I can’t connect to ethernet idky… and wifi got issue. After running 20 minutes of wifi, the connection drops and i always have to manual reconnect from panel!!! Any permanent solution for that?
Kernel: 5.15.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=3e085e35-d3d9-4e6e-9edd-e5671d47887f rw quiet
resume=UUID=4d9a0056-52db-4894-b5b4-4cfb82eeeb43 udev.log_priority=3
Desktop: GNOME 41.3 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.3
Type: Desktop System: Hewlett-Packard product: HP ProOne 400 G1 AiO v: N/A
serial: <superuser required> Chassis: type: 3 serial: <superuser required>
Mobo: Hewlett-Packard model: 18EA serial: <superuser required>
UEFI: Hewlett-Packard v: L03 v02.16 date: 11/25/2014
RAM: total: 3.76 GiB used: 1.28 GiB (34.2%)
RAM Report:
Info: model: Intel Core i3-4160T bits: 64 type: MT MCP arch: Haswell
family: 6 model-id: 0x3C (60) stepping: 3 microcode: 0x28
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1514 high: 2547 min/max: 800/3100 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 947 2: 2547 3: 887
4: 1676 bogomips: 24754
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
dtherm dts epb erms est f16c flush_l1d fma fpu fsgsbase fxsr ht ibpb ibrs
invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe msr
pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good sdbg sep smep ss
ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tsc tsc_adjust
tsc_deadline_timer vme xsave xsaveopt xtopology xtpr
Type: itlb_multihit status: KVM: VMX unsupported
Device-1: Intel 4th Generation Core Processor Family Integrated Graphics
vendor: Hewlett-Packard driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:041e class-ID: 0300
Device-2: Chicony HP High Definition 1MP Webcam type: USB driver: uvcvideo
bus-ID: 3-10:4 chip-ID: 04f2:b453 class-ID: 0e02
Display: wayland server: X.org 1.21.1.3 compositor: gnome-shell driver:
loaded: modesetting alternate: fbdev,vesa display-ID: 0
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:03.0
chip-ID: 8086:0c0c class-ID: 0403
Device-2: Intel 8 Series/C220 Series High Definition Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:8c20 class-ID: 0403
Sound Server-1: ALSA v: k5.15.16-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.43 running: no
vendor: Hewlett-Packard driver: r8168 v: 8.049.02-NAPI modules: r8169
port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp2s0 state: up speed: 10 Mbps duplex: full mac: <filter>
Device-2: Broadcom BCM43228 802.11a/b/g/n driver: bcma-pci-bridge v: N/A
modules: bcma bus-ID: 03:00.0 chip-ID: 14e4:4359 class-ID: 0280
IF-ID-1: wlp3s0b1 state: up mac: <filter>
Device-1: Broadcom HP Portable Bumble Bee type: USB driver: btusb v: 0.8
bus-ID: 3-4:2 chip-ID: 0a5c:21f1 class-ID: fe01 serial: <filter>
Local Storage: total: 465.76 GiB used: 10.93 GiB (2.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST500DM002-1BD142
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: HP74 scheme: GPT
Optical-1: /dev/sr0 vendor: hp model: DVD A DS8ACSH rev: LHS3
dev-links: cdrom
ID-1: / raw-size: 40.04 GiB size: 39.12 GiB (97.69%) used: 9.6 GiB (24.5%)
fs: ext4 dev: /dev/sda7 maj-min: 8:7 label: N/A
uuid: 3e085e35-d3d9-4e6e-9edd-e5671d47887f
used: 25.3 MiB (26.3%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 4E87-8A4B
ID-3: /home raw-size: 100 GiB size: 97.87 GiB (97.87%)
used: 1.31 GiB (1.3%) fs: ext4 dev: /dev/sda8 maj-min: 8:8 label: N/A
uuid: f97ebf7b-42b0-4746-8edc-1a862ccbfd3f
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda9 maj-min: 8:9 label: N/A
uuid: 4d9a0056-52db-4894-b5b4-4cfb82eeeb43
ID-1: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/sda3 maj-min: 8:3 size: 100.89 GiB fs: ntfs label: N/A
uuid: 88348E52348E4364
ID-3: /dev/sda4 maj-min: 8:4 size: 50.1 GiB fs: ntfs label: New Volume
uuid: 2E88E43D88E40565
ID-4: /dev/sda5 maj-min: 8:5 size: 50.1 GiB fs: ntfs label: New Volume
uuid: 70522D3A522D0706
ID-5: /dev/sda6 maj-min: 8:6 size: 509 MiB fs: ntfs label: N/A
uuid: 9E00F7F000F7CCF1
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 4 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:8008 class-ID: 0900
Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:8000 class-ID: 0900
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 3-4:2 info: Broadcom HP Portable Bumble Bee type: Bluetooth
driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s chip-ID: 0a5c:21f1
Device-2: 3-5:3 info: Xiaomi Mi Wireless Combo type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 2717:5010 class-ID: 0301
Device-3: 3-10:4 info: Chicony HP High Definition 1MP Webcam type: Video
Hub-6: 4-0:1 info: Super-speed hub ports: 2 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 29.8 C mobo: 27.8 C
Processes: 203 Uptime: 17m wakeups: 0 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1047 lib: 300
Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.12
