Hi all,
Ive just installed the latest version of Manjaro KDE (changed the SSD), the problem is that the WIFI doesn’t work, the modem is regularly detected, inserted the pw no connection is established. The wired connection work properly.
the system is as follow:
KDE Plasma Version: 5.27.5
KDE Frameworks Version: 5.106.0
Qt Version: 5.15.9
Kernel Version: 6.1.31-2-MANJARO (64-bit)
Graphics Platform: Wayland
Processors: 4 × Intel® Core™ i7-4510U CPU @ 2.00GHz
Memory: 7.7 GiB of RAM
Graphics Processor: Mesa Intel® HD Graphics 4400
Manufacturer: Hewlett-Packard
Product Name: HP ENVY 15 Notebook PC
System Version: 0974110000405F10000620180
The wifi card is a Broadcom 43142.
Strange that in the previous version of Manjaro WIFI worked properly.
Have someone idea of what happen?
TKS in advance
In the meanwhile I’ve upgraded the kernel with 6.3.5-1-MANJARO (64 bit)
does the wifi work with the 6.3?
if not post output from:
mhwd -l -li
Usually you need an extra module (driver) which can be installed with mhwd.
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
network-broadcom-wl 2018.10.07 false PCI
> 0000:09:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
network-r8168 2016.04.20 true PCI
> 0000:08:00.0 (0200:14e4:4365) Network controller Broadcom:
> 0000:0a:00.0 (0302:10de:1391) Display controller nVidia Corporation:
video-hybrid-intel-nvidia-prime 2023.03.23 false PCI
video-hybrid-intel-nvidia-470xx-prime 2023.03.23 false PCI
video-hybrid-intel-nvidia-390xx-bumblebee 2023.03.23 false PCI
video-nvidia 2023.03.23 false PCI
video-nvidia-470xx 2023.03.23 false PCI
video-nvidia-390xx 2023.03.23 false PCI
> 0000:00:02.0 (0300:8086:0a16) Display controller Intel Corporation:
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
Seems no driver is installed, is it?
I try to install with:
pamac build broadcom-wl-dkms
but still not working
you have it already installed…
but you dont have installed the proper video drivers, so post full system info:
inxi -zav7
and also output:
pacman -Qs 'dkms|broadcom|wl'
and are you dual booting with windows? if yes, is fast startup disabled?
and is fast boot disabled in your bios/uefi - you may not have this option there…
brahma:
inxi -zav7
Kernel: 6.3.5-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.3-x86_64
root=UUID=45c63889-359c-4b7b-9fec-92b201c5cde9 rw quiet splash
resume=UUID=816bcb4b-3c50-418d-aa16-005029f79392 udev.log_priority=3
Desktop: KDE Plasma v: 5.27.5 tk: Qt v: 5.15.9 wm: kwin_wayland vt: 2
Type: Laptop System: Hewlett-Packard product: HP ENVY 15 Notebook PC
v: 0974110000405F10000620180 serial: <superuser required> Chassis: type: 10
Mobo: Hewlett-Packard model: 228D v: 77.25 serial: <superuser required>
UEFI: Insyde v: F.11 date: 08/07/2014
System RAM: available: 7.69 GiB used: 2.27 GiB (29.5%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: Intel Core i7-4510U bits: 64 type: MT MCP arch: Haswell
gen: core 4 level: v3 note: check built: 2013-15 process: Intel 22nm
family: 6 model-id: 0x45 (69) stepping: 1 microcode: 0x26
L3: 16 MiB desc: 4x4 MiB
Speed (MHz): avg: 2292 high: 2784 min/max: 800/3100 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1995 2: 2133 3: 2256
4: 2784 bogomips: 20759
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
dtherm dts epb erms est f16c flush_l1d fma fpu fsgsbase fxsr ht ibpb ibrs
ida invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe
msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs
pge pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good sdbg sep smep
ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tsc tsc_adjust
tsc_deadline_timer vme xsave xsaveopt xtopology xtpr
Type: itlb_multihit status: KVM: VMX unsupported
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel Haswell-ULT Integrated Graphics vendor: Hewlett-Packard
driver: i915 v: kernel arch: Gen-7.5 process: Intel 22nm built: 2013 ports:
active: HDMI-A-1,eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:0a16
class-ID: 0300
Device-2: NVIDIA GM107M [GeForce GTX 850M] vendor: Hewlett-Packard
driver: nouveau v: kernel non-free: 530.xx+ status: current (as of 2023-05)
arch: Maxwell code: GMxxx process: TSMC 28nm built: 2014-19 pcie: gen: 1
speed: 2.5 GT/s lanes: 4 link-max: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 0a:00.0 chip-ID: 10de:1391 class-ID: 0302 temp: 44.0 C
Device-3: Suyin HP Truevision HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.3:3 chip-ID: 064e:c344
