After resume from sleep Wifi will be disconnected after a few seconds and is then reconnected. The log shows (probably) what is happening, but I do not have the skills to understand. With each kernel update the reconnect time seems to grow.
relevant inxi:
Kernel: 6.1.55-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: acpi_pm
root=UUID=adcda0b2-d3e3-4d08-a9bd-802191d2faf3 ro efi=runtime nowatchdog
quiet apparmor=1 security=apparmor udev.log_priority=3
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 1
Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: ASUSTeK
ports: active: DP-2 empty: DP-1, DP-3, HDMI-A-1, HDMI-A-2, HDMI-A-3
bus-ID: 00:02.0 chip-ID: 8086:3e91 class-ID: 0300
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.2.1
compositor: kwin_wayland driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: 0
Monitor-1: DP-2 res: 1920x1080 size: N/A modes: N/A
Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
Device-2: TP-Link Archer T3U [Realtek RTL8812BU] driver: rtl88x2bu
type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:8
chip-ID: 2357:012d class-ID: 0000 serial: <filter>
IF: wlp0s20f0u11 state: up mac: <filter>
Local Storage: total
USB
Device-3: 1-11:8 info: TP-Link Archer T3U [Realtek RTL8812BU] type: Network
driver: rtl88x2bu interfaces: 1 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 2357:012d class-ID: 0000
serial: <filter>
The journald log file shows a.o. (hopefully enough data)
20-10-2023 11:48 kernel RTW: suspend start
20-10-2023 11:48 kernel RTW: rtw_suspend_normal: ### ERROR #### driver in IPS ####ERROR###!!!
20-10-2023 11:48 kernel RTW: rtw_dev_unload: driver in IPS-FWLPS
20-10-2023 11:48 kernel e1000e: EEE TX LPI TIMER: 00000011
20-10-2023 11:48 kernel RTW: rtw suspend success in 0 ms
20-10-2023 11:48 kernel sd 4:0:0:0: [sda] Synchronizing SCSI cache
20-10-2023 11:48 kernel sd 4:0:0:0: [sda] Stopping disk
20-10-2023 11:48 kernel ACPI: PM: Preparing to enter system sleep state S3
20-10-2023 11:48 kernel ACPI: PM: Saving platform NVS memory
20-10-2023 11:48 kernel Disabling non-boot CPUs ...
20-10-2023 11:48 kernel smpboot: CPU 1 is now offline
20-10-2023 11:48 kernel smpboot: CPU 2 is now offline
20-10-2023 11:48 kernel smpboot: CPU 3 is now offline
20-10-2023 11:48 kernel ACPI: PM: Low-level resume complete
20-10-2023 11:48 kernel ACPI: PM: Restoring platform NVS memory
20-10-2023 11:48 kernel Enabling non-boot CPUs ...
20-10-2023 11:48 kernel x86: Booting SMP configuration:
20-10-2023 11:48 kernel smpboot: Booting Node 0 Processor 1 APIC 0x2
20-10-2023 11:48 kernel CPU1 is up
20-10-2023 11:48 kernel smpboot: Booting Node 0 Processor 2 APIC 0x4
20-10-2023 11:48 kernel CPU2 is up
20-10-2023 11:48 kernel smpboot: Booting Node 0 Processor 3 APIC 0x6
20-10-2023 11:48 kernel CPU3 is up
20-10-2023 11:48 kernel ACPI: PM: Waking up from system sleep state S3
20-10-2023 11:48 kernel sd 4:0:0:0: [sda] Starting disk
20-10-2023 11:48 kernel i915 0000:00:02.0: [drm] [ENCODER:94:DDI B/PHY B] is disabled/in DSI mode with an ungated DDI clock, gate it
20-10-2023 11:48 kernel i915 0000:00:02.0: [drm] [ENCODER:111:DDI C/PHY C] is disabled/in DSI mode with an ungated DDI clock, gate it
20-10-2023 11:48 kernel i915 0000:00:02.0: [drm] [ENCODER:121:DDI D/PHY D] is disabled/in DSI mode with an ungated DDI clock, gate it
20-10-2023 11:48 kernel i915 0000:00:02.0: [drm] [ENCODER:125:DDI E/PHY E] is disabled/in DSI mode with an ungated DDI clock, gate it
20-10-2023 11:48 kernel nvme nvme0: Shutdown timeout set to 8 seconds
20-10-2023 11:48 kernel nvme nvme0: 4/0/0 default/read/poll queues
20-10-2023 11:48 kernel RTW: resume start
20-10-2023 11:48 kernel RTW: [HALMAC][ALWAYS]shall R reg twice!!
