Wifi card not showing up
Hello everyone, I am completely new to Linux and to the forum so please excuse my ignorance.
I just installed Manjaro (kernel 6.10) and my wifi card is not showing up in the graphic interface. I’ve read a few threads about similar problems on the forum and I ended up trying these commands :
ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host noprefixroute
2: enp2s0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN group default qlen 1000
    link/ether 00:1f:16:c6:06:f8 brd ff:ff:ff:ff:ff:ff
And inxi --admin --filter --verbosity=7
  Kernel: 6.10.13-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    clocksource: hpet avail: acpi_pm
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.10-x86_64
    root=UUID=336d56f5-bdcf-4d97-bb60-56a2c871e18e rw quiet splash apparmor=1
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.18.0
    with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
  Type: Other-vm? System: Acer product: ASPIRE4810TZG v: V1.33
    serial: <superuser required>
  Mobo: Acer model: ASPIRE4810TZG serial: <superuser required>
    part-nu: Montevina_Fab uuid: <superuser required> BIOS: INSYDE v: 1.33
    date: 01/29/2010
  Device-1: Qualcomm Atheros AR8131 Gigabit Ethernet
    vendor: Acer Incorporated ALI driver: atl1c v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 02:00.0 chip-ID: 1969:1063
    class-ID: 0200
  WAN IP: No WAN IP found. Connected to web? SSL issues? Try enabling dig
In the topics I read, many of thoses who faced a similar problem had at least their wifi card showing up in the ‘Network’ field, but this is not the case here. I really think my card is working properly though, because I briefly tried Ubuntu before turning to Manjaro (because Xubuntu was painfully slow) and I was able to connect to wifi with it.
My card is an INTEL112BNHMW
Thanks in advance!
Hi @Gujureja, and welcome!
Looks like maybe the wifi is disabled in the BIOS/UEFI. Or perhaps it even has a hardware switch. Check and please provide the output of:
lsusb
And
lspci
You must have used an older ISO to install from - the kernel
is currently not even availabe anymore.
A full system update will make your system current - install a supported kernel as well.
The update might not go smoothly, though.
If neither inxi nor lsusb nor lspci do not even show the presence of the hardware then it might either be defunct or has become lose/unseated - or it has been switched off somehow.
Not much anyone can do when the system doesn’t even “see” the hardware being even present.
If Ubuntu was able to see the card and use it, try using an older supported kernel rather than the newest, as they do not use the newest, not by default anyway.
Hi, thanks for your quick answers!
@Mirdarthos Here are the outputs of :
lsusb
Summary
Bus 001 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 002: ID 04f2:b160 Chicony Electronics Co., Ltd CNF9113
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
And
lspci
Summary
00:00.0 Host bridge: Intel Corporation Mobile 4 Series Chipset Memory Controller Hub (rev 07)
00:01.0 PCI bridge: Intel Corporation Mobile 4 Series Chipset PCI Express Graphics Port (rev 07)
00:02.0 VGA compatible controller: Intel Corporation Mobile 4 Series Chipset Integrated Graphics Controller (rev 07)
00:1a.0 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #4 (rev 03)
00:1a.1 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #5 (rev 03)
00:1a.7 USB controller: Intel Corporation 82801I (ICH9 Family) USB2 EHCI Controller #2 (rev 03)
00:1b.0 Audio device: Intel Corporation 82801I (ICH9 Family) HD Audio Controller (rev 03)
00:1c.0 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 1 (rev 03)
00:1d.0 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #1 (rev 03)
00:1d.1 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #2 (rev 03)
00:1d.2 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #3 (rev 03)
00:1d.3 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #6 (rev 03)
00:1d.7 USB controller: Intel Corporation 82801I (ICH9 Family) USB2 EHCI Controller #1 (rev 03)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev 93)
00:1f.0 ISA bridge: Intel Corporation ICH9M-E LPC Interface Controller (rev 03)
00:1f.2 SATA controller: Intel Corporation 82801IBM/IEM (ICH9M/ICH9M-E) 4 port SATA Controller [AHCI mode] (rev 03)
00:1f.3 SMBus: Intel Corporation 82801I (ICH9 Family) SMBus Controller (rev 03)
00:1f.6 Signal processing controller: Intel Corporation 82801I (ICH9 Family) Thermal Subsystem (rev 03)
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] RV710/M92 [Mobility Radeon HD 4330/4350/4550]
01:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] RV710/730 HDMI Audio [Radeon HD 4000 series]
02:00.0 Ethernet controller: Qualcomm Atheros AR8131 Gigabit Ethernet (rev c0)
So still no wifi card if I understand well…
I will try updating the kernel with an ethernet connection, as @Nachlese suggested. If the new kernel installed by the update does not recognise the wifi card either, would it be a good idea to install an older one with the sudo mhwd-kernel -i linux000 command?
If yes, which one would you recommend?
Thanks again,
I’ll keep you updated!
Not exactly what I wanted to suggest in that I don’t recommend to update your kernel to a supported one only.
Instead, update the whole system, including the kernel.
If you still have the Xubuntu ISO:
boot from it and run the inxi -zv8 command as well as lsusb and lspci there in the live system
You said it did work there - so comparing the output there with the one from your current Manjaro should provide some differences and clues.
The card should be old enough to be supported - there might be a physical switch to turn it on/off on the front side of the laptop (is what I read).
Opening the device to access the card to re-seat it should be possible.
Looks like the card is accessible after removing the keyboard:
https://youtu.be/eq3iZ8Yk7gw?t=96
Hey, sorry for the late response.
So I tried booting on Xubuntu and, surprise, no wifi. Which is strange because I am absolutely sure that it worked a few weeks ago. I tried all the Fn+F1,F2,F3,etc. combinations, I opened up the laptop and reseated the card as you suggested, but still nothing changed.
BUT I think I found what is going on. I was convinced there was no physical swich, but it turns out I was wrong : there is a touch sensitive button that just looks like a regular LED indicator.
Picture here
I imagine it just died while switched off…
So unless one of you has a miraculous idea about how to make it work again, I guess I’ll just have to find my way around it
Nothing here to add regarding your WiFi.
However, regarding the kernel…
There is no reason that you can’t revert to say kernel 6.6 (LTS) if need be, on the chance that it might magically resolve an issue.
LTS kernels by their very nature receive ongoing tweaking for maximum compatibility and can often be a viable choice in preference to the latest and greatest kernels which typically are not around for long.
Did you already try:
 rfkill list         1 ✘
0: hci0: Bluetooth
	Soft blocked: no
	Hard blocked: no
:footprints:
Consider a USB WiFi Dongle if @andreas85’s command doesn’t pan out.
