foxconn / Hon Hai type: USB driver: btusb v: 0.8 bus-ID: 2-5:6
chip-ID: 0489:e09c class-ID: e001
Local Storage: total: 1.13 TiB used: 521.58 GiB (45.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WDS240G2G0A-00JH30 size: 223.58 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 0000
scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD10JPVX-22JC3T0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: 1A01 scheme: MBR
ID-1: / raw-size: 83.58 GiB size: 81.71 GiB (97.77%) used: 73.06 GiB (89.4%)
fs: ext4 dev: /dev/sda5 maj-min: 8:5
used: 25.3 MiB (26.3%) fs: vfat dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 42.0 C mobo: N/A
Processes: 204 Uptime: 26m wakeups: 1 Memory: 11.6 GiB
used: 2.15 GiB (18.6%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1372 lib: 368 flatpak: 0
Shell: Zsh v: 5.8 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.12
mhwd -l
> 0000:02:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
NAME VERSION FREEDRIVER TYPE
network-r8168 2016.04.20 true PCI
> 0000:00:02.0 (0300:8086:1616) Display controller Intel Corporation:
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
mhwd -li
> Installed PCI configs:
mhwd-kernel -li
Currently running: 5.16.2-1-MANJARO (linux516)
* linux513
* linux516
I am using manjaro for 6 months never had this issue after the update.
Thanks for your attention and help.