20-10-2023 11:48 kernel OOM killer enabled.
20-10-2023 11:48 kernel Restarting tasks ...
20-10-2023 11:48 kernel mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
20-10-2023 11:48 kernel pcieport 0000:00:1b.0: PCI bridge to [bus 01]
20-10-2023 11:48 kernel pcieport 0000:00:1b.0: bridge window [mem 0xa1100000-0xa11fffff]
20-10-2023 11:48 kwin_wayland kwin_libinput: Libinput: client bug: timer event7 debounce: scheduled expiry is in the past (-2909ms), your system is too slow
20-10-2023 11:48 kwin_wayland kwin_libinput: Libinput: client bug: timer event7 debounce: scheduled expiry is in the past (-2902ms), your system is too slow
20-10-2023 11:48 systemd-sleep System returned from sleep state.
20-10-2023 11:48 kernel done.
20-10-2023 11:48 kernel random: crng reseeded on system resumption
20-10-2023 11:48 kernel PM: suspend exit
20-10-2023 11:48 systemd systemd-suspend.service: Deactivated successfully.
20-10-2023 11:48 systemd Finished System Suspend.
20-10-2023 11:48 systemd Stopped target Sleep.
20-10-2023 11:48 systemd Reached target Suspend.
20-10-2023 11:48 systemd Stopped target Suspend.
20-10-2023 11:48 systemd-logind Operation 'sleep' finished.
20-10-2023 11:48 NetworkManager <info> [1697795336.3576] manager: sleep: wake requested (sleeping: yes enabled: yes)
20-10-2023 11:48 NetworkManager <info> [1697795336.3576] device (eno1): state change: unavailable -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
20-10-2023 11:48 NetworkManager <info> [1697795336.4384] device (eno1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
20-10-2023 11:48 kernel e1000e 0000:00:1f.6 eno1: NIC Link is Down
20-10-2023 11:48 NetworkManager <info> [1697795336.6269] device (p2p-dev-wlp0s20f0u11): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
20-10-2023 11:48 NetworkManager <info> [1697795336.6270] manager: NetworkManager state is now DISCONNECTING
20-10-2023 11:48 systemd NetworkManager-dispatcher.service: Deactivated successfully.
20-10-2023 11:49 rtkit-daemon Supervising 0 threads of 0 processes of 0 users.
20-10-2023 11:49 NetworkManager <info> [1697795346.7750] device (wlp0s20f0u11): state change: deactivating -> disconnected (reason 'sleeping', sys-iface-state: 'managed')
20-10-2023 11:49 dbus-daemon [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=587 comm="/usr/bin/NetworkManager --no-daemon")
20-10-2023 11:49 avahi-daemon Withdrawing address record for fd4c:4b32:3230:0:a16:2ffc:d752:62d on wlp0s20f0u11.
20-10-2023 11:49 NetworkManager <info> [1697795346.7758] dhcp4 (wlp0s20f0u11): canceled DHCP transaction
20-10-2023 11:49 avahi-daemon Withdrawing address record for 2a02:a443:c74f:0:aae4:9e96:4888:9307 on wlp0s20f0u11.
20-10-2023 11:49 NetworkManager <info> [1697795346.7759] dhcp4 (wlp0s20f0u11): activation: beginning transaction (timeout in 45 seconds)
20-10-2023 11:49 avahi-daemon Leaving mDNS multicast group on interface wlp0s20f0u11.IPv6 with address 2a02:a443:c74f:0:aae4:9e96:4888:9307.
20-10-2023 11:49 NetworkManager <info> [1697795346.7759] dhcp4 (wlp0s20f0u11): state changed no lease
20-10-2023 11:49 avahi-daemon Joining mDNS multicast group on interface wlp0s20f0u11.IPv6 with address fe80::a7be:6d32:2e4d:3399.
20-10-2023 11:49 NetworkManager <info> [1697795346.7760] dhcp6 (wlp0s20f0u11): canceled DHCP transaction
20-10-2023 11:49 avahi-daemon Registering new address record for fe80::a7be:6d32:2e4d:3399 on wlp0s20f0u11.*.
20-10-2023 11:49 NetworkManager <info> [1697795346.7760] dhcp6 (wlp0s20f0u11): activation: beginning transaction (timeout in 45 seconds)
20-10-2023 11:49 avahi-daemon Withdrawing address record for fe80::a7be:6d32:2e4d:3399 on wlp0s20f0u11.
20-10-2023 11:49 NetworkManager <info> [1697795346.7760] dhcp6 (wlp0s20f0u11): state changed no lease
20-10-2023 11:49 avahi-daemon Leaving mDNS multicast group on interface wlp0s20f0u11.IPv6 with address fe80::a7be:6d32:2e4d:3399.
