I have just switched from Ubuntu to Manjaro a few days ago. And this is the same problem that is bothering me. At first it seemed that the problem starts after closing the lid, but I later noticed that it only disconnects when opening the lid. I did whatever I could - modified /etc/systemd/logind.conf
and set lid related switches to “ignore”. did’t work. Modified /etc/Upower/Upower.conf
, didn’t work. changed lid related settings from settings manager. but still the problem wasn’t solved.
This is my laptop info:
System: Kernel: 5.10.32-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: KDE Plasma 5.21.4
tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 2 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Machine: Type: Laptop System: HP product: HP Laptop 15-ra0xx v: Type1ProductConfigId serial: <filter> Chassis:
type: 10 serial: <filter>
Mobo: HP model: 832C v: 25.53 serial: <filter> UEFI: Insyde v: F.52 date: 03/04/2019
Battery: ID-1: BAT1 charge: 26.8 Wh (98.9%) condition: 27.1/31.1 Wh (87.3%) volts: 12.6 min: 10.9
model: COMPAL PABAS0241231 type: Li-ion serial: <filter> status: Charging
Memory: RAM: total: 3.75 GiB used: 3.13 GiB (83.4%)
CPU: Info: Dual Core model: Intel Celeron N3060 bits: 64 type: MCP arch: Airmont rev: 4 cache: L2: 1024 KiB
bogomips: 6400
Speed: 480 MHz min/max: 480/2480 MHz Core speeds (MHz): 1: 480 2: 1197
Flags: 3dnowprefetch acpi aes aperfmperf apic arat arch_perfmon bts clflush cmov constant_tsc cpuid cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept erms est flexpriority fpu fxsr ht ibpb ibrs ida lahf_lm lm mca
mce md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pclmulqdq pdcm pebs pge pni
popcnt pse pse36 pti rdrand rdtscp rep_good sep smep ss sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq tsc_reliable vme vmx vnmi vpid xtopology xtpr
Graphics: Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Integrated Graphics
vendor: Hewlett-Packard driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:22b1 class-ID: 0300
Device-2: Quanta HP Webcam type: USB driver: uvcvideo bus-ID: 1-5.2:4 chip-ID: 0408:5220 class-ID: 0e02
serial: <filter>
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: intel unloaded: modesetting
alternate: fbdev,vesa resolution: 1366x768~60Hz s-dpi: 96
OpenGL: renderer: Mesa DRI Intel HD Graphics 400 (BSW) v: 4.6 Mesa 21.0.3 compat-v: 3.0
direct render: Yes
Audio: Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series High Definition Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:2284 class-ID: 0403
Sound Server-1: ALSA v: k5.10.32-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.26 running: yes
Network: Device-1: Realtek RTL8723DE 802.11b/g/n PCIe Adapter vendor: Hewlett-Packard driver: rtw_8723de v: N/A
port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:d723 class-ID: 0280
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard driver: r8169
v: kernel port: 1000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Bluetooth: Device-1: Realtek Realtek Bluetooth 4.2 Adapter type: USB driver: btusb v: 0.8 bus-ID: 1-5.3:5
chip-ID: 0bda:b009 class-ID: e001 serial: <filter>
Logical: Message: No logical block device data found.
RAID: Message: No RAID data found.
