WiFi Disconnected, I Manually Reconnected
This is not a big issue, but it happened, shouldn’t have happened I think.
I was working normally, suddenly noticed my laptop got disconnected fro the WiFi. I waited for a few minutes, it didn’t reconnect so I simply disconnected and reconnected again.
I did my homework and searched and found many cases with different details, some with solutions and some without here Search results for 'wifi disconnects' - Manjaro Linux Forum I read them all almost.
Then I thought and looked at:
Should I simply check the checkbox at “Connect automatically with priority”?
I am on LTS by the way.
I am just trying to get my Manjaro KDE (Stable) as perfect as possible.
I will appreciate your feed back.
 sudo inxi --verbosity=8 --filter --w                                             ✔
[sudo] password for oldtux:
  Kernel: 6.6.46-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.6-x86_64
    root=UUID=6b653fb7-09dc-4411-9eb2-e9e3637c4464 rw rootflags=subvol=@
  Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A wm: kwin_x11 dm: SDDM
  Type: Convertible System: HP product: HP Spectre x360 Convertible 13-ae0xx
    v: N/A serial: <filter> Chassis: type: 31 serial: N/A
  Mobo: HP model: 83B9 v: 56.50 serial: <filter> part-nu: 3DR36PA#UUF
    uuid: 37444335-3734-3932-3952-523937344435 UEFI: AMI v: F.36
    date: 03/19/2022
  ID-1: BAT0 charge: 49.0 Wh (100.0%) condition: 49.0/49.0 Wh (100.0%)
    volts: 12.5 min: 11.6 model: HP Primary type: Li-ion serial: N/A
    status: full
  Device-1: hid-0018:04F3:2597.0002-battery model: ELAN2514:00 04F3:2597
    serial: N/A charge: N/A status: N/A
  System RAM: total: 8 GiB available: 7.51 GiB used: 4.26 GiB (56.7%)
    igpu: 64 MiB
  Array-1: capacity: 8 GiB slots: 2 modules: 2 EC: None
    max-module-size: 4 GiB note: est.
  Device-1: Bottom - on board type: LPDDR3 detail: synchronous unbuffered
    (unregistered) size: 4 GiB speed: 2133 MT/s volts: curr: 1.2 min: 1.25
    max: 1.25 width (bits): data: 64 total: 64 manufacturer: Micron
    part-no: MT52L512M32D2PF-093 WT:B serial: N/A
  Device-2: Bottom - on board type: LPDDR3 detail: synchronous unbuffered
  Slot: 0 type: PCIe status: in use info: J6B2 length: long volts: 3.3
    bus-ID: 00:01.0
  Info: model: Intel Core i7-8550U socket: BGA1356 (U3E1) note: check bits: 64
    type: MT MCP arch: Coffee Lake gen: core 8 level: v3 note: check built: 2017
    process: Intel 14nm family: 6 model-id: 0x8E (142) stepping: 0xA (10)
    microcode: 0xF6
    L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 450 high: 800 min/max: 400/4000 base/boost: 3700/8300
    scaling: driver: intel_pstate governor: powersave volts: 1.1 V
    ext-clock: 100 MHz cores: 1: 400 2: 400 3: 400 4: 400 5: 800 6: 400 7: 400
    8: 400 bogomips: 32012
    sgx smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
    vulnerable
  Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915
    v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
    active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
    chip-ID: 8086:5917 class-ID: 0300
  Device-2: Cheng Uei Precision Industry (Foxlink) HP Wide Vision FHD Camera
    driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
    bus-ID: 1-5:3 chip-ID: 05c8:0815 class-ID: 0e02 serial: <filter>
  Display: unspecified server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
    compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: :0 screens: 1
    s-diag: 582mm (22.93") monitors: <missing: xrandr>
  Monitor-1: eDP-1 model: ChiMei InnoLux 0x1376 built: 2015 res: 1920x1080
    dpi: 166 gamma: 1.2 chroma: red: x: 0.639 y: 0.329 green: x: 0.298 y: 0.600
    blue: x: 0.149 y: 0.059 white: x: 0.314 y: 0.329
    size: 293x165mm (11.54x6.5") diag: 336mm (13.2") ratio: 16:9
    modes: 1920x1080
  EDID-Warnings: 1: parse_edid: unknown flag 2
    device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
    inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.1.6-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 620 (KBL
    GT2) device-ID: 8086:5917 memory: 3.67 GiB unified: yes
  API: Vulkan v: 1.3.279 layers: N/A device: 0 type: integrated-gpu
    name: Intel UHD Graphics 620 (KBL GT2) driver: mesa intel v: 24.1.6-arch1.1
    device-ID: 8086:5917 surfaces: xcb,xlib
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard
    driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_soc_avs
    bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
  API: ALSA v: k6.6.46-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.2 status: n/a (root, process) with:
  Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:24fd class-ID: 0280
  Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:4 chip-ID: 8087:0a2b
    class-ID: e001
  Local Storage: total: 238.47 GiB used: 15.36 GiB (6.4%)
    model: MZVLW256HEHP-000H1 size: 238.47 GiB block-size: physical: 512 B
    fw-rev: CXB73H1Q temp: 35.9 C scheme: GPT
  ID-1: / raw-size: 238.17 GiB size: 238.17 GiB (100.00%)
    used: 15.36 GiB (6.4%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
    maj-min: 259:2 label: N/A uuid: 6b653fb7-09dc-4411-9eb2-e9e3637c4464
    used: 584 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:1 label: N/A uuid: 7DB0-B14B
  ID-3: /home raw-size: 238.17 GiB size: 238.17 GiB (100.00%)
  ID-4: /var/cache raw-size: 238.17 GiB size: 238.17 GiB (100.00%)
  ID-5: /var/log raw-size: 238.17 GiB size: 238.17 GiB (100.00%)
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-1:2 info: HP HP Wireless Mouse 220 type: mouse
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 03f0:2141 class-ID: 0301
  Device-2: 1-5:3 info: Cheng Uei Precision Industry (Foxlink) HP Wide
    Vision FHD Camera type: video driver: uvcvideo interfaces: 4 rev: 2.0
  Device-3: 1-7:4 info: Intel Bluetooth wireless interface type: bluetooth
    mode: 1.1 power: 100mA chip-ID: 8087:0a2b class-ID: e001
  Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.0
  System Temperatures: cpu: 45.0 C pch: 42.5 C mobo: N/A
  Fan Speeds (rpm): cpu: 0 mobo: 11008
  Packages: pm: pacman pkgs: 1128 libs: 337 tools: pamac
    1: http://ftp.dei.uc.pt/pub/linux/manjaro/stable/$repo/$arch
    2: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    3: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    4: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    5: https://mirror.funami.tech/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 269
  1: cpu: 11.6% command: firefox pid: 317087 mem: 777.7 MiB (10.1%)
  2: cpu: 10.8% command: firefox pid: 380311 mem: 254.1 MiB (3.3%)
  3: cpu: 3.4% command: firefox pid: 380192 mem: 393.8 MiB (5.1%)
  4: cpu: 3.3% command: firefox pid: 337547 mem: 135.3 MiB (1.7%)
  5: cpu: 3.0% command: firefox pid: 347723 mem: 284.5 MiB (3.6%)
  Memory top: 5 of 269
  1: mem: 777.7 MiB (10.1%) command: firefox pid: 317087 cpu: 11.6%
  2: mem: 415.9 MiB (5.4%) command: plasmashell pid: 2718 cpu: 0.9%
  3: mem: 393.8 MiB (5.1%) command: firefox pid: 380192 cpu: 3.4%
  4: mem: 334.8 MiB (4.3%) command: firefox pid: 317215 cpu: 0.4%
  5: mem: 319.4 MiB (4.1%) command: baloo_file pid: 2648 cpu: 0.0%
Weather:
  Report: temperature: 34.42 C (94 F) conditions: broken clouds wind: from NW
    at 4.1 m/s (15 km/h, 9 mph) cloud cover: 75% humidity: 38%
    pressure: 1009 mb (34 in)
  Locale: <filter> current time: Thu Aug 29 17:48:45 2024 (Africa/Cairo)
    observation time: Thu Aug 29 17:45:58 2024 sunrise: 06:30:41
    sunset: 19:21:41 Source: OpenWeatherMap.org
  Processes: 269 Power: uptime: 1d 20h 16m states: freeze,mem,disk
    suspend: deep avail: s2idle wakeups: 0 hibernate: platform avail: shutdown,
    reboot, suspend, test_resume image: 2.99 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Compilers: N/A Shell: Sudo (sudo) v: 1.9.15p5 default: Bash v: 5.2.32
    running-in: konsole inxi: 3.3.35
That is the default setting , as far as i know.
If you can turn that on - you must have turned it off before.
The reason for the disconnect might be hinted at in the system logs,
but it may just be some microwave oven or someone trying to learn how to annoy/hack people by sending such packets via WLAN
or just a bad connection due to too great a distance
the reason could be almost anything
As @Nachlese says, there may be many causes. One common cause I’ve seen is MAC Randomization. Run inxi -n to see the MAC of your card. Boot again, run inxi again and if MAC Adress has changed MAC Randomization is on and you can disable writing a single conf file:
https://wiki.archlinux.org/title/NetworkManager#Configuring_MAC_address_randomization
I didn’t play with it.
I am sure none of those! 4 meters to the Router and 2 meters to the repeater.
I will try this.
I will report back.
UPDATE.
I did inxi -n and rebooted. I got same MAC address.
This is not a big issue, I am just seeking to make my system as perfect as possible.
Any suggestions?
Awhile back my ISP Xfinity was having problems and even wired would disconnect.
Turn on automatic reconnection
or
investigate, don’t find anything conclusive,
and
turn on automatic reconnection :sunglasses:
or don’t - and reconnect by hand whenever it might happen again
Not for your lo connection (which is the one you have selected in your screenshot). The lo connection is your loopback network device:
