Wifi delay to connect on boot or after suspend (possible bug ?)
Hi !
I switched to manjaro for a few monthesnow: I face a little but annoying issue: wifi is kind of delayed to connect on boot or resume from suspend.
it’s not critical,but all other distro I have tried have quite instant connect so that I do not have to wait for it.
Let’s take resume as example: when pressing power button: it takes roughtly 13-14 sec to try reconnect (wifi icon with “…” in gnome) and then it’s connected at 17sec (wifi icon show as connected): so connection itself is pretty fast, like 3-4sec but I don’t understand why it waits so long before trying.
This is annoying because it’s long enought to let me enter my password, launch any google search I wish and…face a “network missing” error in firefox.
I was used to have wifi connected even before I unlock.
This is not a key issue: delay is same if I just wait on the unlock prompt. and also I save the wifi key as available for all users in wifi settings.
If it helps, here is the output of journalctl starting from when I press power button, til wifi is connected.
You may notice there’s a step from 11:50:00 to 11:50:06 and from 11:50:06 to 14.
>>> journalctl --since "2020-11-15 11:49:58" --until "2020-11-15 11:50:20"
-- Logs begin at Fri 2020-11-13 21:39:31 CET, end at Sun 2020-11-15 11:51:01 CET. --
nov. 15 11:49:58 celestin kernel: Freezing user space processes ... (elapsed 0.002 seconds) done.
nov. 15 11:49:58 celestin kernel: OOM killer disabled.
nov. 15 11:49:58 celestin kernel: Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
nov. 15 11:49:58 celestin kernel: printk: Suspending console(s) (use no_console_suspend to debug)
nov. 15 11:49:58 celestin kernel: queueing ieee80211 work while going to suspend
nov. 15 11:49:58 celestin kernel: ACPI: EC: interrupt blocked
nov. 15 11:49:58 celestin kernel: ACPI: EC: interrupt unblocked
nov. 15 11:49:58 celestin kernel: OOM killer enabled.
nov. 15 11:49:58 celestin kernel: Restarting tasks ... done.
nov. 15 11:49:58 celestin systemd-sleep[3848]: System resumed.
nov. 15 11:49:58 celestin kernel: PM: suspend exit
nov. 15 11:49:58 celestin systemd[1]: systemd-suspend.service: Succeeded.
nov. 15 11:49:58 celestin systemd[1]: Finished Suspend.
nov. 15 11:49:58 celestin audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=?>
nov. 15 11:49:58 celestin audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? >
nov. 15 11:49:58 celestin systemd[1]: Stopped target Sleep.
nov. 15 11:49:58 celestin systemd[1]: Reached target Suspend.
nov. 15 11:49:58 celestin systemd[1]: Stopped target Suspend.
nov. 15 11:49:58 celestin systemd-logind[424]: Operation 'sleep' finished.
nov. 15 11:49:58 celestin kernel: audit: type=1130 audit(1605437398.786:148): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" >
nov. 15 11:49:58 celestin kernel: audit: type=1131 audit(1605437398.786:149): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" >
nov. 15 11:49:58 celestin kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
nov. 15 11:50:00 celestin NetworkManager[418]: <info>  [1605437400.4861] manager: sleep: wake requested (sleeping: yes  enabled: yes)
nov. 15 11:50:00 celestin NetworkManager[418]: <info>  [1605437400.4864] device (wlp2s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'managed')
nov. 15 11:50:00 celestin NetworkManager[418]: <info>  [1605437400.4910] device (p2p-dev-wlp2s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'managed')
nov. 15 11:50:00 celestin NetworkManager[418]: <info>  [1605437400.4927] manager: NetworkManager state is now DISCONNECTED
nov. 15 11:50:00 celestin wpa_supplicant[975]: nl80211: deinit ifname=p2p-dev-wlp2s0 disabled_11b_rates=0
nov. 15 11:50:00 celestin wpa_supplicant[975]: nl80211: deinit ifname=wlp2s0 disabled_11b_rates=0
nov. 15 11:50:00 celestin NetworkManager[418]: <info>  [1605437400.8358] device (wlp2s0): supplicant interface state: internal-starting -> disconnected
nov. 15 11:50:00 celestin NetworkManager[418]: <info>  [1605437400.8360] device (p2p-dev-wlp2s0): state change: unavailable -> unmanaged (reason 'removed', sys-iface-state: 'removed')
nov. 15 11:50:00 celestin NetworkManager[418]: <info>  [1605437400.8377] Wi-Fi P2P device controlled by interface wlp2s0 created
nov. 15 11:50:00 celestin NetworkManager[418]: <info>  [1605437400.8386] manager: (p2p-dev-wlp2s0): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/5)
nov. 15 11:50:00 celestin NetworkManager[418]: <info>  [1605437400.8398] device (p2p-dev-wlp2s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
nov. 15 11:50:00 celestin NetworkManager[418]: <info>  [1605437400.8419] device (wlp2s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
nov. 15 11:50:00 celestin NetworkManager[418]: <info>  [1605437400.8437] device (p2p-dev-wlp2s0): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
nov. 15 11:50:00 celestin gnome-shell[1435]: Removing a network device that was not added
nov. 15 11:50:00 celestin NetworkManager[418]: <warn>  [1605437400.8727] sup-iface[65f72ad4f7e1fb61,2,wlp2s0]: call-p2p-cancel: failed with P2P cancel failed
nov. 15 11:50:06 celestin systemd[1]: NetworkManager-dispatcher.service: Succeeded.
nov. 15 11:50:06 celestin audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? t>
nov. 15 11:50:06 celestin kernel: audit: type=1131 audit(1605437406.246:150): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd>
nov. 15 11:50:14 celestin NetworkManager[418]: <info>  [1605437414.5372] policy: auto-activating connection 'Freebox-5B6587' (ad7fb5ca-6192-4d98-a5f5-435b47bc0297)
nov. 15 11:50:14 celestin NetworkManager[418]: <info>  [1605437414.5388] device (wlp2s0): Activation: starting connection 'Freebox-5B6587' (ad7fb5ca-6192-4d98-a5f5-435b47bc0297)
nov. 15 11:50:14 celestin NetworkManager[418]: <info>  [1605437414.5392] device (wlp2s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
nov. 15 11:50:14 celestin NetworkManager[418]: <info>  [1605437414.5402] manager: NetworkManager state is now CONNECTING
nov. 15 11:50:14 celestin NetworkManager[418]: <info>  [1605437414.5412] device (wlp2s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
nov. 15 11:50:14 celestin NetworkManager[418]: <info>  [1605437414.5423] device (wlp2s0): Activation: (wifi) access point 'Freebox-5B6587' has security, but secrets are required.
nov. 15 11:50:14 celestin NetworkManager[418]: <info>  [1605437414.5424] device (wlp2s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
nov. 15 11:50:14 celestin NetworkManager[418]: <info>  [1605437414.5511] device (wlp2s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
nov. 15 11:50:14 celestin NetworkManager[418]: <info>  [1605437414.5527] device (wlp2s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
nov. 15 11:50:14 celestin NetworkManager[418]: <info>  [1605437414.5539] device (wlp2s0): Activation: (wifi) connection 'Freebox-5B6587' has security, and secrets exist.  No new secrets needed.
nov. 15 11:50:14 celestin NetworkManager[418]: <info>  [1605437414.5540] Config: added 'ssid' value 'Freebox-5B6587'
nov. 15 11:50:14 celestin NetworkManager[418]: <info>  [1605437414.5541] Config: added 'scan_ssid' value '1'
nov. 15 11:50:14 celestin NetworkManager[418]: <info>  [1605437414.5541] Config: added 'bgscan' value 'simple:30:-70:86400'
nov. 15 11:50:14 celestin NetworkManager[418]: <info>  [1605437414.5542] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK'
nov. 15 11:50:14 celestin NetworkManager[418]: <info>  [1605437414.5542] Config: added 'auth_alg' value 'OPEN'
nov. 15 11:50:14 celestin NetworkManager[418]: <info>  [1605437414.5543] Config: added 'psk' value '<hidden>'
nov. 15 11:50:14 celestin wpa_supplicant[975]: wlp2s0: SME: Trying to authenticate with 13:6e:25:86:7f:42 (SSID='Freebox-5B6587' freq=5180 MHz)
nov. 15 11:50:14 celestin kernel: wlp2s0: authenticate with 13:6e:25:86:7f:42
nov. 15 11:50:14 celestin NetworkManager[418]: <info>  [1605437414.6482] device (wlp2s0): supplicant interface state: disconnected -> authenticating
nov. 15 11:50:14 celestin NetworkManager[418]: <info>  [1605437414.6483] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> authenticating
nov. 15 11:50:14 celestin kernel: wlp2s0: send auth to 13:6e:25:86:7f:42 (try 1/3)
nov. 15 11:50:14 celestin wpa_supplicant[975]: wlp2s0: Trying to associate with 13:6e:25:86:7f:42 (SSID='Freebox-5B6587' freq=5180 MHz)
nov. 15 11:50:14 celestin kernel: wlp2s0: authenticated
nov. 15 11:50:14 celestin kernel: wlp2s0: associate with 13:6e:25:86:7f:42 (try 1/3)
nov. 15 11:50:14 celestin NetworkManager[418]: <info>  [1605437414.6526] device (wlp2s0): supplicant interface state: authenticating -> associating
nov. 15 11:50:14 celestin NetworkManager[418]: <info>  [1605437414.6527] device (p2p-dev-wlp2s0): supplicant management interface state: authenticating -> associating
nov. 15 11:50:14 celestin kernel: wlp2s0: RX AssocResp from 13:6e:25:86:7f:42 (capab=0x11 status=0 aid=1)
nov. 15 11:50:14 celestin kernel: wlp2s0: associated
nov. 15 11:50:14 celestin kernel: ath: EEPROM regdomain: 0x80fa
nov. 15 11:50:14 celestin kernel: ath: EEPROM indicates we should expect a country code
nov. 15 11:50:14 celestin kernel: ath: doing EEPROM country->regdmn map search
nov. 15 11:50:14 celestin kernel: ath: country maps to regdmn code: 0x37
nov. 15 11:50:14 celestin kernel: ath: Country alpha2 being used: FR
nov. 15 11:50:14 celestin kernel: ath: Regpair used: 0x37
nov. 15 11:50:14 celestin kernel: ath: regdomain 0x80fa dynamically updated by country element
nov. 15 11:50:14 celestin wpa_supplicant[975]: wlp2s0: Associated with 13:6e:25:86:7f:42
nov. 15 11:50:14 celestin wpa_supplicant[975]: wlp2s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
nov. 15 11:50:14 celestin wpa_supplicant[975]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=FR
nov. 15 11:50:14 celestin NetworkManager[418]: <info>  [1605437414.6669] device (wlp2s0): supplicant interface state: associating -> 4way_handshake
nov. 15 11:50:14 celestin NetworkManager[418]: <info>  [1605437414.6670] device (p2p-dev-wlp2s0): supplicant management interface state: associating -> 4way_handshake
nov. 15 11:50:14 celestin wpa_supplicant[975]: wlp2s0: WPA: Key negotiation completed with 13:6e:25:86:7f:42 [PTK=CCMP GTK=CCMP]
nov. 15 11:50:14 celestin wpa_supplicant[975]: wlp2s0: CTRL-EVENT-CONNECTED - Connection to 13:6e:25:86:7f:42 completed [id=0 id_str=]
nov. 15 11:50:14 celestin kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlp2s0: link becomes ready
nov. 15 11:50:14 celestin NetworkManager[418]: <info>  [1605437414.6763] device (wlp2s0): supplicant interface state: 4way_handshake -> completed
nov. 15 11:50:14 celestin NetworkManager[418]: <info>  [1605437414.6764] device (wlp2s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "Freebox-5B6587"
it’s not link to audit lines.
