Hello, after the last update my wifi driver appears to have failed to build or install properly. I’ve tried both installs of the linux kernel I have and after coming to the conclusion that I likely will not figure this out on google I gathered the following data for you all.
mhwd-kernel -li
Currently running: 6.0.8-1-MANJARO (linux60)
* linux515
* linux60
inxi -Nazy
Device-1: Intel Ethernet X550 vendor: ASUSTeK driver: ixgbe v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 4 port: N/A bus-ID: 24:00.0 chip-ID: 8086:1563
class-ID: 0200
Device-2: Intel Ethernet X550 vendor: ASUSTeK driver: ixgbe v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 4 port: N/A bus-ID: 24:00.1 chip-ID: 8086:1563
class-ID: 0200
Device-3: Intel Wi-Fi 6 AX200 driver: N/A modules: iwlwifi pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 25:00.0 chip-ID: 8086:2723 class-ID: 0280
rfkill list
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
I am currently running my WINDOWS install as i do NOT have access to ethernet connection currently (and will not for a month). How do I fix this, and is it possible to download to my windows install and then build whatever i need to from a file on my windows install (or a USB drive connected to my computer)?
Please edit your topic title to better reflect the problem your having clearly and concisely. I’m sorry, your Wi-Fi driver is AFK (Away From Keyboard)? Does not compute. Please see How to Post.
That driver is included in the kernel with the Intel iwlwifi module. There’s really no reason why it shouldn’t work. Sorry I can’t be more helpful.
I’ve adjusted the title. Thanks, for the welcome. I’ve been running manjaro for over a year, but this is the first thing that I wasn’t able to solve myself.
Yes, that’s why i am so confused… and neither kernel works too.
The weird thing is that it is recognizing iwlwifi as a module for it instead of using it as a driver. Is it possible to instruct it to use the module as a driver?
but I literally restarted it at least 4 times prior with no results… and i also had to switch to windows and back to figure out the commands I used (the mhwd, inxi, and rtfkill)…
I understand that that command was just a query… but it should’ve been working and it wasn’t until I ran that command.
The “solved” on that link is a lie, the OP was not actually successful, although i tried what he did anyway. I also look at other solutions for that and came up with bupkis. That being said I have observed another behavior that is odd.
The only time the driver works is if I boot to Windows and then restart straight into linux. Once a full shutdown has been performed the driver no longer works. This has been repeatable for the last week, and i believe it is what happened the first time it worked
