laosom
17 November 2020 13:08
1
My wifi connection randomly drops when in Manjaro KDE when the 5.4 LTS kernel is loaded.
I only experince this with Manjaro KDE, not with other distros .
When it brakes it displays a KDE popup window , asking for the password.
It seems kernels 5.8 and 5.9 does not produce this .
My wifi router is set to use atomatic for channel select.
I found only these related so far:
t/wifi-frequently-disconnects-and-prompts-me-for-the-password/37498
t/wifi-connection-randomly-disconnects/35520
Please advise
nov 17 12:01:01 dell6540-manjaro CROND[15315]: (root) CMD (run-parts /etc/cron.hourly)
nov 17 12:02:16 dell6540-manjaro wpa_supplicant[760]: wlp3s0: WPA: Group rekeying completed with 10:62:eb:44:66:9d [GTK=TKIP]
nov 17 12:02:17 dell6540-manjaro wpa_supplicant[760]: wlp3s0: WPA: Group rekeying completed with 10:62:eb:44:66:9d [GTK=TKIP]
nov 17 12:02:18 dell6540-manjaro wpa_supplicant[760]: wlp3s0: WPA: Group rekeying completed with 10:62:eb:44:66:9d [GTK=TKIP]
nov 17 12:02:19 dell6540-manjaro wpa_supplicant[760]: wlp3s0: WPA: Group rekeying completed with 10:62:eb:44:66:9d [GTK=TKIP]
nov 17 12:02:20 dell6540-manjaro wpa_supplicant[760]: wlp3s0: Reject scan trigger since one is already pending
nov 17 12:02:20 dell6540-manjaro wpa_supplicant[760]: wlp3s0: WPA: Group rekeying completed with 10:62:eb:44:66:9d [GTK=TKIP]
nov 17 12:02:21 dell6540-manjaro wpa_supplicant[760]: wlp3s0: WPA: Group rekeying completed with 10:62:eb:44:66:9d [GTK=TKIP]
nov 17 12:02:23 dell6540-manjaro kernel: wlp3s0: deauthenticated from 10:62:eb:44:66:9d (Reason: 1=UNSPECIFIED)
nov 17 12:02:23 dell6540-manjaro wpa_supplicant[760]: wlp3s0: CTRL-EVENT-DISCONNECTED bssid=10:62:eb:44:66:9d reason=1
nov 17 12:02:23 dell6540-manjaro wpa_supplicant[760]: wlp3s0: SME: Trying to authenticate with 10:62:eb:44:66:9d (SSID='MISZTI' freq=2412 MHz)
nov 17 12:02:23 dell6540-manjaro kernel: wlp3s0: authenticate with 10:62:eb:44:66:9d
nov 17 12:02:23 dell6540-manjaro kernel: wlp3s0: send auth to 10:62:eb:44:66:9d (try 1/3)
nov 17 12:02:23 dell6540-manjaro wpa_supplicant[760]: wlp3s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
nov 17 12:02:23 dell6540-manjaro NetworkManager[536]: <info> [1605610943.2432] device (wlp3s0): supplicant interface state: completed -> authenticating
nov 17 12:02:23 dell6540-manjaro wpa_supplicant[760]: wlp3s0: Trying to associate with 10:62:eb:44:66:9d (SSID='MISZTI' freq=2412 MHz)
nov 17 12:02:23 dell6540-manjaro kernel: wlp3s0: authenticated
nov 17 12:02:23 dell6540-manjaro kernel: wlp3s0: associate with 10:62:eb:44:66:9d (try 1/3)
nov 17 12:02:23 dell6540-manjaro NetworkManager[536]: <info> [1605610943.2492] device (wlp3s0): supplicant interface state: authenticating -> associating
nov 17 12:02:23 dell6540-manjaro kernel: wlp3s0: RX AssocResp from 10:62:eb:44:66:9d (capab=0x411 status=0 aid=6)
nov 17 12:02:23 dell6540-manjaro wpa_supplicant[760]: wlp3s0: Associated with 10:62:eb:44:66:9d
nov 17 12:02:23 dell6540-manjaro wpa_supplicant[760]: wlp3s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
nov 17 12:02:23 dell6540-manjaro kernel: wlp3s0: associated
nov 17 12:02:23 dell6540-manjaro wpa_supplicant[760]: l2_packet_send - sendto: No buffer space available
nov 17 12:02:23 dell6540-manjaro kernel: wlp3s0: deauthenticating from 10:62:eb:44:66:9d by local choice (Reason: 1=UNSPECIFIED)
nov 17 12:02:23 dell6540-manjaro wpa_supplicant[760]: wlp3s0: CTRL-EVENT-DISCONNECTED bssid=10:62:eb:44:66:9d reason=1 locally_generated=1
nov 17 12:02:23 dell6540-manjaro wpa_supplicant[760]: wlp3s0: WPA: 4-Way Handshake failed - pre-shared key may be incorrect
nov 17 12:02:23 dell6540-manjaro wpa_supplicant[760]: wlp3s0: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="MISZTI" auth_failures=1 duration=10 reason=WRONG_KEY
nov 17 12:02:23 dell6540-manjaro NetworkManager[536]: <info> [1605610943.3049] device (wlp3s0): supplicant interface state: associating -> 4way_handshake
nov 17 12:02:23 dell6540-manjaro NetworkManager[536]: <info> [1605610943.3102] device (wlp3s0): supplicant interface state: 4way_handshake -> disconnected
