Hello, after updating to manjaro latest version I have wifi connection problem, it continuously disconnected me from wifi (I have tried connected to 2 access points) and I only have 1 operating system in my laptop.
I wanted to provide some logs, maybe it will make anyone who interested to help me have easier debug.
inxi -v8azy
Kernel: 6.12.63-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
parameters: BOOT_IMAGE=/vmlinuz-6.12-x86_64
root=UUID=88b94af5-3e27-4634-9d95-d708ff683455 rw quiet splash
pcie_aspm=off
Desktop: KDE Plasma v: 6.5.4 tk: Qt v: N/A info: frameworks v: 6.21.0
wm: kwin_wayland tools: avail: lxlock vt: 1 dm: SDDM Distro: Manjaro
base: Arch Linux
Type: Laptop System: Dell product: Inspiron 3459 v: N/A
serial: <superuser required> Chassis: type: 9 serial: <superuser required>
Mobo: Dell model: 03GMC5 v: A00 serial: <superuser required> part-nu: 06B1
uuid: <superuser required> Firmware: UEFI vendor: Dell v: 01.00.01
date: 10/14/2015
System RAM: total: 16 GiB available: 15.51 GiB used: 3.07 GiB (19.8%)
Array-1: capacity: 16 GiB slots: 2 modules: 2 EC: None
Device-1: DIMM A type: DDR3 detail: synchronous size: 8 GiB
speed: 1600 MT/s volts: curr: 1.35 width (bits): data: 64 total: 64
manufacturer: Samsung part-no: M471B5273DH0-YKO serial: <filter>
Device-2: DIMM B type: DDR3 detail: synchronous size: 8 GiB
manufacturer: Samsung part-no: N/A serial: <filter>
Info: model: Intel Core i5-6200U bits: 64 type: MT MCP arch: Skylake
gen: core 6 level: v3 note: check built: 2015 process: Intel 14nm family: 6
model-id: 0x4E (78) stepping: 3 microcode: 0xF0
Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 454 min/max: 400/2800 scaling: driver: intel_pstate
governor: powersave cores: 1: 454 2: 454 3: 454 4: 454 bogomips: 19204
smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
Type: gather_data_sampling status: Vulnerable: No microcode
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes
Type: mds mitigation: Clear CPU buffers;
Type: mmio_stale_data mitigation: Clear CPU buffers;
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Dell driver: i915
v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: eDP-1
empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Meso XT [Radeon R5 M315]
vendor: Dell driver: amdgpu v: kernel arch: GCN-3 code: Volcanic Islands
process: TSMC 28nm built: 2014-19 pcie: gen: 2 speed: 5 GT/s lanes: 4
link-max: lanes: 8 bus-ID: 01:00.0 chip-ID: 1003:6805 class-ID: 0320
temp: 50.0 C
Device-3: Realtek Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 c
hip-ID: 0bda:5683
compositor: kwin_wayland driver: X: loaded: amdgpu,modesetting
alternate: fbdev,vesa dri: iris,radeonsi gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: AU Optronics 0x2e3c built: 2013 res: mode: 1366x768
hz: 60 scale: 100% (1) dpi: 112 gamma: 1.2 chroma: red: x: 0.580 y: 0.333
green: x: 0.329 y: 0.565 blue: x: 0.153 y: 0.137 white: x: 0.314 y: 0.329
size: 309x173mm (12.17x6.81") diag: 354mm (13.9") ratio: 16:9
modes: 1366x768
API: EGL v: 1.5 hw: drv: intel iris drv: amd radeonsi platforms: device: 0
drv: radeonsi device: 1 drv: iris device: 2 drv: swrast gbm: drv: radeonsi
surfaceless: drv: radeonsi wayland: drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.3.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 520 (SKL GT2)
device-ID: 8086:1916 memory: 15.14 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.4.335 layers: 2 device: 0 type: integrated-gpu name: Intel
HD Graphics 520 (SKL GT2) driver: mesa intel v: 25.3.1-arch1.2
device-ID: 8086:1916 surfaces: N/A device: 1 type: discrete-gpu name: AMD
Radeon R5 M315 (RADV ICELAND) driver: mesa radv v: 25.3.1-arch1.2
device-ID: 1002:6907 surfaces: N/A
