So my wifi originally worked fine with Manjaro, but after i restarted my PC it just stopped working. It works for the first few seconds of me launching my pc but then it just cuts off and stops working. it says im still connected to the internet but with limited connectivity and 0bytes in and 0bytes out, with some small spikes of a couple hundred bytes. Its not a fault with my router itself as my connectivity works completely fine on my phone and on my fathers pc but it just doesnt want to work for me. i restarted multiple times but to no avail.
heres my network info:
vendor: Acer Incorporated ALI driver: r8169
v: kernel port: 3000 bus-ID: 07:00.0
IF: enp7s0 state: down mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi
v: kernel port: 3000 bus-ID: 08:00.0
chip-ID: 8086:2723 class-ID: 0280
IF: wlp8s0 state: up mac: <filter>
Please, in addition provide output of
nmcli device wifi list | cut --characters=-8,26-
UPC203 was the one i was trying to connect to and Kokoska is my hotspot internet when i was testing if it was UPC203 or my computer
Have you double-checked your router settings?
What do you mean by that?
It shows that im connected on the router. shows my mac address in the list of devices.
Here are some tips what to check on your router:
How to setup WiFi:
https://wiki.archlinux.org/title/Network_configuration/Wireless
