Please, I am having difficulties creating a hotspot. I use kde on Manjaro.
Apparently the hotspot is created automatically, the connection appears in the menu, but doesn’t connect
I ran this command journalctl -f and the following came up:
bruno-ser NetworkManager[523]: [1677463418.8356] device (wlp2s0): state change: disconnected → prepare (reason ‘none’, sys-iface-state: ‘managed’)
fev 26 23:03:38 bruno-ser NetworkManager[523]: [1677463418.8364] device (wlp2s0): state change: prepare → config (reason ‘none’, sys-iface-state: ‘managed’)
fev 26 23:03:38 bruno-ser NetworkManager[523]: [1677463418.8366] device (wlp2s0): Activation: (wifi) connection ‘bruno-hotspot’ requires no security. No secrets needed.
fev 26 23:03:38 bruno-ser NetworkManager[523]: [1677463418.8366] Config: added ‘ssid’ value ‘bruno-hotspot’
fev 26 23:03:38 bruno-ser NetworkManager[523]: [1677463418.8367] Config: added ‘mode’ value ‘2’
fev 26 23:03:38 bruno-ser NetworkManager[523]: [1677463418.8367] Config: added ‘frequency’ value ‘2437’
fev 26 23:03:38 bruno-ser NetworkManager[523]: [1677463418.8367] Config: added ‘key_mgmt’ value ‘NONE’
fev 26 23:03:38 bruno-ser wpa_supplicant[1218]: Note: nl80211 driver interface is not designed to be used with ap_scan=2; this can result in connection failures
fev 26 23:03:41 bruno-ser NetworkManager[523]: [1677463421.6172] audit: op=“statistics” interface=“enp1s0” ifindex=2 args=“0” pid=1912 uid=1000 result=“success”
fev 26 23:03:41 bruno-ser NetworkManager[523]: [1677463421.6253] audit: op=“statistics” interface=“enp1s0” ifindex=2 args=“500” pid=2390 uid=1000 result=“success”
fev 26 23:03:42 bruno-ser wpa_supplicant[1218]: nl80211: kernel reports: Authentication algorithm number required
fev 26 23:03:42 bruno-ser wpa_supplicant[1218]: wlp2s0: Failed to start AP functionality
Thanks in advance for any help
