Hi, I’ve been having an issue for over a month now where I have a solid WiFi signal but a few times per day the WiFi disconnects and I get the “Wi-Fi password dialog - KDE Daemon” pop-up prompting me to type in my password. Which it should already know. Here’s some terminal output. I’m happy to provide more, if someone can suggest what else would help diagnose this issue. Any ideas? Thank you.
Kernel: 5.4.74-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=fd979e97-fda3-46fc-9367-13bb68274046 rw quiet apparmor=1
Desktop: KDE Plasma 5.20.2 tk: Qt 5.15.1 info: latte-dock wm: kwin_x11
dm: SDDM Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 2349GCU v: ThinkPad T430
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 2349GCU serial: <filter> UEFI [Legacy]: LENOVO
v: G1ETC1WW (2.81 ) date: 06/18/2019
ID-1: BAT0 charge: 33.6 Wh condition: 50.3/56.2 Wh (90%) volts: 11.4/10.8
model: LGC 45N1005 type: Li-ion serial: <filter> status: Discharging
Info: Dual Core model: Intel Core i5-3320M bits: 64 type: MT MCP
arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
L2 cache: 3072 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 20756
Speed: 1197 MHz min/max: 1200/3300 MHz Core speeds (MHz): 1: 1197 2: 1197
3: 1197 4: 1197
Vulnerabilities: Type: itlb_multihit status: KVM: Vulnerable
Type: srbds status: Vulnerable: No microcode
Device-1: Intel 3rd Gen Core processor Graphics vendor: Lenovo driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:0166
Device-2: Chicony thinkpad t430s camera type: USB driver: uvcvideo
bus ID: 1-1.6:5 chip ID: 04f2:b2da
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: intel
unloaded: modesetting alternate: fbdev,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.7x9.4")
s-diag: 485mm (19.1")
Monitor-1: LVDS1 res: 1600x900 hz: 60 dpi: 131 size: 310x170mm (12.2x6.7")
diag: 354mm (13.9")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2)
v: 4.2 Mesa 20.2.1 compat-v: 3.0 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:1e20
Sound Server: ALSA v: k5.4.74-1-MANJARO
Device-1: Intel 82579LM Gigabit Network vendor: Lenovo driver: e1000e
v: 3.2.6-k port: 6080 bus ID: 00:19.0 chip ID: 8086:1502
IF: enp0s25 state: down mac: <filter>
Device-2: Intel Centrino Advanced-N 6205 [Taylor Peak] driver: iwlwifi
v: kernel port: efa0 bus ID: 03:00.0 chip ID: 8086:0085
Local Storage: total: 447.13 GiB used: 41.08 GiB (9.2%)
ID-1: /dev/sda vendor: SanDisk model: SSD PLUS 480GB size: 447.13 GiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
rev: 04RL scheme: MBR
ID-1: / raw size: 447.13 GiB size: 439.11 GiB (98.21%)
used: 41.08 GiB (9.4%) fs: ext4 dev: /dev/sda1
System Temperatures: cpu: 48.0 C mobo: 0.0 C
Fan Speeds (RPM): cpu: 3770
Processes: 199 Uptime: 8h 53m Memory: 15.33 GiB used: 3.30 GiB (21.5%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 clang: 10.0.1 Packages:
pacman: 1399 lib: 416 flatpak: 0 Shell: Bash v: 5.0.18 running in: konsole
inxi: 3.1.08