nov 17 12:02:23 dell6540-manjaro NetworkManager[536]: <info> [1605610943.3121] device (wlp3s0): Activation: (wifi) disconnected during association, asking for new key
nov 17 12:02:23 dell6540-manjaro NetworkManager[536]: <info> [1605610943.3123] device (wlp3s0): state change: activated -> need-auth (reason 'supplicant-disconnect', sys-iface-state: 'managed')
nov 17 12:02:23 dell6540-manjaro NetworkManager[536]: <info> [1605610943.3276] dhcp4 (wlp3s0): canceled DHCP transaction
nov 17 12:02:23 dell6540-manjaro NetworkManager[536]: <info> [1605610943.3276] dhcp4 (wlp3s0): state changed bound -> done
nov 17 12:02:23 dell6540-manjaro NetworkManager[536]: <info> [1605610943.3283] manager: NetworkManager state is now CONNECTING
nov 17 12:02:23 dell6540-manjaro dbus-daemon[535]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.5' (uid=0 pid=536 comm="/usr/bin/NetworkManager --no-daemon " label="unconfined")
nov 17 12:02:23 dell6540-manjaro systemd[1]: Starting Network Manager Script Dispatcher Service...
nov 17 12:02:23 dell6540-manjaro dbus-daemon[535]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
nov 17 12:02:23 dell6540-manjaro audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
nov 17 12:02:23 dell6540-manjaro systemd[1]: Started Network Manager Script Dispatcher Service.
nov 17 12:02:23 dell6540-manjaro kernel: audit: type=1130 audit(1605610943.342:86): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
nov 17 12:02:23 dell6540-manjaro kded5[959]: plasma-nm: Unhandled active connection state change: 1
nov 17 12:02:23 dell6540-manjaro kded5[959]: plasma-nm: virtual NMVariantMapMap SecretAgent::GetSecrets(const NMVariantMapMap&, const QDBusObjectPath&, const QString&, const QStringList&, uint)
nov 17 12:02:23 dell6540-manjaro kded5[959]: plasma-nm: Path: "/org/freedesktop/NetworkManager/Settings/6"
nov 17 12:02:23 dell6540-manjaro kded5[959]: plasma-nm: Setting name: "802-11-wireless-security"
nov 17 12:02:23 dell6540-manjaro kded5[959]: plasma-nm: Hints: ()
nov 17 12:02:23 dell6540-manjaro kded5[959]: plasma-nm: Flags: 3
nov 17 12:02:23 dell6540-manjaro NetworkManager[536]: <info> [1605610943.4097] device (wlp3s0): supplicant interface state: disconnected -> inactive
laosom
19 November 2020 11:02
2
I checked also the arch wikis
https://wiki.archlinux.org/index.php/Network_configuration/Wireless
https://wiki.archlinux.org/index.php/wpa_supplicant
and found this:
Password-related problems
wpa_supplicant may not work properly if directly passed via stdin particularly long or complex passphrases which include special characters. This may lead to errors such as failed 4-way WPA handshake, PSK may be wrong when launching wpa_supplicant.
In order to solve this try using here strings wpa_passphrase <<< “” or passing a file to the -c flag instead:
wpa_supplicant -i -c /etc/wpa_supplicant/example.conf
In some instances it was found that storing the passphrase cleartext in the psk key of the wpa_supplicant.conf network block gave positive results (see [2]). However, this approach is rather insecure. Using wpa_cli to create this file instead of manually writing it gives the best results most of the time and therefore is the recommended way to proceed.
laosom
19 November 2020 12:10
3
I use the option "Store password for this user only encrypted " in KDE Wallet.
j8a
19 November 2020 12:32
4
Hi @laosom ,
Please post the output of the following command in the terminal: inxi -N.
Regards
laosom
19 November 2020 15:51
5
Hi j8a
I tried with the recommended configuration in /etc/NetworkManager/conf.d/wifi_rand_mac.conf
but wifi breaks with the same errors.
lali@dell6540-manjaro:~$ inxi -N
Network: Device-1: Intel Ethernet I217-LM driver: e1000e
Device-2: Intel Centrino Advanced-N 6235 driver: iwlwifi
laosom
19 November 2020 16:02
6
I am testing this on 2 laptops. On another one it disconnected onyl once if I remember correctly.
That one is:
[lali@latitudee6500 ~]$ inxi -N
Network: Device-1: Intel 82567LM Gigabit Network driver: e1000e
Device-2: Intel WiFi Link 5100 driver: iwlwifi
Althouh I am unsure if it is really kernel related,
the annoying is, that kernel updates in the 5.4 LTS series do not make any difference or fix.