20-10-2023 11:49 avahi-daemon Interface wlp0s20f0u11.IPv6 no longer relevant for mDNS.
20-10-2023 11:49 avahi-daemon Interface wlp0s20f0u11.IPv4 no longer relevant for mDNS.
20-10-2023 11:49 avahi-daemon Leaving mDNS multicast group on interface wlp0s20f0u11.IPv4 with address 192.168.2.126.
20-10-2023 11:49 avahi-daemon Withdrawing address record for 192.168.2.126 on wlp0s20f0u11.
20-10-2023 11:49 NetworkManager <info> [1697795346.7769] device (wlp0s20f0u11): set-hw-addr: set MAC address to 96:B1:8F:D6:AB:1D (scanning)
20-10-2023 11:49 avahi-daemon Joining mDNS multicast group on interface wlp0s20f0u11.IPv4 with address 192.168.2.126.
20-10-2023 11:49 avahi-daemon New relevant interface wlp0s20f0u11.IPv4 for mDNS.
20-10-2023 11:49 avahi-daemon Registering new address record for 192.168.2.126 on wlp0s20f0u11.IPv4.
20-10-2023 11:49 systemd Starting Network Manager Script Dispatcher Service...
20-10-2023 11:49 dbus-daemon [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
20-10-2023 11:49 systemd Started Network Manager Script Dispatcher Service.
20-10-2023 11:49 NetworkManager <info> [1697795346.8235] manager: NetworkManager state is now DISCONNECTED
20-10-2023 11:49 plasmashell Could not find the Plasmoid for Plasma::FrameSvgItem(0x560cf44dd4f0) QQmlContext(0x560cf2001660) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
20-10-2023 11:49 kernel start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
20-10-2023 11:49 kernel RTW: ERROR rtw_halmac_led_cfg: pinmux set fail!(0x64)
20-10-2023 11:49 kernel RTW: nolinked power save leave
20-10-2023 11:49 wpa_supplicant wlp0s20f0u11: Reject scan trigger since one is already pending
20-10-2023 11:49 nmbd [2023/10/20 11:49:08.015222, 0] ../../source3/libsmb/nmblib.c:923(send_udp)
20-10-2023 11:49 nmbd Packet send failed to 192.168.2.255(138) ERRNO=Network is unreachable
20-10-2023 11:49 nmbd [2023/10/20 11:49:10.017461, 0] ../../source3/libsmb/nmblib.c:923(send_udp)
20-10-2023 11:49 NetworkManager <info> [1697795351.1092] policy: auto-activating connection 'Arjan' (6d830b65-5c84-4954-a550-41824f99e07f)
20-10-2023 11:49 NetworkManager <info> [1697795351.1094] device (wlp0s20f0u11): Activation: starting connection 'Arjan' (6d830b65-5c84-4954-a550-41824f99e07f)
20-10-2023 11:49 NetworkManager <info> [1697795351.1095] device (wlp0s20f0u11): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
20-10-2023 11:49 NetworkManager <info> [1697795351.1096] manager: NetworkManager state is now CONNECTING
20-10-2023 11:49 kernel RTW: nolinked power save enter
20-10-2023 11:49 NetworkManager <info> [1697795351.1203] device (wlp0s20f0u11): set-hw-addr: reset MAC address to 30:DE:4B:84:A8:CF (preserve)
20-10-2023 11:49 NetworkManager <info> [1697795351.1204] device (wlp0s20f0u11): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
20-10-2023 11:49 NetworkManager <info> [1697795351.1206] device (wlp0s20f0u11): Activation: (wifi) access point 'Arjan' has security, but secrets are required.
20-10-2023 11:49 NetworkManager <info> [1697795351.1206] device (wlp0s20f0u11): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
20-10-2023 11:49 NetworkManager <info> [1697795351.1207] sup-iface[f3a425310db561a3,1,wlp0s20f0u11]: wps: type pbc start...
20-10-2023 11:49 NetworkManager <info> [1697795351.1332] device (wlp0s20f0u11): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
20-10-2023 11:49 kded5 kf.networkmanagerqt: void NetworkManager::ConnectionPrivate::onPropertiesChanged(const QVariantMap&) Unhandled property "VersionId"
20-10-2023 11:49 plasmashell kf.networkmanagerqt: void NetworkManager::ConnectionPrivate::onPropertiesChanged(const QVariantMap&) Unhandled property "VersionId"
20-10-2023 11:49 sayonara "Object does not exist at path â/org/freedesktop/NetworkManager/ActiveConnection/9â"
20-10-2023 11:49 NetworkManager <info> [1697795351.1341] device (wlp0s20f0u11): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
20-10-2023 11:49 NetworkManager <info> [1697795351.1343] device (wlp0s20f0u11): Activation: (wifi) connection 'Arjan' has security, and secrets exist. No new secrets needed.
