WiFi disconnects on lid close
My WiFi is getting disconnected whenever I close the lid. Bluetooth etc. are remaining intact. This started happening after the latest update.
I’ve set it up to only lock the screen on lid close in the Advanced Power Management Settings.
WiFi doesn’t get disconnected if I lock the screen without closing the lid.
WiFi gets disconnected even if I set it to do nothing on lid closure.
Please help.
inxi -Fazy
  Kernel: 5.10.2-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  root=UUID=fe64fafd-1c2a-4b55-846f-c264196ff166 rw nomce "acpi_osi=Windows
  2018" quiet resume=UUID=4517ac81-4ac6-42a0-8e7a-a5870b5f98df
  Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 wm: kwin_x11 dm: GDM 3.38.2, SDDM
  Distro: Manjaro Linux
  Type: Laptop System: HP product: HP Pavilion Laptop 14-bf1xx
  v: Type1ProductConfigId serial: <filter> Chassis: type: 10 serial: <filter>
  Mobo: HP model: 83CE v: 59.38 serial: <filter> UEFI: Insyde v: F.31
  date: 10/30/2017
  ID-1: BAT1 charge: 2.3 Wh condition: 31.1/42.1 Wh (74%) volts: 10.7/11.6
  model: Hewlett-Packard PABAS0241231 type: Li-ion serial: <filter>
  status: Unknown
  Info: Quad Core model: Intel Core i7-8550U bits: 64 type: MT MCP
  arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: A (10)
  microcode: E0 L2 cache: 8 MiB
  flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 32012
  Speed: 800 MHz min/max: 400/1800 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
  4: 800 5: 800 6: 800 7: 800 8: 800
  Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
  Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915
  v: kernel bus ID: 00:02.0 chip ID: 8086:5917
  Device-2: NVIDIA GM108M [GeForce 940MX] vendor: Hewlett-Packard
  driver: nvidia v: 455.45.01 alternate: nouveau,nvidia_drm bus ID: 01:00.0
  chip ID: 10de:134d
  Device-3: Chicony HP Wide Vision HD Camera type: USB driver: uvcvideo
  bus ID: 1-5:4 chip ID: 04f2:b5d6
  Display: x11 server: X.Org 1.20.10 compositor: kwin_x11
  driver: modesetting,nvidia alternate: fbdev,intel,nouveau,nv,vesa
  display ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 115 s-size: 424x238mm (16.7x9.4")
  s-diag: 486mm (19.1")
  Monitor-1: eDP-1 res: 1920x1080 dpi: 158 size: 309x173mm (12.2x6.8")
  diag: 354mm (13.9")
  OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.3.1
  direct render: Yes
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard
  driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus ID: 00:1f.3
  chip ID: 8086:9d71
  Sound Server: ALSA v: k5.10.2-2-MANJARO
  vendor: Hewlett-Packard driver: r8168 v: 8.048.03-NAPI modules: r8169
  port: 3000 bus ID: 02:00.0 chip ID: 10ec:8168
  Device-2: Intel Wireless 7265 driver: iwlwifi v: kernel port: 3000
  bus ID: 03:00.0 chip ID: 8086:095a
  Local Storage: total: 1.03 TiB used: 544.99 GiB (51.9%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
  size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
  serial: <filter> rev: RSM7
  ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SD8SN8U-128G-1006
  size: 119.24 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
  serial: <filter> rev: 0006
  ID-1: / raw size: 50 GiB size: 48.72 GiB (97.43%) used: 37.14 GiB (76.2%)
  fs: ext4 dev: /dev/sdb5 maj-min: 8:21
  ID-2: /boot/efi raw size: 277 MiB size: 276.4 MiB (99.80%)
  used: 280 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
  ID-3: /home raw size: 60.87 GiB size: 59.67 GiB (98.02%)
  used: 31.76 GiB (53.2%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18
  Kernel: swappiness: 5 (default 60) cache pressure: 50 (default 100)
  ID-1: swap-1 type: partition size: 8.1 GiB used: 2.58 GiB (31.9%)
  priority: -2 dev: /dev/sdb3 maj-min: 8:19
  System Temperatures: cpu: 36.0 C mobo: 29.8 C
  Processes: 328 Uptime: 23h 42m wakeups: 6 Memory: 7.69 GiB
  used: 4.63 GiB (60.2%) Init: systemd v: 247 Compilers: gcc: 10.2.0
  Packages: 1961 pacman: 1960 lib: 453 flatpak: 1 Shell: fish v: 3.1.2
  running in: server inxi: 3.2.01
I solved it (or so I thought). Had to edit my /etc/systemd/logind.conf to
#  This file is part of systemd.
#  systemd is free software; you can redistribute it and/or modify it
#  under the terms of the GNU Lesser General Public License as published by
#  the Free Software Foundation; either version 2.1 of the License, or
#  (at your option) any later version.
# Entries in this file show the compile time defaults.
# You can change settings by editing this file.
# Defaults can be restored by simply deleting this file.
# See logind.conf(5) for details.
[Login]
#NAutoVTs=6
#ReserveVT=6
#KillUserProcesses=no
#KillOnlyUsers=
#KillExcludeUsers=root
#InhibitDelayMaxSec=5
#UserStopDelaySec=10
#HandlePowerKey=poweroff
#HandleSuspendKey=suspend
#HandleHibernateKey=hibernate
HandleLidSwitch=ignore
HandleLidSwitchExternalPower=ignore
HandleLidSwitchDocked=ignore
#HandleRebootKey=reboot
#PowerKeyIgnoreInhibited=no
#SuspendKeyIgnoreInhibited=no
#HibernateKeyIgnoreInhibited=no
LidSwitchIgnoreInhibited=no
#RebootKeyIgnoreInhibited=no
#HoldoffTimeoutSec=30s
#IdleAction=ignore
#IdleActionSec=30min
#RuntimeDirectorySize=10%
#RuntimeDirectoryInodes=400k
#RemoveIPC=yes
#InhibitorsMax=8192
#SessionsMax=8192
and reboot.
EDIT: The problem is back after reboot.
Deleting the file /etc/systemd/logind.conf altogether seems to have fixed my issue (it said in the file that deleting it restores defaults, so I don’t think it breaks anything else).
The fix has survived a reboot, so I hope it works as a permanent fix.