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:9d70
class-ID: 0403
API: ALSA v: k6.12.63-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse
Device-1: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: Dell Vostro 3470 driver: ath9k v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:0036 class-ID: 0280
IF: wlan0 state: down mac: <filter>
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
bus-ID: 03:00.0 chip-ID: 10ec:8136 class-ID: 0200
Info: services: iwd, NetworkManager, systemd-timesyncd
WAN IP: No WAN IP found. Connected to web? SSL issues? Try enabling dig
Device-1: Qualcomm Atheros driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:6 chip-ID: 0cf3:e005
class-ID: e001
Local Storage: total: 465.76 GiB used: 24.64 GiB (5.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Hitachi model: HTS725050A7E630
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: B390 scheme: MBR
ID-1: / raw-size: 460.76 GiB size: 452.46 GiB (98.20%) used: 24.37 GiB (5.4%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 88b94af7-3e37-4634-9d55-d708ff684405
ID-2: /boot raw-size: 512 MiB size: 511 MiB (99.80%)
used: 183.3 MiB (35.9%) fs: vfat dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: ACBC-C6AD
ID-3: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%)
used: 96.9 MiB (19.0%) fs: vfat dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: AB2C-5C1C
ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 3d0f7c29-5e5f-4c58-9593-d41b9b9d281f
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-3:2 info: China Resource Semico Keyboard type: keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 98mA chip-ID: 1a2c:2124 class-ID: 0300
Device-2: 1-5:3 info: Realtek Integrated_Webcam_HD type: video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 0bda:5683 class-ID: 0e02 serial: <filter>
Device-3: 1-6:4 info: Realtek RTS5129 Card Reader Controller
power: 500mA chip-ID: 0bda:0129 class-ID: ff00 serial: <filter>
Device-4: 1-8:6 info: Qualcomm Atheros type: bluetooth driver: btusb
interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 100mA chip-ID: 0cf3:e005 class-ID: e001
Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.0
System Temperatures: cpu: 42.0 C pch: 39.5 C mobo: 39.0 C gpu: amdgpu
temp: 52.0 C
Fan Speeds (rpm): cpu: 0
Packages: pm: pacman pkgs: 1333 libs: 343 tools: pamac,yay pm: flatpak
pkgs: 0
1: https://mirrors2.manjaro.org/stable/$repo/$arch
2: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
3: https://mirrors.manjaro.org/repo/stable/$repo/$arch
Processes:
CPU top: 5 of 217
1: cpu: 666% command: ps pid: 2696 mem: 3.96 MiB (0.0%)
2: cpu: 88.9% command: codium pid: 2276 mem: 428.4 MiB (2.6%)
3: cpu: 87.3% command: devsense.php.ls pid: 2610 mem: 177.7 MiB (1.1%)
4: cpu: 58.8% command: intelephense.js started-by: codium pid: 2518
mem: 363.9 MiB (2.2%)
5: cpu: 32.7% command: exe pid: 2300 mem: 282.3 MiB (1.7%)
Memory top: 5 of 217
1: mem: 428.4 MiB (2.6%) command: codium pid: 2276 cpu: 88.9%
2: mem: 380.3 MiB (2.3%) command: plasmashell pid: 1019 cpu: 5.4%
3: mem: 363.9 MiB (2.2%) command: intelephense.js started-by: codium
pid: 2518 cpu: 58.8%
4: mem: 324.1 MiB (2.0%) command: codium pid: 2209 cpu: 14.5%
5: mem: 282.3 MiB (1.7%) command: exe pid: 2300 cpu: 32.7%
Processes: 217 Power: uptime: 25m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.18 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 258 default: graphical
tool: systemctl
Compilers: gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.40```
rfkill list
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
1: hci0: Bluetooth
Soft blocked: no
Hard blocked: no```
ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host noprefixroute