20-10-2023 11:49 NetworkManager <info> [1697795351.1343] Config: added 'ssid' value 'Arjan'
20-10-2023 11:49 NetworkManager <info> [1697795351.1343] Config: added 'scan_ssid' value '1'
20-10-2023 11:49 NetworkManager <info> [1697795351.1343] Config: added 'freq_list' value '5035 5040 5045 5055 5060 5080 5170 5180 5190 5200 5210 5220 5230 5240 5250 5260 5280 5290 5300 5320 5500 5520 5540 5560 5580 5600 5620 5640 5660 5680 5700 5745 5760 5765 5785 5800 5805 5825 4915 4920 4925 4935 4945 4960 4980'
20-10-2023 11:49 NetworkManager <info> [1697795351.1343] Config: added 'bgscan' value 'simple:30:-65:300'
20-10-2023 11:49 NetworkManager <info> [1697795351.1343] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK'
20-10-2023 11:49 NetworkManager <info> [1697795351.1343] Config: added 'psk' value '<hidden>'
20-10-2023 11:49 wpa_supplicant wlp0s20f0u11: WPS-CANCEL
20-10-2023 11:49 wpa_supplicant wlp0s20f0u11: Trying to associate with c8:d1:2a:15:75:a0 (SSID='Arjan' freq=5500 MHz)
20-10-2023 11:49 kernel RTW: [HALMAC][ALWAYS]shall R reg twice!!
20-10-2023 11:49 NetworkManager <info> [1697795351.8027] device (wlp0s20f0u11): supplicant interface state: disconnected -> associating
20-10-2023 11:49 kernel RTW: rtw_set_802_11_connect(wlp0s20f0u11) fw_state=0x00000008
20-10-2023 11:49 wpa_supplicant wlp0s20f0u11: CTRL-EVENT-STARTED-CHANNEL-SWITCH freq=5500 ht_enabled=1 ch_offset=1 ch_width=80 MHz cf1=5530 cf2=0
20-10-2023 11:49 kernel RTW: start auth
20-10-2023 11:49 kernel RTW: auth success, start assoc
20-10-2023 11:49 wpa_supplicant wlp0s20f0u11: Associated with c8:d1:2a:15:75:a0
20-10-2023 11:49 wpa_supplicant wlp0s20f0u11: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
20-10-2023 11:49 kernel RTW: assoc success
20-10-2023 11:49 kernel RTW: ============ STA [c8:d1:2a:15:75:a0] ===================
20-10-2023 11:49 kernel RTW: mac_id : 0
20-10-2023 11:49 kernel RTW: wireless_mode : 0x44
20-10-2023 11:49 kernel RTW: mimo_type : 2
20-10-2023 11:49 kernel RTW: static smps : N
20-10-2023 11:49 kernel RTW: bw_mode : 80MHz, ra_bw_mode : 80MHz
20-10-2023 11:49 kernel RTW: rate_id : 9
20-10-2023 11:49 kernel RTW: rssi : -1 (%), rssi_level : 0
20-10-2023 11:49 kernel RTW: is_support_sgi : Y, is_vht_enable : Y
20-10-2023 11:49 kernel RTW: disable_ra : N, disable_pt : N
20-10-2023 11:49 kernel RTW: is_noisy : N
20-10-2023 11:49 kernel RTW: txrx_state : 0
20-10-2023 11:49 kernel RTW: curr_tx_rate : CCK_1M (L)
20-10-2023 11:49 kernel RTW: curr_tx_bw : 20MHz
20-10-2023 11:49 kernel RTW: curr_retry_ratio : 0
20-10-2023 11:49 kernel RTW: ra_mask : 0x00000000fffffff0
20-10-2023 11:49 NetworkManager <info> [1697795352.0031] device (wlp0s20f0u11): supplicant interface state: associating -> associated
20-10-2023 11:49 kernel RTW: rtw_aes_decrypt(wlp0s20f0u11) no_gkey_bc_cnt:1, no_gkey_mc_cnt:0
20-10-2023 11:49 kernel RTW: recv eapol packet 1/4
20-10-2023 11:49 kernel RTW: send eapol packet 2/4
20-10-2023 11:49 wpa_supplicant wlp0s20f0u11: WPA: Key negotiation completed with c8:d1:2a:15:75:a0 [PTK=CCMP GTK=CCMP]
20-10-2023 11:49 wpa_supplicant wlp0s20f0u11: CTRL-EVENT-CONNECTED - Connection to c8:d1:2a:15:75:a0 completed [id=0 id_str=]
20-10-2023 11:49 wpa_supplicant bgscan simple: Failed to enable signal strength monitoring
20-10-2023 11:49 kernel RTW: recv eapol packet 3/4
20-10-2023 11:49 kernel RTW: send eapol packet 4/4
20-10-2023 11:49 kernel RTW: set pairwise key camid:0, addr:c8:d1:2a:15:75:a0, kid:0, type:AES
20-10-2023 11:49 kernel IPv6: ADDRCONF(NETDEV_CHANGE): wlp0s20f0u11: link becomes ready
20-10-2023 11:49 kernel RTW: set group key camid:1, addr:c8:d1:2a:15:75:a0, kid:1, type:AES
20-10-2023 11:49 NetworkManager <info> [1697795352.7374] device (wlp0s20f0u11): supplicant interface state: associated -> completed
20-10-2023 11:49 avahi-daemon New relevant interface wlp0s20f0u11.IPv6 for mDNS.
20-10-2023 11:49 NetworkManager <info> [1697795352.7374] device (wlp0s20f0u11): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "Arjan"
20-10-2023 11:49 NetworkManager <info> [1697795352.7375] device (wlp0s20f0u11): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
20-10-2023 11:49 NetworkManager <info> [1697795352.7377] dhcp4 (wlp0s20f0u11): activation: beginning transaction (timeout in 45 seconds)
20-10-2023 11:49 NetworkManager <info> [1697795352.7495] dhcp4 (wlp0s20f0u11): state changed new lease, address=192.168.2.126
20-10-2023 11:49 NetworkManager <info> [1697795352.7497] policy: set 'Arjan' (wlp0s20f0u11) as default for IPv4 routing and DNS
20-10-2023 11:49 NetworkManager <info> [1697795352.7604] device (wlp0s20f0u11): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
20-10-2023 11:49 NetworkManager <info> [1697795352.7637] device (wlp0s20f0u11): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
20-10-2023 11:49 NetworkManager <info> [1697795352.7639] device (wlp0s20f0u11): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
20-10-2023 11:49 NetworkManager <info> [1697795352.7641] manager: NetworkManager state is now CONNECTED_SITE
20-10-2023 11:49 NetworkManager <info> [1697795352.7643] device (wlp0s20f0u11): Activation: successful, device activated.
20-10-2023 11:49 plasmashell Could not find the Plasmoid for Plasma::FrameSvgItem(0x560cf0b15920) QQmlContext(0x560cf2001660) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
20-10-2023 11:49 NetworkManager <info> [1697795353.8043] manager: NetworkManager state is now CONNECTED_GLOBAL
20-10-2023 11:49 NetworkManager <info> [1697795354.5559] dhcp6 (wlp0s20f0u11): activation: beginning transaction (timeout in 45 seconds)
20-10-2023 11:49 NetworkManager <info> [1697795354.5563] policy: set 'Arjan' (wlp0s20f0u11) as default for IPv6 routing and DNS
20-10-2023 11:49 avahi-daemon Joining mDNS multicast group on interface wlp0s20f0u11.IPv6 with address 2a02:a443:c74f:0:aae4:9e96:4888:9307.
20-10-2023 11:49 avahi-daemon Registering new address record for 2a02:a443:c74f:0:aae4:9e96:4888:9307 on wlp0s20f0u11.*.
20-10-2023 11:49 avahi-daemon Registering new address record for fd4c:4b32:3230:0:a16:2ffc:d752:62d on wlp0s20f0u11.*.
20-10-2023 11:49 NetworkManager <info> [1697795354.5679] dhcp6 (wlp0s20f0u11): state changed new lease
20-10-2023 11:49 systemd NetworkManager-dispatcher.service: Deactivated successfully.
The wifi driver (github RinCat) is installed via dkms:
dkms status
rtl88x2bu/5.13.1.r189.12cfcd8, 5.15.133-1-MANJARO, x86_64: installed
rtl88x2bu/5.13.1.r189.12cfcd8, 6.1.55-1-MANJARO, x86_64: installed
vboxhost/7.0.10_OSE, 5.15.133-1-MANJARO, x86_64: installed
vboxhost/7.0.10_OSE, 6.1.55-1-MANJARO, x86_64: installed
Thanks very much for advice / tips / links how to solve this issue.
