Hello, I have a fresh Manjaro install (dual boot) on a new laptop. The wifi drops out when I don’t use it. Strangely, when it’s dropped, if I open networks on the task bar and keep it open with mouse over, it starts up again.
I’m relatively new to linux/Manjaro. Any suggestions welcome. Please let me know what system info/logs would be useful to diagnose.
Thanks.
yes would not hurt to provide info on your setup
$ inxi --admin --verbosity=7 --filter --no-host --width
also
journalctl -b -| grep iwlwifi
also refer;
I am having an issue with my dell xps 15 9520 in term of the Wi-Fi speed. I’m getting 3 mbps whereas my full internet speed is 90 mbps. The connection works as expected with a cable. I had the same issue on other distros too, but on Pop OS there is this fix, where you set wifi.powersave = 2 in /etc/NetworkManager/conf.d/default-wifi-powersave-on.conf.
Is there a similar fix for Manjaro?
EDIT:
I also added these lines in /etc/modprobe.d/wifi.conf
options iwlwifi swcrypto=1 # enables software…
Hello!
I have a Dell 7420 with Manjaro KDE
Linux dell 5.15.74-3-MANJARO #1 SMP PREEMPT Sat Oct 15 13:39:11 UTC 2022 x86_64 GNU/Linux
everything works (except for fingerprint, not supported) but the WiFi. It is fine most of the time but, seems randomly, every 1-2 months or sometimes after 1-2 weeks, it stops working.
The connections drops, the Network Manager widget shows no networks, and the only way to make it work again is shutting down and start again the laptop.
Note that a “restart” wo…
gentlewalk:
This may be normal - you likely need to go over your power settings.
Thanks for the advice so far.
I’m testing the bios adjustment as described here , I’ve reviewed power settings already. So ruled out that as an issue. I have not resolved the issue. Meanwhile:
Output from:
Kernel: 5.15.74-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=5a52655d-1460-4808-9438-34f90bb6cf87 rw quiet
resume=UUID=53061de9-d0d0-4ea1-a624-59e13c8362c9 udev.log_priority=3
Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.6 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Dynabook product: SATELLITE PRO C40-J v: PYS46A-00E00J
serial: <superuser required>
Mobo: Dynabook model: DBIIP306 v: V3.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: TN16SV1.12 date: 07/20/2022
ID-1: BAT0 charge: 44.9 Wh (100.0%) condition: 44.9/45.6 Wh (98.5%)
volts: 8.6 min: 7.6 model: Intel SR 1 SR Real Battery type: Unknown
serial: <filter> status: full
RAM: total: 15.31 GiB used: 3.64 GiB (23.8%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
microcode: 0xA4
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1028 high: 1118 min/max: 400/4700 scaling:
driver: intel_pstate governor: powersave cores: 1: 1019 2: 1111 3: 1066
4: 996 5: 924 6: 1118 7: 1033 8: 960 bogomips: 44864
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
rdt_a rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd
sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
prctl and seccomp
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] driver: i915 v: kernel
arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports: active: eDP-1
empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:9a49
class-ID: 0300
Device-2: Sunplus Innovation USB Camera type: USB driver: uvcvideo
bus-ID: 3-4:3 chip-ID: 1bcf:2087 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: ChiMei InnoLux 0x14d4 built: 2016 res: 1920x1080
hz: 60 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 22.1.7
direct render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio driver: snd_hda_intel
v: kernel alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:a0c8 class-ID: 0401
Sound API: ALSA v: k5.15.74-3-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.58 running: yes
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:a0f0 class-ID: 0280
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000
bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: down mac: <filter>
bus-ID: 3-10:5 chip-ID: 8087:0026 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 2.29 TiB used: 13.98 GiB (0.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba
model: KBG40ZNV512G MEMORY size: 476.94 GiB block-size: physical: 512 B
rev: AEJA0104 temp: 29.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Western Digital model: WD My
Passport 0820 size: 1.82 TiB block-size: physical: 512 B logical: 512 B
type: N/A serial: <filter> rev: 1007 scheme: MBR
ID-1: / raw-size: 58.59 GiB size: 57.37 GiB (97.92%) used: 12.29 GiB (21.4%)
fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8 label: N/A
uuid: 5a52655d-1460-4808-9438-34f90bb6cf87
ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%) used: 316 KiB
(0.1%) fs: vfat dev: /dev/nvme0n1p6 maj-min: 259:6 label: NO_LABEL
uuid: 6C27-ED68
ID-3: /home raw-size: 37.66 GiB size: 36.77 GiB (97.64%) used: 1.69 GiB
(4.6%) fs: ext4 dev: /dev/nvme0n1p9 maj-min: 259:9 label: N/A
uuid: 568b6755-36ff-4520-a3c4-4049fc48e0d7
ID-1: swap-1 type: partition size: 19.53 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p7 maj-min: 259:7 label: N/A
uuid: 53061de9-d0d0-4ea1-a624-59e13c8362c9
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 260 MiB fs: vfat label: ESP
uuid: 5837-EFB2
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 346.67 GiB fs: ntfs
label: TIS0041000H uuid: 2A46386A46383941
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 990 MiB fs: ntfs label: WinRE
uuid: 681E3AD91E3AA04C
ID-5: /dev/nvme0n1p5 maj-min: 259:5 size: 11.84 GiB fs: vfat
label: HDDRECOVERY uuid: 669B-719B
ID-6: /dev/sda1 maj-min: 8:1 size: 1.82 TiB fs: ntfs label: My Passport
uuid: F474B7AA74B76DCC
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-3:2 info: Dell MS116 Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 413c:301a class-ID: 0301
Device-2: 3-4:3 info: Sunplus Innovation USB Camera type: Video
Device-3: 3-6:4 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Device-4: 3-10:5 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Device-1: 4-1:2 info: Western Digital My Passport Ultra (WDBMWV WDBZFP)
type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s
power: 896mA chip-ID: 1058:0820 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 45.0 C mobo: N/A
Processes: 251 Uptime: 3m wakeups: 188 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: pm: pacman pkgs: 1289 libs: 348 tools: pamac,yay pm: flatpak
pkgs: 0 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.22
And from
Oct 27 21:32:58 S2 kernel: iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
Oct 27 21:32:58 S2 kernel: iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
Oct 27 21:32:58 S2 kernel: iwlwifi 0000:00:14.3: TLV_FW_FSEQ_VERSION: FSEQ Version: 89.3.35.37
Oct 27 21:32:58 S2 kernel: iwlwifi 0000:00:14.3: loaded firmware version 66.f1c864e0.0 QuZ-a0-hr-b0-66.ucode op_mode iwlmvm now
Oct 27 21:32:58 S2 kernel: iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6 AX201 160MHz, REV=0x354
Oct 27 21:32:58 S2 kernel: iwlwifi 0000:00:14.3: Detected RF HR B5, rfid=0x10a100
Oct 27 21:32:58 S2 kernel: iwlwifi 0000:00:14.3: base HW address: 10:51:07:55:83:b3
Oct 27 21:32:58 S2 kernel: iwlwifi 0000:00:14.3 wlo1: renamed from wlan0
Oct 27 21:32:58 S2 NetworkManager[435]: <info> [1666866778.9423] rfkill0: found Wi-Fi radio killswitch (at /sys/devices/pci0000:00/0000:00:14.3/ieee80211/phy0/rfkill0) (driver iwlwifi)
Oct 27 10:50:17 S2 plasmashell[780]: org.kde.klipper: Invalid or non-local url for preview: QUrl("iwlwifi")
giukas
November 4, 2022, 7:39pm
#5
I have exactly the same issue on a Dell latitude 5410 with same adapter. It happened twice and now can’t resume wifi at all.
Did you fix it?
No. I’ll let you know if I work it out. If you could share anything that works too it would be appreciated.
Simply disable wifi powersave mode
giukas
November 8, 2022, 6:42am
#9
I did this and everything seems fine (been 2 days)
nmcli networking on
Yes, it’s got to do with power save wifi mode.
I hope I disabled it everywhere in settings
