Hello,
my wifi was working just fine, but suddenly it stopped working, the Ethernet is working just fine. I even went back to kernel 5.4 to see whether downgrade would help but no luck there.
dmesg:
[ 2.428334] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[ 2.434981] iwlwifi 0000:00:14.3: loaded firmware version 46.6b541b68.0 op_mode iwlmvm
[ 2.567587] iwlwifi 0000:00:14.3: Detected Intel(R) Dual Band Wireless AC 9560, REV=0x318
[ 3.603417] iwlwifi 0000:00:14.3: Collecting data: trigger 15 fired.
[ 3.853530] iwlwifi 0000:00:14.3: Not valid error log pointer 0x00000000 for Init uCode
[ 3.853546] iwlwifi 0000:00:14.3: Fseq Registers:
[ 3.853554] iwlwifi 0000:00:14.3: 0x42E9EE4A | FSEQ_ERROR_CODE
[ 3.853562] iwlwifi 0000:00:14.3: 0x00000000 | FSEQ_TOP_INIT_VERSION
[ 3.853571] iwlwifi 0000:00:14.3: 0x096D2A27 | FSEQ_CNVIO_INIT_VERSION
[ 3.853579] iwlwifi 0000:00:14.3: 0x0000A384 | FSEQ_OTP_VERSION
[ 3.853587] iwlwifi 0000:00:14.3: 0xB5D79E67 | FSEQ_TOP_CONTENT_VERSION
[ 3.853596] iwlwifi 0000:00:14.3: 0x2FA17AA6 | FSEQ_ALIVE_TOKEN
[ 3.853604] iwlwifi 0000:00:14.3: 0x793A0D6A | FSEQ_CNVI_ID
[ 3.853612] iwlwifi 0000:00:14.3: 0x3DE1773B | FSEQ_CNVR_ID
[ 3.853621] iwlwifi 0000:00:14.3: 0x01000100 | CNVI_AUX_MISC_CHIP
[ 3.853631] iwlwifi 0000:00:14.3: 0x01300202 | CNVR_AUX_MISC_CHIP
[ 3.853642] iwlwifi 0000:00:14.3: 0x0000485B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 3.853683] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 3.853755] iwlwifi 0000:00:14.3: SecBoot CPU1 Status: 0x3, CPU2 Status: 0x2319
[ 3.853756] iwlwifi 0000:00:14.3: Failed to start INIT ucode: -110
[ 3.853757] iwlwifi 0000:00:14.3: Firmware not running - cannot dump error
[ 3.866205] iwlwifi 0000:00:14.3: Failed to run INIT ucode: -110
inxi -Fxx:
System: Host: manbox Kernel: 5.4.150-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: Xfce 4.16.0 tk: Gtk 3.24.29
wm: xfwm dm: LightDM Distro: Manjaro Linux base: Arch Linux
Machine: Type: Laptop System: ASUSTeK product: ROG Strix G531GT_G531GT v: 1.0 serial: <superuser required>
Mobo: ASUSTeK model: G531GT v: 1.0 serial: <superuser required> UEFI: American Megatrends v: G531GT.307
date: 04/28/2020
Battery: ID-1: BAT0 charge: 43.8 Wh (98.0%) condition: 44.7/50.5 Wh (88.4%) volts: 12.5 min: 12.5
model: ASUSTeK ASUS Battery serial: N/A status: Not charging
CPU: Info: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Kaby Lake note: check rev: D cache: L2: 12 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 62431
Speed: 4082 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 4082 2: 4098 3: 4090 4: 4096 5: 4025 6: 4097 7: 4091
8: 4095 9: 4090 10: 4095 11: 4086 12: 4098
Graphics: Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: ASUSTeK driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:3e9b
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK driver: nvidia v: 470.63.01
bus-ID: 01:00.0 chip-ID: 10de:1f91
Display: x11 server: X.Org 1.20.13 compositor: xfwm4 driver: loaded: modesetting,nvidia unloaded: nouveau
alternate: fbdev,nv,vesa resolution: 1: 1920x1080~120Hz 2: 1920x1080~60Hz s-dpi: 96
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.2.3 direct render: Yes
Audio: Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
chip-ID: 8086:a348
Sound Server-1: ALSA v: k5.4.150-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Network: Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:a370
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8168 v: 8.049.02-NAPI
port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168
IF: eno2 state: up speed: 100 Mbps duplex: full mac: d4:5d:64:58:2a:85
Bluetooth: Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB driver: btusb v: 0.8 bus-ID: 1-14:5
chip-ID: 8087:0aaa
Drives: Local Storage: total: 931.51 GiB used: 709.68 GiB (76.2%)
ID-1: /dev/nvme0n1 vendor: PNY model: CS3030 1TB SSD size: 931.51 GiB speed: 31.6 Gb/s lanes: 4
serial: PNY15200006520506897
Partition: ID-1: / size: 881.73 GiB used: 709.68 GiB (80.5%) fs: ext4 dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1
Swap: ID-1: swap-1 type: partition size: 34.34 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p3
Sensors: System Temperatures: cpu: 51.0 C mobo: N/A
Fan Speeds (RPM): cpu: 3800
Info: Processes: 292 Uptime: 6m Memory: 31.22 GiB used: 2.79 GiB (8.9%) Init: systemd v: 249 Compilers: gcc: 11.1.0
clang: 12.0.1 Packages: pacman: 1238 Shell: Bash v: 5.1.8 running-in: alacritty inxi: 3.3.07
uname -r:
5.4.150-1-MANJARO
The same issue was on 5.10 and 5.14
The fast boot is disabled. This is not dual boot.
