i am using manjaro kde, kernel 5.11 with kde 5.21, on an hp laptop with i3 and no dedicated graphics card
my wifi gets deactivated when ever i close my laptop lid, what can i do for it??
lid
Do nothing
like in below screenshot:i tried that already it didn’t work so i rolled back to lts kernel 5.4
everything’s fine now wifi works properly and crashes are gone for good
uname --kernel-release
5.4.100-1-MANJARO
Kernel: 5.4.100-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
root=UUID=ec48b121-69d3-4cfd-88ea-cf9c898dacbd ro quiet apparmor=1
Desktop: KDE Plasma 5.21.1 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: HP product: HP 250 G6 Notebook PC
v: Type1ProductConfigId serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 832A v: 23.70 serial: <filter> UEFI: Insyde v: F.52
date: 03/04/2019
ID-1: BAT1 charge: 35.7 Wh condition: 36.8/41.6 Wh (88%) volts: 16.8/14.6
model: Hewlett-Packard PABAS0241231 type: Li-ion serial: <filter>
status: Charging
RAM: total: 3.76 GiB used: 1.87 GiB (49.5%)
Info: Dual Core model: Intel Core i3-7020U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: A (10)
microcode: E0 L2 cache: 3 MiB bogomips: 18406
Speed: 800 MHz min/max: 400/1800 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs intel_pt invpcid invpcid_single lahf_lm lm mca
mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme
vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf
Device-1: Intel HD Graphics 620 vendor: Hewlett-Packard driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:5916 class ID: 0300
Device-2: Sunplus Innovation HP TrueVision HD Camera type: USB
driver: uvcvideo bus ID: 1-5:3 chip ID: 1bcf:2c9b class ID: 0e02
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa display ID: :0
screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 102 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.3.4
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus ID: 00:1f.3
chip ID: 8086:9d71 class ID: 0403
Sound Server: ALSA v: k5.4.100-1-MANJARO
vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus ID: 01:00.0
chip ID: 10ec:8168 class ID: 0200
Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
v: kernel port: 3000 bus ID: 02:00.0 chip ID: 8086:24fb class ID: 0280
Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
bus ID: 1-4:2 chip ID: 8087:0aa7 class ID: e001
Message: Required tool hciconfig not installed. Check --recommends
Local Storage: total: 931.51 GiB used: 64.18 GiB (6.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: 4C scheme: GPT
Optical-1: /dev/sr0 vendor: hp model: DVDRW DA8AESH rev: XH6M
dev-links: cdrom
rw: cd-r,cd-rw,dvd-r state: running
ID-1: / raw size: 931.22 GiB size: 915.6 GiB (98.32%) used: 64.18 GiB (7.0%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: ec48b121-69d3-4cfd-88ea-cf9c898dacbd
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 031A-DD6C
Message: No Unmounted partitions found.
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
Device-1: 1-4:2 info: Intel Wireless-AC 3168 Bluetooth type: Bluetooth
driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s chip ID: 8087:0aa7
class ID: e001
Device-2: 1-5:3 info: Sunplus Innovation HP TrueVision HD Camera type: Video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s chip ID: 1bcf:2c9b
class ID: 0e02
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
chip ID: 1d6b:0003 class ID: 0900
System Temperatures: cpu: 41.5 C mobo: 29.8 C
Processes: 184 Uptime: 18m wakeups: 2 Init: systemd v: 247 Compilers:
gcc: 10.2.0 Packages: 1527 pacman: 1507 lib: 439 flatpak: 15 snap: 5
Shell: Bash v: 5.1.0 running in: konsole inxi: 3.3.01
Can you
) by clicking the pencil below your own question.uname --kernel-release
)This topic was automatically closed 15 days after the last reply. New replies are no longer allowed.