I changed kernel boot line at start by adding “audit=0”. Behavior at resume is same, without the 2 audit lines between 11:50:06 & 11:50:14
I tried to disable network dispatcher service: no change.
Here is a log of mint live cd after resume from suspend, it needs only 3-4 to wake up and get connected.
I only put the 3 lines where I loose so many seconds in Manjaro:
I pressed power button at 16:28:00
Nov 15 16:28:00 mint wpa_supplicant[1331]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
Nov 15 16:28:01 mint ModemManager[1506]: <info>  Couldn't check support for device '/sys/devices/pci0000:00/0000:00:1c.2/0000:02:00.0': not supported by any plugin
Nov 15 16:28:03 mint NetworkManager[1300]: <info>  [1605457683.6806] policy: auto-activating connection 'Auto Freebox-5B6587' (c11db935-d20c-40b9-b9e8-eb69fb155ae2)
Hi,
I would like to add
This extra delay is visible with both Manjaro fresh install & Manjaro live session (USB), both needs roughly 17sec from pression power button (to resume from suspend) to wifi connected.
As a comparison, both Mint & Solus live session (USB) needs 3-4sec to do same (also using Network Manager & wpa_supplicant).
I also change network manager logging level to “debug” instead of default “info”. here is the log (much longer), I pressed power button (to wake from suspend) at 9:19:00
There are a few more time steps than before (maybe due to debug logging?)
from 09:19:03 to 09:19:06
from 09:19:07 to 09:19:11
from 09:19:11 to 09:19:15
-- Logs begin at Fri 2020-11-13 21:39:31 CET, end at Mon 2020-11-16 09:20:23 CET. --
nov. 16 09:19:01 celestin kernel: Freezing user space processes ... (elapsed 0.003 seconds) done.
nov. 16 09:19:01 celestin kernel: OOM killer disabled.
nov. 16 09:19:01 celestin kernel: Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
nov. 16 09:19:01 celestin kernel: printk: Suspending console(s) (use no_console_suspend to debug)
nov. 16 09:19:01 celestin kernel: psmouse serio1: Failed to disable mouse on isa0060/serio1
nov. 16 09:19:01 celestin kernel: ACPI: EC: interrupt blocked
nov. 16 09:19:01 celestin kernel: ACPI: EC: interrupt unblocked
nov. 16 09:19:01 celestin kernel: OOM killer enabled.
nov. 16 09:19:01 celestin kernel: Restarting tasks ... done.
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.4555] connectivity: (wlp2s0,IPv4,21) skip connectivity check due to no carrier
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.4556] connectivity: (wlp2s0,IPv6,22) skip connectivity check due to no carrier
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.4566] connectivity: (wlp2s0,IPv4,23) skip connectivity check due to no carrier
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.4567] connectivity: (wlp2s0,IPv6,24) skip connectivity check due to no carrier
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.4568] connectivity: (wlp2s0,IPv4,21) check completed: NONE; no carrier
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.4568] connectivity: (wlp2s0,IPv6,22) check completed: NONE; no carrier
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.4569] connectivity: (wlp2s0,IPv4,23) check completed: NONE; no carrier
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.4569] connectivity: (wlp2s0,IPv6,24) check completed: NONE; no carrier
nov. 16 09:19:01 celestin kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
nov. 16 09:19:01 celestin systemd-sleep[2266]: System resumed.
nov. 16 09:19:01 celestin kernel: PM: suspend exit
nov. 16 09:19:01 celestin systemd[1]: systemd-suspend.service: Succeeded.
nov. 16 09:19:01 celestin systemd[1]: Finished Suspend.
nov. 16 09:19:01 celestin systemd[1]: Stopped target Sleep.
nov. 16 09:19:01 celestin systemd[1]: Reached target Suspend.
nov. 16 09:19:01 celestin systemd[1]: Stopped target Suspend.
nov. 16 09:19:01 celestin systemd-logind[474]: Operation 'sleep' finished.
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.8730] sleep-monitor-sd: received RESUME signal
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.8731] sleep-monitor-sd: inhibit: taking sleep inhibitor...
nov. 16 09:19:01 celestin NetworkManager[471]: <info>  [1605514741.8734] manager: sleep: wake requested (sleeping: yes  enabled: yes)
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.8735] manager: sleep: waking up...
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.8737] manager: rfkill: Wi-Fi hw-enabled 1 sw-enabled 1
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.8737] manager: rfkill: WWAN hw-enabled 1 sw-enabled 1
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.8738] manager: rfkill: enabling Wi-Fi devices (hw_enabled 1, sw_enabled 1, user_enabled 1)
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.8738] manager: rfkill: enabling WWAN devices (hw_enabled 1, sw_enabled 1, user_enabled 1)
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.8739] device[d18b1e3770f3c0b2] (wlp2s0): unmanaged: flags set to [!sleeping,!by-type,!platform-init,!user-explicit,!user-settings=0x0/0x79/managed], set-managed [sleeping=0x1], reason managed, transition-state)
nov. 16 09:19:01 celestin NetworkManager[471]: <info>  [1605514741.8740] device (wlp2s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'managed')
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.8740] device[d18b1e3770f3c0b2] (wlp2s0): add_pending_action (1): 'in-state-change'
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.8742] platform-linux: sysctl: reading '/proc/sys/net/ipv6/conf/wlp2s0/accept_ra': '1'
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.8743] platform-linux: sysctl: reading '/proc/sys/net/ipv6/conf/wlp2s0/forwarding': '0'
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.8744] platform-linux: sysctl: reading '/proc/sys/net/ipv6/conf/wlp2s0/hop_limit': '64'
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.8745] platform-linux: sysctl: reading '/proc/sys/net/ipv6/conf/wlp2s0/use_tempaddr': '0'
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.8746] device[d18b1e3770f3c0b2] (wlp2s0): will enable userland IPv6LL
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.8746] platform-linux: link: change 2: user-ipv6ll: set IPv6 address generation mode to none
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.8748] platform-linux: do-request-link: 2
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.8749] platform: (wlp2s0) signal: link changed: 2: wlp2s0 <UP;broadcast,multicast,up> mtu 1500 arp 1 wifi? init addrgenmode none addr 9C:B6:D0:8B:33:C5 brd FF:FF:FF:FF:FF:FF driver ath10k_pci rx:529,207236 tx:98,13646
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.8750] device[d18b1e3770f3c0b2] (wlp2s0): queued link change for ifindex 2
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.8751] platform-linux: do-change-link[2]: success changing link: success
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.8753] platform-linux: sysctl: setting '/proc/sys/net/ipv6/conf/wlp2s0/disable_ipv6' to '1' (current value is '0')
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.8755] platform-linux: sysctl: setting '/proc/sys/net/ipv6/conf/wlp2s0/disable_ipv6' to '0' (current value is '1')
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.8756] platform-linux: sysctl: setting '/proc/sys/net/ipv6/conf/wlp2s0/accept_ra' to '0' (current value is '1')
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.8757] platform-linux: sysctl: setting '/proc/sys/net/ipv6/conf/wlp2s0/use_tempaddr' to '0' (current value is identical)
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.8759] platform-linux: sysctl: setting '/proc/sys/net/ipv6/conf/wlp2s0/forwarding' to '0' (current value is identical)
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.8759] device[d18b1e3770f3c0b2] (wlp2s0): bringing up device 2
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.8760] platform: (wlp2s0) link: setting up
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.8760] platform-linux: link: change 2: flags: set 0x1/0x1 ([up] / [up])
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.8761] platform-linux: do-request-link: 2
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.8762] platform-linux: do-change-link[2]: success changing link: success
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.8763] device[d18b1e3770f3c0b2] (wlp2s0): preparing device
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.8764] platform-linux: sysctl: setting '/proc/sys/net/ipv6/conf/wlp2s0/use_tempaddr' to '0' (current value is identical)
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.8766] rules-manager: sync
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.8766] device[d18b1e3770f3c0b2] (wlp2s0): ip4-config: update (commit=1, new-config=(nil))
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.8767] device[d18b1e3770f3c0b2] (wlp2s0): ip4-config: clear IP Config instance (/org/freedesktop/NetworkManager/IP4Config/3)
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.8770] dns-mgr: (device_ip_config_changed): queueing DNS updates (1)
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.8771] dns-mgr: (device_ip_config_changed): DNS configuration did not change
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.8771] dns-mgr: (device_ip_config_changed): no DNS changes to commit (0)
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.8774] device[d18b1e3770f3c0b2] (wlp2s0): ip6-config: update (commit=1, new-config=(nil))
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.8774] device[d18b1e3770f3c0b2] (wlp2s0): ip6-config: clear IP Config instance (/org/freedesktop/NetworkManager/IP6Config/3)
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.8777] dns-mgr: (device_ip_config_changed): queueing DNS updates (1)
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.8778] dns-mgr: (device_ip_config_changed): DNS configuration did not change
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.8778] dns-mgr: (device_ip_config_changed): no DNS changes to commit (0)
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.8789] device[610956ce60b342a3] (p2p-dev-wlp2s0): add_pending_action (2): 'recheck-available'
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.8791] device[d18b1e3770f3c0b2] (wlp2s0): add_pending_action (2): 'waiting-for-supplicant'
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.8792] device[d18b1e3770f3c0b2] (wlp2s0): device not yet available for transition to DISCONNECTED
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.8801] device[d18b1e3770f3c0b2] (wlp2s0): remove_pending_action (1): 'in-state-change'
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.8803] manager: rfkill: enabling Wi-Fi devices (hw_enabled 1, sw_enabled 1, user_enabled 1)
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.8804] manager: rfkill: enabling WWAN devices (hw_enabled 1, sw_enabled 1, user_enabled 1)
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.8804] device[610956ce60b342a3] (p2p-dev-wlp2s0): unmanaged: flags set to [user-settings,!sleeping,!by-type,!platform-init=0x40/0x59/unmanaged], set-managed [sleeping=0x1], reason managed)
nov. 16 09:19:01 celestin NetworkManager[471]: <info>  [1605514741.8804] manager: NetworkManager state is now DISCONNECTED
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.8810] sleep-monitor-sd: inhibit: inhibitor fd is 19
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.8811] device[610956ce60b342a3] (p2p-dev-wlp2s0): remove_pending_action (1): 'recheck-available'
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.9560] sup-iface[2c7a9b60ae3dbc9a,1,???]: new supplicant interface /fi/w1/wpa_supplicant1/Interfaces/1 on :1.16
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.9616] sup-iface[2c7a9b60ae3dbc9a,1,???]: supports 16 scan SSIDs (scan: +active +ssid)
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.9622] sup-iface[2c7a9b60ae3dbc9a,1,wlp2s0]: supplicant interface for ifindex=2, ifname="wlp2s0", driver="nl80211" (requested nl80211,wext)
nov. 16 09:19:01 celestin NetworkManager[471]: <info>  [1605514741.9624] device (wlp2s0): supplicant interface state: internal-starting -> disconnected
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.9625] device[d18b1e3770f3c0b2] (wlp2s0): supplicant ready
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.9625] device[d18b1e3770f3c0b2] (wlp2s0): add_pending_action (2): 'recheck-available'
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.9625] manager: (p2p-dev-wlp2s0): removing device (managed 0, wol 0)
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.9626] device[610956ce60b342a3] (p2p-dev-wlp2s0): ip4-config: update (commit=0, new-config=(nil))
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.9626] device[610956ce60b342a3] (p2p-dev-wlp2s0): ip6-config: update (commit=0, new-config=(nil))
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.9634] device[610956ce60b342a3] (p2p-dev-wlp2s0): disposing
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.9634] device[610956ce60b342a3] (p2p-dev-wlp2s0): ip4-config: update (commit=1, new-config=(nil))
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.9635] device[610956ce60b342a3] (p2p-dev-wlp2s0): ip6-config: update (commit=1, new-config=(nil))
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.9635] device[610956ce60b342a3] (p2p-dev-wlp2s0): finalize(): NMDeviceWifiP2P
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.9635] device[d18b1e3770f3c0b2] (wlp2s0): remove_pending_action (1): 'waiting-for-supplicant'
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.9636] device[9f7353d9c9c10e7c] (p2p-dev-wlp2s0): constructed (NMDeviceWifiP2P)
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.9637] device[9f7353d9c9c10e7c] (p2p-dev-wlp2s0): add_pending_action (1): 'waiting-for-supplicant'
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.9637] device[9f7353d9c9c10e7c] (p2p-dev-wlp2s0): P2P: WPA supplicant management interface changed to /fi/w1/wpa_supplicant1/Interfaces/1.
