Good morning,
I’m aware that there are other threads talking about output issues on the latest proprietary NVIDIA drivers, yet I don’t think any of them have had any issues related to DisplayPort functionality. If anyone knows of an up-to-date workaround, I’d highly appreciate anyone telling me.
I use two ViewSonic VX3276-QHD monitors for my desktop, which contains a GTX960 as of now. A couple of driver versions ago, a bug manifested itself, that causes any displays connected via DisplayPort to constantly connect and reconnect. My left monitor is plugged in via HDMI, which is why the bug isn’t that much of a problem, since I still have at least one monitor to work with. My system is all up to date with the stable branch, so I hope that this problem can be resolved soon.
https ://imgur.com/a/OkHsP4M
(Forum won’t let me post links, so just take out the space)
CPU: AMD Ryzen 9 5900X (12-core, 3.7GHz)
GPU: ASUS-brand NVIDIA GTX960 (4GB)
RAM: 32GB DDR4
MB: MSI X570-A PRO
inxi output
Kernel: 5.15.74-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=35af9d74-d4af-4ef5-bba5-e8d44e4b9e45 rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.6 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: Micro-Star model: MAG B550 TOMAHAWK (MS-7C91) v: 2.0
serial: <superuser required> UEFI: American Megatrends LLC. v: A.90
date: 03/17/2022
RAM: total: 31.27 GiB used: 4.24 GiB (13.5%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3 gen: 4
level: v3 note: check built: 2021-22 process: TSMC n7 (7nm)
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 smt: enabled cache:
L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB desc: 12x512 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 2788 high: 3591 min/max: 2200/4950 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3591 2: 2878
3: 2875 4: 2879 5: 2877 6: 2877 7: 2846 8: 2367 9: 2853 10: 2756 11: 2752
12: 2612 13: 3508 14: 2492 15: 2879 16: 2869 17: 2623 18: 2808 19: 2681
20: 2824 21: 2613 22: 2196 23: 2882 24: 2382 bogomips: 177648
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
prctl and seccomp
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GM206 [GeForce GTX 960] vendor: ASUSTeK driver: nvidia
v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current
(as of 2022-10) arch: Maxwell code: GMxxx process: TSMC 28nm
built: 2014-19 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 2b:00.0 chip-ID: 10de:1401 class-ID: 0300
Device-2: Logitech HD Pro Webcam C920 type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-6:5 chip-ID: 046d:082d
class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 92 s-size: 707x393mm (27.83x15.47")
s-diag: 809mm (31.85")
Monitor-1: HDMI-0 res: 2560x1440 hz: 60 dpi: 93
size: 698x393mm (27.48x15.47") diag: 801mm (31.54") modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 960/PCIe/SSE2 v: 4.6.0 NVIDIA
520.56.06 direct render: Yes
Device-1: NVIDIA GM206 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 1-6:5 chip-ID: 046d:082d pcie:
class-ID: 0102 gen: 3 serial: <filter> speed: 8 GT/s lanes: 16
bus-ID: 2b:00.1 chip-ID: 10de:0fba class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
bus-ID: 2d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech HD Pro Webcam C920 type: USB
Device-4: Texas Instruments PCM2902 Audio Codec type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-4:2 chip-ID: 08bb:2902
class-ID: 0300
Sound API: ALSA v: k5.15.74-3-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.58 running: yes
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: e000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp5s0 state: down mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: d000 bus-ID: 2a:00.0
IF: enp42s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IP v6: <filter> type: noprefixroute scope: global
Device-1: TP-Link UB500 Adapter type: USB driver: btusb v: 0.8 bus-ID: 1-5:4
chip-ID: 2357:0604 class-ID: e001 serial: <filter>
Local Storage: total: 3.18 TiB used: 1.39 TiB (43.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SA2000M8500G