2: enp3s0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN group default qlen 1000
link/ether XX:XX:XX:XX:XX:XX brd ff:ff:ff:ff:ff:ff
altname enx20474XXXXXX
4: wlan0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default qlen 1000
link/ether XX:XX:XX:XX:XX:XX brd ff:ff:ff:ff:ff:ff```
lspci -v
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Host Bridge/DRAM Registers (rev 08)
Subsystem: Dell Device 06b1
Flags: bus master, fast devsel, latency 0
Capabilities: <access denied>
Kernel driver in use: skl_uncore
00:02.0 VGA compatible controller: Intel Corporation Skylake GT2 [HD Graphics 520] (rev 07) (prog-if 00 [VGA controller])
DeviceName: Onboard IGD
Flags: bus master, fast devsel, latency 0, IRQ 129
Memory at d1000000 (64-bit, non-prefetchable) [size=16M]
Memory at b0000000 (64-bit, prefetchable) [size=256M]
I/O ports at f000 [size=64]
Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
Kernel driver in use: i915
Kernel modules: i915
00:14.0 USB controller: Intel Corporation Sunrise Point-LP USB 3.0 xHCI Controller (rev 21) (prog-if 30 [XHCI])
Flags: bus master, medium devsel, latency 0, IRQ 124
Memory at d2210000 (64-bit, non-prefetchable) [size=64K]
Kernel driver in use: xhci_hcd
00:14.2 Signal processing controller: Intel Corporation Sunrise Point-LP Thermal subsystem (rev 21)
Flags: bus master, fast devsel, latency 0, IRQ 18
Memory at d2230000 (64-bit, non-prefetchable) [size=4K]
Kernel driver in use: intel_pch_thermal
Kernel modules: intel_pch_thermal
00:15.0 Signal processing controller: Intel Corporation Sunrise Point-LP Serial IO I2C Controller #0 (rev 21)
Flags: bus master, fast devsel, latency 0, IRQ 16
Memory at d222f000 (64-bit, non-prefetchable) [size=4K]
Kernel driver in use: intel-lpss
Kernel modules: intel_lpss_pci
00:15.1 Signal processing controller: Intel Corporation Sunrise Point-LP Serial IO I2C Controller #1 (rev 21)
Flags: bus master, fast devsel, latency 0, IRQ 17
Memory at d222e000 (64-bit, non-prefetchable) [size=4K]
00:16.0 Communication controller: Intel Corporation Sunrise Point-LP CSME HECI #1 (rev 21)
Flags: bus master, fast devsel, latency 0, IRQ 131
Memory at d222d000 (64-bit, non-prefetchable) [size=4K]
Kernel driver in use: mei_me
Kernel modules: mei_me
00:17.0 SATA controller: Intel Corporation Sunrise Point-LP SATA Controller [AHCI mode] (rev 21) (prog-if 01 [AHCI 1.0])
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 123
Memory at d2228000 (32-bit, non-prefetchable) [size=8K]
Memory at d222c000 (32-bit, non-prefetchable) [size=256]
I/O ports at f090 [size=8]
I/O ports at f080 [size=4]
I/O ports at f060 [size=32]
Memory at d222b000 (32-bit, non-prefetchable) [size=2K]
Kernel driver in use: ahci
00:1c.0 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #1 (rev f1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 120
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: e000-efff [size=4K] [16-bit]
Memory behind bridge: c0000000-d02fffff [size=259M] [32-bit]
Prefetchable memory behind bridge: [disabled] [64-bit]
Kernel driver in use: pcieport
00:1c.4 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #5 (rev f1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 121
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: [disabled] [16-bit]
Memory behind bridge: d2100000-d21fffff [size=1M] [32-bit]
00:1c.5 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #6 (rev f1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 122
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
I/O behind bridge: d000-dfff [size=4K] [16-bit]
Memory behind bridge: d2000000-d20fffff [size=1M] [32-bit]
00:1f.0 ISA bridge: Intel Corporation Sunrise Point-LP LPC Controller (rev 21)
00:1f.2 Memory controller: Intel Corporation Sunrise Point-LP PMC (rev 21)
Flags: fast devsel
Memory at d2224000 (32-bit, non-prefetchable) [disabled] [size=16K]
00:1f.3 Audio device: Intel Corporation Sunrise Point-LP HD Audio (rev 21) (prog-if 00 [HDA compatible])
Flags: bus master, fast devsel, latency 32, IRQ 139
Memory at d2220000 (64-bit, non-prefetchable) [size=16K]
Memory at d2200000 (64-bit, non-prefetchable) [size=64K]
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel, snd_soc_avs
00:1f.4 SMBus: Intel Corporation Sunrise Point-LP SMBus (rev 21)
Flags: medium devsel, IRQ 16
Memory at d222a000 (64-bit, non-prefetchable) [size=256]
I/O ports at f040 [size=32]
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
01:00.0 Display controller: Advanced Micro Devices, Inc. [AMD/ATI] Meso XT [Radeon R5 M315] (rev 87)
Flags: bus master, fast devsel, latency 0, IRQ 130
Memory at c0000000 (64-bit, prefetchable) [size=256M]
Memory at d0000000 (64-bit, prefetchable) [size=2M]
I/O ports at e000 [size=256]
Memory at d0200000 (32-bit, non-prefetchable) [size=256K]
Expansion ROM at d0240000 [disabled] [size=128K]
Kernel driver in use: amdgpu
Kernel modules: amdgpu
02:00.0 Network controller: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter (rev 01)
Subsystem: Dell Vostro 3470
Memory at d2100000 (64-bit, non-prefetchable) [size=512K]
Expansion ROM at d2180000 [disabled] [size=64K]
Kernel driver in use: ath9k
Kernel modules: ath9k
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL810xE PCI Express Fast Ethernet controller (rev 07)
I/O ports at d000 [size=256]
Memory at d2004000 (64-bit, non-prefetchable) [size=4K]
Memory at d2000000 (64-bit, prefetchable) [size=16K]
Kernel driver in use: r8169
Kernel modules: r8169```
lsmod | grep ath9k
ath9k 221184 0
ath9k_common 49152 1 ath9k
ath9k_hw 573440 2 ath9k_common,ath9k
ath 40960 3 ath9k_common,ath9k,ath9k_hw
mac80211 1638400 2 ath9k,ath9k_hw
cfg80211 1388544 4 ath9k_common,ath9k,ath,mac80211
rfkill 40960 9 ath9k,bluetooth,dell_laptop,cfg80211```
journalctl -u NetworkManager -f
Dec 29 09:11:28 My-Pc NetworkManager[495]: <info> [1766974288.7153] device (wlan0): new IWD device state is connecting
Dec 29 09:11:28 My-Pc NetworkManager[495]: <info> [1766974288.7304] device (wlan0): Activation: starting connection 'Dec 29 09:11:28 My-Pc NetworkManager[495]: <warn> [1766974288.8417] device (wlan0): Activation: failed for connection 'MyWifi' (7e4e7d5e-a113-431e-993b-6c158r7c2ab5)
Dec 29 09:11:28 My-Pc NetworkManager[495]: <info> [1766974288.7357] device (wlan0): state change: disconnected -> prepare (reason 'none', managed-type: 'full')
Dec 29 09:11:28 My-Pc NetworkManager[495]: <info> [1766974288.7420] manager: NetworkManager state is now CONNECTING
Dec 29 09:11:28 My-Pc NetworkManager[495]: <info> [1766974288.7455] device (wlan0): state change: prepare -> config (reason 'none', managed-type: 'full')
Dec 29 09:11:28 My-Pc NetworkManager[495]: <info> [1766974288.8361] device (wlan0): new IWD device state is disconnected
Dec 29 09:11:28 My-Pc NetworkManager[495]: <info> [1766974288.8367] device (wlan0): state change: config -> failed (reason 'supplicant-disconnect', managed-type: 'full')
Dec 29 09:11:28 My-Pc NetworkManager[495]: <info> [1766974288.8396] manager: NetworkManager state is now DISCONNECTED
Dec 29 09:11:28 My-Pc NetworkManager[495]: <info> [1766974288.8437] device (wlan0): state change: failed -> disconnected (reason 'none', managed-type: 'full')```
I have tried some solution including: trying to use different kernel currenly running 6.12, tried to switch 6.6, and following tutorial on disabling power safe and disable random mac ( RTL8822CE Instability even with newest kernel - #2 by Arrababiski ). The problem is still persist.