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.9637] device[9f7353d9c9c10e7c] (p2p-dev-wlp2s0): add_pending_action (2): 'recheck-available'
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.9638] device[9f7353d9c9c10e7c] (p2p-dev-wlp2s0): remove_pending_action (1): 'waiting-for-supplicant'
nov. 16 09:19:01 celestin NetworkManager[471]: <info>  [1605514741.9638] Wi-Fi P2P device controlled by interface wlp2s0 created
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.9638] device[9f7353d9c9c10e7c] (p2p-dev-wlp2s0): start setup of NMDeviceWifiP2P, kernel ifindex 0
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.9639] device[9f7353d9c9c10e7c] (p2p-dev-wlp2s0): unmanaged: flags set to [platform-init,!by-type=0x10/0x18/unmanaged/unrealized], set-managed [by-type=0x8])
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.9639] device[9f7353d9c9c10e7c] (p2p-dev-wlp2s0): unmanaged: flags set to [platform-init,user-settings,!by-type=0x50/0x58/unmanaged/unrealized], set-unmanaged [user-settings=0x40])
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.9640] device[9f7353d9c9c10e7c] (p2p-dev-wlp2s0): unmanaged: flags set to [user-settings,!by-type,!platform-init=0x40/0x58/unmanaged/unrealized], set-managed [platform-init=0x10])
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.9641] manager: rfkill: Wi-Fi hw-enabled 1 sw-enabled 1
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.9641] device[9f7353d9c9c10e7c] (p2p-dev-wlp2s0): unmanaged: flags set to [user-settings,!sleeping,!by-type,!platform-init=0x40/0x59/unmanaged/unrealized], set-managed [sleeping=0x1])
nov. 16 09:19:01 celestin NetworkManager[471]: <info>  [1605514741.9647] manager: (p2p-dev-wlp2s0): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/4)
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.9654] device[d18b1e3770f3c0b2] (wlp2s0): add_pending_action (2): 'queued-state-change-disconnected'
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.9654] device[d18b1e3770f3c0b2] (wlp2s0): queue-state[disconnected, reason:supplicant-available, id:691]: queue state change
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.9655] device[d18b1e3770f3c0b2] (wlp2s0): is available, will transition to disconnected
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.9655] device[d18b1e3770f3c0b2] (wlp2s0): remove_pending_action (1): 'recheck-available'
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.9655] device[9f7353d9c9c10e7c] (p2p-dev-wlp2s0): remove_pending_action (0): 'recheck-available'
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.9656] device[d18b1e3770f3c0b2] (wlp2s0): queue-state[disconnected, reason:supplicant-available, id:691]: change state
nov. 16 09:19:01 celestin NetworkManager[471]: <info>  [1605514741.9656] device (wlp2s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.9656] device[d18b1e3770f3c0b2] (wlp2s0): add_pending_action (2): 'in-state-change'
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.9657] device[d18b1e3770f3c0b2] (wlp2s0): will enable userland IPv6LL
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.9657] platform-linux: link: change 2: user-ipv6ll: set IPv6 address generation mode to none
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.9658] platform-linux: do-request-link: 2
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.9659] platform-linux: do-change-link[2]: success changing link: success
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.9661] platform-linux: sysctl: setting '/proc/sys/net/ipv6/conf/wlp2s0/disable_ipv6' to '1' (current value is '0')
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.9662] platform-linux: sysctl: setting '/proc/sys/net/ipv6/conf/wlp2s0/disable_ipv6' to '0' (current value is '1')
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.9663] platform-linux: sysctl: setting '/proc/sys/net/ipv6/conf/wlp2s0/accept_ra' to '0' (current value is identical)
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.9664] platform-linux: sysctl: setting '/proc/sys/net/ipv6/conf/wlp2s0/use_tempaddr' to '0' (current value is identical)
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.9664] platform-linux: sysctl: setting '/proc/sys/net/ipv6/conf/wlp2s0/forwarding' to '0' (current value is identical)
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.9675] device[d18b1e3770f3c0b2] (wlp2s0): wifi-scan: start periodic scan (0 SSIDs to probe scan)
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.9677] device[d18b1e3770f3c0b2] (wlp2s0): wifi-scan: scanning-state: scanning
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.9677] device[d18b1e3770f3c0b2] (wlp2s0): add_pending_action (3): 'wifi-scan'
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.9678] connectivity: (wlp2s0,IPv4,25) skip connectivity check due to no carrier
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.9678] connectivity: (wlp2s0,IPv6,26) skip connectivity check due to no carrier
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.9679] device[d18b1e3770f3c0b2] (wlp2s0): remove_pending_action (2): 'in-state-change'
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.9679] device[d18b1e3770f3c0b2] (wlp2s0): remove_pending_action (1): 'queued-state-change-disconnected'
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.9679] connectivity: (wlp2s0,IPv4,25) check completed: NONE; no carrier
nov. 16 09:19:01 celestin NetworkManager[471]: <debug> [1605514741.9680] connectivity: (wlp2s0,IPv6,26) check completed: NONE; no carrier
nov. 16 09:19:01 celestin gnome-shell[1565]: Removing a network device that was not added
nov. 16 09:19:02 celestin wpa_supplicant[1022]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
nov. 16 09:19:02 celestin systemd[1451]: app-gnome-org.gnome.DejaDup.Monitor-1961.scope: Succeeded.
nov. 16 09:19:03 celestin wpa_supplicant[1022]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
nov. 16 09:19:03 celestin NetworkManager[471]: <debug> [1605514743.9692] connectivity: (wlp2s0,IPv4,27) skip connectivity check due to no carrier
nov. 16 09:19:03 celestin NetworkManager[471]: <debug> [1605514743.9693] connectivity: (wlp2s0,IPv6,28) skip connectivity check due to no carrier
nov. 16 09:19:03 celestin NetworkManager[471]: <debug> [1605514743.9694] connectivity: (wlp2s0,IPv4,27) check completed: NONE; no carrier
nov. 16 09:19:03 celestin NetworkManager[471]: <debug> [1605514743.9694] connectivity: (wlp2s0,IPv6,28) check completed: NONE; no carrier
nov. 16 09:19:06 celestin NetworkManager[471]: <debug> [1605514746.8437] device[d18b1e3770f3c0b2] (wlp2s0): wifi-scan: scanning-state: idle (notify last-scan)
nov. 16 09:19:06 celestin NetworkManager[471]: <debug> [1605514746.8439] device[d18b1e3770f3c0b2] (wlp2s0): wifi-scan: start periodic scan (0 SSIDs to probe scan)
nov. 16 09:19:06 celestin NetworkManager[471]: <debug> [1605514746.8440] device[d18b1e3770f3c0b2] (wlp2s0): wifi-scan: scanning-state: scanning
nov. 16 09:19:07 celestin systemd[1]: NetworkManager-dispatcher.service: Succeeded.
nov. 16 09:19:07 celestin NetworkManager[471]: <debug> [1605514747.9683] connectivity: (wlp2s0,IPv4,29) skip connectivity check due to no carrier
nov. 16 09:19:07 celestin NetworkManager[471]: <debug> [1605514747.9685] connectivity: (wlp2s0,IPv6,30) skip connectivity check due to no carrier
nov. 16 09:19:07 celestin NetworkManager[471]: <debug> [1605514747.9686] connectivity: (wlp2s0,IPv4,29) check completed: NONE; no carrier
nov. 16 09:19:07 celestin NetworkManager[471]: <debug> [1605514747.9686] connectivity: (wlp2s0,IPv6,30) check completed: NONE; no carrier
nov. 16 09:19:11 celestin NetworkManager[471]: <debug> [1605514751.6945] device[d18b1e3770f3c0b2] (wlp2s0): wifi-scan: scanning-state: idle (notify last-scan)
nov. 16 09:19:11 celestin NetworkManager[471]: <debug> [1605514751.6947] device[d18b1e3770f3c0b2] (wlp2s0): wifi-scan: start periodic scan (0 SSIDs to probe scan)
nov. 16 09:19:11 celestin NetworkManager[471]: <debug> [1605514751.6950] device[d18b1e3770f3c0b2] (wlp2s0): wifi-scan: scanning-state: scanning
nov. 16 09:19:13 celestin systemd[1]: fprintd.service: Succeeded.