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: S5Z42105 temp: 34.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 2TB
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 1B6Q scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: LaCie model: Rugged FW USB3
size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 051E scheme: GPT
ID-1: / raw-size: 465.46 GiB size: 457.09 GiB (98.20%) used: 282.02 GiB
(61.7%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 35af9d74-d4af-4ef5-bba5-e8d44e4b9e45
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 312 KiB
(0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: NO_LABEL
uuid: 2B82-0D30
ID-3: /home/<filter>/workspace raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
used: 1.12 TiB (62.4%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: workspace
uuid: 7a34c2d9-114b-4911-b027-f8136490a79c
ID-1: /dev/sdb1 maj-min: 8:17 size: 931.51 GiB fs: exfat label: amsterdam
uuid: CEF4-8659
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Hub-2: 1-2:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-4:3 info: Areson Corp Akko 2.4G Wireless Keyboard
type: Keyboard driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 25a7:2420 class-ID: 0301
Device-2: 1-5:4 info: TP-Link UB500 Adapter type: Bluetooth driver: btusb
interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA chip-ID: 2357:0604
Device-3: 1-6:5 info: Logitech HD Pro Webcam C920 type: Video,Audio
power: 500mA chip-ID: 046d:082d class-ID: 0102 serial: <filter>
Device-4: 1-8:6 info: Micro Star MYSTIC LIGHT type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 500mA chip-ID: 1462:7c91 class-ID: 0300 serial: <filter>
Hub-3: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-4: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-4:2 info: Texas Instruments PCM2902 Audio Codec
type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 08bb:2902 class-ID: 0300
Hub-5: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Device-1: 4-3:2 info: LaCie Rugged USB3-FW type: Mass Storage driver: uas
interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 896mA chip-ID: 059f:1061
class-ID: 0806 serial: <filter>
System Temperatures: cpu: 43.1 C mobo: N/A gpu: nvidia temp: 49 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 23%
Processes: 403 Uptime: 40m wakeups: 0 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: 1524 pm: pacman pkgs: 1511 libs: 388 tools: pamac pm: flatpak
pkgs: 13 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.22
xrandr output
The output from xrandr
switches around just like in the NVIDIA settings application. So I’ll post both possible outputs (had to spam xrandr to catch it while the second monitor was detected as plugged in).
Screen 0: minimum 8 x 8, current 2560 x 1440, maximum 16384 x 16384
DVI-I-0 disconnected (normal left inverted right x axis y axis)
DVI-I-1 disconnected (normal left inverted right x axis y axis)
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
HDMI-0 connected primary 2560x1440+0+0 (normal left inverted right x axis y axis) 698mm x 393mm
2560x1440 59.95*+ 74.93
2560x1080 59.94 50.00 29.97 25.00 23.98
2048x1152 60.00
1920x1440 60.00
1920x1200 59.88
1920x1080 60.00 59.94 50.00 29.97 25.00 23.98 60.00 50.04
1680x1050 59.95
1440x900 59.89
1440x576 50.00
1440x480 59.94
1280x1024 75.02 60.02
1280x720 60.00 59.94 50.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32 56.25
720x576 50.00
720x480 59.94
640x480 75.00 72.81 59.94 59.93
DP-4 disconnected (normal left inverted right x axis y axis)
DP-5 disconnected (normal left inverted right x axis y axis)
2048x1152 60.00
1920x1440 60.00
1920x1200 59.88
1680x1050 59.95
1440x900 59.89
1440x576 50.00
1440x480 59.94
720x576 50.00
720x480 59.94
DP-4 connected (normal left inverted right x axis y axis)
2560x1440 59.95 + 74.93
3840x2160 59.94 50.00 29.97 25.00 23.98
2048x1152 60.00
1920x1440 60.00
1920x1200 59.88
1680x1050 59.95
1440x900 59.89
1440x576 50.00
720x576 50.00
720x480 59.94
If more information is needed please don’t hesitate to ask.
Edit: Added system info, inxi output and xrandr outputs