Drives: Local Storage: total: 465.76 GiB used: 321.68 GiB (69.1%)
ID-1: /dev/sda vendor: Seagate model: ST500LT012-1DG142 size: 465.76 GiB speed: 6.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: YAM1 scheme: GPT
Optical-1: /dev/sr0 vendor: hp model: DVDRW GUE1N rev: UE00 dev-links: cdrom
Features: speed: 24 multisession: yes audio: yes dvd: yes rw: cd-r,cd-rw,dvd-r,dvd-ram state: running
Partition: ID-1: / size: 27.39 GiB used: 22.7 GiB (82.9%) fs: ext4 dev: /dev/sda4 label: N/A
uuid: cc1538dd-32ea-4296-9f1c-b08c11714ab9
ID-2: /boot/efi size: 498.7 MiB used: 54.5 MiB (10.9%) fs: vfat dev: /dev/sda1 label: N/A uuid: 66B8-1543
ID-3: /home size: 31.25 GiB used: 20.2 GiB (64.6%) fs: ext4 dev: /dev/sda5 label: home
uuid: a06b726c-de97-4474-80c3-873121196ec4
ID-4: /mnt/media/Drive1 size: 150.32 GiB used: 127.72 GiB (85.0%) fs: ntfs dev: /dev/sda6 label: Drive1
uuid: 6EAE098C2F7D4E1D
ID-5: /mnt/media/Drive2 size: 150.32 GiB used: 128.8 GiB (85.7%) fs: ntfs dev: /dev/sda7 label: Drive2
uuid: 55CD67C21BA8982A
ID-6: /mnt/reserved size: 36 GiB used: 21.22 GiB (58.9%) fs: ntfs dev: /dev/sda8 label: reserved
uuid: 2BD9711A328BD245
Swap: ID-1: swap-1 type: partition size: 4 GiB used: 1021.3 MiB (24.9%) priority: -2 dev: /dev/sda9 label: N/A
uuid: 08673926-7361-4d2a-8303-9f12f37f44ea
Unmounted: ID-1: /dev/sda2 size: 64.01 GiB fs: ntfs label: Windows uuid: FE48793C4878F4AD
ID-2: /dev/sda3 size: 635 MiB fs: ntfs label: N/A uuid: 12AC3697AC367577
USB: Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 7 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002
Device-1: 1-2:7 info: Logitech M105 Optical Mouse type: Mouse driver: hid-generic,usbhid interfaces: 1
rev: 2.0 speed: 1.5 Mb/s power: 100mA chip-ID: 046d:c077 class-ID: 0301
Hub-2: 1-5:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s power: 100mA chip-ID: 05e3:0608
Device-1: 1-5.2:4 info: Quanta HP Webcam type: Video driver: uvcvideo interfaces: 2 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 0408:5220 class-ID: 0e02 serial: <filter>
Device-2: 1-5.3:5 info: Realtek Realtek Bluetooth 4.2 Adapter type: Bluetooth driver: btusb interfaces: 2
rev: 1.1 speed: 12 Mb/s power: 500mA chip-ID: 0bda:b009 class-ID: e001 serial: <filter>
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s chip-ID: 1d6b:0003
Sensors: System Temperatures: cpu: 49.0 C mobo: 27.8 C
Info: Processes: 213 Uptime: 15h 02m wakeups: 7 Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages:
pacman: 1460 Shell: Zsh v: 5.8 running-in: konsole inxi: 3.3.04
And this is the journalctl
output when opening the lid:
> -- Journal begins at Fri 2021-04-30 02:02:51 +06, ends at Tue 2021-05-04 15:16:54 +06. --
28607a28608,28684
> May 04 15:16:44 hp kwin_x11[821]: kwin_core: XCB error: 152 (BadDamage), sequence: 55082, resource id: 16382982, major code: 143 (DAMAGE), minor code: 3 (Subtract)
> May 04 15:16:48 hp kernel: wlo1: deauthenticating from cc:2d:21:00:f0:40 by local choice (Reason: 3=DEAUTH_LEAVING)
> May 04 15:16:49 hp wpa_supplicant[537]: wlo1: CTRL-EVENT-DISCONNECTED bssid=cc:2d:21:00:f0:40 reason=3 locally_generated=1
> May 04 15:16:49 hp kernel: rtw_8723de 0000:02:00.0: sta cc:2d:21:00:f0:40 with macid 0 left
> May 04 15:16:49 hp kernel: rtw_8723de 0000:02:00.0: stop vif d8:9c:67:24:5a:19 on port 0
> May 04 15:16:49 hp avahi-daemon[476]: Interface wlo1.IPv6 no longer relevant for mDNS.
> May 04 15:16:49 hp systemd-networkd[222]: wlo1: Link DOWN
> May 04 15:16:49 hp avahi-daemon[476]: Leaving mDNS multicast group on interface wlo1.IPv6 with address fe80::279c:e3a6:5e92:d2b9.
> May 04 15:16:49 hp systemd-networkd[222]: wlo1: Lost carrier
> May 04 15:16:49 hp kernel: audit: type=1130 audit(1620119809.190:381): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> May 04 15:16:49 hp audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> May 04 15:16:49 hp avahi-daemon[476]: Interface wlo1.IPv4 no longer relevant for mDNS.