nov. 16 09:19:15 celestin NetworkManager[471]: <debug> [1605514755.9727] connectivity: (wlp2s0,IPv4,31) skip connectivity check due to no carrier
nov. 16 09:19:15 celestin NetworkManager[471]: <debug> [1605514755.9728] connectivity: (wlp2s0,IPv6,32) skip connectivity check due to no carrier
nov. 16 09:19:15 celestin NetworkManager[471]: <debug> [1605514755.9729] connectivity: (wlp2s0,IPv4,31) check completed: NONE; no carrier
nov. 16 09:19:15 celestin NetworkManager[471]: <debug> [1605514755.9730] connectivity: (wlp2s0,IPv6,32) check completed: NONE; no carrier
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.5477] device[d18b1e3770f3c0b2] (wlp2s0): wifi-scan: scanning-state: idle (notify last-scan)
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.5480] device[d18b1e3770f3c0b2] (wlp2s0): add_pending_action (2): 'autoactivate'
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.5481] device[d18b1e3770f3c0b2] (wlp2s0): remove_pending_action (1): 'wifi-scan'
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.5515] policy: auto-activating connection 'Freebox-5B6587' (ad7fb5ca-6192-4d98-a5f5-435b47bc0297)
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.5517] active-connection[0x5655179bf580]: set device "wlp2s0" [0x565517a4e0b0]
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.5517] device[d18b1e3770f3c0b2] (wlp2s0): add_pending_action (2): 'activation-2'
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.5522] active-connection[0x5655179bf580]: constructed (NMActRequest, version-id 2, type managed)
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.5523] device[d18b1e3770f3c0b2] (wlp2s0): remove_pending_action (1): 'autoactivate'
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.5527] device (wlp2s0): Activation: starting connection 'Freebox-5B6587' (ad7fb5ca-6192-4d98-a5f5-435b47bc0297)
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.5528] device[d18b1e3770f3c0b2] (wlp2s0): activation-stage: schedule activate_stage1_device_prepare,v4 (id 798)
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.5528] device[d18b1e3770f3c0b2] (wlp2s0): activation-stage: invoke activate_stage1_device_prepare,v4 (id 798)
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.5530] device (wlp2s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.5530] device[d18b1e3770f3c0b2] (wlp2s0): add_pending_action (2): 'in-state-change'
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.5535] active-connection[0x5655179bf580]: set state activating (was unknown)
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.5538] manager: NetworkManager state is now CONNECTING
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.5540] active-connection[0x5655179bf580]: check-master-ready: not signalling (state activating, no master)
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.5541] manager: ActivatingConnection now Freebox-5B6587
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.5542] device[d18b1e3770f3c0b2] (wlp2s0): remove_pending_action (1): 'in-state-change'
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.5545] device[d18b1e3770f3c0b2] (wlp2s0): activation-stage: synchronously invoke activate_stage2_device_config,v4
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.5545] device (wlp2s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.5546] device[d18b1e3770f3c0b2] (wlp2s0): add_pending_action (2): 'in-state-change'
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.5549] device[d18b1e3770f3c0b2] (wlp2s0): remove_pending_action (1): 'in-state-change'
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.5549] rules-manager: sync
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.5550] device[d18b1e3770f3c0b2] (wlp2s0): bringing up device 2
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.5550] platform: (wlp2s0) link: setting up
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.5550] platform-linux: link: change 2: flags: set 0x1/0x1 ([up] / [up])
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.5551] platform-linux: do-request-link: 2
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.5552] platform-linux: do-change-link[2]: success changing link: success
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.5552] device (wlp2s0): Activation: (wifi) access point 'Freebox-5B6587' has security, but secrets are required.
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.5552] device (wlp2s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.5553] device[d18b1e3770f3c0b2] (wlp2s0): add_pending_action (2): 'in-state-change'
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.5557] device[d18b1e3770f3c0b2] (wlp2s0): remove_pending_action (1): 'in-state-change'
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.5571] Secrets requested for connection /org/freedesktop/NetworkManager/Settings/1 (Freebox-5B6587/802-11-wireless-security)
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.5571] settings-connection[da3eb5df711bdab7,ad7fb5ca-6192-4d98-a5f5-435b47bc0297]: (802-11-wireless-security:0x565517a49bd0) secrets requested flags 0x1 hints '(none)'
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.5575] agent-manager: ([cc7e5e3c25732d06/"Freebox-5B6587"/"802-11-wireless-security"]) system settings secrets sufficient
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.5578] settings-connection[da3eb5df711bdab7,ad7fb5ca-6192-4d98-a5f5-435b47bc0297]: (802-11-wireless-security:0x7fecb0003de0) existing secrets returned
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.5578] settings-connection[da3eb5df711bdab7,ad7fb5ca-6192-4d98-a5f5-435b47bc0297]: (802-11-wireless-security:0x7fecb0003de0) secrets request completed
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.5582] settings-connection[da3eb5df711bdab7,ad7fb5ca-6192-4d98-a5f5-435b47bc0297]: (802-11-wireless-security:0x7fecb0003de0) new agent secrets processed
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.5594] ++ connection 'update connection' (0x565517a31740/NMSimpleConnection/"802-11-wireless" < 0x565517a317a0/NMSimpleConnection/"802-11-wireless") [/org/freedesktop/NetworkManager/Settings/1]:
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.5595] ++ 802-11-wireless-security  [ 0x5655179f6d70 < 0x5655179f6950 ]
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.5595] ++ 802-11-wireless-security.psk = ****
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.5600] device[d18b1e3770f3c0b2] (wlp2s0): activation-stage: schedule activate_stage1_device_prepare,v4 (id 802)
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.5602] device[d18b1e3770f3c0b2] (wlp2s0): activation-stage: invoke activate_stage1_device_prepare,v4 (id 802)
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.5602] device (wlp2s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.5602] device[d18b1e3770f3c0b2] (wlp2s0): add_pending_action (2): 'in-state-change'
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.5607] device[d18b1e3770f3c0b2] (wlp2s0): remove_pending_action (1): 'in-state-change'
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.5609] device[d18b1e3770f3c0b2] (wlp2s0): activation-stage: synchronously invoke activate_stage2_device_config,v4
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.5609] device (wlp2s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.5610] device[d18b1e3770f3c0b2] (wlp2s0): add_pending_action (2): 'in-state-change'
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.5613] device[d18b1e3770f3c0b2] (wlp2s0): remove_pending_action (1): 'in-state-change'
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.5613] rules-manager: sync
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.5614] device[d18b1e3770f3c0b2] (wlp2s0): bringing up device 2
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.5614] platform: (wlp2s0) link: setting up
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.5614] platform-linux: link: change 2: flags: set 0x1/0x1 ([up] / [up])
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.5615] platform-linux: do-request-link: 2
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.5616] platform-linux: do-change-link[2]: success changing link: success
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.5616] device (wlp2s0): Activation: (wifi) connection 'Freebox-5B6587' has security, and secrets exist.  No new secrets needed.
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.5616] Config: added 'ssid' value 'Freebox-5B6587'
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.5616] Config: added 'scan_ssid' value '1'
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.5617] Config: added 'bgscan' value 'simple:30:-70:86400'
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.5617] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK'
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.5617] Config: added 'psk' value '<hidden>'
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.5617] sup-iface[2c7a9b60ae3dbc9a,1,wlp2s0]: assoc[d0ef2a8db2dc707b]: starting association...
nov. 16 09:19:16 celestin wpa_supplicant[1022]: wlp2s0: SME: Trying to authenticate with 13:6e:25:86:7f:42 (SSID='Freebox-5B6587' freq=5180 MHz)
nov. 16 09:19:16 celestin kernel: wlp2s0: authenticate with 13:6e:25:86:7f:42
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.5771] sup-iface[2c7a9b60ae3dbc9a,1,wlp2s0]: assoc[d0ef2a8db2dc707b]: association request successful
nov. 16 09:19:16 celestin kernel: wlp2s0: send auth to 13:6e:25:86:7f:42 (try 1/3)
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.6279] device (wlp2s0): supplicant interface state: disconnected -> authenticating
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.6280] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> authenticating
nov. 16 09:19:16 celestin wpa_supplicant[1022]: wlp2s0: Trying to associate with 13:6e:25:86:7f:42 (SSID='Freebox-5B6587' freq=5180 MHz)
nov. 16 09:19:16 celestin kernel: wlp2s0: authenticated
nov. 16 09:19:16 celestin kernel: wlp2s0: associate with 13:6e:25:86:7f:42 (try 1/3)
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.6340] device (wlp2s0): supplicant interface state: authenticating -> associating
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.6340] device (p2p-dev-wlp2s0): supplicant management interface state: authenticating -> associating
nov. 16 09:19:16 celestin kernel: wlp2s0: RX AssocResp from 13:6e:25:86:7f:42 (capab=0x11 status=0 aid=1)
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6401] platform: (wlp2s0) signal: link changed: 2: wlp2s0 <UP,LOWER_UP;broadcast,multicast,up,lowerup> mtu 1500 arp 1 wifi? init addrgenmode none addr 9C:B6:D0:8B:33:C5 brd FF:FF:FF:FF:FF:FF driver ath10k_pci rx:529,207236 tx:98,13646
nov. 16 09:19:16 celestin kernel: wlp2s0: associated
nov. 16 09:19:16 celestin kernel: ath: EEPROM regdomain: 0x80fa
nov. 16 09:19:16 celestin kernel: ath: EEPROM indicates we should expect a country code
nov. 16 09:19:16 celestin kernel: ath: doing EEPROM country->regdmn map search
nov. 16 09:19:16 celestin kernel: ath: country maps to regdmn code: 0x37
nov. 16 09:19:16 celestin kernel: ath: Country alpha2 being used: FR
nov. 16 09:19:16 celestin kernel: ath: Regpair used: 0x37
nov. 16 09:19:16 celestin kernel: ath: regdomain 0x80fa dynamically updated by country element
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6402] device[d18b1e3770f3c0b2] (wlp2s0): queued link change for ifindex 2
nov. 16 09:19:16 celestin wpa_supplicant[1022]: wlp2s0: Associated with 13:6e:25:86:7f:42
nov. 16 09:19:16 celestin wpa_supplicant[1022]: wlp2s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
nov. 16 09:19:16 celestin wpa_supplicant[1022]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=FR
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.6469] device (wlp2s0): supplicant interface state: associating -> 4way_handshake
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.6470] device (p2p-dev-wlp2s0): supplicant management interface state: associating -> 4way_handshake
nov. 16 09:19:16 celestin wpa_supplicant[1022]: wlp2s0: WPA: Key negotiation completed with 13:6e:25:86:7f:42 [PTK=CCMP GTK=CCMP]
nov. 16 09:19:16 celestin wpa_supplicant[1022]: wlp2s0: CTRL-EVENT-CONNECTED - Connection to 13:6e:25:86:7f:42 completed [id=0 id_str=]
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6494] platform: (wlp2s0) signal: route   6   added: type unicast table 255 ff00::/8 via :: dev 2 metric 256 mss 0 rt-src rt-boot
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6495] device[d18b1e3770f3c0b2] (wlp2s0): queued IP6 config change
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6496] platform: (wlp2s0) signal: link changed: 2: wlp2s0 <UP,LOWER_UP;broadcast,multicast,up,running,lowerup> mtu 1500 arp 1 wifi? init addrgenmode none addr 9C:B6:D0:8B:33:C5 brd FF:FF:FF:FF:FF:FF driver ath10k_pci rx:531,207670 tx:100,14063
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6497] device[d18b1e3770f3c0b2] (wlp2s0): queued link change for ifindex 2
nov. 16 09:19:16 celestin kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlp2s0: link becomes ready
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6501] device[d18b1e3770f3c0b2] (wlp2s0): ip6-config: update (commit=0, new-config=0x5655179b1ac0)
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6507] device[d18b1e3770f3c0b2] (wlp2s0): ip6-config: set IP Config instance (/org/freedesktop/NetworkManager/IP6Config/4)
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6511] dns-mgr: (device_ip_config_changed): queueing DNS updates (1)
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6511] dns-mgr: (device_ip_config_changed): DNS configuration did not change
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6512] dns-mgr: (device_ip_config_changed): no DNS changes to commit (0)
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.6547] device (wlp2s0): supplicant interface state: 4way_handshake -> completed
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.6547] device (wlp2s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "Freebox-5B6587"
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6548] firewall: [779942e3256485ba,change*:"wlp2s0"]: firewall zone change wlp2s0:default (not running, simulate success)
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.6548] device (p2p-dev-wlp2s0): supplicant management interface state: 4way_handshake -> completed
