Wifi drops repeatedly
Isn’t it today that my wifi has some problem with Manjaro
But this time I’m not sure if it was some configuration I made or just a bad route from my internet provider
The posts were deleted, but I had already reported problems with previous versions of Manjaro. The solution was to configure the system to ignore IPV6.
Actually wifi without IPV6 is more stable, if I set on automatic wifi does not work, because it falls at all times
My network doesn’t have IPV6, I can certify that because I checked the network with another notebook with windows and smartphones too. But I don’t use it.
There’s something in Manjaro that makes the connection drop all the time. I suspect IPV6 but it could be anything, the Qualcomm Atheros card doesn’t have many positive feedbacks…
If someone can help me I’m grateful
System details
System:    Kernel: 5.7.14-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
           Desktop: KDE Plasma 5.19.4 tk: Qt 5.15.0 info: latte-dock wm: kwin_x11 dm: SDDM
           Distro: Manjaro Linux
Machine:   Type: Laptop System: ASUSTeK product: S400CA v: 1.0 serial: <filter>
           Mobo: ASUSTeK model: S400CA v: 1.0 serial: <filter> UEFI: American Megatrends
           v: S400CA.210 date: 01/27/2014
Battery:   ID-1: BAT0 charge: 34.3 Wh condition: 35.7/45.3 Wh (79%) volts: 11.2/11.2
           model: ASUSTek X402--40 type: Li-ion serial: N/A status: Unknown cycles: 450
CPU:       Topology: Dual Core model: Intel Core i5-3317U bits: 64 type: MT MCP
           arch: Ivy Bridge rev: 9 L2 cache: 3072 KiB
           flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 13574
           Speed: 1504 MHz min/max: 800/2600 MHz Core speeds (MHz): 1: 1195 2: 1188 3: 1201
           4: 1261
Graphics:  Device-1: Intel 3rd Gen Core processor Graphics vendor: ASUSTeK driver: i915
           v: kernel bus ID: 00:02.0 chip ID: 8086:0166
           Device-2: Chicony UVC 1.00 device HD UVC WebCam type: USB driver: uvcvideo
           bus ID: 1-1.2:3 chip ID: 04f2:b354
           Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: intel resolution:
           1: 1366x768~60Hz 2: 1366x768~60Hz s-dpi: 96
           OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2) v: 4.2 Mesa 20.1.5
           compat-v: 3.0 direct render: Yes
Audio:     Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: ASUSTeK
           driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:1e20
           Sound Server: ALSA v: k5.7.14-1-MANJARO
Network:   Device-1: Qualcomm Atheros AR9485 Wireless Network Adapter vendor: AzureWave
           driver: ath9k v: kernel port: f040 bus ID: 02:00.0 chip ID: 168c:0032
           IF: wlp2s0 state: down mac: <filter>
           Device-2: Qualcomm Atheros AR8161 Gigabit Ethernet vendor: ASUSTeK driver: alx
           v: kernel port: e000 bus ID: 03:00.0 chip ID: 1969:1091
           IF-ID-1: docker0 state: down mac: <filter>
Drives:    Local Storage: total: 689.33 GiB used: 88.75 GiB (12.9%)
           ID-1: /dev/sda vendor: Kingston model: SA400S37240G size: 223.57 GiB speed: 6.0 Gb/s
           serial: <filter> rev: B1D2 scheme: GPT
           ID-2: /dev/sdb type: USB vendor: JMicron Tech model: Generic size: 465.76 GiB
           serial: <filter> rev: 0508 scheme: GPT
Partition: ID-1: / size: 42.71 GiB used: 32.21 GiB (75.4%) fs: ext4 dev: /dev/sda2
           ID-2: /home size: 174.21 GiB used: 56.54 GiB (32.5%) fs: ext4 dev: /dev/sda3
Swap:      Alert: No Swap data was found.
Sensors:   System Temperatures: cpu: 69.0 C mobo: N/A
           Fan Speeds (RPM): cpu: 4000
Info:      Processes: 228 Uptime: 57m Memory: 7.67 GiB used: 2.27 GiB (29.6%) Init: systemd
           v: 245 target: graphical.target Compilers: gcc: 10.1.0 clang: 10.0.1 Packages: 1735
           pacman: 1713 flatpak: 20 snap: 2 Shell: fish v: 3.1.0-444-g23339ae15 default: Bash
           v: 5.0.18 running in: konsole inxi: 3.1.05
To disable IPv6 completely just add this to boot params:
ipv6.disable=1
In /etc/default/grub or /etc/sysctl.d/40-ipv6.conf like here?
in /etc/default/grub on the GRUB_CMDLINE_LINUX line then run
sudo update-grub
(and reboot)
Setting GRUB_CMDLINE_LINUX="ipv6.disable=1" solves the issue, I tested for hours and drop only one time.
Good to hear.
I used to have a similar card … so let me show you one of the things I always did on that:
In file /etc/modprobe.d/ath9k.conf (create if not present)
options ath9k nohwcrypt=1
This command would do it in one shot:
echo -e "options ath9k nohwcrypt=1" | sudo tee /etc/modprobe.d/ath9k.conf
Explanation:
It passes an option to the wireless module you’re using [ath9k]
“nohwcrypt” = No Hardware Decryption
“1” = Enables this option
You will still have encryption but it will be done software side instead of hardware.
Reason: Just gave better results. Normally I chase ‘hardware acceleration’ on everything else. But finnicky radio cards? … no. If they are weird and we can offload the work it usually ends up better.
This is one parameter I already set up in last post ‘-’. So this is already created. By the way you help me in that post LoL
That’s it, problem solved! Some “networks features” for me, get in the way than help.
After some more tests, I confirm some instability with the system. Randomly there is still a drop. Can be my wifi card?
Possible.
But there are other things to try…
You have bluetooth, right? Do you use it? Can you check stability with it disabled?
I do not have bluetooth
Hm. OK … 2 more module options that might be somewhat helpful:
bt_ant_diversity=1 ps_enable=0
(you can add them to the same options line in the modprobe file like above with nohwcrypt)
The first one may or may not have any effect - it is intended to increase wifi performance at the cost of disabling bt, and the second is making sure power savings is disabled.
Got it, I added the parameters and rebooted in the line, I’m checking if it will happen again.
in case it happens I’ll report here again
so I thank you for your quick response and help
you may have a look here too
https://wiki.archlinux.org/index.php/IPv6
Yes, I’ve read the documentation, so I assumed at first that one of the prime suspects is the IPV6.
this article is what I quoted above
but can be other things like ISP , router or card. If you are interested this is the old post that I related in old manjaro version
But this last parameter maybe can solve this issue definitely, i need to test first
didn’t work , same thing happened
Screenshot_20200819_194838
Screenshot_20200819_194857
re-reading the old post I did, I’m not surprised I didn’t get a positive result
it is really being difficult to perform remote activities with this kind of stability that Atheros is performing
Using dmesg I encontred this errors:
[ 3520.921026] i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=178184 end=178185) time 227 us, min 763, max 767, scanline start 762, end 772
[ 3715.133301] wlp2s0: authenticate with 0c:80:63:ca:0a:49
[ 3715.154134] wlp2s0: send auth to 0c:80:63:ca:0a:49 (try 1/3)
[ 3715.208591] wlp2s0: authenticated
[ 3715.211145] wlp2s0: associate with 0c:80:63:ca:0a:49 (try 1/3)
[ 3715.241491] wlp2s0: RX AssocResp from 0c:80:63:ca:0a:49 (capab=0x411 status=0 aid=3)
[ 3715.241664] wlp2s0: associated
[ 4098.670114] wlp2s0: authenticate with 0c:80:63:ca:0a:49
[ 4098.690475] wlp2s0: send auth to 0c:80:63:ca:0a:49 (try 1/3)
[ 4098.965447] wlp2s0: send auth to 0c:80:63:ca:0a:49 (try 2/3)
[ 4099.163735] wlp2s0: send auth to 0c:80:63:ca:0a:49 (try 3/3)
[ 4099.174047] wlp2s0: authentication with 0c:80:63:ca:0a:49 timed out
[ 4100.679230] wlp2s0: authenticate with 0c:80:63:ca:0a:49
[ 4100.698619] wlp2s0: send auth to 0c:80:63:ca:0a:49 (try 1/3)
[ 4100.738299] wlp2s0: authenticated
[ 4100.741797] wlp2s0: associate with 0c:80:63:ca:0a:49 (try 1/3)
[ 4101.149883] wlp2s0: associate with 0c:80:63:ca:0a:49 (try 2/3)
[ 4101.211607] wlp2s0: RX AssocResp from 0c:80:63:ca:0a:49 (capab=0x411 status=0 aid=3)
[ 4101.211756] wlp2s0: associated
[ 4226.689433] wlp2s0: authenticate with 0c:80:63:ca:0a:49
[ 4226.708780] wlp2s0: send auth to 0c:80:63:ca:0a:49 (try 1/3)
[ 4227.342763] wlp2s0: authenticated
[ 4227.345271] wlp2s0: associate with 0c:80:63:ca:0a:49 (try 1/3)
[ 4227.377503] wlp2s0: RX AssocResp from 0c:80:63:ca:0a:49 (capab=0x411 status=0 aid=3)
[ 4227.377683] wlp2s0: associated
[ 4232.523921] audit: type=1111 audit(1597876949.748:131): pid=576 uid=0 auid=4294967295 ses=4294967295 msg='op=statistics arg="refresh-rate-ms" pid=1466 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 4234.776494] audit: type=1111 audit(1597876952.001:132): pid=576 uid=0 auid=4294967295 ses=4294967295 msg='op=device-disconnect interface="wlp2s0" ifindex=3 pid=1466 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 4234.812098] audit: type=1130 audit(1597876952.034:133): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 4234.885117] wlp2s0: deauthenticating from 0c:80:63:ca:0a:49 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 4234.887728] audit: type=1111 audit(1597876952.111:134): pid=576 uid=0 auid=4294967295 ses=4294967295 msg='op=statistics arg="refresh-rate-ms" pid=1466 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 4241.381319] audit: type=1111 audit(1597876958.604:135): pid=576 uid=0 auid=4294967295 ses=4294967295 msg='op=connection-activate uuid=de4af258-996f-4d08-ac94-0c451d25e733 name="ovelha_negra" pid=1466 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
this is definitely related to what’s happening
In Live USB (manjaro 20.0.3) the WiFi seems to not drop