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1
alternate: fbdev,vesa dri: crocus,nouveau gpu: i915,nouveau
d-rect: 3286x1848 display-ID: 0
Monitor-1: HDMI-A-1 pos: top-right res: 1920x1080 size: N/A modes: N/A
Monitor-2: eDP-1 pos: bottom-l res: 1366x768 size: N/A modes: N/A
API: OpenGL v: 4.6 Mesa 23.0.3 renderer: Mesa Intel HD Graphics 4400 (HSW
GT2) direct-render: Yes
Device-1: Intel Haswell-ULT HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0a0c
class-ID: 0403
Device-2: Intel 8 Series HD Audio vendor: Hewlett-Packard 8
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20
class-ID: 0403
API: ALSA v: k6.3.5-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.70 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Device-1: Broadcom BCM43142 802.11b/g/n vendor: Hewlett-Packard driver: wl
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 08:00.0
chip-ID: 14e4:4365 class-ID: 0280
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 4000 bus-ID: 09:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-1: Broadcom BCM43142A0 Bluetooth Device driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.7:5
chip-ID: 0a5c:216c class-ID: fe01 serial: <filter>
Local Storage: total: 465.76 GiB used: 15.15 GiB (3.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT500MX500SSD1
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 045 scheme: GPT
Optical-1: /dev/sr0 vendor: hp model: DVDRW SU208FB rev: HH01
dev-links: cdrom
ID-1: / raw-size: 40.04 GiB size: 39.11 GiB (97.69%) used: 8.88 GiB (22.7%)
fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 45c63889-359c-4b7b-9fec-92b201c5cde9
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 8DF1-A8CE
ID-3: /home raw-size: 386.95 GiB size: 379.81 GiB (98.15%)
used: 3.31 GiB (0.9%) fs: ext4 dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: 951c1ff9-c8ac-4e44-ab81-8c3c3b21ba85
ID-4: /var raw-size: 30.27 GiB size: 29.63 GiB (97.87%)
used: 2.97 GiB (10.0%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: 010a0898-ade2-40ab-aa0b-1393628573c9
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 816bcb4b-3c50-418d-aa16-005029f79392
Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8000
Device-1: 1-1.3:3 info: Suyin HP Truevision HD type: video
lanes: 1 mode: 2.0 power: 500mA chip-ID: 064e:c344 class-ID: 0e02
serial: <filter>
Device-2: 1-1.5:6 info: Validity Sensors Swipe Fingerprint Sensor
type: <vendor specific> driver: N/A interfaces: 1 rev: 1.1
chip-ID: 138a:0050 class-ID: ff00 serial: <filter>
Device-3: 1-1.7:5 info: Broadcom BCM43142A0 Bluetooth Device
type: Bluetooth driver: btusb interfaces: 4 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 0a5c:216c
Hub-3: 2-0:1 info: hi-speed hub with single TT ports: 9 rev: 2.0
Device-1: 2-1:2 info: Shenzhen Rapoo 5G Wireless Device
type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 200mA
chip-ID: 24ae:2002 class-ID: 0301
Device-2: 2-2:3 info: Logitech Unifying Receiver type: keyboard,mouse
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0
chip-ID: 046d:c534 class-ID: 0301
Hub-4: 3-0:1 info: super-speed hub ports: 4 rev: 3.0
System Temperatures: cpu: 58.0 C mobo: N/A gpu: nouveau temp: 44.0 C
Processes: 185 Uptime: 3h 18m wakeups: 4 Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1191 libs: 366 tools: pamac pm: flatpak pkgs: 0
Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.27
I’ve forced again the installation, then reboot, and changed the protection, instead of WPA Personal I’ve setted WPA/WPA2, now seems working.
I’m honestly little bit surprise…
Now I try to reboot again so I can check if working properly.
All my computers are “Windows free” from more about 30 years, this is an old laptop “refurbished” with a new SSD and Manjaro, the fast boot is disabled, it’s fast enough
local/broadcom-wl-dkms 6.30.223.271-36
Broadcom 802.11 Linux STA wireless driver
local/dkms 3.0.11-1
Dynamic Kernel Modules System
local/foomatic-db 3:20230402-1
Foomatic - The collected knowledge about printers, drivers, and driver options in XML files, used by foomatic-db-engine to generate PPD files.
local/hwloc 2.9.1-1
Portable Hardware Locality is a portable abstraction of hierarchical architectures
local/layer-shell-qt 5.27.5-1 (plasma)
Qt component to allow applications to make use of the Wayland wl-layer-shell protocol
so now its working normally?
Yes it is!
now work normally, at least the WIFI
system
Closed
12 June 2023 04:27
14