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6550] firewall: [779942e3256485ba,change*:"wlp2s0"]: complete: fake success
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6550] device[d18b1e3770f3c0b2] (wlp2s0): activation-stage: schedule activate_stage3_ip_config_start,v4 (id 833)
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6550] device[d18b1e3770f3c0b2] (wlp2s0): activation-stage: invoke activate_stage3_ip_config_start,v4 (id 833)
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6551] active-connection[0x5655179bf580]: set state-flags layer2-ready,lifetime-bound-to-profile-visibility (was lifetime-bound-to-profile-visibility)
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.6554] device (wlp2s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6554] device[d18b1e3770f3c0b2] (wlp2s0): add_pending_action (2): 'in-state-change'
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6562] device[d18b1e3770f3c0b2] (wlp2s0): remove_pending_action (1): 'in-state-change'
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6564] device[d18b1e3770f3c0b2] (wlp2s0): IPv4 config method is auto
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6566] device[d18b1e3770f3c0b2] (wlp2s0): ipv4.dhcp-client-id: no explicit client-id configured
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.6568] dhcp4 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6573] device[d18b1e3770f3c0b2] (wlp2s0): IPv6 config method is auto
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6573] device[d18b1e3770f3c0b2] (wlp2s0): will enable userland IPv6LL
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6574] platform-linux: link: change 2: user-ipv6ll: set IPv6 address generation mode to none
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6575] platform-linux: do-request-link: 2
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6577] platform-linux: do-change-link[2]: success changing link: success
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6579] platform-linux: sysctl: setting '/proc/sys/net/ipv6/conf/wlp2s0/disable_ipv6' to '1' (current value is '0')
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6582] platform-linux: sysctl: setting '/proc/sys/net/ipv6/conf/wlp2s0/disable_ipv6' to '0' (current value is '1')
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6587] platform-linux: sysctl: setting '/proc/sys/net/ipv6/conf/wlp2s0/accept_ra' to '0' (current value is identical)
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6589] platform: (wlp2s0) signal: route   6 removed: type unicast table 255 ff00::/8 via :: dev 2 metric 256 mss 0 rt-src rt-boot
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6589] device[d18b1e3770f3c0b2] (wlp2s0): queued IP6 config change
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6591] platform: (wlp2s0) signal: route   6   added: type unicast table 255 ff00::/8 via :: dev 2 metric 256 mss 0 rt-src rt-boot
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6594] platform-linux: sysctl: reading '/proc/sys/net/ipv6/conf/default/use_tempaddr': '0'
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6595] platform-linux: sysctl: reading '/proc/sys/net/ipv6/conf/wlp2s0/router_solicitation_interval': '4'
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6596] platform-linux: sysctl: reading '/proc/sys/net/ipv6/conf/wlp2s0/router_solicitations': '-1'
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6597] platform-linux: sysctl: reading '/proc/sys/net/ipv6/conf/wlp2s0/max_addresses': '16'
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6599] device[d18b1e3770f3c0b2] (wlp2s0): linklocal6: starting IPv6 with method 'auto', but the device has no link-local addresses configured. Wait.
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6600] device[d18b1e3770f3c0b2] (wlp2s0): linklocal6: generated stable-privacy IPv6LL address fe80::50b0:9d5b:185d:bdb3
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6603] device[d18b1e3770f3c0b2] (wlp2s0): ip6-config: update (commit=1, new-config=0x5655179b18a0)
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6604] platform: (wlp2s0) address: adding or updating IPv6 address: fe80::50b0:9d5b:185d:bdb3/64 lft forever pref forever lifetime 185-0[4294967295,4294967295] dev 2 flags noprefixroute src unknown
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6607] platform: (wlp2s0) signal: address 6   added: fe80::50b0:9d5b:185d:bdb3/64 lft forever pref forever lifetime 185-0[4294967295,4294967295] dev 2 flags permanent,noprefixroute,tentative src kernel
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6608] platform-linux: do-add-ip6-address[2: fe80::50b0:9d5b:185d:bdb3]: success
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6609] platform: (wlp2s0) route: append     IPv6 route: type unicast fe80::/64 via :: dev 2 metric 600 mss 0 rt-src ipv6ll
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6617] platform: (wlp2s0) signal: route   6   added: type unicast fe80::/64 via :: dev 2 metric 600 mss 0 rt-src rt-kernel
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6618] platform-linux: do-add-ip6-route[type unicast fe80::/64 via :: dev 2 metric 600 mss 0 rt-src rt-kernel]: success
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6626] device[d18b1e3770f3c0b2] (wlp2s0): ip6-config: update IP Config instance (/org/freedesktop/NetworkManager/IP6Config/4)
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6627] dns-mgr: (device_ip_config_changed): queueing DNS updates (1)
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6627] dns-mgr: (device_ip_config_changed): DNS configuration did not change
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6628] dns-mgr: (device_ip_config_changed): no DNS changes to commit (0)
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6630] platform-linux: sysctl: setting '/proc/sys/net/ipv6/conf/wlp2s0/use_tempaddr' to '0' (current value is identical)
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6644] dhcp4 (wlp2s0): send REQUEST to 255.255.255.255
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6681] device[d18b1e3770f3c0b2] (wlp2s0): ip6-config: update (commit=0, new-config=0x5655179b18a0)
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6689] device[d18b1e3770f3c0b2] (wlp2s0): ip6-config: update IP Config instance (/org/freedesktop/NetworkManager/IP6Config/4)
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6689] dns-mgr: (device_ip_config_changed): queueing DNS updates (1)
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6690] dns-mgr: (device_ip_config_changed): DNS configuration did not change
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6690] dns-mgr: (device_ip_config_changed): no DNS changes to commit (0)
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6765] dhcp4 (wlp2s0): received ACK of 192.168.1.14 from 0.0.0.0
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.6810] dhcp4 (wlp2s0): option dhcp_lease_time      => '7200'
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.6811] dhcp4 (wlp2s0): option domain_name          => 'lan'
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.6811] dhcp4 (wlp2s0): option domain_name_servers  => '192.168.1.254'
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.6811] dhcp4 (wlp2s0): option expiry               => '1605521956'
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.6812] dhcp4 (wlp2s0): option host_name            => 'celestin'
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.6812] dhcp4 (wlp2s0): option ip_address           => '192.168.1.14'
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.6812] dhcp4 (wlp2s0): option requested_broadcast_address => '1'
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.6812] dhcp4 (wlp2s0): option requested_domain_name => '1'
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.6812] dhcp4 (wlp2s0): option requested_domain_name_servers => '1'
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.6813] dhcp4 (wlp2s0): option requested_domain_search => '1'
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.6813] dhcp4 (wlp2s0): option requested_host_name  => '1'
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.6813] dhcp4 (wlp2s0): option requested_interface_mtu => '1'
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.6813] dhcp4 (wlp2s0): option requested_ms_classless_static_routes => '1'
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.6813] dhcp4 (wlp2s0): option requested_nis_domain => '1'
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.6814] dhcp4 (wlp2s0): option requested_nis_servers => '1'
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.6814] dhcp4 (wlp2s0): option requested_ntp_servers => '1'
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.6814] dhcp4 (wlp2s0): option requested_rfc3442_classless_static_routes => '1'
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.6814] dhcp4 (wlp2s0): option requested_root_path  => '1'
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.6815] dhcp4 (wlp2s0): option requested_routers    => '1'
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.6815] dhcp4 (wlp2s0): option requested_static_routes => '1'
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.6815] dhcp4 (wlp2s0): option requested_subnet_mask => '1'
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.6815] dhcp4 (wlp2s0): option requested_time_offset => '1'
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.6815] dhcp4 (wlp2s0): option requested_wpad       => '1'
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.6816] dhcp4 (wlp2s0): option routers              => '192.168.1.254'
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.6816] dhcp4 (wlp2s0): option subnet_mask          => '255.255.255.0'
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.6816] dhcp4 (wlp2s0): state changed unknown -> bound
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6816] device[d18b1e3770f3c0b2] (wlp2s0): new DHCPv4 client state 1
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6825] device[d18b1e3770f3c0b2] (wlp2s0): activation-stage: schedule activate_stage5_ip_config_result_4,v4 (id 848)
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6826] device[d18b1e3770f3c0b2] (wlp2s0): activation-stage: invoke activate_stage5_ip_config_result_4,v4 (id 848)
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6827] device[d18b1e3770f3c0b2] (wlp2s0): ip4-config: update (commit=1, new-config=0x565517a455b0)
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6828] platform: (wlp2s0) address: adding or updating IPv4 address: 192.168.1.14/24 brd 192.168.1.255 lft 7200sec pref 7200sec lifetime 185-0[7200,7200] dev 2 flags noprefixroute src unknown
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6831] platform: (wlp2s0) signal: address 4   added: 192.168.1.14/24 brd 192.168.1.255 lft 7200sec pref 7200sec lifetime 185-185[7200,7200] dev 2 flags noprefixroute src kernel
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6831] device[d18b1e3770f3c0b2] (wlp2s0): queued IP4 config change
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6833] platform: (wlp2s0) signal: route   4   added: type local table 255 192.168.1.14/32 via 0.0.0.0 dev 2 metric 0 mss 0 rt-src rt-kernel scope host pref-src 192.168.1.14
nov. 16 09:19:16 celestin dbus-daemon[470]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.1' (uid=0 pid=471 comm="/usr/bin/NetworkManager --no-daemon " label="unconfined")
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6834] platform-linux: do-add-ip4-address[2: 192.168.1.14/24]: success
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6835] platform: (wlp2s0) route: append     IPv4 route: type unicast 192.168.1.0/24 via 0.0.0.0 dev 2 metric 600 mss 0 rt-src rt-kernel scope link pref-src 192.168.1.14
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6837] platform: (wlp2s0) signal: route   4   added: type unicast 192.168.1.0/24 via 0.0.0.0 dev 2 metric 600 mss 0 rt-src rt-kernel scope link pref-src 192.168.1.14
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6838] platform-linux: do-add-ip4-route[type unicast 192.168.1.0/24 via 0.0.0.0 dev 2 metric 600 mss 0 rt-src rt-kernel scope link pref-src 192.168.1.14]: success
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6838] platform: (wlp2s0) route: append     IPv4 route: type unicast 0.0.0.0/0 via 192.168.1.254 dev 2 metric 20600 mss 0 rt-src dhcp
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6841] platform: (wlp2s0) signal: route   4   added: type unicast 0.0.0.0/0 via 192.168.1.254 dev 2 metric 20600 mss 0 rt-src rt-dhcp scope global
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6842] platform-linux: do-add-ip4-route[type unicast 0.0.0.0/0 via 192.168.1.254 dev 2 metric 20600 mss 0 rt-src rt-dhcp scope global]: success
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6849] device[d18b1e3770f3c0b2] (wlp2s0): ip4-config: set IP Config instance (/org/freedesktop/NetworkManager/IP4Config/4)
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6852] dns-mgr: (device_ip_config_changed): queueing DNS updates (1)
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6852] dns-mgr: (device_ip_config_changed): DNS configuration did not change
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6853] dns-mgr: (device_ip_config_changed): no DNS changes to commit (0)
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6857] active-connection[0x5655179bf580]: set state-flags layer2-ready,ip4-ready,lifetime-bound-to-profile-visibility (was layer2-ready,lifetime-bound-to-profile-visibility)
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.6861] device (wlp2s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6861] device[d18b1e3770f3c0b2] (wlp2s0): add_pending_action (2): 'in-state-change'
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6871] dispatcher: (10) (wlp2s0) dispatching action 'pre-up' (with callback)
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6898] device[d18b1e3770f3c0b2] (wlp2s0): remove_pending_action (1): 'in-state-change'
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.6901] device[d18b1e3770f3c0b2] (wlp2s0): ip4-config: update (commit=0, new-config=0x565517a45470)
nov. 16 09:19:16 celestin systemd[1]: Starting Network Manager Script Dispatcher Service...
