Wifi was working but stopping frequently, and now it stopped working.
this is my PC’s info:
Kernel: 5.8.16-2-MANJARO x86_64 bits: 64 compiler: N/A
Desktop: KDE Plasma 5.19.5 Distro: Manjaro Linux
Type: Laptop System: ASUSTeK product: X550LD v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X550LD v: 1.0 serial: <filter>
BIOS: American Megatrends v: X550LD.302 date: 04/14/2014
ID-1: BAT0 charge: 69.7 Wh condition: 77.0/77.0 Wh (100%)
model: ASUSTeK X550A30 status: Discharging
Topology: Dual Core model: Intel Core i7-4500U bits: 64 type: MT MCP
arch: Haswell rev: 1 L2 cache: 4096 KiB
bogomips: 19161
Speed: 1797 MHz min/max: 800/3000 MHz Core speeds (MHz): 1: 914 2: 1237
3: 915 4: 1285
Device-1: Intel Haswell-ULT Integrated Graphics vendor: ASUSTeK driver: i915
v: kernel bus ID: 00:02.0
Device-2: NVIDIA GF117M [GeForce 610M/710M/810M/820M / GT
620M/625M/630M/720M]
driver: nouveau v: kernel bus ID: 04:00.0
Device-3: Chicony USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus ID: 2-5:2
Display: x11 server: X.Org 1.20.9 driver: intel,nouveau
unloaded: modesetting resolution: 1366x768~60Hz
OpenGL: renderer: Mesa DRI Intel HD Graphics 4400 (HSW GT2)
v: 4.5 Mesa 20.1.8 direct render: Yes
Device-1: Intel Haswell-ULT HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus ID: 00:03.0
Device-2: Intel 8 Series HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus ID: 00:1b.0
Sound Server: ALSA v: k5.8.16-2-MANJARO
vendor: ASUSTeK driver: r8169 v: kernel port: e000 bus ID: 02:00.1
IF: enp2s0f1 state: down mac: <filter>
Device-2: Ralink RT3290 Wireless 802.11n 1T/1R PCIe vendor: Foxconn
driver: N/A port: e000 bus ID: 03:00.0
IF-ID-1: docker0 state: down mac: <filter>
Local Storage: total: 223.57 GiB used: 42.96 GiB (19.2%)
ID-1: /dev/sda vendor: Silicon Power model: SPCC Solid State Disk
ID-1: / size: 210.40 GiB used: 42.96 GiB (20.4%) fs: ext4 dev: /dev/sda1
ID-1: swap-1 type: partition size: 8.80 GiB used: 0 KiB (0.0%)
dev: /dev/sda2
System Temperatures: cpu: 39.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 188 Uptime: 2m Memory: 7.66 GiB used: 609.4 MiB (7.8%)
Init: systemd Compilers: gcc: 10.2.0 Packages: 1307 Shell: Zsh v: 5.8
inxi: 3.1.05
indent preformatted text by 4 spaces
Hi, and if you try using an LTS kernel like 5.4 or 4.19 to check if the problem persists…
Also you can try disabling mac address randomization and IPv6
It worked, thanks