I did not experince it with 5.7 5.8 5.9 kernels so far, but I wonder what is wrong with it.
Ubuntu based distros are fine with 5.4.
I even tried to create additional users to be sure the kde config files are not messed up,
but I am unsure about the results. It seems more stable though.
I haven’t tested it with my original user and not encrypted password (clear text ).
I would like to understand the wpa errors and the possible fixes.
j8a
19 November 2020 20:50
7
Hi, @laosom
Please, can you check from the terminal that the linux-firmware is installed on your system?
sudo pacman -Qi linux-firmware
The output may look like this:
Name : linux-firmware Version : 20201113.r1774.2ea8667-1 Description : Firmware files for Linux (Manjaro Overlay Package) Architecture : any URL : https://git.kernel.org/?p=linux/kernel/git/firmware/linux-firmware.git;a=summary Licenses : GPL2 GPL3 custom Groups : None Provides : None Depends On : None Optional Deps : None Required By : linux419 linux54 Optional For : None Conflicts With : linux-firmware-git kernel26-firmware ar9170-fw iwlwifi-1000-ucode iwlwifi-3945-ucode iwlwifi-4965-ucode iwlwifi-5000-ucode iwlwifi-5150-ucode iwlwifi-6000-ucode rt2870usb-fw rt2x00-rt61-fw rt2x00-rt71w-fw Replaces : kernel26-firmware ar9170-fw iwlwifi-1000-ucode iwlwifi-3945-ucode iwlwifi-4965-ucode iwlwifi-5000-ucode iwlwifi-5150-ucode iwlwifi-6000-ucode rt2870usb-fw rt2x00-rt61-fw rt2x00-rt71w-fw Installed Size : 603,01 MiB Packager : Helmut Stult <helmut@manjaro.org> Build Date : vie 13 nov 2020 13:14:13 Install Date : jue 19 nov 2020 09:01:51 Install Reason : Explicitly installed Install Script : No Validated By : Signature
Just in case either you have no output or it is not installed run the following command on the terminal:
sudo pacman -S linux-firmware
Hope it help, regards
laosom
20 November 2020 15:28
8
Hi j8a,
Yes I have:
lali@dell6540-manjaro:~$ sudo pacman -Qi linux-firmware
Architecture : any
Groups : None
Provides : None
Depends On : None
Required By : linux419 linux54 linux58 linux59
Optional For : None
Packager : Helmut Stult helmut@manjaro.org
Build Date : 2020. nov. 13., péntek, 17:14:13 CET
Install Date : 2020. nov. 18., szerda, 17:27:36 CET
Install Reason : Installed as a dependency for another package
Install Script : No
lali@dell6540-manjaro:~$ grep -i linux-firmware /var/log/pacman.log
[2020-08-11T15:30:54+0200] [ALPM] upgraded linux-firmware (20200519.r1641.8ba6fa6-1 -> 20200716.r1675.1d1c80b-1)
[2020-08-16T16:55:47+0200] [ALPM] upgraded linux-firmware (20200716.r1675.1d1c80b-1 -> 20200807.r1689.c331aa9-1)
[2020-08-27T20:12:01+0200] [ALPM] upgraded linux-firmware (20200807.r1689.c331aa9-1 -> 20200817.r1695.7a30af1-1)
[2020-09-08T20:11:28+0200] [ALPM] upgraded linux-firmware (20200817.r1695.7a30af1-1 -> 20200901.r1699.d5f9eea-1)
[2020-10-04T20:28:17+0200] [ALPM] upgraded linux-firmware (20200901.r1699.d5f9eea-1 -> 20200923.r1716.afbfb5f-1)
[2020-10-20T08:08:59+0200] [ALPM] upgraded linux-firmware (20200923.r1716.afbfb5f-1 -> 20201005.r1732.58d41d0-1)
[2020-11-05T18:36:25+0100] [ALPM] upgraded linux-firmware (20201005.r1732.58d41d0-1 -> 20201023.r1747.dae4b4c-1)
[2020-11-18T17:27:36+0100] [ALPM] upgraded linux-firmware (20201023.r1747.dae4b4c-1 -> 20201113.r1774.2ea8667-1)
j8a
24 November 2020 13:26
9
Hi @laosom ,
I read the wiki Arch posts and I suggest you to consider the following:
Create an wpa supplicant interface with:
sudo wpa_supplicant -i -c /etc/wpa_supplicant/wlp3s0.conf
Then, with a text editor open example.conf and write the text.
network={
ssid=“MISZTI”
psk=“I do not know your passphrase”
Save, and rerun wpa_supplicant.
Hope it helps, regards
laosom
30 November 2020 17:05
10
Hi Javier,
Would you explain why that would help ?
I use NetworkManager and KDE wallet to store the password ecrypted.
j8a
30 November 2020 18:23
11
Hi, @laosom
Please, take a look at this post.
`` `https://forum.manjaro.org/t/wifi-disconnects-randomly/38077/9```
Maybe, you could find the answer to your question reading the wiki archlinux posts.
Regards