nov. 16 09:19:16 celestin dbus-daemon[470]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
nov. 16 09:19:16 celestin systemd[1]: Started Network Manager Script Dispatcher Service.
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:1 'pre-up' [wlp2s0]: new request (0 scripts)
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:1 'pre-up' [wlp2s0]: environment: CONNECTION_DBUS_PATH=/org/freedesktop/NetworkManager/Settings/1
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.7181] dispatcher: (10) succeeded but no scripts invoked
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:1 'pre-up' [wlp2s0]: environment: CONNECTION_FILENAME=/etc/NetworkManager/system-connections/Freebox-5B6587.nmconnection
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.7182] device[d18b1e3770f3c0b2] (wlp2s0): add_pending_action (2): 'queued-state-change-secondaries'
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:1 'pre-up' [wlp2s0]: environment: CONNECTION_UUID=ad7fb5ca-6192-4d98-a5f5-435b47bc0297
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.7182] device[d18b1e3770f3c0b2] (wlp2s0): queue-state[secondaries, reason:none, id:854]: queue state change
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:1 'pre-up' [wlp2s0]: environment: CONNECTION_ID=Freebox-5B6587
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.7183] device[d18b1e3770f3c0b2] (wlp2s0): queue-state[secondaries, reason:none, id:854]: change state
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:1 'pre-up' [wlp2s0]: environment: DEVICE_IFACE=wlp2s0
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.7184] device (wlp2s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:1 'pre-up' [wlp2s0]: environment: DEVICE_IP_IFACE=wlp2s0
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.7184] device[d18b1e3770f3c0b2] (wlp2s0): add_pending_action (3): 'in-state-change'
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:1 'pre-up' [wlp2s0]: environment: PATH=/usr/local/sbin:/usr/local/bin:/usr/bin:/var/lib/snapd/snap/bin
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.7189] device[d18b1e3770f3c0b2] (wlp2s0): add_pending_action (4): 'queued-state-change-activated'
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:1 'pre-up' [wlp2s0]: environment: NM_DISPATCHER_ACTION=pre-up
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.7189] device[d18b1e3770f3c0b2] (wlp2s0): queue-state[activated, reason:none, id:855]: queue state change
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:1 'pre-up' [wlp2s0]: completed: no scripts
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.7190] device[d18b1e3770f3c0b2] (wlp2s0): device entered SECONDARIES state
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.7190] device[d18b1e3770f3c0b2] (wlp2s0): remove_pending_action (3): 'in-state-change'
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.7190] device[d18b1e3770f3c0b2] (wlp2s0): remove_pending_action (2): 'queued-state-change-secondaries'
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.7191] device[d18b1e3770f3c0b2] (wlp2s0): queue-state[activated, reason:none, id:855]: change state
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.7191] device (wlp2s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.7191] device[d18b1e3770f3c0b2] (wlp2s0): add_pending_action (3): 'in-state-change'
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.7204] active-connection[0x5655179bf580]: set state activated (was activating)
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.7209] manager: NetworkManager state is now CONNECTED_LOCAL
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.7213] active-connection[0x5655179bf580]: check-master-ready: not signalling (state activated, no master)
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.7213] device[d18b1e3770f3c0b2] (wlp2s0): remove_pending_action (2): 'activation-2'
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.7251] ++ connection 'update connection' (0x565517a16760/NMSimpleConnection/"802-11-wireless" < 0x565517a31740/NMSimpleConnection/"802-11-wireless") [/org/freedesktop/NetworkManager/Settings/1]:
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.7253] ++ 802-11-wireless-security  [ 0x5655179f6e20 < 0x5655179f6d70 ]
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.7253] ++ 802-11-wireless-security.psk < ****
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.7262] dns-mgr: (device_state_changed): queueing DNS updates (1)
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.7263] dns-mgr: (update_routing_and_dns): queueing DNS updates (2)
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.7267] manager: NetworkManager state is now CONNECTED_SITE
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.7271] policy: set 'Freebox-5B6587' (wlp2s0) as default for IPv4 routing and DNS
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.7271] manager: PrimaryConnection now Freebox-5B6587
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.7277] dns-mgr: (update_routing_and_dns): DNS configuration changed
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.7277] dns-mgr: (update_routing_and_dns): no DNS changes to commit (1)
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.7278] dns-mgr: (device_state_changed): DNS configuration changed
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.7278] dns-mgr: (device_state_changed): committing DNS changes (0)
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.7278] dns-mgr: update-dns: updating resolv.conf
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.7332] device (wlp2s0): Activation: successful, device activated.
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.7333] device[d18b1e3770f3c0b2] (wlp2s0): set metered value 4
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.7337] manager: new metered value: 4
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.7341] dispatcher: (11) (wlp2s0) dispatching action 'up'
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.7358] connectivity: (wlp2s0,IPv4,33) start request to 'http://www.archlinux.org/check_network_status.txt' (systemd-resolved not available)
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.7361] connectivity: (wlp2s0,IPv6,34) start request to 'http://www.archlinux.org/check_network_status.txt' (systemd-resolved not available)
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.7363] device[d18b1e3770f3c0b2] (wlp2s0): remove_pending_action (1): 'in-state-change'
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.7364] device[d18b1e3770f3c0b2] (wlp2s0): remove_pending_action (0): 'queued-state-change-activated'
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.7504] connectivity: (wlp2s0,IPv6,34) check completed: LIMITED; check failed: (7) Couldn't connect to server
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.7505] device[d18b1e3770f3c0b2] (wlp2s0): connectivity state changed from NONE to LIMITED
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.7507] manager: connectivity checking indicates LIMITED
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.7510] dispatcher: (12) dispatching action 'connectivity-change'
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.7513] device[d18b1e3770f3c0b2] (wlp2s0): ip4-config: update (commit=1, new-config=0x565517a45970)
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.7514] platform: (wlp2s0) address: adding or updating IPv4 address: 192.168.1.14/24 brd 192.168.1.255 lft 7200sec pref 7200sec lifetime 185-0[7200,7200] dev 2 flags noprefixroute src unknown
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.7517] platform-linux: do-add-ip4-address[2: 192.168.1.14/24]: success
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:2 'up' [wlp2s0]: new request (0 scripts)
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:2 'up' [wlp2s0]: environment: CONNECTION_DBUS_PATH=/org/freedesktop/NetworkManager/Settings/1
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:2 'up' [wlp2s0]: environment: CONNECTION_FILENAME=/etc/NetworkManager/system-connections/Freebox-5B6587.nmconnection
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:2 'up' [wlp2s0]: environment: CONNECTION_UUID=ad7fb5ca-6192-4d98-a5f5-435b47bc0297
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:2 'up' [wlp2s0]: environment: CONNECTION_ID=Freebox-5B6587
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:2 'up' [wlp2s0]: environment: DEVICE_IFACE=wlp2s0
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:2 'up' [wlp2s0]: environment: DEVICE_IP_IFACE=wlp2s0
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:2 'up' [wlp2s0]: environment: IP4_ADDRESS_0=192.168.1.14/24 192.168.1.254
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:2 'up' [wlp2s0]: environment: IP4_NUM_ADDRESSES=1
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:2 'up' [wlp2s0]: environment: IP4_GATEWAY=192.168.1.254
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:2 'up' [wlp2s0]: environment: IP4_NAMESERVERS=192.168.1.254
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:2 'up' [wlp2s0]: environment: IP4_DOMAINS=lan
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:2 'up' [wlp2s0]: environment: IP4_ROUTE_0=192.168.1.14/32 0.0.0.0 0
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:2 'up' [wlp2s0]: environment: IP4_ROUTE_1=192.168.1.0/24 0.0.0.0 600
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:2 'up' [wlp2s0]: environment: IP4_NUM_ROUTES=2
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.7551] dispatcher: (11) succeeded but no scripts invoked
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:2 'up' [wlp2s0]: environment: IP6_ADDRESS_0=fe80::50b0:9d5b:185d:bdb3/64 0.0.0.0
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:2 'up' [wlp2s0]: environment: IP6_NUM_ADDRESSES=1
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:2 'up' [wlp2s0]: environment: IP6_GATEWAY=0.0.0.0
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.7560] dispatcher: (12) succeeded but no scripts invoked
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:2 'up' [wlp2s0]: environment: IP6_ROUTE_0=ff00::/8 :: 256
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:2 'up' [wlp2s0]: environment: IP6_ROUTE_1=fe80::/64 :: 600
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:2 'up' [wlp2s0]: environment: IP6_NUM_ROUTES=2
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:2 'up' [wlp2s0]: environment: DHCP4_DHCP_LEASE_TIME=7200
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:2 'up' [wlp2s0]: environment: DHCP4_DOMAIN_NAME=lan
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:2 'up' [wlp2s0]: environment: DHCP4_DOMAIN_NAME_SERVERS=192.168.1.254
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:2 'up' [wlp2s0]: environment: DHCP4_EXPIRY=1605521956
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:2 'up' [wlp2s0]: environment: DHCP4_HOST_NAME=celestin
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:2 'up' [wlp2s0]: environment: DHCP4_IP_ADDRESS=192.168.1.14
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:2 'up' [wlp2s0]: environment: DHCP4_REQUESTED_BROADCAST_ADDRESS=1
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:2 'up' [wlp2s0]: environment: DHCP4_REQUESTED_DOMAIN_NAME=1
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:2 'up' [wlp2s0]: environment: DHCP4_REQUESTED_DOMAIN_NAME_SERVERS=1
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:2 'up' [wlp2s0]: environment: DHCP4_REQUESTED_DOMAIN_SEARCH=1
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:2 'up' [wlp2s0]: environment: DHCP4_REQUESTED_HOST_NAME=1
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:2 'up' [wlp2s0]: environment: DHCP4_REQUESTED_INTERFACE_MTU=1
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:2 'up' [wlp2s0]: environment: DHCP4_REQUESTED_MS_CLASSLESS_STATIC_ROUTES=1
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:2 'up' [wlp2s0]: environment: DHCP4_REQUESTED_NIS_DOMAIN=1