> May 04 15:16:49 hp systemd[1]: Starting Load/Save RF Kill Switch Status...
> ░░ Subject: A start job for unit systemd-rfkill.service has begun execution
> ░░ Defined-By: systemd
> ░░ Support: https://forum.manjaro.org/c/support
> ░░ A start job for unit systemd-rfkill.service has begun execution.
> ░░ The job identifier is 8279.
> May 04 15:16:49 hp avahi-daemon[476]: Leaving mDNS multicast group on interface wlo1.IPv4 with address 192.168.0.110.
> May 04 15:16:49 hp NetworkManager[480]: <info> [1620119809.0936] manager: rfkill: Wi-Fi now disabled by radio killswitch
> May 04 15:16:49 hp avahi-daemon[476]: Withdrawing address record for fe80::279c:e3a6:5e92:d2b9 on wlo1.
> May 04 15:16:49 hp NetworkManager[480]: <info> [1620119809.0940] device (wlo1): state change: activated -> unavailable (reason 'none', sys-iface-state: 'managed')
> May 04 15:16:49 hp avahi-daemon[476]: Withdrawing address record for 192.168.0.110 on wlo1.
> May 04 15:16:49 hp kernel: audit: type=1130 audit(1620119809.740:382): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> May 04 15:16:49 hp audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> May 04 15:16:49 hp systemd-logind[485]: Lid opened.
> May 04 15:16:49 hp wpa_supplicant[537]: rfkill: WLAN soft blocked
> May 04 15:16:49 hp NetworkManager[480]: <info> [1620119809.1368] dhcp4 (wlo1): canceled DHCP transaction
> May 04 15:16:49 hp dbus-daemon[479]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.5' (uid=0 pid=480 comm="/usr/bin/NetworkManager --no-daemon ")
> May 04 15:16:49 hp NetworkManager[480]: <info> [1620119809.1369] dhcp4 (wlo1): state changed bound -> terminated
> May 04 15:16:49 hp wpa_supplicant[537]: nl80211: deinit ifname=wlo1 disabled_11b_rates=0
> May 04 15:16:49 hp NetworkManager[480]: <info> [1620119809.1412] device (wlo1): set-hw-addr: set MAC address to 9E:6A:0C:22:56:6A (scanning)
> May 04 15:16:49 hp dbus-daemon[479]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
> May 04 15:16:49 hp systemd[1]: Started Load/Save RF Kill Switch Status.
> ░░ Subject: A start job for unit systemd-rfkill.service has finished successfully
> ░░ A start job for unit systemd-rfkill.service has finished successfully.
> May 04 15:16:49 hp NetworkManager[480]: <info> [1620119809.3771] manager: NetworkManager state is now DISCONNECTED
> May 04 15:16:49 hp systemd[1]: Starting Network Manager Script Dispatcher Service...
> ░░ Subject: A start job for unit NetworkManager-dispatcher.service has begun execution
> ░░ A start job for unit NetworkManager-dispatcher.service has begun execution.
> ░░ The job identifier is 8287.
> May 04 15:16:49 hp kded5[817]: plasma-nm: Network connectivity limited, scheduling notification
> May 04 15:16:49 hp systemd[1]: Started Network Manager Script Dispatcher Service.
> ░░ Subject: A start job for unit NetworkManager-dispatcher.service has finished successfully
> ░░ A start job for unit NetworkManager-dispatcher.service has finished successfully.
> May 04 15:16:54 hp systemd[1]: systemd-rfkill.service: Succeeded.
> ░░ Subject: Unit succeeded
> ░░ The unit systemd-rfkill.service has successfully entered the 'dead' state.
> May 04 15:16:54 hp kernel: audit: type=1131 audit(1620119814.220:383): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> May 04 15:16:54 hp audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> May 04 15:16:59 hp systemd[1]: NetworkManager-dispatcher.service: Succeeded.
> ░░ The unit NetworkManager-dispatcher.service has successfully entered the 'dead' state.
> May 04 15:16:59 hp audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> May 04 15:16:59 hp kernel: audit: type=1131 audit(1620119819.540:384): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
I did not have this kind of weird problem in Ubuntu.