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:2 'up' [wlp2s0]: environment: DHCP4_REQUESTED_NIS_SERVERS=1
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:2 'up' [wlp2s0]: environment: DHCP4_REQUESTED_NTP_SERVERS=1
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:2 'up' [wlp2s0]: environment: DHCP4_REQUESTED_RFC3442_CLASSLESS_STATIC_ROUTES=1
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:2 'up' [wlp2s0]: environment: DHCP4_REQUESTED_ROOT_PATH=1
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:2 'up' [wlp2s0]: environment: DHCP4_REQUESTED_ROUTERS=1
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:2 'up' [wlp2s0]: environment: DHCP4_REQUESTED_STATIC_ROUTES=1
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:2 'up' [wlp2s0]: environment: DHCP4_REQUESTED_SUBNET_MASK=1
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:2 'up' [wlp2s0]: environment: DHCP4_REQUESTED_TIME_OFFSET=1
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:2 'up' [wlp2s0]: environment: DHCP4_REQUESTED_WPAD=1
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:2 'up' [wlp2s0]: environment: DHCP4_ROUTERS=192.168.1.254
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:2 'up' [wlp2s0]: environment: DHCP4_SUBNET_MASK=255.255.255.0
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:2 'up' [wlp2s0]: environment: PATH=/usr/local/sbin:/usr/local/bin:/usr/bin:/var/lib/snapd/snap/bin
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:2 'up' [wlp2s0]: environment: NM_DISPATCHER_ACTION=up
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:2 'up' [wlp2s0]: completed: no scripts
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:3 'connectivity-change': new request (0 scripts)
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:3 'connectivity-change': environment: CONNECTIVITY_STATE=LIMITED
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:3 'connectivity-change': environment: PATH=/usr/local/sbin:/usr/local/bin:/usr/bin:/var/lib/snapd/snap/bin
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:3 'connectivity-change': environment: NM_DISPATCHER_ACTION=connectivity-change
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:3 'connectivity-change': completed: no scripts
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.9027] connectivity: (wlp2s0,IPv4,33) check completed: FULL; expected response
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.9028] device[d18b1e3770f3c0b2] (wlp2s0): connectivity state changed from NONE to FULL
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.9030] manager: connectivity checking indicates FULL
nov. 16 09:19:16 celestin NetworkManager[471]: <info>  [1605514756.9031] manager: NetworkManager state is now CONNECTED_GLOBAL
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.9035] dispatcher: (13) dispatching action 'connectivity-change'
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.9039] device[d18b1e3770f3c0b2] (wlp2s0): ip4-config: update (commit=1, new-config=0x565517a45ab0)
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.9040] platform: (wlp2s0) address: adding or updating IPv4 address: 192.168.1.14/24 brd 192.168.1.255 lft 7200sec pref 7200sec lifetime 185-0[7200,7200] dev 2 flags noprefixroute src unknown
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.9042] platform-linux: do-add-ip4-address[2: 192.168.1.14/24]: success
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.9043] platform: (wlp2s0) route: append     IPv4 route: type unicast 0.0.0.0/0 via 192.168.1.254 dev 2 metric 600 mss 0 rt-src dhcp
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.9045] platform: (wlp2s0) signal: route   4   added: type unicast 0.0.0.0/0 via 192.168.1.254 dev 2 metric 600 mss 0 rt-src rt-dhcp scope global
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.9046] device[d18b1e3770f3c0b2] (wlp2s0): queued IP4 config change
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.9047] platform-linux: do-add-ip4-route[type unicast 0.0.0.0/0 via 192.168.1.254 dev 2 metric 600 mss 0 rt-src rt-dhcp scope global]: success
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.9047] platform: (wlp2s0) ip4-route: delete type unicast 0.0.0.0/0 via 192.168.1.254 dev 2 metric 20600 mss 0 rt-src rt-dhcp scope global
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.9049] platform: (wlp2s0) signal: route   4 removed: type unicast 0.0.0.0/0 via 192.168.1.254 dev 2 metric 20600 mss 0 rt-src rt-dhcp scope global
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.9050] platform-linux: do-delete-ip4-route[type unicast 0.0.0.0/0 via 192.168.1.254 dev 2 metric 20600 mss 0 rt-src rt-dhcp scope global]: success
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.9056] device[d18b1e3770f3c0b2] (wlp2s0): ip4-config: update IP Config instance (/org/freedesktop/NetworkManager/IP4Config/4)
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.9059] dns-mgr: (device_ip_config_changed): queueing DNS updates (1)
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.9060] dns-mgr: (device_ip_config_changed): DNS configuration did not change
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.9061] dns-mgr: (device_ip_config_changed): no DNS changes to commit (0)
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.9064] device[d18b1e3770f3c0b2] (wlp2s0): ip4-config: update (commit=0, new-config=0x565517a45830)
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:4 'connectivity-change': new request (0 scripts)
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:4 'connectivity-change': environment: CONNECTIVITY_STATE=FULL
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:4 'connectivity-change': environment: PATH=/usr/local/sbin:/usr/local/bin:/usr/bin:/var/lib/snapd/snap/bin
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:4 'connectivity-change': environment: NM_DISPATCHER_ACTION=connectivity-change
nov. 16 09:19:16 celestin nm-dispatcher[2600]: req:4 'connectivity-change': completed: no scripts
nov. 16 09:19:16 celestin NetworkManager[471]: <debug> [1605514756.9114] dispatcher: (13) succeeded but no scripts invoked
nov. 16 09:19:17 celestin wpa_supplicant[1022]: wlp2s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-73 noise=-99 txrate=6000
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.2754] platform: (wlp2s0) signal: address 6 changed: fe80::50b0:9d5b:185d:bdb3/64 lft forever pref forever lifetime 187-0[4294967295,4294967295] dev 2 flags permanent,noprefixroute src kernel
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.2755] device[d18b1e3770f3c0b2] (wlp2s0): queued IP6 config change
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.2756] platform: (wlp2s0) signal: route   6   added: type local table 255 fe80::50b0:9d5b:185d:bdb3/128 via :: dev 2 metric 0 mss 0 rt-src rt-kernel
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.2761] device[d18b1e3770f3c0b2] (wlp2s0): ip6-config: update (commit=0, new-config=0x5655179b1bd0)
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.2766] device[d18b1e3770f3c0b2] (wlp2s0): ip6-config: update IP Config instance (/org/freedesktop/NetworkManager/IP6Config/4)
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.2767] dns-mgr: (device_ip_config_changed): queueing DNS updates (1)
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.2768] dns-mgr: (device_ip_config_changed): DNS configuration did not change
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.2768] dns-mgr: (device_ip_config_changed): no DNS changes to commit (0)
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.2769] device[d18b1e3770f3c0b2] (wlp2s0): linklocal6: waiting for link-local addresses successful, continue with method auto
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.2769] device[d18b1e3770f3c0b2] (wlp2s0): addrconf6: using the device EUI-64 identifier
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.2771] device[d18b1e3770f3c0b2] (wlp2s0): ip6-config: update (commit=1, new-config=0x5655179b1570)
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.2771] platform: (wlp2s0) address: adding or updating IPv6 address: fe80::50b0:9d5b:185d:bdb3/64 lft forever pref forever lifetime 187-0[4294967295,4294967295] dev 2 flags permanent,noprefixroute src unknown
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.2780] platform-linux: do-add-ip6-address[2: fe80::50b0:9d5b:185d:bdb3]: success
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.2785] device[d18b1e3770f3c0b2] (wlp2s0): ip6-config: update IP Config instance (/org/freedesktop/NetworkManager/IP6Config/4)
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.2786] dns-mgr: (device_ip_config_changed): queueing DNS updates (1)
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.2786] dns-mgr: (device_ip_config_changed): DNS configuration did not change
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.2787] dns-mgr: (device_ip_config_changed): no DNS changes to commit (0)
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.2788] ndisc[0x565517a83210,"wlp2s0"]: starting neighbor discovery for ifindex 2 (solicit)
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.2788] ndisc-lndp[0x565517a83210,"wlp2s0"]: processing libndp events
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.2789] ndisc[0x565517a83210,"wlp2s0"]: scheduling RA timeout in 30 seconds
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.2789] ndisc[0x565517a83210,"wlp2s0"]: scheduling explicit router solicitation request in 0 seconds.
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.7378] connectivity: (wlp2s0,IPv6,35) start request to 'http://www.archlinux.org/check_network_status.txt' (systemd-resolved not available)
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.7468] connectivity: (wlp2s0,IPv6,35) check completed: LIMITED; check failed: (7) Couldn't connect to server
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.9341] ndisc[0x565517a83210,"wlp2s0"]: router solicitation sent
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.9342] ndisc[0x565517a83210,"wlp2s0"]: scheduling router solicitation retry in 4 seconds.
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.9392] ndisc-lndp[0x565517a83210,"wlp2s0"]: processing libndp events
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.9394] ndisc-lndp[0x565517a83210,"wlp2s0"]: received router advertisement at 188
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.9394] ndisc[0x565517a83210,"wlp2s0"]: complete-address: using an stable-privacy address
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.9395] ndisc[0x565517a83210,"wlp2s0"]: scheduling next now/lifetime check: 1800 seconds
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.9395] ndisc[0x565517a83210,"wlp2s0"]: neighbor discovery configuration changed [dGARSD]:
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.9395] ndisc[0x565517a83210,"wlp2s0"]:   dhcp-level managed
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.9395] ndisc[0x565517a83210,"wlp2s0"]:   hop limit      : 64
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.9396] ndisc[0x565517a83210,"wlp2s0"]:   gateway fe80::a236:9fff:fe6b:6da4 pref medium exp 1799,9953
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.9396] ndisc[0x565517a83210,"wlp2s0"]:   address 3a01:c56:ca8e:3a1:34b3:9717:8f46:3a7b exp 86399,9953
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.9396] ndisc[0x565517a83210,"wlp2s0"]:   route 3a01:c56:ca8e:3a1::/64 via fe80::a236:9fff:fe6b:6da4 pref medium exp 1799,9953
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.9397] ndisc[0x565517a83210,"wlp2s0"]:   dns_server 3a01:c56:ca8e:3a1::2 exp 7199,9953
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.9397] ndisc[0x565517a83210,"wlp2s0"]:   dns_domain lan exp 7199,9953
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.9398] device[d18b1e3770f3c0b2] (wlp2s0): Activation: Stage 3 of 5 (IP Configure Start) starting DHCPv6 as requested by IPv6 router...
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.9401] device[d18b1e3770f3c0b2] (wlp2s0): ipv6.dhcp-iaid: using 3134327015 (0xbad208e7) IAID (str: 'ifname', explicit 0)
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.9401] device[d18b1e3770f3c0b2] (wlp2s0): ipv6.dhcp-duid: generate lease DUID '00:04:07:47:ff:9c:6d:79:36:28:2f:f1:60:38:31:5f:69:f5' (prefer lease)
nov. 16 09:19:18 celestin NetworkManager[471]: <info>  [1605514758.9403] dhcp6 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.9404] device[d18b1e3770f3c0b2] (wlp2s0): mtu: set IPv6 MTU to 1500
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.9405] device[d18b1e3770f3c0b2] (wlp2s0): activation-stage: schedule activate_stage5_ip_config_result_6,v6 (id 912)
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.9409] device[d18b1e3770f3c0b2] (wlp2s0): activation-stage: invoke activate_stage5_ip_config_result_6,v6 (id 912)
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.9411] device[d18b1e3770f3c0b2] (wlp2s0): ip6-config: update (commit=1, new-config=0x5655179b1570)
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.9412] platform-linux: sysctl: reading '/proc/sys/net/ipv6/conf/wlp2s0/mtu': '1500'
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.9413] platform: (wlp2s0) address: adding or updating IPv6 address: fe80::50b0:9d5b:185d:bdb3/64 lft forever pref forever lifetime 188-0[4294967295,4294967295] dev 2 flags permanent,noprefixroute src unknown
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.9414] platform-linux: do-add-ip6-address[2: fe80::50b0:9d5b:185d:bdb3]: success
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.9414] platform: (wlp2s0) address: adding or updating IPv6 address: 3a01:c56:ca8e:3a1:34b3:9717:8f46:3a7b/64 lft 86400sec pref 14400sec lifetime 188-0[14400,86400] dev 2 flags noprefixroute src unknown
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.9417] platform: (wlp2s0) signal: address 6   added: 3a01:c56:ca8e:3a1:34b3:9717:8f46:3a7b/64 lft 86400sec pref 14400sec lifetime 188-187[14401,86401] dev 2 flags noprefixroute,tentative src kernel
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.9417] device[d18b1e3770f3c0b2] (wlp2s0): queued IP6 config change
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.9417] platform-linux: do-add-ip6-address[2: 3a01:c56:ca8e:3a1:34b3:9717:8f46:3a7b]: success
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.9418] platform: (wlp2s0) route: append     IPv6 route: type unicast 3a01:c56:ca8e:3a1::/64 via fe80::a236:9fff:fe6b:6da4 dev 2 metric 600 mss 0 rt-src ndisc
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.9420] platform: (wlp2s0) signal: route   6   added: type unicast 3a01:c56:ca8e:3a1::/64 via fe80::a236:9fff:fe6b:6da4 dev 2 metric 600 mss 0 rt-src rt-ra
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.9420] platform-linux: do-add-ip6-route[type unicast 3a01:c56:ca8e:3a1::/64 via fe80::a236:9fff:fe6b:6da4 dev 2 metric 600 mss 0 rt-src rt-ra]: success
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.9421] platform: (wlp2s0) route: append     IPv6 route: type unicast ::/0 via fe80::a236:9fff:fe6b:6da4 dev 2 metric 20600 mss 0 rt-src ndisc
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.9422] platform: (wlp2s0) signal: route   6   added: type unicast ::/0 via fe80::a236:9fff:fe6b:6da4 dev 2 metric 20600 mss 0 rt-src rt-ra
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.9422] platform-linux: do-add-ip6-route[type unicast ::/0 via fe80::a236:9fff:fe6b:6da4 dev 2 metric 20600 mss 0 rt-src rt-ra]: success
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.9431] device[d18b1e3770f3c0b2] (wlp2s0): ip6-config: update IP Config instance (/org/freedesktop/NetworkManager/IP6Config/4)
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.9431] dns-mgr: (device_ip_config_changed): queueing DNS updates (1)
nov. 16 09:19:18 celestin NetworkManager[471]: <info>  [1605514758.9434] policy: set 'Freebox-5B6587' (wlp2s0) as default for IPv6 routing and DNS
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.9435] dns-mgr: (device_ip_config_changed): DNS configuration changed
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.9436] dns-mgr: (device_ip_config_changed): committing DNS changes (0)
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.9436] dns-mgr: update-dns: updating resolv.conf
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.9525] device[d18b1e3770f3c0b2] (wlp2s0): ip6-config: update (commit=0, new-config=0x5655179b1790)
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.9532] device[d18b1e3770f3c0b2] (wlp2s0): ip6-config: update IP Config instance (/org/freedesktop/NetworkManager/IP6Config/4)
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.9533] dns-mgr: (device_ip_config_changed): queueing DNS updates (1)
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.9534] dns-mgr: (device_ip_config_changed): DNS configuration did not change
nov. 16 09:19:18 celestin NetworkManager[471]: <debug> [1605514758.9534] dns-mgr: (device_ip_config_changed): no DNS changes to commit (0)
nov. 16 09:19:19 celestin dbus-daemon[470]: [system] Activating via systemd: service name='net.reactivated.Fprint' unit='fprintd.service' requested by ':1.71' (uid=1000 pid=1565 comm="/usr/bin/gnome-shell " label="unconfined")
nov. 16 09:19:19 celestin systemd[1]: Starting Fingerprint Authentication Daemon...
nov. 16 09:19:19 celestin dbus-daemon[470]: [system] Successfully activated service 'net.reactivated.Fprint'
nov. 16 09:19:19 celestin systemd[1]: Started Fingerprint Authentication Daemon.
nov. 16 09:19:19 celestin gnome-shell[1565]: Can't update stage views actor StLabel is on because it needs an allocation.
nov. 16 09:19:19 celestin gnome-shell[1565]: Can't update stage views actor ClutterText is on because it needs an allocation.
nov. 16 09:19:19 celestin NetworkManager[471]: <debug> [1605514759.6178] ndisc-lndp[0x565517a83210,"wlp2s0"]: processing libndp events
Hello,
Please take a look at this topics from archived forum:
Probably you will benefit from even more such topics from there:
https://archived.forum.manjaro.org/search?q=Atheros%20QCA6174%20
Hi! thanks for feedback.
I will have look, but I must say I already checked several forums (Manjaro but also Arch and others).
I will try again the firmware change and also I will check if other live sessions I try ( Mint or other ) use same firmware or not.
Regarding the overheating:I think it should not be my situation: I do those test while doing close to nothing with wifi (except searching forums :wink: ): there’s no heavy load.
Also wifi works fine, as long as a QCA6174 can work fine…speed and sensitvity are not so nice, but connexion is stable once connected.
After check: firmware version is same between Manjaro and Mint (live session):
here is dmesg | grep ath10k output:
Manjaro:
[    3.514571] ath10k_pci 0000:02:00.0: enabling device (0000 -> 0002)
[    3.518107] ath10k_pci 0000:02:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
[    3.780501] ath10k_pci 0000:02:00.0: qca6174 hw3.2 target 0x05030000 chip_id 0x00340aff sub 1a56:143a
[    3.780506] ath10k_pci 0000:02:00.0: kconfig debug 1 debugfs 1 tracing 1 dfs 0 testmode 0
[    3.781235] ath10k_pci 0000:02:00.0: firmware ver WLAN.RM.4.4.1-00140-QCARMSWPZ-1 api 6 features wowlan,ignore-otp,mfp crc32 29eb8ca1
[    3.850182] ath10k_pci 0000:02:00.0: board_file api 2 bmi_id N/A crc32 4ac0889b
[    3.943819] ath10k_pci 0000:02:00.0: htt-ver 3.60 wmi-op 4 htt-op 3 cal otp max-sta 32 raw 0 hwcrypto 1
[    4.030113] ath10k_pci 0000:02:00.0 wlp2s0: renamed from wlan0
Mint:
[   10.704019] ath10k_pci 0000:02:00.0: enabling device (0000 -> 0002)
[   10.706959] ath10k_pci 0000:02:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
[   11.104910] ath10k_pci 0000:02:00.0: qca6174 hw3.2 target 0x05030000 chip_id 0x00340aff sub 1a56:143a
[   11.104914] ath10k_pci 0000:02:00.0: kconfig debug 0 debugfs 1 tracing 1 dfs 0 testmode 0
[   11.105492] ath10k_pci 0000:02:00.0: firmware ver WLAN.RM.4.4.1-00140-QCARMSWPZ-1 api 6 features wowlan,ignore-otp,mfp crc32 29eb8ca1
[   11.234404] ath10k_pci 0000:02:00.0: board_file api 2 bmi_id N/A crc32 4ac0889b
[   11.308665] ath10k_pci 0000:02:00.0: unsupported HTC service id: 1536
[   11.327892] ath10k_pci 0000:02:00.0: htt-ver 3.60 wmi-op 4 htt-op 3 cal otp max-sta 32 raw 0 hwcrypto 1
[   11.435769] ath10k_pci 0000:02:00.0 wlp2s0: renamed from wlan0
[   11.753948] ath10k_pci 0000:02:00.0: unsupported HTC service id: 1536
Both are strictly identical except those 2 “HTC” lines on mint side.
Then I also followed the suggestion with board.bin as in the post of @tbg here:
it changed slightly dmesg:>
[    3.331062] ath10k_pci 0000:02:00.0: enabling device (0000 -> 0002)
[    3.340023] ath10k_pci 0000:02:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
[    3.782238] ath10k_pci 0000:02:00.0: qca6174 hw3.2 target 0x05030000 chip_id 0x00340aff sub 1a56:143a
[    3.782243] ath10k_pci 0000:02:00.0: kconfig debug 1 debugfs 1 tracing 1 dfs 0 testmode 0
[    3.782901] ath10k_pci 0000:02:00.0: firmware ver WLAN.RM.4.4.1-00140-QCARMSWPZ-1 api 6 features wowlan,ignore-otp,mfp crc32 29eb8ca1
[    3.849307] ath10k_pci 0000:02:00.0: board_file api 1 bmi_id N/A crc32 70c38a29
[    3.944689] ath10k_pci 0000:02:00.0: htt-ver 3.60 wmi-op 4 htt-op 3 cal otp max-sta 32 raw 0 hwcrypto 1
[    4.035324] ath10k_pci 0000:02:00.0 wlp2s0: renamed from wlan0
=> it changed api 2 to api 1 (and crc) in line:
But connexion timings does not change => same behavior
